Bonjour, gros soucis depuis qq temps avec les commandes de projecteurs du plugin
exemple de demande de passage en ‹ auto ›
log du scénario
[2024-11-27 10:24:48][SCENARIO] Exécution de la commande [Extérieur][Piscine_pro][Projecteur (AutoOnOff)] avec comme option(s) : {"background":"0","select":"2"}
[2024-11-27 10:24:48][SCENARIO] Class 'GuzzleHttp\Cookie\FileCookieJar' not found
Log de NetatmoPro
0000|[2024-11-27 10:25:44] DEBUG execute:: options:array (
0001|'background' => '0',
0002|'select' => '2',
0003|)
0004|[2024-11-27 10:25:44] DEBUG execute:: this:netatmoproCmd::__set_state(array(
0005|'id' => '19645',
0006|'logicalId' => 'floodlight_set_config',
0007|'generic_type' => '',
0008|'eqType' => 'netatmopro',
0009|'name' => 'Projecteur (AutoOnOff)',
0010|'order' => '9',
0011|'type' => 'action',
0012|'subType' => 'select',
0013|'eqLogic_id' => '1739',
0014|'isHistorized' => '0',
0015|'unite' => '',
0016|'configuration' =>
0017|array (
0018|'listValue' => '0|Off;1|On;2|Auto',
0019|'timeline::enable' => '0',
0020|'interact::auto::disable' => '0',
0021|'actionConfirm' => '0',
0022|'minValue' => '',
0023|'maxValue' => '',
0024|),
0025|'template' => '{"dashboard":"core::default","mobile":"core::default"}',
0026|'display' => '{"invertBinary":"0","showNameOndashboard":"1","showNameOnmobile":"1","showIconAndNamedashboard":"0","showIconAndNamemobile":"0","forceReturnLineBefore":"0","forceReturnLineAfter":"0"}',
0027|'value' => '19651',
0028|'isVisible' => '1',
0029|'alert' => '[]',
0030|'_collectDate' => '',
0031|'_valueDate' => '',
0032|'_eqLogic' =>
0033|netatmopro::__set_state(array(
0034|'id' => '1739',
0035|'name' => 'Piscine_pro',
0036|'logicalId' => '70:ee:50:51:f7:04',
0037|'generic_type' => NULL,
0038|'object_id' => '4',
0039|'eqType_name' => 'netatmopro',
0040|'isVisible' => '1',
0041|'isEnable' => '1',
0042|'configuration' => '{"type":"NOC","version":1,"scope":"read_presence","createtime":"2020-07-05 11:20:32","dashboard":["status","sd_status","alim_status","light_mode_status"],"updatetime":"2024-10-13 02:55:05","home_id":"5da5f34c07dc93ddef4a5a61","home_name":"Ensues la Redonne","previousIsEnable":"1","previousIsVisible":"1","pwdChanged":"true","vpn_url":"https:\\/\\/prodvpn-eu-1.netatmo.net\\/restricted\\/10.255.164.4\\/xxxxxxxxxxxxxxxxxxxxx\\/xxxxxxxxxxxxxxxxxxxxxxxxx,,","is_local":true,"setup_date":1571156812,"firmware_revision":3020000,"wifi_state":"full","wifi_strength":36,"comment":""}',
0043|'timeout' => NULL,
0044|'category' => '{"heating":"0","security":"0","energy":"0","light":"0","opening":"0","automatism":"0","multimedia":"0","default":"0"}',
0045|'display' => '{"width":"384px","height":"218px","backGraph::info":"0","backGraph::format":"month","backGraph::type":"areaspline","backGraph::color":"#4572a7","layout::dashboard":"table","layout::dashboard::table::nbLine":"4","layout::dashboard::table::nbColumn":"3","layout::dashboard::table::parameters":{"center":"0","styletd":"","styletable":"","text::td::1::1":"","style::td::1::1":"","text::td::1::2":"","style::td::1::2":"","text::td::1::3":"","style::td::1::3":"","text::td::2::1":"","style::td::2::1":"","text::td::2::2":"","style::td::2::2":"","text::td::2::3":"","style::td::2::3":"","text::td::3::1":"","style::td::3::1":"","text::td::3::2":"","style::td::3::2":"","text::td::3::3":"","style::td::3::3":"","text::td::4::1":"","style::td::4::1":"","text::td::4::2":"","style::td::4::2":"","text::td::4::3":"","style::td::4::3":""},"layout::dashboard::table::cmd::19641::line":1,"layout::dashboard::table::cmd::19641::column":1,"layout::dashboard::table::cmd::19642::line":1,"layout::dashboard::table::cmd::19642::column":1,"layout::dashboard::table::cmd::19643::line":1,"layout::dashboard::table::cmd::19643::column":1,"layout::dashboard::table::cmd::19644::line":1,"layout::dashboard::table::cmd::19644::column":1,"layout::dashboard::table::cmd::19651::line":"2","layout::dashboard::table::cmd::19651::column":"2","layout::dashboard::table::cmd::19645::line":"2","layout::dashboard::table::cmd::19645::column":"2","layout::dashboard::table::cmd::19646::line":1,"layout::dashboard::table::cmd::19646::column":1,"layout::dashboard::table::cmd::19647::line":1,"layout::dashboard::table::cmd::19647::column":1,"layout::dashboard::table::cmd::19648::line":1,"layout::dashboard::table::cmd::19648::column":1,"layout::dashboard::table::cmd::19649::line":1,"layout::dashboard::table::cmd::19649::column":1,"layout::dashboard::table::cmd::19650::line":1,"layout::dashboard::table::cmd::19650::column":1,"widgetTmpl":"1"}',
0046|'order' => '16',
0047|'comment' => '',
0048|'tags' => '',
0049|'_debug' => false,
0050|'_object' =>
0051|jeeObject::__set_state(array(
0052|'id' => '4',
0053|'name' => 'Extérieur',
0054|'father_id' => '20',
0055|'isVisible' => '1',
0056|'position' => '3',
0057|'configuration' => '{"parentNumber":1,"summary::global::security":"0","summary::global::motion":"0","summary::global::door":"0","summary::global::windows":"0","summary::global::shutter":"1","summary::global::light":"1","summary::global::outlet":"0","summary::global::temperature":"0","summary::global::humidity":"0","summary::global::luminosity":"0","summary::global::power":"1","summary:0087|[2024-11-27 10:25:58] INFO webhook:: jsonData:'{"user_id":"xxxxxxxxxxxxxxxxxxxxxxxxxxx","snapshot_id":"xxxxxxxxxxxxxxxxxxxxxxxxxxxx","snapshot_key":"xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx","snapshot_url":"https:\\/\\/netatmocameraimage.blob.core.windows.net\\/production\\/xxxxxxxxxxxxxxxxxxxxxxxxxxxx?sv=2017-11-09&sr=b&se=2024-11-27T09:30:17Z&sp=r&spr=https&sig=xxxxxxxxxxxxxxxxxxxxxxxxx%3D","event_type":"human","camera_id":"70:ee:50:5d:4a:d5","device_id":"70:ee:50:5d:4a:d5","home_id":"xxxxxxxxxxxxxxxxxxxxxxxxxxx","home_name":"Ensues la Redonne","event_id":"6746e57df66348c4a4021ea3","message":"Personne d\\u00e9tect\\u00e9e par Salle \\u00e0 manger","push_type":"NACamera-human"}'
0088|[2024-11-27 10:25:58] INFO webhook:: jsonData:'{"user_id":"xxxxxxxxxxxxxxxxxxxxxxx","snapshot_id":"xxxxxxxxxxxxxxxxxxxxxxxxxxx","snapshot_key":"xxxxxxxxxxxxxxxxxxxxxxxxxxxxxx","snapshot_url":"https:\\/\\/netatmocameraimage.blob.core.windows.net\\/production\\/xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx?sv=2017-11-09&sr=b&se=2024-11-27T09:30:17Z&sp=r&spr=https&sig=xxxxxxxxxxxxxxxxxxxxxxxxxxxxx%3D","event_type":"human","camera_id":"70:ee:50:5d:4a:d5","device_id":"70:ee:50:5d:4a:d5","home_id":"xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx","home_name":"Ensues la Redonne","event_id":"xxxxxxxxxxxxxxxxxxxxxxx","message":"Personne d\\u00e9tect\\u00e9e par Salle \\u00e0 manger","push_type":"NACamera-human"}'
0089|[2024-11-27 10:26:09] DEBUG cron:: refresh:''
0090|[2024-11-27 10:26:47] INFO webhook:: jsonData:'{"user_id":"xxxxxxxxxxxxxxxxxxxxxxxxxx","snapshot_id":"xxxxxxxxxxxxxxxxxxxxxxxxx","snapshot_key":"xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx","snapshot_url":"https:\\/\\/netatmocameraimage.blob.core.windows.net\\/production\\/xxxxxxxxxxxxxxxxxxxxxxxxxxxxxx?sv=2017-11-09&sr=b&se=2024-11-27T09:31:19Z&sp=r&spr=https&sig=xxxxxxxxxxxxxxxxxxxxxxxxxxxx%3D","event_type":"movement","camera_id":"70:ee:50:5d:2b:58","device_id":"70:ee:50:5d:2b:58","home_id":"xxxxxxxxxxxxxxxxxxxxx","home_name":"Ensues la Redonne","event_id":"xxxxxxxxxxxxxxxxxxxxxxxxx","message":"Mouvement d\\u00e9tect\\u00e9 par Bureau","push_type":"NACamera-movement"}'
0091|[2024-11-27 10:26:47] INFO webhook:: jsonData:'{"user_id":"xxxxxxxxxxxxxxxxxxxxxx","snapshot_id":"xxxxxxxxxxxxxxxxxxxxxxxx","snapshot_key":"xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx","snapshot_url":"https:\\/\\/netatmocameraimage.blob.core.windows.net\\/production\\/xxxxxxxxxxxxxxxxxxxxxxxxxxxx?sv=2017-11-09&sr=b&se=2024-11-27T09:31:19Z&sp=r&spr=https&sig=xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx%3D","event_type":"movement","camera_id":"70:ee:50:5d:2b:58","device_id":"70:ee:50:5d:2b:58","home_id":"xxxxxxxxxxxxxxxxxxxx","home_name":"Ensues la Redonne","event_id":"xxxxxxxxxxxxxxxxxxxxxxxxx","message":"Mouvement d\\u00e9tect\\u00e9 par Bureau","push_type":"NACamera-movement"}'
Par ailleurs, malgrés le fait que tout fonctionne normalement en dehors des projecteurs, j’ai tenté une synchronisation, et j’obtiens ça :
J’ai aussi tenté l’Association netatmo’, mais elle se termine par :
Cette page n’est pas disponible pour le moment
georgein.eu.jeedom.link ne peut actuellement pas traiter cette demande.
Bon courage !!
Petit log de http.error supplémentaire :
0013|[Wed Nov 27 10:11:14.460918 2024] [php7:error] [pid 396778:tid 396778] [client 192.168.2.241:60865] PHP Fatal error: Uncaught Error: Class 'GuzzleHttp\\Cookie\\FileCookieJar' not found in /var/www/html/plugins/netatmopro/core/class/netatmopro.class.php:1081\nStack trace:\n#0 /var/www/html/plugins/netatmopro/core/class/netatmopro.class.php(1286): netatmopro::GetGuzzleHd()\n#1 /var/www/html/core/class/cmd.class.php(1325): netatmoproCmd->execute()\n#2 /var/www/html/core/ajax/cmd.ajax.php(102): cmd->execCmd()\n#3 {main}\n thrown in /var/www/html/plugins/netatmopro/core/class/netatmopro.class.php on line 1081
0014|[Wed Nov 27 10:11:14.588361 2024] [php7:error] [pid 393657:tid 393657] [client 192.168.2.241:60842] PHP Fatal error: Uncaught Error: Class 'GuzzleHttp\\Cookie\\FileCookieJar' not found in /var/www/html/plugins/netatmopro/core/class/netatmopro.class.php:1081\nStack trace:\n#0 /var/www/html/plugins/netatmopro/core/class/netatmopro.class.php(1286): netatmopro::GetGuzzleHd()\n#1 /var/www/html/core/class/cmd.class.php(1325): netatmoproCmd->execute()\n#2 /var/www/html/core/ajax/cmd.ajax.php(102): cmd->execCmd()\n#3 {main}\n thrown in /var/www/html/plugins/netatmopro/core/class/netatmopro.class.php on line 1081
0015|[Wed Nov 27 10:11:14.712173 2024] [php7:error] [pid 381696:tid 381696] [client 192.168.2.241:60864] PHP Fatal error: Uncaught Error: Class 'GuzzleHttp\\Cookie\\FileCookieJar' not found in /var/www/html/plugins/netatmopro/core/class/netatmopro.class.php:1081\nStack trace:\n#0 /var/www/html/plugins/netatmopro/core/class/netatmopro.class.php(1286): netatmopro::GetGuzzleHd()\n#1 /var/www/html/core/class/cmd.class.php(1325): netatmoproCmd->execute()\n#2 /var/www/html/core/ajax/cmd.ajax.php(102): cmd->execCmd()\n#3 {main}\n thrown in /var/www/html/plugins/netatmopro/core/class/netatmopro.class.php on line 1081
0016|[Wed Nov 27 10:11:22.600045 2024] [php7:error] [pid 395284:tid 395284] [client 192.168.2.241:60870] PHP Fatal error: Uncaught Error: Class 'GuzzleHttp\\Cookie\\FileCookieJar' not found in /var/www/html/plugins/netatmopro/core/class/netatmopro.class.php:1081\nStack trace:\n#0 /var/www/html/plugins/netatmopro/core/class/netatmopro.class.php(1286): netatmopro::GetGuzzleHd()\n#1 /var/www/html/core/class/cmd.class.php(1325): netatmoproCmd->execute()\n#2 /var/www/html/core/ajax/cmd.ajax.php(102): cmd->execCmd()\n#3 {main}\n thrown in /var/www/html/plugins/netatmopro/core/class/netatmopro.class.php on line 1081
0017|[Wed Nov 27 10:11:22.916711 2024] [php7:error] [pid 385699:tid 385699] [client 192.168.2.241:60872] PHP Fatal error: Uncaught Error: Class 'GuzzleHttp\\Cookie\\FileCookieJar' not found in /var/www/html/plugins/netatmopro/core/class/netatmopro.class.php:1081\nStack trace:\n#0 /var/www/html/plugins/netatmopro/core/class/netatmopro.class.php(1286): netatmopro::GetGuzzleHd()\n#1 /var/www/html/core/class/cmd.class.php(1325): netatmoproCmd->execute()\n#2 /var/www/html/core/ajax/cmd.ajax.php(102): cmd->execCmd()\n#3 {main}\n thrown in /var/www/html/plugins/netatmopro/core/class/netatmopro.class.php on line 1081
0018|[Wed Nov 27 10:11:24.690090 2024] [php7:error] [pid 381696:tid 381696] [client 192.168.2.241:60878] PHP Fatal error: Uncaught Error: Class 'GuzzleHttp\\Cookie\\FileCookieJar' not found in /var/www/html/plugins/netatmopro/core/class/netatmopro.class.php:1081\nStack trace:\n#0 /var/www/html/plugins/netatmopro/core/class/netatmopro.class.php(1286): netatmopro::GetGuzzleHd()\n#1 /var/www/html/core/class/cmd.class.php(1325): netatmoproCmd->execute()\n#2 /var/www/html/core/ajax/cmd.ajax.php(102): cmd->execCmd()\n#3 {main}\n thrown in /var/www/html/plugins/netatmopro/core/class/netatmopro.class.php on line 1081
