J’ai depuis quelques jours une absence de remontée des évenements sur le plugin Ajax,
La partie contrôle des groupes est fonctionnelle mais plus la remontée des events.
J’ai tenté une reconnexion, synchro des éléments en vain.
Côté Ajax l’user mail jeedom est bien toujours en attente.
La partie accès externe est toujours active et j’ai bien accès à la page de connexion jeedom depuis l’IP public et le port associé.
Voici les logs :
[2024-12-10 22:53:22][DEBUG] : [request] https://cloud.jeedom.com/service/ajaxSystem?path=%2Frefresh => {"userId":"7563F068","refreshToken":"aK-wT0NIbQrdFVsNABhlFCm-P4E"}
[2024-12-10 22:53:22][DEBUG] : [refreshToken] {"sessionToken":"AfBCFCuoMVCgM0r1BlqJtgDidfM","userId":"7563F068","refreshToken":"uRhoh7PLrosuweZvby53i54juF8"}
[2024-12-10 22:53:22][DEBUG] : [request] https://cloud.jeedom.com/service/ajaxSystem?path=%2Fuser%2F7563F068%2Fhubs%2F002079C1%2Fgroups%2F00000002%2Fcommands%2Farming&session_token=AfBCFCuoMVCgM0r1BlqJtgDidfM => {"command":"ARM","ignoreProblems":true}
[2024-12-10 22:53:26][DEBUG] : [request] https://cloud.jeedom.com/service/ajaxSystem?path=%2Fuser%2F7563F068%2Fhubs%2F002079C1%2Fgroups%2F00000002%2Fcommands%2Farming&session_token=AfBCFCuoMVCgM0r1BlqJtgDidfM => {"command":"DISARM","ignoreProblems":true}
[2024-12-10 22:53:47][DEBUG] : [request] https://cloud.jeedom.com/service/ajaxSystem?path=%2Fuser%2F7563F068%2Fhubs%2F002079C1%2Fcommands%2Farming&session_token=AfBCFCuoMVCgM0r1BlqJtgDidfM => {"command":"ARM","ignoreProblems":true}
[2024-12-10 22:53:51][DEBUG] : [request] https://cloud.jeedom.com/service/ajaxSystem?path=%2Fuser%2F7563F068%2Fhubs%2F002079C1%2Fcommands%2Farming&session_token=AfBCFCuoMVCgM0r1BlqJtgDidfM => {"command":"NIGHT_MODE_ON","ignoreProblems":true}
[2024-12-10 22:53:55][DEBUG] : [request] https://cloud.jeedom.com/service/ajaxSystem?path=%2Fuser%2F7563F068%2Fhubs%2F002079C1%2Fcommands%2Farming&session_token=AfBCFCuoMVCgM0r1BlqJtgDidfM => {"command":"DISARM","ignoreProblems":true}
[2024-12-10 22:53:58][ERROR] : Erreur exécution de la commande [Extérieur][Maison][Armement] : Erreur lors de la requete à Ajax System : {"state":"nok","error":"Can no put Ajax server"}
[2024-12-10 22:54:05][DEBUG] : [request] https://cloud.jeedom.com/service/ajaxSystem?path=%2Fuser%2F7563F068%2Fhubs%2F002079C1%2Fcommands%2Farming&session_token=AfBCFCuoMVCgM0r1BlqJtgDidfM => {"command":"NIGHT_MODE_ON","ignoreProblems":true}
[2024-12-10 22:55:56][DEBUG] : [request] https://cloud.jeedom.com/service/ajaxSystem?path=%2Fuser%2F7563F068%2Fhubs%2F002079C1%2Fgroups%2F00000001%2Fcommands%2Farming&session_token=AfBCFCuoMVCgM0r1BlqJtgDidfM => {"command":"ARM","ignoreProblems":true}
[2024-12-10 22:56:42][DEBUG] : [request] https://cloud.jeedom.com/service/ajaxSystem?path=%2Fuser%2F7563F068%2Fhubs&session_token=AfBCFCuoMVCgM0r1BlqJtgDidfM => null
[2024-12-10 22:56:43][DEBUG] : [{"hubId":"002079C1","hubBindingRole":"MASTER"}]
[2024-12-10 22:56:43][DEBUG] : [request] https://cloud.jeedom.com/service/ajaxSystem?path=%2Fuser%2F7563F068%2Fhubs%2F002079C1&session_token=AfBCFCuoMVCgM0r1BlqJtgDidfM => null
[2024-12-10 22:56:43][DEBUG] : {"hubSubtype":"HUB_2","name":"Maison","id":"002079C1","state":"PARTIALLY_ARMED_NIGHT_MODE_OFF","timeZone":"EUROPE_PARIS","color":"WHITE","tampered":false,"capabilities":["DFU"],"externallyPowered":true,"ledBrightnessLevel":10,"chargingMode":"CONTINUOUS","noiseLevel":{"high":false,"avgValueChannel1":-95,"avgValueChannel2":-95,"avgValueDataChannel":-91},"debugLogState":"ETHERNET_ONLY","panicSirenOnPanicButton":false,"limits":{"rooms":50,"groups":9,"cameras":25,"sensors":100,"users":50},"groupsEnabled":true,"firmware":{"version":"2.25.118","newVersionAvailable":false,"latestAvailableVersion":"","autoupdateEnabled":true},"ethernet":{"enabled":true,"dns":"192.168.1.1","ip":"192.168.1.44","gate":"192.168.1.1","dhcp":false,"mask":"255.255.255.0"},"armPreventionMode":"ALERT_USER","panicSirenOnAnyTamper":true,"battery":{"chargeLevelPercentage":100,"state":"CHARGED"},"hardwareVersions":{"cpu":5,"wifi":0,"ethernet":1,"flash":3,"pcb":96,"rfm":10,"zwave":0,"modem":10},"warnings":{"hub":0,"allDevices":0},"fireAlarm":{"triggerOnAllSensors":false,"doubleImpulses":false,"alarmPropagationTimeoutSeconds":null,"alarmPropagationTimeoutExpirationTimestamp":0,"alarmPropagationState":"DISABLED","alarmPropagationDetails":{"multiApartmentBuildingModeEnabled":false}},"cms":{"address":"0.0.0.0","port":0,"addressReserve":"0.0.0.0","portReserve":0,"ethernetEnabled":false,"cmsProtocol":"CID","cmsConnectionMode":"ALWAYS_UP","siaAccountNumber":"000","siaEncryptionKey":null,"siaEncryptionType":"OFF","sendPanicButtonLocation":false,"alarmRecoveryNotificationSettings":{"alarmRecoveryReportMode":"REPORT_IMMEDIATELY","additionalAlarmRecoveriesToReport":["PANIC"]},"gprsAddress":"0.0.0.0","gprsPort":0,"gprsAddressReserve":"0.0.0.0","gprsPortReserve":0,"gprsEnabled":false,"activeChannels":[],"pingPeriodSeconds":0},"imageUrls":null,"activeChannels":["ETHERNET"],"pingPeriodSeconds":60,"offlineAlarmSeconds":300,"ledIndicationMode":"HUB_SERVER_CONNECTION","jeweller":{"lostHeartbeatsThreshold":8,"detectorPingIntervalSeconds":36},"connectionTestInProgress":false,"hubMalfunctions":[],"blockedByServiceProvider":false,"connectionLostAsMalfunction":true,"alarmAsMalfunctionWhenArming":false,"hubAddress":null,"alarmVerification":{"verificationEnabled":false,"verificationTimeout":30},"alarmConfirmation":{"commonDevice":{"status":"DISABLED","timeoutMinutes":30,"confirmedAlarmOn":["DELAYED_DEVICES"]},"holdUpDevice":{"status":"DISABLED","timeoutMinutes":480}},"geoFence":{"radiusMeters":150,"latitude":"48.60517296774541","longitude":"2.5048911944031715"},"armPreventionConditions":["NO_SERVER_CONNECTION","TAMPERED","LOW_BATTERY_CHARGE","NO_EXTERNAL_POWER"],"restoreRequiredAfterAlarmCondition":[],"alarmCondition":[],"twoStageArming":{"enabled":false,"applicationTriggeredArming":{"countdownDurationSeconds":30,"state":"NOT_STARTED","expirationUnixTime":null},"deviceTriggeredArming":{"countdownDurationSeconds":60,"finalDoorBounceCountdownDurationSeconds":3,"state":"NOT_STARTED","expirationUnixTime":null}},"postAlarmIndicationRules":["CONFIRMED_ALARM","UNCONFIRMED_ALARM"],"connectivityNotificationSettings":{"channelOfflineAlarmDelaySeconds":300,"enabledChannelNotifications":[]},"currentStandard":"EU","siaCpSettings":{"exitTimeRestart":false,"recentClosing":true,"alarmCancelWindow":true,"unvacatedPremises":true,"lastSecondsNotification":5,"silentExit":"DISABLED"},"batterySavingMode":{"batterySaveModeEnable":"DISABLED","batterySaveModeEnableV2":null,"batterySaveModeStatus":"NORMAL","batterySaveModeActiveTime":10,"batterySaveModePingPeriodMin":360},"gradeMode":"GRADE_3","eventDelayEnable":[],"jammingAsAlarm":"ALARM","interconnectWithoutHub":{"iwhNetworkTestState":"IWH_TEST_STOPPED","iwhNetworkTestEndTime":null,"iwhNetworkTestInitiatorId":"00000000","iwhEnabled":"DEACTIVATED","activeFireAlarms":[]},"modemImei":"","bukhoorMode":{"fpBukhoorEnabled":"DEACTIVATED","fpBukhoorState":"INACTIVE","fpBukhoorEndTime":null,"fpBukhoorForbidTimeStart":0,"fpBukhoorForbidTimeEnd":420},"externalPowerLossDelayTimer":0,"armPreventionsSystem":["BOLT_SWITCH_CONTACT"],"callSettings":null,"vdsLockingStatus":"NOT_STARTED","safeBatteryCharging":null,"photoOnDemandDetails":null,"batteryChargingFlags":null,"gsm":{"signalLevel":null,"gprsEnabled":false,"simCardState":"MISSING","networkStatus":null,"activeSimCard":0,"simCards":[{"number":"","apn":"internet","username":"","password":"","balanceNumber":"","trafficTxKb":0,"trafficRxKb":0,"lastTrafficResetTimestamp":0},{"number":"","apn":"internet","username":"","password":"","balanceNumber":"","trafficTxKb":0,"trafficRxKb":0,"lastTrafficResetTimestamp":0}],"disableIcmpBeforeConnecting":false,"virtualOperatorAllowed":false,"roamingEnabled":false},"passwordLength":0}
[2024-12-10 22:56:43][DEBUG] : [request] https://cloud.jeedom.com/service/ajaxSystem?path=%2Fuser%2F7563F068%2Fhubs%2F002079C1%2Fdevices&session_token=AfBCFCuoMVCgM0r1BlqJtgDidfM => null
[2024-12-10 22:56:43][DEBUG] : [{"id":"304823B2","deviceType":"DoorProtect","deviceName":"Porte Garage","roomId":"00000001","groupId":"00000002","color":"WHITE","online":true},{"id":"30482C75","deviceType":"DoorProtect","deviceName":"Porte Entr\u00e9e","roomId":"00000002","groupId":"00000002","color":"WHITE","online":true},{"id":"3040E633","deviceType":"DoorProtect","deviceName":"Porte Fen\u00eatre Salon","roomId":"00000003","groupId":"00000002","color":"WHITE","online":true},{"id":"304811A0","deviceType":"DoorProtect","deviceName":"Fen\u00eatre Cuisine","roomId":"00000004","groupId":"00000002","color":"WHITE","online":true},{"id":"304FB319","deviceType":"DoorProtectPlus","deviceName":"Coffre fort","roomId":"00000005","groupId":"00000001","color":"BLACK","online":true},{"id":"304693CE","deviceType":"MotionProtect","deviceName":"Garage","roomId":"00000001","groupId":"00000002","color":"WHITE","online":true},{"id":"304650E5","deviceType":"MotionProtect","deviceName":"Palier ","roomId":"00000006","groupId":"00000002","color":"WHITE","online":true},{"id":"303D6092","deviceType":"KeypadTouchscreen","deviceName":"Keypad","roomId":"00000002","groupId":"00000002","color":"BLACK","online":true},{"id":"301EA362","deviceType":"SpaceControl","deviceName":"SpaceControl","roomId":"00000008","groupId":"00000001","color":"WHITE","online":true},{"id":"00257DA1","deviceType":"StreetSiren","deviceName":"StreetSiren","roomId":"00000007","groupId":"00000002","color":"WHITE","online":true}]
[2024-12-10 22:56:43][DEBUG] : [request] https://cloud.jeedom.com/service/ajaxSystem?path=%2Fuser%2F7563F068%2Fhubs%2F002079C1%2Fdevices%2F304823B2&session_token=AfBCFCuoMVCgM0r1BlqJtgDidfM => null
[2024-12-10 22:56:44][DEBUG] : [request] https://cloud.jeedom.com/service/ajaxSystem?path=%2Fuser%2F7563F068%2Fhubs%2F002079C1%2Fdevices%2F304823B2&session_token=AfBCFCuoMVCgM0r1BlqJtgDidfM => null
[2024-12-10 22:56:44][DEBUG] : [request] https://cloud.jeedom.com/service/ajaxSystem?path=%2Fuser%2F7563F068%2Fhubs%2F002079C1%2Fdevices%2F30482C75&session_token=AfBCFCuoMVCgM0r1BlqJtgDidfM => null
[2024-12-10 22:56:44][DEBUG] : [request] https://cloud.jeedom.com/service/ajaxSystem?path=%2Fuser%2F7563F068%2Fhubs%2F002079C1%2Fdevices%2F3040E633&session_token=AfBCFCuoMVCgM0r1BlqJtgDidfM => null
[2024-12-10 22:56:44][DEBUG] : [request] https://cloud.jeedom.com/service/ajaxSystem?path=%2Fuser%2F7563F068%2Fhubs%2F002079C1%2Fdevices%2F304811A0&session_token=AfBCFCuoMVCgM0r1BlqJtgDidfM => null
[2024-12-10 22:56:45][DEBUG] : [request] https://cloud.jeedom.com/service/ajaxSystem?path=%2Fuser%2F7563F068%2Fhubs%2F002079C1%2Fdevices%2F304811A0&session_token=AfBCFCuoMVCgM0r1BlqJtgDidfM => null
[2024-12-10 22:56:45][DEBUG] : [request] https://cloud.jeedom.com/service/ajaxSystem?path=%2Fuser%2F7563F068%2Fhubs%2F002079C1%2Fdevices%2F304FB319&session_token=AfBCFCuoMVCgM0r1BlqJtgDidfM => null
[2024-12-10 22:56:45][DEBUG] : [request] https://cloud.jeedom.com/service/ajaxSystem?path=%2Fuser%2F7563F068%2Fhubs%2F002079C1%2Fdevices%2F304693CE&session_token=AfBCFCuoMVCgM0r1BlqJtgDidfM => null
[2024-12-10 22:56:45][DEBUG] : [request] https://cloud.jeedom.com/service/ajaxSystem?path=%2Fuser%2F7563F068%2Fhubs%2F002079C1%2Fdevices%2F304650E5&session_token=AfBCFCuoMVCgM0r1BlqJtgDidfM => null
[2024-12-10 22:56:46][DEBUG] : [request] https://cloud.jeedom.com/service/ajaxSystem?path=%2Fuser%2F7563F068%2Fhubs%2F002079C1%2Fdevices%2F304650E5&session_token=AfBCFCuoMVCgM0r1BlqJtgDidfM => null
[2024-12-10 22:56:46][DEBUG] : [request] https://cloud.jeedom.com/service/ajaxSystem?path=%2Fuser%2F7563F068%2Fhubs%2F002079C1%2Fdevices%2F303D6092&session_token=AfBCFCuoMVCgM0r1BlqJtgDidfM => null
[2024-12-10 22:56:46][DEBUG] : [request] https://cloud.jeedom.com/service/ajaxSystem?path=%2Fuser%2F7563F068%2Fhubs%2F002079C1%2Fdevices%2F301EA362&session_token=AfBCFCuoMVCgM0r1BlqJtgDidfM => null
[2024-12-10 22:56:46][DEBUG] : [request] https://cloud.jeedom.com/service/ajaxSystem?path=%2Fuser%2F7563F068%2Fhubs%2F002079C1%2Fdevices%2F00257DA1&session_token=AfBCFCuoMVCgM0r1BlqJtgDidfM => null
[2024-12-10 22:56:47][DEBUG] : [request] https://cloud.jeedom.com/service/ajaxSystem?path=%2Fuser%2F7563F068%2Fhubs%2F002079C1%2Fgroups&session_token=AfBCFCuoMVCgM0r1BlqJtgDidfM => null
[2024-12-10 22:56:47][DEBUG] : [{"id":"00000001","groupName":"Coffre fort ","imageUrls":null,"bulkArmInvolved":true,"bulkDisarmInvolved":false,"state":"ARMED","twoStageArming":{"enabled":true,"applicationTriggeredArmingState":"NOT_STARTED","deviceTriggeredArmingState":"NOT_STARTED"}},{"id":"00000002","groupName":"Maison ","imageUrls":null,"bulkArmInvolved":true,"bulkDisarmInvolved":true,"state":"DISARMED","twoStageArming":{"enabled":true,"applicationTriggeredArmingState":"NOT_STARTED","deviceTriggeredArmingState":"NOT_STARTED"}}]
Informations Jeedom
Core : 4.4.19 (master)
DNS Jeedom : non
Plugin : Ajax Systems
Version : 2024-09-08 01:20:30 (stable)
Merci d’avance
