j’ai un service zigbee qui ne veut plus démarrer…
Voici le log du service en question
Une idée?
Merci à vous!
0000|> zigbee2mqtt@1.42.0 start
0001|> node index.js
0002|Starting Zigbee2MQTT without watchdog.
0003|[2025-04-03 06:34:22] e[32minfoe[39m: z2m: Logging to console, file (filename: log.log)
0004|[2025-04-03 06:34:22] e[32minfoe[39m: z2m: Loaded external converter '/var/www/html/plugins/z2m/core/class/../config/converters/Danfoss/icon.js'
0005|[2025-04-03 06:34:22] e[34mdebuge[39m: z2m: Loaded state from file /var/www/html/plugins/z2m/data/state.json
0006|[2025-04-03 06:34:23] e[32minfoe[39m: z2m: Starting Zigbee2MQTT version 1.42.0 (commit #861cba63)
0007|[2025-04-03 06:34:23] e[34mdebuge[39m: z2m: sd-notify loaded
0008|[2025-04-03 06:34:23] e[32minfoe[39m: z2m: Starting zigbee-herdsman (2.1.9)
0009|[2025-04-03 06:34:23] e[34mdebuge[39m: z2m: Using zigbee-herdsman with settings: '"{\"network\":{\"panID\":4241,\"extendedPanID\":[161,151,203,54,53,204,132,79],\"channelList\":[11],\"networkKey\":\"HIDDEN\"},\"databasePath\":\"/var/www/html/plugins/z2m/data/database.db\",\"databaseBackupPath\":\"/var/www/html/plugins/z2m/data/database.db.backup\",\"backupPath\":\"/var/www/html/plugins/z2m/data/coordinator_backup.json\",\"serialPort\":{\"path\":\"/dev/serial/by-id/usb-1a86_USB_Serial-if00-port0\",\"adapter\":\"ezsp\"},\"adapter\":{\"disableLED\":false}}"'
0010|[2025-04-03 06:34:24] e[34mdebuge[39m: zh:ezsp: Adapter concurrent: 8
0011|[2025-04-03 06:34:24] e[34mdebuge[39m: zh:controller: Starting with options '{"network":{"networkKeyDistribute":false,"networkKey":"HIDDEN","panID":4241,"extendedPanID":[161,151,203,54,53,204,132,79],"channelList":[11]},"serialPort":{"path":"/dev/serial/by-id/usb-1a86_USB_Serial-if00-port0","adapter":"ezsp"},"adapter":{"disableLED":false},"databasePath":"/var/www/html/plugins/z2m/data/database.db","databaseBackupPath":"/var/www/html/plugins/z2m/data/database.db.backup","backupPath":"/var/www/html/plugins/z2m/data/coordinator_backup.json"}'
0012|[2025-04-03 06:34:24] e[33mwarninge[39m: zh:ezsp: 'ezsp' driver is deprecated and will only remain to provide support for older firmware (pre 7.4.x). Migration to 'ember' is recommended. If using Zigbee2MQTT see https://github.com/Koenkk/zigbee2mqtt/discussions/21462
0013|[2025-04-03 06:34:24] e[34mdebuge[39m: zh:ezsp:uart: RTS/CTS config is off, enabling software flow control.
0014|[2025-04-03 06:34:24] e[34mdebuge[39m: zh:ezsp:uart: Opening SerialPort with {"path":"/dev/serial/by-id/usb-1a86_USB_Serial-if00-port0","baudRate":115200,"rtscts":false,"autoOpen":false,"parity":"none","stopBits":1,"xon":true,"xoff":true}
0015|[2025-04-03 06:34:24] e[34mdebuge[39m: zh:ezsp:uart: Serialport opened
0016|[2025-04-03 06:34:24] e[34mdebuge[39m: zh:ezsp:uart: Uart reseting
0017|[2025-04-03 06:34:24] e[34mdebuge[39m: zh:ezsp:uart: --> Write reset
0018|[2025-04-03 06:34:24] e[34mdebuge[39m: zh:ezsp:uart: --> [1ac038bc7e]
0019|[2025-04-03 06:34:24] e[34mdebuge[39m: zh:ezsp:uart: -?- waiting reset
0020|[2025-04-03 06:34:24] e[34mdebuge[39m: zh:ezsp:uart: <-- [4bf8]
0021|[2025-04-03 06:34:34] e[31merrore[39m: zh:ezsp:uart: --> Error: Error: {"sequence":-1} after 10000ms
0022|[2025-04-03 06:34:34] e[31merrore[39m: zh:ezsp:ezsp: Connection attempt 1 error: Error: Failure to connect
0023|[2025-04-03 06:34:34] e[34mdebuge[39m: zh:ezsp:uart: Port closed. Error? null
0024|[2025-04-03 06:34:34] e[34mdebuge[39m: zh:ezsp:ezsp: onSerialClose()
0025|[2025-04-03 06:34:34] e[34mdebuge[39m: zh:ezsp:driv: onEzspClose()
0026|[2025-04-03 06:34:34] e[34mdebuge[39m: zh:ezsp: onDriverClose()
0027|[2025-04-03 06:34:39] e[34mdebuge[39m: zh:ezsp:ezsp: Next attempt 2
0028|[2025-04-03 06:34:39] e[34mdebuge[39m: zh:ezsp:uart: RTS/CTS config is off, enabling software flow control.
0029|[2025-04-03 06:34:39] e[34mdebuge[39m: zh:ezsp:uart: Opening SerialPort with {"path":"/dev/serial/by-id/usb-1a86_USB_Serial-if00-port0","baudRate":115200,"rtscts":false,"autoOpen":false,"parity":"none","stopBits":1,"xon":true,"xoff":true}
0030|[2025-04-03 06:34:39] e[34mdebuge[39m: zh:ezsp:uart: Serialport opened
0031|[2025-04-03 06:34:39] e[34mdebuge[39m: zh:ezsp:uart: Uart reseting
0032|[2025-04-03 06:34:39] e[34mdebuge[39m: zh:ezsp:uart: --> Write reset
0033|[2025-04-03 06:34:39] e[34mdebuge[39m: zh:ezsp:uart: --> [1ac038bc7e]
0034|[2025-04-03 06:34:39] e[34mdebuge[39m: zh:ezsp:uart: -?- waiting reset
0035|[2025-04-03 06:34:39] e[34mdebuge[39m: zh:ezsp:uart: <-- [62f8]
0036|[2025-04-03 06:34:49] e[31merrore[39m: zh:ezsp:uart: --> Error: Error: {"sequence":-1} after 10000ms
0037|[2025-04-03 06:34:49] e[31merrore[39m: zh:ezsp:ezsp: Connection attempt 2 error: Error: Failure to connect
0038|[2025-04-03 06:34:49] e[34mdebuge[39m: zh:ezsp:uart: Port closed. Error? null
0039|[2025-04-03 06:34:49] e[34mdebuge[39m: zh:ezsp:ezsp: onSerialClose()
0040|[2025-04-03 06:34:49] e[34mdebuge[39m: zh:ezsp:driv: onEzspClose()
0041|[2025-04-03 06:34:49] e[34mdebuge[39m: zh:ezsp: onDriverClose()
0042|[2025-04-03 06:34:59] e[34mdebuge[39m: zh:ezsp:ezsp: Next attempt 3
0043|[2025-04-03 06:34:59] e[34mdebuge[39m: zh:ezsp:uart: RTS/CTS config is off, enabling software flow control.
0044|[2025-04-03 06:34:59] e[34mdebuge[39m: zh:ezsp:uart: Opening SerialPort with {"path":"/dev/serial/by-id/usb-1a86_USB_Serial-if00-port0","baudRate":115200,"rtscts":false,"autoOpen":false,"parity":"none","stopBits":1,"xon":true,"xoff":true}
0045|[2025-04-03 06:34:59] e[34mdebuge[39m: zh:ezsp:uart: Serialport opened
0046|[2025-04-03 06:34:59] e[34mdebuge[39m: zh:ezsp:uart: Uart reseting
0047|[2025-04-03 06:34:59] e[34mdebuge[39m: zh:ezsp:uart: --> Write reset
0048|[2025-04-03 06:34:59] e[34mdebuge[39m: zh:ezsp:uart: --> [1ac038bc7e]
0049|[2025-04-03 06:34:59] e[34mdebuge[39m: zh:ezsp:uart: -?- waiting reset
0050|[2025-04-03 06:34:59] e[34mdebuge[39m: zh:ezsp:uart: <-- [49f8]
0051|[2025-04-03 06:35:09] e[31merrore[39m: zh:ezsp:uart: --> Error: Error: {"sequence":-1} after 10000ms
0052|[2025-04-03 06:35:09] e[31merrore[39m: zh:ezsp:ezsp: Connection attempt 3 error: Error: Failure to connect
0053|[2025-04-03 06:35:09] e[34mdebuge[39m: zh:ezsp:uart: Port closed. Error? null
0054|[2025-04-03 06:35:09] e[34mdebuge[39m: zh:ezsp:ezsp: onSerialClose()
0055|[2025-04-03 06:35:09] e[34mdebuge[39m: zh:ezsp:driv: onEzspClose()
0056|[2025-04-03 06:35:09] e[34mdebuge[39m: zh:ezsp: onDriverClose()
0057|[2025-04-03 06:35:24] e[34mdebuge[39m: zh:ezsp:ezsp: Next attempt 4
0058|[2025-04-03 06:35:24] e[34mdebuge[39m: zh:ezsp:uart: RTS/CTS config is off, enabling software flow control.
0059|[2025-04-03 06:35:24] e[34mdebuge[39m: zh:ezsp:uart: Opening SerialPort with {"path":"/dev/serial/by-id/usb-1a86_USB_Serial-if00-port0","baudRate":115200,"rtscts":false,"autoOpen":false,"parity":"none","stopBits":1,"xon":true,"xoff":true}
0060|[2025-04-03 06:35:24] e[34mdebuge[39m: zh:ezsp:uart: Serialport opened
0061|[2025-04-03 06:35:24] e[34mdebuge[39m: zh:ezsp:uart: Uart reseting
0062|[2025-04-03 06:35:24] e[34mdebuge[39m: zh:ezsp:uart: --> Write reset
0063|[2025-04-03 06:35:24] e[34mdebuge[39m: zh:ezsp:uart: --> [1ac038bc7e]
0064|[2025-04-03 06:35:24] e[34mdebuge[39m: zh:ezsp:uart: -?- waiting reset
0065|[2025-04-03 06:35:24] e[34mdebuge[39m: zh:ezsp:uart: <-- [43e4]
0066|[2025-04-03 06:35:34] e[31merrore[39m: zh:ezsp:uart: --> Error: Error: {"sequence":-1} after 10000ms
0067|[2025-04-03 06:35:34] e[31merrore[39m: zh:ezsp:ezsp: Connection attempt 4 error: Error: Failure to connect
0068|[2025-04-03 06:35:34] e[34mdebuge[39m: zh:ezsp:driv: EZSP could not connect: Error: Failure to connect
0069|[2025-04-03 06:35:34] e[31merrore[39m: z2m: Error while starting zigbee-herdsman
0070|[2025-04-03 06:35:34] e[31merrore[39m: z2m: Failed to start zigbee
0071|[2025-04-03 06:35:34] e[31merrore[39m: z2m: Check https://www.zigbee2mqtt.io/guide/installation/20_zigbee2mqtt-fails-to-start.html for possible solutions
0072|[2025-04-03 06:35:34] e[31merrore[39m: z2m: Exiting...
0073|[2025-04-03 06:35:34] e[31merrore[39m: z2m: Error: Failure to connect
0074|at Ezsp.connect (/var/www/html/plugins/z2m/resources/zigbee2mqtt/node_modules/zigbee-herdsman/src/adapter/ezsp/driver/ezsp.ts:364:19)
0075|at Driver.startup (/var/www/html/plugins/z2m/resources/zigbee2mqtt/node_modules/zigbee-herdsman/src/adapter/ezsp/driver/driver.ts:186:13)
0076|at EZSPAdapter.start (/var/www/html/plugins/z2m/resources/zigbee2mqtt/node_modules/zigbee-herdsman/src/adapter/ezsp/adapter/ezspAdapter.ts:152:16)
0077|at Controller.start (/var/www/html/plugins/z2m/resources/zigbee2mqtt/node_modules/zigbee-herdsman/src/controller/controller.ts:137:29)
0078|at Zigbee.start (/var/www/html/plugins/z2m/resources/zigbee2mqtt/lib/zigbee.ts:69:27)
0079|at Controller.start (/var/www/html/plugins/z2m/resources/zigbee2mqtt/lib/controller.ts:161:27)
0080|at start (/var/www/html/plugins/z2m/resources/zigbee2mqtt/index.js:154:5)
0081|/var/www/html/plugins/z2m/resources/zigbee2mqtt/node_modules/winston/node_modules/readable-stream/lib/_stream_writable.js:264
0082|var er = new ERR_STREAM_WRITE_AFTER_END();
0083|^
0084|Error: write after end
0085|at writeAfterEnd (/var/www/html/plugins/z2m/resources/zigbee2mqtt/node_modules/winston/node_modules/readable-stream/lib/_stream_writable.js:264:12)
0086|at DerivedLogger.Writable.write (/var/www/html/plugins/z2m/resources/zigbee2mqtt/node_modules/winston/node_modules/readable-stream/lib/_stream_writable.js:300:21)
0087|at DerivedLogger.log (/var/www/html/plugins/z2m/resources/zigbee2mqtt/node_modules/winston/lib/winston/logger.js:231:12)
0088|at Logger.log (/var/www/html/plugins/z2m/resources/zigbee2mqtt/lib/util/logger.ts:198:25)
0089|at Logger.debug (/var/www/html/plugins/z2m/resources/zigbee2mqtt/lib/util/logger.ts:219:14)
0090|at SerialDriver.onPortClose (/var/www/html/plugins/z2m/resources/zigbee2mqtt/node_modules/zigbee-herdsman/src/adapter/ezsp/driver/uart.ts:380:16)
0091|at Object.onceWrapper (node:events:633:26)
0092|at SerialPort.emit (node:events:530:35)
0093|at port.close.then.closing (/var/www/html/plugins/z2m/resources/zigbee2mqtt/node_modules/@serialport/stream/dist/index.js:242:18)
Informations Jeedom Luna
Core : 4.4.19 (master)
DNS Jeedom Luna : non
Plugin : JeeZigbee
Version : 2025-01-15 01:01:47 (stable)
Statut Démon : Démarré - (2025-04-03 08:25:33)
````Texte préformaté`
