Voici ce que je vois lors de l’installation des dépendances :
Début d'installation des dépendances
E: Could not get lock /var/lib/dpkg/lock - open (11: Resource temporarily unavailable)
E: Unable to lock the administration directory (/var/lib/dpkg/), is another process using it?
Get:1 http://archive.raspberrypi.org jessie InRelease [22.9 kB]
Get:2 http://mirrordirector.raspbian.org jessie InRelease [15.0 kB]
Get:3 https://deb.nodesource.com jessie InRelease [4584 B]
Get:4 http://mirrordirector.raspbian.org jessie/main armhf Packages [9540 kB]
Get:5 http://archive.raspberrypi.org jessie/main armhf Packages [170 kB]
Hit https://deb.nodesource.com jessie/main Sources
Get:6 https://deb.nodesource.com jessie/main armhf Packages [771 B]
Get:7 https://deb.nodesource.com jessie/main Translation-en [162 B]
Get:8 https://deb.nodesource.com jessie/main Translation-en [162 B]
Get:9 http://archive.raspberrypi.org jessie/ui armhf Packages [58.9 kB]
Get:10 https://deb.nodesource.com jessie/main Translation-en [162 B]
Get:11 https://deb.nodesource.com jessie/main Translation-en [162 B]
Get:12 https://deb.nodesource.com jessie/main Translation-en [162 B]
Ign https://deb.nodesource.com jessie/main Translation-en
Ign http://archive.raspberrypi.org jessie/main Translation-en
Ign http://archive.raspberrypi.org jessie/ui Translation-en
Hit http://mirrordirector.raspbian.org jessie/contrib armhf Packages
Hit http://mirrordirector.raspbian.org jessie/non-free armhf Packages
Hit http://mirrordirector.raspbian.org jessie/rpi armhf Packages
Ign http://mirrordirector.raspbian.org jessie/contrib Translation-en
Ign http://mirrordirector.raspbian.org jessie/main Translation-en
Ign http://mirrordirector.raspbian.org jessie/non-free Translation-en
Ign http://mirrordirector.raspbian.org jessie/rpi Translation-en
Fin installation des dépendances
Il me récupère bien les infos de ma tondeuse sur le serveur de Worx:
Coté installation de Mosquitto, cela m’a l’air OK aussi.
J’ai tenté, une réinstallation, et relance des dépendances, une resyncho avec le cloud et de lancer la commande refresh du plugin mais rien n’y fait.
J’ai l’impression que c’est cette erreur « Could not get lock /var/lib/dpkg/lock » dans l’installation des dépendances qui pose problème.
A noter qu’initialement, j’avais installé la version précédent du plugin, je n’avais pas l’erreur 500 mais je n’avais pas de remonté d’info sur le dashboard. Et depuis l’installation de la dernière mise à jour du plugin, j’ai l’erreur 500 en plus.
En consultant les différents forums, je n’ai pas trouvé de pistes sur le sujet.
Si quelqu’un peut m’aider…ça serait très gentil à vous
j’ai appliqué la procédure et je n’ai plus l’erreur lors de l’installation des dépendances.
Reading package lists...
Building dependency tree...
Reading state information...
lsb-release is already the newest version.
php-pear is already the newest version.
The following packages were automatically installed and are no longer required:
python-crypto python-ecdsa python-jwt python-lockfile python-oauthlib
python-paramiko
Use 'apt-get autoremove' to remove them.
0 upgraded, 0 newly installed, 0 to remove and 338 not upgraded.
Hit http://mirrordirector.raspbian.org jessie InRelease
Hit http://archive.raspberrypi.org jessie InRelease
Hit https://deb.nodesource.com jessie InRelease
Hit http://mirrordirector.raspbian.org jessie/main armhf Packages
Hit http://archive.raspberrypi.org jessie/main armhf Packages
Hit http://archive.raspberrypi.org jessie/ui armhf Packages
Hit https://deb.nodesource.com jessie/main armhf Packages
Get:1 https://deb.nodesource.com jessie/main Translation-en [162 B]
Get:2 https://deb.nodesource.com jessie/main Translation-en [162 B]
Get:3 https://deb.nodesource.com jessie/main Translation-en [162 B]
Get:4 https://deb.nodesource.com jessie/main Translation-en [162 B]
Get:5 https://deb.nodesource.com jessie/main Translation-en [162 B]
libmosquitto-dev is already the newest version.
mosquitto is already the newest version.
mosquitto-clients is already the newest version.
python-paramiko
E: Unable to locate package php5.6-dev
E: Couldn't find any package by regex 'php5.6-dev'
Cependant, j’ai toujours les erreurs 500.
Donc, le plugin n’est pas compatible avec jessie, c’est ce que je comprends
J’avoue que la mise à jour en Debian me fait peur, je n’ai jamais fait cela et je suis novice en la matière (j’ai récupéré installation tel quelle lors de l’achat de ma maison).
@papa_coni, dans ce cas, si tu veux vraiment être rassuré:
assure-toi d’avoir un backup de ton jeedom sur ton ordi
procure toi une seconde carte sd (16gb minimum)
installe buster (c’est facile, tu trouveras des tutos sur le site officiel de Raspberry)
éteint ton pi actuel proprement, échange les cartes sd et carte l’ancienne, en cas de soucis il te suffira de la remettre en place et ton install existante redémarrera
install jeedom sur la nouvelle carte
restaure le backup précédemment copié
relance les dépendances (ou attend que jeedom le fasse) sur les plugins qui en ont et tu vas retrouver ton jeedom installé sur buster
Génial, merci beaucoup. PAr contre, je boot sur la carte SD mais j’ai aussi un SSD branché en USB (je pense que jeedom est dessus).
Si j’installe buster sur la carte (je veux bien un lien au passage histoire de ne pas me tromper), cela impactera-t-il ce qu’il y a sur le SSD ? Et dois-jechanger une config sur buster pour lui permettre dialoguer avec le SSD ensuite ?
Désolé si je n’utilise pas le bon vocabulaire…mais je tente de m’améliorer à travers des échanges comme celui-ci
Pour le SSD, cela dépend comment tu as installé raspian, mais si tu en as un, c’est que tu as dû l’installer dessus…
En attendant de tout mettre en place pour la MAJ, à tous hasard clique sur la commande « refreshValue » de ton équipement.
Justement, il est là le problème. Ce n’est pas moi qu’il l’ai installé. L’ancien propriétaire de la maison que j’ai acheté il y a 3 ans m’a légué l’installation telle quelle.
Et la commande refreshvalue provoque aussi une erreur 500 et je ne vois rien dans les logs du plugin…
Ok, dans ce cas tu peux suivre les explications de @Mips mais débranche et garde précieusement le ssd et la carte SD (ou fait une sauvegarde de la carte SD avec Win32 Disk Imager par exemple).
Si tu n’arrive pas à faire la MAJ tu auras juste à remettre la sd et le ssd en place.
Merci à tous pour vos précieux conseils et votre réactivité. Je vais programmer l’achat d’une carte SD et enclencher la démarche de migration sous buster.
Dernière question, à votre connaissance, tous les plugins (même non officiels) sont-ils compatibles sous Buster ?
Voici ce que j’ai :
