Ha bha non, ça marche pas.
Enfin si, selon le log ça fonctionne mais l’état sur le dashboard ne correspond pas au log.
2020-05-22 09:00:06][INFO] : Reçu sur Jeedom : *2*1000#0*68##
[2020-05-22 09:00:06][DEBUG] : Jeemyhomescs_Equipement : Array ( [trame] => *2*1000#0*68## [format] => BUS_EVENT [mode] => UNKNOWN [media] => SCS [type] => scene [value] => [dimension] => [param] => [A] => [PL] => [date] => 2020-05-22 09:00:06 )
[2020-05-22 09:00:06][DEBUG] : Jeemyhomescs_Trame non interprétée
[2020-05-22 09:00:06][INFO] : Reçu sur Jeedom : *2*1000#1*68##
[2020-05-22 09:00:06][DEBUG] : Jeemyhomescs_Equipement : Array ( [trame] => *2*1000#1*68## [format] => BUS_EVENT [mode] => UNKNOWN [media] => SCS [type] => scene [value] => [dimension] => [param] => [A] => [PL] => [date] => 2020-05-22 09:00:06 )
[2020-05-22 09:00:06][INFO] : Reçu sur Jeedom : *2*0*68##
[2020-05-22 09:00:06][DEBUG] : Jeemyhomescs_Equipement : Array ( [trame] => *2*0*68## [format] => BUS_COMMAND [mode] => UNICAST [media] => SCS [type] => automatism [value] => MOVE_STOP [dimension] => [param] => [A] => 6 [PL] => 8 [date] => 2020-05-22 09:00:06 )
[2020-05-22 09:00:06][DEBUG] : Jeemyhomescs_BUS_COMMAND
[2020-05-22 09:00:06][DEBUG] : Update Status Automatism
[2020-05-22 09:00:06][DEBUG] : last : CLOSED Sous_device : 00 duréecmd : 28 id cmd : 1 date : 1590130806
[2020-05-22 09:00:06][DEBUG] : sousdevice : 00 LogicalID : 68 updatedate :
[2020-05-22 09:00:06][DEBUG] : Bouton normal
[2020-05-22 09:00:06][DEBUG] : Action move_STOP
[2020-05-22 09:00:06][DEBUG] : updatedate : Newpos : 5679038692.8571
[2020-05-22 09:00:06][DEBUG] : mise a jour du status : CLOSED
[2020-05-22 09:00:06][INFO] : Reçu sur Jeedom : *2*1*68##
[2020-05-22 09:00:06][DEBUG] : Jeemyhomescs_Equipement : Array ( [trame] => *2*1*68## [format] => BUS_COMMAND [mode] => UNICAST [media] => SCS [type] => automatism [value] => MOVE_UP [dimension] => [param] => [A] => 6 [PL] => 8 [date] => 2020-05-22 09:00:06 )
[2020-05-22 09:00:06][DEBUG] : Action MOVE_UP
[2020-05-22 09:00:06][DEBUG] : Point UP
[2020-05-22 09:00:06][DEBUG] : Move time : 28
[2020-05-22 09:00:06][DEBUG] : mise a jour du status : UP
[2020-05-22 09:00:06][INFO] : Reçu sur Jeedom : *2*1000#0*62##
[2020-05-22 09:00:06][DEBUG] : Jeemyhomescs_Equipement : Array ( [trame] => *2*1000#0*62## [format] => BUS_EVENT [mode] => UNKNOWN [media] => SCS [type] => scene [value] => [dimension] => [param] => [A] => [PL] => [date] => 2020-05-22 09:00:06 )
[2020-05-22 09:00:07][INFO] : Reçu sur Jeedom : *2*0*62##
[2020-05-22 09:00:07][DEBUG] : Jeemyhomescs_Equipement : Array ( [trame] => *2*0*62## [format] => BUS_COMMAND [mode] => UNICAST [media] => SCS [type] => automatism [value] => MOVE_STOP [dimension] => [param] => [A] => 6 [PL] => 2 [date] => 2020-05-22 09:00:07 )
[2020-05-22 09:00:07][DEBUG] : Jeemyhomescs_BUS_COMMAND
[2020-05-22 09:00:07][DEBUG] : Update Status Automatism
[2020-05-22 09:00:07][DEBUG] : last : Sous_device : 00 duréecmd : 14 id cmd : 26 date : 1590130807
[2020-05-22 09:00:07][DEBUG] : sousdevice : 00 LogicalID : 62 updatedate :
[2020-05-22 09:00:07][DEBUG] : Bouton normal
[2020-05-22 09:00:07][DEBUG] : Action move_STOP
[2020-05-22 09:00:07][DEBUG] : updatedate : Newpos : 11358077292.857
[2020-05-22 09:00:07][DEBUG] : mise a jour du status :
[2020-05-22 09:00:07][INFO] : Reçu sur Jeedom : *2*1000#1*62##
[2020-05-22 09:00:07][DEBUG] : Jeemyhomescs_Equipement : Array ( [trame] => *2*1000#1*62## [format] => BUS_EVENT [mode] => UNKNOWN [media] => SCS [type] => scene [value] => [dimension] => [param] => [A] => [PL] => [date] => 2020-05-22 09:00:07 )
[2020-05-22 09:00:07][DEBUG] : Jeemyhomescs_Trame non interprétée
[2020-05-22 09:00:07][INFO] : Reçu sur Jeedom : *2*1*62##
[2020-05-22 09:00:07][DEBUG] : Jeemyhomescs_Equipement : Array ( [trame] => *2*1*62## [format] => BUS_COMMAND [mode] => UNICAST [media] => SCS [type] => automatism [value] => MOVE_UP [dimension] => [param] => [A] => 6 [PL] => 2 [date] => 2020-05-22 09:00:07 )
[2020-05-22 09:00:07][DEBUG] : Action MOVE_UP
[2020-05-22 09:00:07][DEBUG] : mise a jour du status : OPEN
[2020-05-22 09:01:07][INFO] : Reçu sur Jeedom : *2*0*62##
[2020-05-22 09:01:07][DEBUG] : Jeemyhomescs_Equipement : Array ( [trame] => *2*0*62## [format] => BUS_COMMAND [mode] => UNICAST [media] => SCS [type] => automatism [value] => MOVE_STOP [dimension] => [param] => [A] => 6 [PL] => 2 [date] => 2020-05-22 09:01:07 )
[2020-05-22 09:01:07][DEBUG] : Jeemyhomescs_BUS_COMMAND
[2020-05-22 09:01:07][DEBUG] : Update Status Automatism
[2020-05-22 09:01:07][DEBUG] : last : OPEN Sous_device : 00 duréecmd : 14 id cmd : 26 date : 1590130867
[2020-05-22 09:01:07][DEBUG] : sousdevice : 00 LogicalID : 62 updatedate :
[2020-05-22 09:01:07][DEBUG] : Bouton normal
[2020-05-22 09:01:07][DEBUG] : Action move_STOP
[2020-05-22 09:01:07][DEBUG] : updatedate : Newpos : 11358077721.429
[2020-05-22 09:01:07][DEBUG] : mise a jour du status : OPEN
[2020-05-22 09:01:07][INFO] : Reçu sur Jeedom : *2*0*68##
[2020-05-22 09:01:07][DEBUG] : Jeemyhomescs_Equipement : Array ( [trame] => *2*0*68## [format] => BUS_COMMAND [mode] => UNICAST [media] => SCS [type] => automatism [value] => MOVE_STOP [dimension] => [param] => [A] => 6 [PL] => 8 [date] => 2020-05-22 09:01:07 )
[2020-05-22 09:01:07][DEBUG] : last : UP Sous_device : 00 duréecmd : 28 id cmd : 1 date : 1590130867
[2020-05-22 09:01:07][DEBUG] : sousdevice : 00 LogicalID : 68 updatedate : 1590130834
[2020-05-22 09:01:07][DEBUG] : updatedate : 1590130834 Newpos : 217.85714285714
[2020-05-22 09:01:07][DEBUG] : last_status : Up, status : 218
Pour l’équipement en PL68, le log fini bien sur le status OPEN de même que pour celui en PL62 mais sur l’équipement, si le status du PL68 est bien OPEN (comme le statnum d’ailleurs) et celui du PL62, c’est 0.
