Retour d'état GLEDOPTO RGBW GL-C-007 non fonctionnel
J’ai réussi à intégrer mes modules GLEDOPTO RGBW GL-C-007 sans problèmes.
Par contre, je constate que le retour d’état ne fonctionne pas et reste sur 1 tout le temps.
Avez-vous ce problème aussi ?
Voici les informations brutes :
    "ieee": "00:12:4b:00:23:2f:20:f8",
    "nwk": 58069,
    "status": 2,
    "lqi": "255",
    "rssi": "-57",
    "last_seen": "1662042475.456894",
    "node_descriptor": "01:40:8e:00:00:50:a0:00:00:00:a0:00:00",
    "endpoints": [
            "id": 11,
            "status": 1,
            "device_type": 528,
            "profile_id": 49246,
            "manufacturer": "GLEDOPTO",
            "model": "GL-C-007",
            "output_clusters": [],
            "input_clusters": [
                    "id": 0,
                    "name": "Basic",
                    "attributes": [
                            "id": 0,
                            "name": "zcl_version",
                            "value": 1
                            "id": 1,
                            "name": "app_version",
                            "value": 1
                            "id": 2,
                            "name": "stack_version",
                            "value": 2
                            "id": 3,
                            "name": "hw_version",
                            "value": 1
                            "id": 4,
                            "name": "manufacturer",
                            "value": "GLEDOPTO"
                            "id": 5,
                            "name": "model",
                            "value": "GL-C-007"
                            "id": 6,
                            "name": "date_code",
                            "value": "20131206"
                            "id": 7,
                            "name": "power_source",
                            "value": 1
                            "id": 16384,
                            "name": "sw_build_id",
                            "value": "3.0.1"
                    "id": 3,
                    "name": "Identify",
                    "attributes": []
                    "id": 4,
                    "name": "Groups",
                    "attributes": []
                    "id": 5,
                    "name": "Scenes",
                    "attributes": []
                    "id": 6,
                    "name": "On\/Off",
                    "attributes": [
                            "id": 0,
                            "name": "on_off",
                            "value": 1
                    "id": 8,
                    "name": "Level control",
                    "attributes": [
                            "id": 0,
                            "name": "current_level",
                            "value": 254
                    "id": 768,
                    "name": "Color Control",
                    "attributes": [
                            "id": 3,
                            "name": "current_x",
                            "value": 11141
                            "id": 4,
                            "name": "current_y",
                            "value": 45874
                            "id": 7,
                            "name": "color_temperature",
                            "value": 255
    "signature": {
        "node_desc": {
            "logical_type": 1,
            "reserved": 0,
            "aps_flags": 0,
            "frequency_band": 8,
            "mac_capability_flags": 142,
            "manufacturer_code": 0,
            "maximum_buffer_size": 80,
            "maximum_incoming_transfer_size": 160,
            "server_mask": 0,
            "maximum_outgoing_transfer_size": 160,
        "endpoints": {
            "11": {
                "device_type": 528,
                "input_clusters": [
                    0,
                    3,
                    4,
                    5,
                    6,
                    8,
                    768
    "class": "zhaquirks.gledopto.soposhgu10"
Merci pour votre aide.
Bruce
J’avais le même modèle et jamais eu le retour d’état du coup j’utilise un GL-C-008P et là il y a le retour d’état
Quelle est le logical ID de votre commande état ? 1::6::0
Salut @Furaxworld,
Le logical Id est le 11::6::0
Oopss sorry loupé celui-là "id": 11,
Merci du retour :wink:
J’ai plusieurs module Gledopto RGBW GL-C-007 et voici comment j’ai solutionné le problème :
il faut ajouter une commande « refresh »
Oups j’ai oublié de te joindre ce que ça donne…
Super si ça fonctionne mais pour mon information, d’où sortez vous un logical ID refresh?
C’est un truc interne jeedom qui dit que suite a chaque action faut explicitement demandé au module les nouvelles valeurs, c’est malheureusement obligatoire si le fabricant ne suis pas la norme zigbee 3.0
Oui exactement c’est bien Loic qui m’a donné cette logical ID
Encore Merci @Loic !
