Alors le problème du fil est : dépendances qui ne s’installent pas
Toi c’est démon qui démarre pas. Donc déjà pas pareil. Tu squattés donc le fil du copain. PS : Ubuntu passes ton chemin, c’est pas supporter
Je pensais aider une communauté, mais tant pis je passe mon chemin
PS:
j’ai bien un pb de dependance, voir de script dependencies.sh ligne 3 mais on s’en fout ca aidera personne
Début de l'installation
--2020-02-19 08:24:01-- https://raw.githubusercontent.com/lunarok/jeedom_nodejs/master/nodejs.sh
Resolving raw.githubusercontent.com (raw.githubusercontent.com)... 151.101.240.133
Connecting to raw.githubusercontent.com (raw.githubusercontent.com)|151.101.240.133|:443... connected.
HTTP
request sent, awaiting response... 200 OK
Length: 1491 (1.5K) [text/plain]
Saving to: 'dependencies.sh'
0K . 100% 44.9M=0s
2020-02-19 08:24:02 (44.9 MB/s) - 'dependencies.sh' saved [1491/1491]
***dependencies.sh: 3: [: espeasy: unexpected operator***
Version actuelle : 12
Hit:1 http://ppa.launchpad.net/ondrej/php/ubuntu bionic InRelease
Hit:2 http://ports.ubuntu.com bionic InRelease
Get:3 http://ports.ubuntu.com bionic-security InRelease [88.7 kB]
Hit:4 https://deb.nodesource.com/node_12.x bionic InRelease
Hit:5 http://mirrors.dotsrc.org/armbian-apt bionic InRelease
Get:6 http://ports.ubuntu.com bionic-updates InRelease [88.7 kB]
Get:7 http://ports.ubuntu.com bionic-backports InRelease [74.6 kB]
Get:8 http://ports.ubuntu.com bionic-updates/main armhf Packages [589 kB]
Get:9 http://ports.ubuntu.com bionic-updates/universe armhf Packages [885 kB]
Fetched 1726 kB in 6s (293 kB/s)
Reading package lists...
Building dependency tree...
Reading state information...
lsb-release is already the newest version (9.20170808ubuntu1).
The following packages were automatically installed and are no longer required:
libdrm-etnaviv1 libllvm8
Use 'sudo apt autoremove' to remove them.
0 upgraded, 0 newly installed, 0 to remove and 1 not upgraded.
Ok, version suffisante
npm WARN deprecated request@2.88.2: request has been deprecated, see https://github.com/request/request/issues/3142
added 48 packages from 58 contributors and audited 64 packages in 13.863s
found 0 vulnerabilities
rm: cannot remove '/tmp/espeasy_dep': No such file or directory
Fin de l'installation
J’ai testé le plugin sur plusieurs plateformes (Docker syno, Ubuntu, Debian).
Le seul où je n’ai eu aucun souci, c’est avec Debian.
J’avais installé une Ubuntu par habitude, mais… au final, ce n’était pas le bon plan.
Là, je remonte une maquette sur une Debian pour ne plus être embêté.
A étudier le passage à Debian. OS supporté par Jeedom.
Tu seras moins embêté.
Pour les non initiés, je vais traduire cette intervention :
Bonjour @MarcM,
es-tu sûr de parler du même problème ? En effet, tu remontes un pb de démon alors que l’objet de ce topic est un pb de dépendances.
Je te conseille donc de créer ton propre sujet.
De plus, saches que Unbuntu n’est pas supporté par Jeedom. Il vaudrait donc mieux passer sur Debian.(Attention à la version, car toutes ne sont pas bien supportées non plus)
Ce n’est pas toujours facile de comprendre le Lunarokien. Mais avec un peu d’entrainement, on y arrive ![]()
C’est pas il ‹ faudrait › mieux passer a debian, mais un vrai impératif (ah moins de pas avoir besoin du forum)
Et la version c’est buster, sinon faudra migrer a la rentrée prochaine
Merci pour cette précision, je ne savais pas.
Bonjour à tous, depuis la mise à jour que j’ai effectué hier soir , démon NOK , impossible de le redémarrer, vraiment critique pour moi car espeasy gère la carte électronique de gestion d’eau de mon aquarium d’eau de mer, comment faire pour revenir à la version précédente ?? Je dois m’absenter ce matin, je reviens cet après midi, j’espère vraiment trouver une solution , merci à vous tous
avez vous vraiment cherché (réponse dans le sujet juste avant le votre) et que l’on arrête pas d’aborder depuis 1 semaine ? Problème Démon suite à la maj du 31 mai - #56 par fganee
Désolé dans la précipitation lors de ma recherche google je suis tombé sur ce premier sujet, merci
