Retour d'état inopérant avec thermostat Zigbee MOES BHT-002-GBLZB
Installation : Plugin zigbee officiel + clef consbee II (dernier firmware).
Le thermostat est bien reconnu par le plugin.
Je récupère la température ambiante, celle de consigne, la commande de modification de la t° de consigne fonctionne.
Seul le statut qui m’indique si le thermostat est enclenché ou à l’arrêt ne fonctionne pas. Toujours à 0.
Voici les informations brutes qd le thermostat est à l’arrêt :
    "ieee": "50:32:5f:ff:fe:28:9e:03",
    "nwk": 49455,
    "status": 2,
    "lqi": "255",
    "rssi": "-45",
    "last_seen": "1633820459.9772892",
    "node_descriptor": "01:40:8e:02:10:52:52:00:00:2c:52:00:00",
    "endpoints": [
            "id": 1,
            "status": 1,
            "device_type": 769,
            "profile_id": 260,
            "manufacturer": "_TZE200_aoclfnxz",
            "model": "TS0601",
            "output_clusters": [
                    "id": 10,
                    "name": "Time",
                    "attributes": []
                    "id": 25,
                    "name": "Ota",
                    "attributes": []
            "input_clusters": [
                    "id": 0,
                    "name": "Basic",
                    "attributes": [
                            "id": 0,
                            "name": "zcl_version",
                            "value": 3
                            "id": 1,
                            "name": "app_version",
                            "value": 65
                            "id": 2,
                            "name": "stack_version",
                            "value": 0
                            "id": 3,
                            "name": "hw_version",
                            "value": 1
                            "id": 4,
                            "name": "manufacturer",
                            "value": "_TZE200_aoclfnxz"
                            "id": 5,
                            "name": "model",
                            "value": "TS0601"
                            "id": 6,
                            "name": "date_code",
                            "value": ""
                            "id": 7,
                            "name": "power_source",
                            "value": 1
                    "id": 4,
                    "name": "Groups",
                    "attributes": []
                    "id": 5,
                    "name": "Scenes",
                    "attributes": []
                    "id": 61184,
                    "name": "Tuya Manufacturer Specicific",
                    "attributes": [
                            "id": 528,
                            "name": "target_temperature",
                            "value": 20
                            "id": 536,
                            "name": "temperature",
                            "value": 210
                            "id": 1027,
                            "name": "schedule_mode",
                            "value": 1
                            "id": 1026,
                            "name": "manual_mode",
                            "value": 0
                            "id": 257,
                            "name": "enabled",
                            "value": 1
                            "id": 1060,
                            "name": "running_mode",
                            "value": 1
                            "id": 296,
                            "name": "child_lock",
                            "value": 0
                    "id": 513,
                    "name": "MoesBHTThermostat",
                    "attributes": [
                            "id": 0,
                            "name": "local_temp",
                            "value": 2100
                            "id": 18,
                            "name": "occupied_heating_setpoint",
                            "value": 2000
                            "id": 28,
                            "name": "system_mode",
                            "value": 4
                            "id": 30,
                            "value": 0
                            "id": 37,
                            "name": "programing_oper_mode",
                            "value": 0
                            "id": 41,
                            "name": "running_state",
                            "value": 0
                    "id": 516,
                    "name": "Thermostat User Interface Configuration",
                    "attributes": [
                            "id": 1,
                            "name": "keypad_lockout",
                            "value": 0
    "signature": {
        "model": "TS0601",
        "node_desc": {
            "logical_type": 1,
            "reserved": 0,
            "aps_flags": 0,
            "frequency_band": 8,
            "mac_capability_flags": 142,
            "manufacturer_code": 4098,
            "maximum_buffer_size": 82,
            "maximum_incoming_transfer_size": 82,
            "server_mask": 11264,
            "maximum_outgoing_transfer_size": 82,
        "endpoints": {
            "1": {
                "profile_id": 260,
                "device_type": 769,
                "input_clusters": [
                    0,
                    4,
                    5,
                    61184,
                    513,
                    516
                    10,
                    25
    "class": "zhaquirks.tuya.electric_heating"
Voici les infos qd le thermostat est enclenché:
La commande d’info crée par le plugin : « 1::513::30 » reste à 0
et il manque la commande d’info : « 1::513::41 ».
J’ai essayé de créer la dernière mais elle reste toujours à 0.
Si quelqu’un peut m’aider, ce sera avec plaisir de le lire.
Cordialement
Ce sujet a été automatiquement fermé après 4 heures. Aucune réponse n’est permise dorénavant.
