Probleme zigbee plus aucune réponse
depuis hier soir je n’ai plus aucun retour d’état de mes appareils en zigbee. La panne est venu comme ca sans prévenir sans modification sur le maillage ou ajout suppression d’appareil.
ci joint un extrait du log du plug-in :
][INFO] : [zigbee_OBJ][heating_pieceDeVieCuisine] Erreur lors de la requete : http://127.0.0.1:8089/device/attributes(POST), data : {"ieee":"a4:c1:38:65:e7:51:07:52","endpoint":1,"cluster":6,"cluster_type":"in","attributes":[0],"allowCache":0} erreur : {"state":"error","result":"","code":0}
[2023-10-28 11:03:53][DEBUG] : http://127.0.0.1:8089/device/attributes type : POST
[2023-10-28 11:03:53][DEBUG] : {"ieee":"a4:c1:38:65:e7:51:07:52","endpoint":1,"cluster":1794,"cluster_type":"in","attributes":[0],"allowCache":0}
[2023-10-28 11:03:58][INFO] : [zigbee_OBJ][heating_pieceDeVieCuisine] Erreur lors de la requete : http://127.0.0.1:8089/device/attributes(POST), data : {"ieee":"a4:c1:38:65:e7:51:07:52","endpoint":1,"cluster":1794,"cluster_type":"in","attributes":[0],"allowCache":0} erreur : {"state":"error","result":"","code":0}
[2023-10-28 11:03:58][DEBUG] : http://127.0.0.1:8089/device/attributes type : POST
[2023-10-28 11:03:58][DEBUG] : {"ieee":"a4:c1:38:65:e7:51:07:52","endpoint":1,"cluster":2820,"cluster_type":"in","attributes":[1291],"allowCache":0}
[2023-10-28 11:04:03][INFO] : [zigbee_OBJ][heating_pieceDeVieCuisine] Erreur lors de la requete : http://127.0.0.1:8089/device/attributes(POST), data : {"ieee":"a4:c1:38:65:e7:51:07:52","endpoint":1,"cluster":2820,"cluster_type":"in","attributes":[1291],"allowCache":0} erreur : {"state":"error","result":"","code":0}
[2023-10-28 11:04:03][DEBUG] : http://127.0.0.1:8089/device/attributes type : POST
[2023-10-28 11:04:03][DEBUG] : {"ieee":"a4:c1:38:e5:79:0c:53:90","endpoint":1,"cluster":6,"cluster_type":"in","attributes":[0],"allowCache":0}
[2023-10-28 11:04:13][INFO] : [zigbee_OBJ][heating_sdb] Erreur lors de la requete : http://127.0.0.1:8089/device/attributes(POST), data : {"ieee":"a4:c1:38:e5:79:0c:53:90","endpoint":1,"cluster":6,"cluster_type":"in","attributes":[0],"allowCache":0} erreur : {"state":"error","result":"[0xc9e1:1:0x0006]: Message send failure","code":0}
[2023-10-28 11:04:13][DEBUG] : http://127.0.0.1:8089/device/attributes type : POST
[2023-10-28 11:04:13][DEBUG] : {"ieee":"a4:c1:38:e5:79:0c:53:90","endpoint":1,"cluster":1794,"cluster_type":"in","attributes":[0],"allowCache":0}
[2023-10-28 11:04:23][INFO] : [zigbee_OBJ][heating_sdb] Erreur lors de la requete : http://127.0.0.1:8089/device/attributes(POST), data : {"ieee":"a4:c1:38:e5:79:0c:53:90","endpoint":1,"cluster":1794,"cluster_type":"in","attributes":[0],"allowCache":0} erreur : {"state":"error","result":"[0xc9e1:1:0x0702]: Message send failure","code":0}
[2023-10-28 11:04:23][DEBUG] : http://127.0.0.1:8089/device/attributes type : POST
[2023-10-28 11:04:23][DEBUG] : {"ieee":"a4:c1:38:e5:79:0c:53:90","endpoint":1,"cluster":2820,"cluster_type":"in","attributes":[1291],"allowCache":0}
[2023-10-28 11:04:34][INFO] : [zigbee_OBJ][heating_sdb] Erreur lors de la requete : http://127.0.0.1:8089/device/attributes(POST), data : {"ieee":"a4:c1:38:e5:79:0c:53:90","endpoint":1,"cluster":2820,"cluster_type":"in","attributes":[1291],"allowCache":0} erreur : {"state":"error","result":"[0xc9e1:1:0x0b04]: Message send failure","code":0}
[2023-10-28 11:04:34][DEBUG] : http://127.0.0.1:8089/device/attributes type : POST
[2023-10-28 11:04:34][DEBUG] : {"ieee":"a4:c1:38:b8:62:07:98:7b","endpoint":1,"cluster":6,"cluster_type":"in","attributes":[0],"allowCache":0}
Ma question pouvez vous m’aider ?
J’arrive de commander certain appareil mais je n’ai aucune remonté d’état, le graph du maillage indique que des liaison sans réponse
j’ai bien lus la documentation mais aucun module na été supprimé ou ajouté donc pas besoin de régénération du maillage enfin je pense.
merci pour vos futur lumière…
Pas d’image sur site externe, collez les directement dans votre message.
Lien supprimé.
bonjour
s’est édité :wink:
Bienvenu dans le monde du zigbee avec des comportements comme cela incompréhensible. Le mieux serait déjà de migrer sur jeezigbee ça limite ce genre de problème
Bonjour Loïc,
Quelles sont les différence avec celui que j’ai acheté car ce que je comprends c’est que je dois en acheter un autre pour le même principe sauf plus fonctionnel.
Y’a t’il une prise en charge étant donné que zigbee a été acheté à 6€ et le nouveau en vaut 4 ?
Il est bien évidemment gratuit si tu as déjà acheté l’ancien plugin je ne comprends donc pas pourquoi tu dis que tu dois repayer ça sera vraiment n’importe quoi de notre part si c’était le cas. Surtout qu’on a jamais eu ce genre de politique si un plugin en remplace un autre alors il est offert à tous ceux qui ont acheté le premier…. Malgré le faite que nous on est fait le travail en double et donc que techniquement ça nous a coûté beaucoup d’argent
Je m’excuse je voyais un tarif…
Après click effectivement pas de passage à la caisse, je vais essayer le parametrage de ce plug in dès mon retour au domicile.
@Loic
je viens de télécharger le plugin JeeZigbee (z2m) coté mqtt2 aucun soucis démon vert, mais sur JeeZigbee impossible de lancer le démon voici le log du démon :
> zigbee2mqtt@1.33.1 start
> node index.js
Zigbee2MQTT:error 2023-10-28 18:20:11: MQTT error: getaddrinfo ENOTFOUND :0
Zigbee2MQTT:error 2023-10-28 18:20:11: MQTT failed to connect, exiting...
Zigbee2MQTT:error 2023-10-28 18:20:12: MQTT error: getaddrinfo ENOTFOUND :0
finalement en vert sur mqt2d mais log du démon :
[2023-10-28 16:38:27]INFO : Start mqtt2d
[2023-10-28 16:38:27]INFO : Log level on  : debug
[2023-10-28 16:38:27]INFO : Socket port : 55035
[2023-10-28 16:38:27]INFO : MQTT : mqtt://:
[2023-10-28 16:38:27]INFO : Username : jeedom
[2023-10-28 16:38:27]INFO : Password : egXDMUFKFS1lNKmWGKXXXXX
[2023-10-28 16:38:27]INFO : PID file : /tmp/jeedom/mqtt2/deamon.pid
[2023-10-28 16:38:27]INFO : Apikey : KTQffdG02ABSQfOXXXXXXXXXXXX
[2023-10-28 16:38:27]INFO : Callback : http://127.0.0.1:80/plugins/mqtt2/core/php/jeeMqtt2.php
[2023-10-28 16:38:27]INFO : Cycle : 0.3
[2023-10-28 16:38:27]INFO : Client key : undefined
[2023-10-28 16:38:27]INFO : Client crt : undefined
[2023-10-28 16:38:27]INFO : CA : undefined
[2023-10-28 16:38:28]INFO : Connect to mqtt server
Sat, 28 Oct 2023 16:38:28 GMT body-parser deprecated undefined extended: provide extended option at jeedom/jeedom.js:168:31
[2023-10-28 16:38:28]DEBUG : HTTP listen on 127.0.0.1 port : 55035 started
[2023-10-28 16:38:59]ERROR : Reconnection to mqtt server
[2023-10-28 16:39:30]ERROR : Reconnection to mqtt server
[2023-10-28 16:40:01]ERROR : Reconnection to mqtt server
[2023-10-28 16:40:32]ERROR : Reconnection to mqtt server
d’où peux venir le problème ? Merci car log pas très parlant … Merci
Configuration de Mqtt manager pas bonne je t’invite à suivre la documentation du plugin pour tout bien faire.
