Voici un premier exemple avec Jeedom Connect :
[2026-09-21 12:44:28]WARNING : Client must always be masked.
Le niveau de log est configuré sur AUCUN et pourtant j’obtiens quand même un WARNING.
Ce WARNING se produit systématiquement à chaque fermeture de l’application mobile.
Voici le log en mode DEBUG mais il est incomplet car extrêmement verbeux :
[2026-09-21 12:52:29] INFO : Start daemon
[2026-09-21 12:52:29] INFO : Log level : debug
[2026-09-21 12:52:29] DEBUG : Socket port : 58090
[2026-09-21 12:52:29] DEBUG : PID file : /tmp/jeedom/JeedomConnect/deamon.pid
[2026-09-21 12:52:29] DEBUG : ** Starting Jeedom daemon **
[2026-09-21 12:52:29] INFO : ** Jeedom daemon started **
[2026-09-21 12:52:29] DEBUG : ** Starting JC Websocket daemon **
[2026-09-21 12:52:29] INFO : ** JC Websocket daemon started **
[2026-09-21 12:52:29] DEBUG : Starting loop to retrieve all events
[2026-09-21 12:52:29] DEBUG : Start listening
[2026-09-21 12:53:13] INFO : New connection: #1 from IP: ('192.168.0.127', 50994)
[2026-09-21 12:53:13] INFO : Number of client connected #1
[2026-09-21 12:53:13]WARNING : Clients not authenticated #1
[2026-09-21 12:53:13] DEBUG : [WEBSOCKET RECEIVE] message: {"method":"CONNECT","params":{"apiKey":"XXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXX","deviceId":"4XXXXXXX-XXXX-XXX-XXXX-XXXXXXXXXXXX","deviceName":"iPhone","userHash":"x6XXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXr","appVersion":"1.29.0","pluginRequire":"1.7.1","token":"XXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXX","platformOs":"ios","osVersion":"27.0","appTypeVersion":"stable","buildVersion":"115"},"jsonrpc":"2.0","id":1789987992090}
Je n’ai plus trop de temps maintenant aussi reviendrai-je plus tard.
