Je viens d’installer le plugin ZigbeeLinker stable et je pense qu’il y a un soucis. C’est une première installation, aucun autre plugin zigbee. J’utilise une clé Conbee II que j’ai mise à jour dans le doute et visiblement, il me manque un fichier d’après les logs.
# INSTALL : Zigbee2mqtt #
##### apt-get update in progress
Hit:1 http://security.debian.org buster/updates InRelease
Hit:2 http://deb.debian.org/debian buster InRelease
Hit:3 http://deb.debian.org/debian buster-updates InRelease
Hit:4 http://deb.debian.org/debian buster-backports InRelease
Hit:5 https://deb.nodesource.com/node_14.x buster InRelease
Reading package lists...
##### Install or update Git
Building dependency tree...
Reading state information...
g++ is already the newest version (4:8.3.0-1).
gcc is already the newest version (4:8.3.0-1).
git is already the newest version (1:2.20.1-2+deb10u3).
make is already the newest version (4.2.1-1.2).
0 upgraded, 0 newly installed, 0 to remove and 6 not upgraded.
##### Install or update NodeJs
NodeJs 14 already installed : Nothing to do !
# INSTALLING : Mosquitto (server) #
mosquitto is already the newest version (1.5.7-1+deb10u1).
# INSTALLING : Mosquitto for Php #
Mosquitto for Php is already installed, nothing to do
##### Install Socat
Socat is already installed, nothing to do
##### Install yaml php and restart apache
Yaml is already installed, nothing to do
##### Stopping Zigbee2mqtt deamon #
##### Update : Download update from Zigbee2mqtt git
##### up to date
##### Configure deamon and start it
mv: cannot stat '/opt/zigbee2mqtt/data/database.db': No such file or directory
mv: cannot stat '/opt/zigbee2mqtt/data/state.json': No such file or directory
chown: cannot access '/var/www/html/plugins/zigbee2mqtt/data/zigbee2mqtt/state.json': No such file or directory
chown: cannot access '/var/www/html/plugins/zigbee2mqtt/data/zigbee2mqtt/database.db': No such file or directory
Created symlink /etc/systemd/system/multi-user.target.wants/zigbee2mqtt.service -> /etc/systemd/system/zigbee2mqtt.service.
# END #
Avez vous une idée de pourquoi il me manque ces fichiers ?
Edit: Je viens de tester l’application Deconz sur mon pc pour vérifier le bon fonctionnement de ma clé / capteurs. Tout est OK.
J’ai essayé la version beta du plugin et malheureusement le service crash toujours à la seule différence que je n’ai plus rien dans les logs.
Cordialement
