Merci pour ton retour.
Je viens de faire la mise à jour mais j’au toujours le même problème.
J’ai donc un virtuel dans lequel je reprends les commandes et info du plugin « Volet proportionnel »
J’ai affecté les types génériques suivants sur chacune de mes commandes:
J’ai précisé le range sur mon action commande et info dans mon virtuel:
Dans le plugin Alexa, j’ai bien sélectionné le mode volet:
→ Détection toujours impossible
Ps: Voici un extrait du JSON:
"endpointId": "829",
"friendlyName": "Salle de bain des parents Volet",
"description": "[Salle de bain des parents][Volet]",
"manufacturerName": "Jeedom",
"cookie": {
"none": "empty",
"cmd_set_off": "9182",
"cmd_set_slider": "9184",
"cmd_set_on": "9186",
"cmd_get_state": "9183"
"displayCategories": [
"INTERIOR_BLIND"
"capabilities": [
"type": "AlexaInterface",
"interface": "Alexa.RangeController",
"instance": "Blind.Lift",
"version": "3",
"properties": {
"supported": [
"name": "rangeValue"
"proactivelyReported": false,
"retrievable": true
"capabilityResources": {
"friendlyNames": [
"@type": "asset",
"value": {
"assetId": "Alexa.Setting.Opening"
"configuration": {
"supportedRange": {
"minimumValue": 0,
"maximumValue": 100,
"precision": 1
"unitOfMeasure": "Alexa.Unit.Percent"
"semantics": {
"actionMappings": [
"@type": "ActionsToDirective",
"actions": [
"Alexa.Actions.Close"
"directive": {
"name": "SetRangeValue",
"payload": {
"rangeValue": 0
"actions": [
"Alexa.Actions.Open"
"directive": {
"payload": {
"rangeValue": 100
"actions": [
"Alexa.Actions.Lower"
"directive": {
"name": "AdjustRangeValue",
"payload": {
"rangeValueDelta": -10,
"rangeValueDeltaDefault": false
"actions": [
"Alexa.Actions.Raise"
"directive": {
"payload": {
"rangeValueDelta": 10,
"stateMappings": [
"@type": "StatesToValue",
"states": [
"Alexa.States.Closed"
"value": 0
"@type": "StatesToRange",
"states": [
"Alexa.States.Open"
"range": {
"minimumValue": 1,
"maximumValue": 100
"interface": "Alexa",
"version": "3"
Si je peux aider d’avantage, n’hésites pas.
