[RESOLU] Plus de TTS sur Jeedom
Je viens de m’apercevoir que je n’avais plus aucun TTS qui ne fonctionne sur le Google Home.
Dans les logs http, j’ai cette erreur :
[Wed Apr 22 11:06:15.255209 2020] [:error] [pid 28243] [client 192.168.0.xx:42392] PHP Fatal error:  Uncaught Error: Class '' not found in /var/www/html/core/api/tts.php:98
Stack trace:
#0 {main}
  thrown in /var/www/html/core/api/tts.php on line 98
[Wed Apr 22 11:06:22.760599 2020] [:error] [pid 4836] [client 192.168.0.xx:42398] PHP Fatal error:  Uncaught Error: Class '' not found in /var/www/html/core/api/tts.php:98
Stack trace:
#0 {main}
[Wed Apr 22 11:08:49.262831 2020] [core:notice] [pid 684] AH00052: child pid 28245 exit signal Segmentation fault (11)
[Wed Apr 22 11:08:49.262953 2020] [core:notice] [pid 684] AH00052: child pid 28243 exit signal Segmentation fault (11)
[Wed Apr 22 11:08:49.262993 2020] [core:notice] [pid 684] AH00052: child pid 4920 exit signal Segmentation fault (11)
[Wed Apr 22 11:08:49.277593 2020] [mpm_prefork:notice] [pid 684] AH00169: caught SIGTERM, shutting down
[Wed Apr 22 11:09:13.149777 2020] [mpm_prefork:notice] [pid 732] AH00163: Apache/2.4.25 (Debian) OpenSSL/1.0.2u configured -- resuming normal operations
[Wed Apr 22 11:09:13.272572 2020] [core:notice] [pid 732] AH00094: Command line: '/usr/sbin/apache2'
[Wed Apr 22 11:09:13.583436 2020] [:error] [pid 858] [client xx.xx.xx.xx:52867] PHP Fatal error:  Uncaught Error: Class 'ajax' not found in /var/www/html/core/ajax/event.ajax.php:36
Stack trace:
#0 {main}
  thrown in /var/www/html/core/ajax/event.ajax.php on line 36, referer: https://xxxxxx.xxx/index.php?v=d&p=dashboard
[Wed Apr 22 11:15:37.282166 2020] [:error] [pid 1688] [client 192.168.0.xx:44102] PHP Fatal error:  Uncaught Error: Class '' not found in /var/www/html/core/api/tts.php:98
Stack trace:
#0 {main}
[Wed Apr 22 11:18:54.521307 2020] [:error] [pid 4258] [client 192.168.0.xx:44338] PHP Fatal error:  Uncaught Error: Class '' not found in /var/www/html/core/api/tts.php:98
Stack trace:
#0 {main}
[Wed Apr 22 11:21:26.386616 2020] [:error] [pid 4222] [client 192.168.0.xx:44492] PHP Fatal error:  Uncaught Error: Class '' not found in /var/www/html/core/api/tts.php:98
Stack trace:
#0 {main}
[Wed Apr 22 11:22:22.859948 2020] [:error] [pid 1685] [client xx.xx.xx.xx:61495] script '/var/www/html/elrekt.php' not found or unable to stat
[Wed Apr 22 11:22:37.317728 2020] [:error] [pid 32043] [client 192.168.0.xx:44556] PHP Fatal error:  Uncaught Error: Class '' not found in /var/www/html/core/api/tts.php:98
Stack trace:
#0 {main}
Si quelqu’un peut m’aider car je ne sais pas ou chercher.
Merci d’avance.
Bonjour @wisecam,
Sujet résolu ?
Quelle ont été les manipulations pour le résoudre ? ça peut servir à d’autres personnes dans le même cas.
Problème identique chez moi qui correspond à la mise à jour de fin mars je pense :
https://jeedom.github.io/plugin-gcast/fr_FR/changelog
[Tue Apr 28 13:41:03.507411 2020] [:error] [pid 11202] [client 10.125.1.12:53574] PHP Fatal error:  Uncaught Error: Class '' not found in /var/www/html/core/api/tts.php:98
Stack trace:
#0 {main}
Qui revient à chaque fois que je veux envoyer un message sur le GoogleHome
Je cherche et reviens si je trouve une solution
@wisecam : si tu l’as déjà, je la veux bien :stuck_out_tongue:
Bonne journée
EDIT :
Problème résolu en sauvegardant la page /index.php?v=d&p=administration de Jeedom qui mentionne le moteur TTS - j’étais passé à côté de cette nouveauté
Pour info - Jeedom en V4.0.52
Par le message d’erreur Class '' et le code de tts.php, je crois qu’il faut sélectionner un Moteur TTS sur l’onglet Général de Réglages/Système/Configuration:
Oui, c’est ce que j’ai trouvé également.
Super merci, ca fait un moment que je cherchais… :sweat_smile: :grin:
