Alors oui j’ai moins d’erreurs et surtout j’ai un temps de réponse plus rapide…
Au niveau des erreurs, je viens de voir que j’ai souvent les mêmes modules qui posent problème:
2020-01-09 00:00:20.107 Error, Node050, ERROR: Dropping command, expected response not received after 1 attempt(s)
2020-01-09 00:00:20.110 Error, Node049, ERROR: ZW_SEND_DATA could not be delivered to Z-Wave stack
2020-01-09 00:00:24.108 Error, Node049, ERROR: Dropping command, expected response not received after 1 attempt(s)
2020-01-09 00:00:24.117 Error, Node049, ERROR: ZW_SEND_DATA could not be delivered to Z-Wave stack
2020-01-09 00:00:28.109 Error, Node049, ERROR: Dropping command, expected response not received after 1 attempt(s)
2020-01-09 00:25:11.578 Error, Node050, ERROR: Dropping command, expected response not received after 1 attempt(s)
2020-01-09 00:25:11.581 Error, Node049, ERROR: ZW_SEND_DATA could not be delivered to Z-Wave stack
2020-01-09 00:25:15.580 Error, Node049, ERROR: Dropping command, expected response not received after 1 attempt(s)
2020-01-09 00:35:53.615 Error, Node019, ERROR: Dropping command, expected response not received after 1 attempt(s)
2020-01-09 00:37:37.410 Error, Node019, ERROR: Dropping command, expected response not received after 1 attempt(s)
2020-01-09 00:39:12.987 Error, Node019, ERROR: Dropping command, expected response not received after 1 attempt(s)
2020-01-09 00:43:14.274 Error, Node019, ERROR: Dropping command, expected response not received after 1 attempt(s)
2020-01-09 00:43:56.784 Error, Node019, ERROR: Dropping command, expected response not received after 1 attempt(s)
2020-01-09 00:44:31.605 Error, Node019, ERROR: Dropping command, expected response not received after 1 attempt(s)
2020-01-09 00:45:20.906 Error, Node019, ERROR: Dropping command, expected response not received after 1 attempt(s)
2020-01-09 00:46:02.900 Error, Node019, ERROR: Dropping command, expected response not received after 1 attempt(s)
2020-01-09 00:46:07.182 Error, Node056, ERROR: Dropping command, expected response not received after 1 attempt(s)
2020-01-09 01:00:11.441 Error, Node051, ERROR: Dropping command, expected response not received after 1 attempt(s)
2020-01-09 01:00:11.446 Error, Node048, ERROR: ZW_SEND_DATA could not be delivered to Z-Wave stack
2020-01-09 01:00:16.297 Error, Node050, ERROR: Dropping command, expected response not received after 1 attempt(s)
2020-01-09 01:25:10.614 Error, Node050, ERROR: Dropping command, expected response not received after 1 attempt(s)
2020-01-09 01:25:10.673 Error, Node049, ERROR: ZW_SEND_DATA could not be delivered to Z-Wave stack
2020-01-09 01:25:14.615 Error, Node049, ERROR: Dropping command, expected response not received after 1 attempt(s)
2020-01-09 02:20:13.522 Error, Node050, ERROR: Dropping command, expected response not received after 1 attempt(s)
2020-01-09 03:05:13.022 Error, Node048, ERROR: Dropping command, expected response not received after 1 attempt(s)
2020-01-09 03:16:37.311 Error, Node056, ERROR: Dropping command, expected response not received after 1 attempt(s)
2020-01-09 03:20:10.125 Error, Node049, ERROR: ZW_SEND_DATA could not be delivered to Z-Wave stack
2020-01-09 03:20:14.114 Error, Node049, ERROR: Dropping command, expected response not received after 2 attempt(s)
2020-01-09 03:20:28.334 Error, Node056, ERROR: Dropping command, expected response not received after 1 attempt(s)
2020-01-09 03:35:11.439 Error, Node050, ERROR: Dropping command, expected response not received after 1 attempt(s)
2020-01-09 03:35:11.597 Error, Node049, ERROR: ZW_SEND_DATA could not be delivered to Z-Wave stack
2020-01-09 03:35:15.594 Error, Node049, ERROR: Dropping command, expected response not received after 1 attempt(s)
2020-01-09 03:40:11.337 Error, Node050, ERROR: Dropping command, expected response not received after 1 attempt(s)
2020-01-09 03:40:11.341 Error, Node049, ERROR: ZW_SEND_DATA could not be delivered to Z-Wave stack
2020-01-09 04:06:52.285 Error, Node056, ERROR: Dropping command, expected response not received after 1 attempt(s)
2020-01-09 04:10:10.689 Error, Node050, ERROR: Dropping command, expected response not received after 1 attempt(s)
2020-01-09 04:15:11.616 Error, Node050, ERROR: Dropping command, expected response not received after 1 attempt(s)
2020-01-09 04:20:10.804 Error, Node050, ERROR: Dropping command, expected response not received after 1 attempt(s)
2020-01-09 04:20:10.809 Error, Node049, ERROR: ZW_SEND_DATA could not be delivered to Z-Wave stack
2020-01-09 04:20:14.806 Error, Node049, ERROR: Dropping command, expected response not received after 1 attempt(s)
2020-01-09 04:45:12.314 Error, Node050, ERROR: Dropping command, expected response not received after 1 attempt(s)
2020-01-09 04:45:12.317 Error, Node049, ERROR: ZW_SEND_DATA could not be delivered to Z-Wave stack
2020-01-09 04:45:16.316 Error, Node049, ERROR: Dropping command, expected response not received after 1 attempt(s)
2020-01-09 05:05:10.826 Error, Node051, ERROR: Dropping command, expected response not received after 1 attempt(s)
2020-01-09 05:05:11.692 Error, Node051, ERROR: ZW_SEND_DATA could not be delivered to Z-Wave stack
2020-01-09 05:10:11.367 Error, Node051, ERROR: Dropping command, expected response not received after 1 attempt(s)
2020-01-09 05:10:11.902 Error, Node048, ERROR: ZW_SEND_DATA could not be delivered to Z-Wave stack
2020-01-09 05:10:11.993 Error, Node050, ERROR: ZW_SEND_DATA could not be delivered to Z-Wave stack
2020-01-09 05:10:15.990 Error, Node050, ERROR: Dropping command, expected response not received after 1 attempt(s)
2020-01-09 05:25:14.837 Error, Node050, ERROR: Dropping command, expected response not received after 1 attempt(s)
2020-01-09 05:30:11.095 Error, Node050, ERROR: Dropping command, expected response not received after 1 attempt(s)
2020-01-09 05:35:10.576 Error, Node051, ERROR: Dropping command, expected response not received after 1 attempt(s)
2020-01-09 05:35:10.581 Error, Node048, ERROR: ZW_SEND_DATA could not be delivered to Z-Wave stack
2020-01-09 05:35:14.579 Error, Node048, ERROR: Dropping command, expected response not received after 1 attempt(s)
2020-01-09 05:40:11.176 Error, Node050, ERROR: Dropping command, expected response not received after 1 attempt(s)
2020-01-09 06:20:15.199 Error, Node051, ERROR: Dropping command, expected response not received after 1 attempt(s)
2020-01-09 06:27:14.332 Error, Node019, ERROR: Dropping command, expected response not received after 1 attempt(s)
2020-01-09 06:30:06.693 Error, Node051, ERROR: ZW_SEND_DATA could not be delivered to Z-Wave stack
2020-01-09 06:30:14.487 Error, Node046, ERROR: Dropping command, expected response not received after 1 attempt(s)
2020-01-09 06:37:29.541 Error, Node056, ERROR: Dropping command, expected response not received after 1 attempt(s)
2020-01-09 06:45:12.834 Error, Node048, ERROR: Dropping command, expected response not received after 1 attempt(s)
2020-01-09 07:00:41.174 Error, Node019, ERROR: Dropping command, expected response not received after 1 attempt(s)
2020-01-09 07:04:06.299 Error, Node019, ERROR: Dropping command, expected response not received after 1 attempt(s)
2020-01-09 07:04:06.302 Error, Node019, ERROR: ZW_SEND_DATA could not be delivered to Z-Wave stack
2020-01-09 07:04:10.301 Error, Node019, ERROR: Dropping command, expected response not received after 1 attempt(s)
2020-01-09 07:15:11.152 Error, Node050, ERROR: Dropping command, expected response not received after 1 attempt(s)
2020-01-09 07:15:11.156 Error, Node051, ERROR: ZW_SEND_DATA could not be delivered to Z-Wave stack
2020-01-09 07:15:15.154 Error, Node051, ERROR: Dropping command, expected response not received after 1 attempt(s)
2020-01-09 07:35:11.333 Error, Node050, ERROR: Dropping command, expected response not received after 1 attempt(s)
2020-01-09 07:35:11.336 Error, Node049, ERROR: ZW_SEND_DATA could not be delivered to Z-Wave stack
2020-01-09 07:35:15.334 Error, Node049, ERROR: Dropping command, expected response not received after 1 attempt(s)
2020-01-09 07:50:04.874 Error, Node018, ERROR: Dropping command, expected response not received after 1 attempt(s)
2020-01-09 07:50:11.390 Error, Node018, ERROR: Dropping command, expected response not received after 1 attempt(s)
2020-01-09 07:50:11.729 Error, Node018, ERROR: ZW_SEND_DATA could not be delivered to Z-Wave stack
2020-01-09 07:50:12.376 Error, Node018, ERROR: ZW_SEND_DATA could not be delivered to Z-Wave stack
2020-01-09 07:50:12.535 Error, Node018, ERROR: ZW_SEND_DATA could not be delivered to Z-Wave stack
2020-01-09 07:50:15.393 Error, Node018, ERROR: Dropping command, expected response not received after 2 attempt(s)
2020-01-09 07:50:19.396 Error, Node018, ERROR: Dropping command, expected response not received after 1 attempt(s)
2020-01-09 07:50:23.399 Error, Node018, ERROR: Dropping command, expected response not received after 1 attempt(s)
2020-01-09 07:50:23.403 Error, Node018, ERROR: ZW_SEND_DATA could not be delivered to Z-Wave stack
2020-01-09 07:50:27.402 Error, Node018, ERROR: Dropping command, expected response not received after 1 attempt(s)
2020-01-09 07:50:28.136 Error, Node018, ERROR: ZW_SEND_DATA could not be delivered to Z-Wave stack
2020-01-09 08:00:10.586 Error, Node050, ERROR: Dropping command, expected response not received after 1 attempt(s)
2020-01-09 08:00:10.590 Error, Node049, ERROR: ZW_SEND_DATA could not be delivered to Z-Wave stack
2020-01-09 08:00:14.588 Error, Node049, ERROR: Dropping command, expected response not received after 1 attempt(s)
2020-01-09 08:04:50.656 Error, Node019, ERROR: Dropping command, expected response not received after 1 attempt(s)
2020-01-09 08:34:05.490 Error, Node056, ERROR: Dropping command, expected response not received after 1 attempt(s)
2020-01-09 08:55:10.755 Error, Node051, ERROR: Dropping command, expected response not received after 1 attempt(s)
2020-01-09 08:55:11.264 Error, Node051, ERROR: ZW_SEND_DATA could not be delivered to Z-Wave stack
2020-01-09 09:08:10.069 Error, Node056, ERROR: Dropping command, expected response not received after 1 attempt(s)
2020-01-09 09:12:53.223 Error, Node056, ERROR: Dropping command, expected response not received after 1 attempt(s)
2020-01-09 09:30:15.707 Error, Node050, ERROR: Dropping command, expected response not received after 1 attempt(s)
2020-01-09 09:35:14.161 Error, Node050, ERROR: Dropping command, expected response not received after 1 attempt(s)
2020-01-09 09:35:14.165 Error, Node049, ERROR: ZW_SEND_DATA could not be delivered to Z-Wave stack
2020-01-09 09:35:18.162 Error, Node049, ERROR: Dropping command, expected response not received after 1 attempt(s)
2020-01-09 09:58:18.015 Error, Node056, ERROR: Dropping command, expected response not received after 1 attempt(s)
2020-01-09 10:03:18.446 Error, Node056, ERROR: Dropping command, expected response not received after 1 attempt(s)
2020-01-09 10:10:10.211 Error, Node049, ERROR: ZW_SEND_DATA could not be delivered to Z-Wave stack
2020-01-09 10:10:14.208 Error, Node049, ERROR: Dropping command, expected response not received after 1 attempt(s)
2020-01-09 10:15:10.481 Error, Node050, ERROR: Dropping command, expected response not received after 1 attempt(s)
2020-01-09 10:15:10.484 Error, Node049, ERROR: ZW_SEND_DATA could not be delivered to Z-Wave stack
2020-01-09 10:15:14.483 Error, Node049, ERROR: Dropping command, expected response not received after 1 attempt(s)
2020-01-09 10:40:10.738 Error, Node050, ERROR: Dropping command, expected response not received after 1 attempt(s)
2020-01-09 10:40:11.480 Error, Node049, ERROR: ZW_SEND_DATA could not be delivered to Z-Wave stack
2020-01-09 10:40:15.478 Error, Node049, ERROR: Dropping command, expected response not received after 1 attempt(s)
2020-01-09 10:48:31.281 Error, Node056, ERROR: Dropping command, expected response not received after 1 attempt(s)
2020-01-09 10:50:11.517 Error, Node051, ERROR: Dropping command, expected response not received after 1 attempt(s)
2020-01-09 10:50:11.521 Error, Node048, ERROR: ZW_SEND_DATA could not be delivered to Z-Wave stack
2020-01-09 10:50:15.519 Error, Node048, ERROR: Dropping command, expected response not received after 1 attempt(s)
2020-01-09 10:53:44.362 Error, Node056, ERROR: Dropping command, expected response not received after 1 attempt(s)
2020-01-09 10:55:12.739 Error, Node050, ERROR: Dropping command, expected response not received after 1 attempt(s)
2020-01-09 10:55:12.742 Error, Node049, ERROR: ZW_SEND_DATA could not be delivered to Z-Wave stack
2020-01-09 10:55:16.740 Error, Node049, ERROR: Dropping command, expected response not received after 1 attempt(s)
2020-01-09 10:58:13.516 Error, Node018, ERROR: Dropping command, expected response not received after 1 attempt(s)
2020-01-09 10:58:49.512 Error, Node019, ERROR: Dropping command, expected response not received after 1 attempt(s)
2020-01-09 10:59:19.412 Error, Node018, ERROR: Dropping command, expected response not received after 1 attempt(s)
2020-01-09 11:00:15.029 Error, Node051, ERROR: Dropping command, expected response not received after 1 attempt(s)
2020-01-09 11:00:15.043 Error, Node051, ERROR: ZW_SEND_DATA could not be delivered to Z-Wave stack
2020-01-09 11:15:12.392 Error, Node050, ERROR: Dropping command, expected response not received after 1 attempt(s)
2020-01-09 11:15:12.647 Error, Node049, ERROR: ZW_SEND_DATA could not be delivered to Z-Wave stack
2020-01-09 11:15:16.394 Error, Node049, ERROR: Dropping command, expected response not received after 1 attempt(s)
2020-01-09 11:25:15.464 Error, Node048, ERROR: Dropping command, expected response not received after 1 attempt(s)
2020-01-09 11:38:41.925 Error, Node056, ERROR: Dropping command, expected response not received after 1 attempt(s)
2020-01-09 11:44:09.879 Error, Node056, ERROR: Dropping command, expected response not received after 1 attempt(s)
2020-01-09 12:00:11.925 Error, Node048, ERROR: Dropping command, expected response not received after 1 attempt(s)
2020-01-09 12:20:10.833 Error, Node051, ERROR: Dropping command, expected response not received after 1 attempt(s)
2020-01-09 12:25:10.808 Error, Node050, ERROR: Dropping command, expected response not received after 1 attempt(s)
2020-01-09 12:25:10.899 Error, Node049, ERROR: ZW_SEND_DATA could not be delivered to Z-Wave stack
2020-01-09 12:25:14.810 Error, Node049, ERROR: Dropping command, expected response not received after 1 attempt(s)
2020-01-09 12:28:52.533 Error, Node056, ERROR: Dropping command, expected response not received after 1 attempt(s)
2020-01-09 12:34:33.976 Error, Node056, ERROR: Dropping command, expected response not received after 1 attempt(s)
2020-01-09 12:55:12.134 Error, Node050, ERROR: Dropping command, expected response not received after 1 attempt(s)
2020-01-09 12:55:12.137 Error, Node049, ERROR: ZW_SEND_DATA could not be delivered to Z-Wave stack
2020-01-09 12:55:16.135 Error, Node049, ERROR: Dropping command, expected response not received after 1 attempt(s)
2020-01-09 13:00:10.905 Error, Node049, ERROR: ZW_SEND_DATA could not be delivered to Z-Wave stack
2020-01-09 13:00:14.896 Error, Node049, ERROR: Dropping command, expected response not received after 1 attempt(s)
2020-01-09 13:05:10.147 Error, Node050, ERROR: Dropping command, expected response not received after 1 attempt(s)
2020-01-09 13:05:10.218 Error, Node049, ERROR: ZW_SEND_DATA could not be delivered to Z-Wave stack
2020-01-09 13:05:14.149 Error, Node049, ERROR: Dropping command, expected response not received after 1 attempt(s)
2020-01-09 13:25:09.938 Error, Node050, ERROR: Dropping command, expected response not received after 1 attempt(s)
2020-01-09 13:25:09.944 Error, Node049, ERROR: ZW_SEND_DATA could not be delivered to Z-Wave stack
2020-01-09 13:25:13.940 Error, Node049, ERROR: Dropping command, expected response not received after 1 attempt(s)
2020-01-09 13:30:07.777 Error, Node049, ERROR: ZW_SEND_DATA could not be delivered to Z-Wave stack
2020-01-09 13:30:11.774 Error, Node049, ERROR: Dropping command, expected response not received after 1 attempt(s)
Je vais tenter ce soir de couper les fusible et redémarrer les modules correspondant… on verra bien…
