Probleme tahoma
bonjours j ai ce message error
[MySQL] Error code : 23000 (1062). Duplicate entry ‹ 52-salsalon › for key ‹ unique › : INSERT INTO cmd SET id = :id, logicalId = :logicalId, generic_type = :generic_type, eqType = :eqType, name = :name, order = :order, type = :type, subType = :subType, eqLogic_id = :eqLogic_id, isHistorized = :isHistorized, unite = :unite, configuration = :configuration, template = :template, display = :display, value = :value, isVisible = :isVisible, alert = :alert
J’ai un message similaire :
Erreur sur tahoma::pull() : [MySQL] Error code : 23000 (1062). Duplicate entry ‹ 34-Chauffage Eco › for key ‹ unique › : INSERT INTO cmd SET id = :id, logicalId = :logicalId, generic_type = :generic_type, eqType = :eqType, name = :name, order = :order, type = :type, subType = :subType, eqLogic_id = :eqLogic_id, isHistorized = :isHistorized, unite = :unite, configuration = :configuration, template = :template, display = :display, value = :value, isVisible = :isVisible, alert = :alert
Etant débutant sur Jeedom (VM Delta), je ne sais pas comment le résoudre.
Merci de votre aide
Une solution ?
bonjour j avais desactiver le plugin puis reactiver
