J’ai installer jeedom sur raspberry 3b+ → version 4.0.25
J’ai également installer sur mon raspberry en gpio, une carte razberry pour le protocole z-wave
J’ai installé le plugin zwave version 3.2.12.
Je configure le plugin avec le port /dev/ttyAMAO 8083.
Tous les voyants sont au vert MAIS impossible de rentrer en mode inclusion « Controller is busy »
en regardant les logs du plugin:
Always, OpenZwave Version 1.4.0 Starting Up
2019-11-03 18:44:33.265 Info, Setting Up Provided Network Key for Secure Communications
2019-11-03 18:44:33.266 Info, mgr, Added driver for controller /dev/ttyAMA0
2019-11-03 18:44:33.266 Info, Opening controller /dev/ttyAMA0
2019-11-03 18:44:33.266 Info, Trying to open serial port /dev/ttyAMA0 (attempt 1)
2019-11-03 18:44:33.266 Info, Serial port /dev/ttyAMA0 opened (attempt 1)
2019-11-03 18:44:33.266 Detail, contrlr, Queuing (Command) FUNC_ID_ZW_GET_VERSION: 0x01, 0x03, 0x00, 0x15, 0xe9
2019-11-03 18:44:33.267 Detail, contrlr, Queuing (Command) FUNC_ID_ZW_MEMORY_GET_ID: 0x01, 0x03, 0x00, 0x20, 0xdc
2019-11-03 18:44:33.267 Detail, contrlr, Queuing (Command) FUNC_ID_ZW_GET_CONTROLLER_CAPABILITIES: 0x01, 0x03, 0x00, 0x05, 0xf9
2019-11-03 18:44:33.267 Detail, contrlr, Queuing (Command) FUNC_ID_SERIAL_API_GET_CAPABILITIES: 0x01, 0x03, 0x00, 0x07, 0xfb
2019-11-03 18:44:33.267 Detail, contrlr, Queuing (Command) FUNC_ID_ZW_GET_SUC_NODE_ID: 0x01, 0x03, 0x00, 0x56, 0xaa
2019-11-03 18:44:33.267 Info, contrlr, Sending (Command) message (Callback ID=0x00, Expected Reply=0x15) - FUNC_ID_ZW_GET_VERSION: 0x01, 0x03, 0x00, 0x15, 0xe9
2019-11-03 18:44:34.267 Error, contrlr, ERROR: Dropping command, expected response not received after 1 attempt(s)
2019-11-03 18:44:34.267 Detail, contrlr, Removing current message
2019-11-03 18:44:34.268 Detail, contrlr, Notification: Notification - TimeOut
2019-11-03 18:44:34.273 Detail,
2019-11-03 18:44:34.273 Info, contrlr, Sending (Command) message (Callback ID=0x00, Expected Reply=0x20) - FUNC_ID_ZW_MEMORY_GET_ID: 0x01, 0x03, 0x00, 0x20, 0xdc
2019-11-03 18:44:35.273 Error, contrlr, ERROR: Dropping command, expected response not received after 1 attempt(s)
2019-11-03 18:44:35.273 Detail, contrlr, Removing current message
2019-11-03 18:44:35.273 Detail, contrlr, Notification: Notification - TimeOut
2019-11-03 18:44:35.277 Detail,
2019-11-03 18:44:35.277 Info, contrlr, Sending (Command) message (Callback ID=0x00, Expected Reply=0x05) - FUNC_ID_ZW_GET_CONTROLLER_CAPABILITIES: 0x01, 0x03, 0x00, 0x05, 0xf9
2019-11-03 18:44:36.277 Error, contrlr, ERROR: Dropping command, expected response not received after 1 attempt(s)
2019-11-03 18:44:36.277 Detail, contrlr, Removing current message
2019-11-03 18:44:36.277 Detail, contrlr, Notification: Notification - TimeOut
2019-11-03 18:44:36.279 Detail,
2019-11-03 18:44:36.279 Info, contrlr, Sending (Command) message (Callback ID=0x00, Expected Reply=0x07) - FUNC_ID_SERIAL_API_GET_CAPABILITIES: 0x01, 0x03, 0x00, 0x07, 0xfb
2019-11-03 18:44:37.280 Error, contrlr, ERROR: Dropping command, expected response not received after 1 attempt(s)
2019-11-03 18:44:37.280 Detail, contrlr, Removing current message
2019-11-03 18:44:37.280 Detail, contrlr, Notification: Notification - TimeOut
2019-11-03 18:44:37.282 Detail,
2019-11-03 18:44:37.283 Info, contrlr, Sending (Command) message (Callback ID=0x00, Expected Reply=0x56) - FUNC_ID_ZW_GET_SUC_NODE_ID: 0x01, 0x03, 0x00, 0x56, 0xaa
2019-11-03 18:44:38.283 Error, contrlr, ERROR: Dropping command, expected response not received after 1 attempt(s)
2019-11-03 18:44:38.283 Detail, contrlr, Removing current message
2019-11-03 18:44:38.283 Detail, contrlr, Notification: Notification - TimeOut
Quelqu’un pourrait il m’aider à résoudre ce problème?
MErci d’avance les jeedomiens
