Retour d'etat Entrée Shelly UNI
Je rencontre un problème avec un retour d’état aléatoire des entrées de mon module Shelly
Voici le serveur web du produit → les deux entrées sont a 1
Voici le Dashbord Jeedom
2022-11-20 V2-2
Voici le log dans plugin Shelly
[2022-11-20 12:06:28][DEBUG] : Call : http://192.168.xx.xx/status, return : 200,
content : {"wifi_sta":{"connected":true,"ssid":"xxxxx","ip":"192.168.xx.xx","rssi":-89},
"cloud":{"enabled":false,"connected":false},"mqtt":{"connected":false},
"time":"12:06","unixtime":1668942388,"serial":314,"has_update":false,"mac":"XXXXXXXXX","cfg_changed_cnt":0,
"actions_stats":{"skipped":0},"relays":[{"ison":false,"has_timer":false,"timer_started":0,"timer_duration":0,"timer_remaining":0,"source":"input"},
{"ison":false,"has_timer":false,"timer_started":0,"timer_duration":0,"timer_remaining":0,"source":"input"}],
"inputs":[{"input":1,"event":"","event_cnt":1},{"input":1,"event":"","event_cnt":1}],
"adcs":[{"voltage":0.02}],"ext_sensors":{"temperature_unit":"C"},
"ext_temperature":{"0":{"hwID":"0505","tC":8.80,"tF":47.84}},"ext_humidity":{"0":{"hwID":"0505","hum":80.60}},
"update":{"status":"idle","has_update":false,"new_version":"20221027-121732/v1.12.1-ga9117d3","old_version":"20221027-121732/v1.12.1-ga9117d3"},
"ram_total":50784,"ram_free":34172,"fs_size":233681,"fs_free":140811,"uptime":449}
La commande des sorties fonctionnent correctement et le retour de température aussi
Voila
merci d’avance pour le retour
