Voici les logs lorsque je réinstalle les dépendances :
[2020-07-04 21:27:17][DEBUG] : This is a message from googlecast program local
[2020-07-04 21:28:16][DEBUG] : This is a message from googlecast program local
[2020-07-04 21:28:16][INFO] : Process stopped !
[2020-07-04 21:30:14][DEBUG] : getInfoHttp : cmd=getconfig|data=cast_build_revision
[2020-07-04 21:30:15][DEBUG] : getInfoHttp : Error while accessing device (offline ?)
[2020-07-04 21:30:15][DEBUG] : getInfoHttp : Result error (previous result) : 1.42.172094
[2020-07-04 21:30:15][DEBUG] : getInfoHttp : Result error (with default) : 1.42.172094 => 1.42.172094
[2020-07-04 21:30:15][DEBUG] : getInfoHttp : cmd=getconfig|data=opencast_pin_code
[2020-07-04 21:30:16][DEBUG] : getInfoHttp : Error while accessing device (offline ?)
[2020-07-04 21:30:16][DEBUG] : getInfoHttp : Result error (previous result) : unknown
[2020-07-04 21:30:16][DEBUG] : getInfoHttp : Result error (with default) : unknown => unknown
[2020-07-04 21:30:16][DEBUG] : getInfoHttp : cmd=getconfig|data=cast_build_revision
[2020-07-04 21:30:16][DEBUG] : Request response content : Array ( [bssid] => 78:11:dc:4a:29:8e [build_version] => 180336 [cast_build_revision] => 1.42.180336 [closed_caption] => Array ( ) [connected] => 1 [ethernet_connected] => [has_update] => [hotspot_bssid] => FA:8F:CA:3C:8E:80 [ip_address] => 192.168.2.45 [locale] => fr [location] => Array ( [country_code] => FR [latitude] => 255 [longitude] => 255 ) [mac_address] => 00:00:00:00:00:00 [name] => Smart Clock [opt_in] => Array ( [crash] => 1 [opencast] => [stats] => 1 ) [public_key] => MIIBCgKCAQEAo37bqyEWm1T5FLwIn+016rh7DaQGtHHGfnFHhhsc8Nw0rInNm91oiKjBcvTOwGJ7K8cz+s32pJ8mQDiJI/9NbqLCOHoqnaZpXvmJsAAkzEEmCKRoVo3ZFmWStTcM4iB6Szs7noHRDw90qWMt8F8imlp6nQiALCKMKda0wx0drkGAEjO6gvJw/lePTAKuC0RfD6B/BJQxGyq+a4Xfk+bh6JXE75pPiWDkIZIIX6+IB27hNogY2ECh3Pr+3ml5oIuMVGkXy1JcW3rekfE0sT2Jx8P4eDO4CTGltfM7g8zWNSx/lxnUjwQR+6tWysShaqBkbFxZnA6lDATvC5zi2lsPbwIDAQAB [release_track] => gb-stable-channel [setup_state] => 60 [setup_stats] => Array ( [historically_succeeded] => 1 [num_check_connectivity] => 0 [num_connect_wifi] => 0 [num_connected_wifi_not_saved] => 0 [num_initial_eureka_info] => 0 [num_obtain_ip] => 0 ) [ssdp_udn] => 85840f88-28c0-719e-3d86-e6efc4f8487f [ssid] => reyur-wifi-5g [time_format] => 2 [timezone] => Europe/Paris [tos_accepted] => 1 [uma_client_id] => f6cf1fd3-73b0-4efc-a9d0-30e16d712a1e [uptime] => 24617.367074 [version] => 10 [wpa_configured] => 1 [wpa_id] => 0 [wpa_state] => 10 )
[2020-07-04 21:30:16][DEBUG] : getInfoHttp : Result success : 1.42.180336 => 1.42.180336
[2020-07-04 21:30:16][DEBUG] : getInfoHttp : cmd=getconfig|data=opencast_pin_code
[2020-07-04 21:30:16][DEBUG] : Request response content : Array ( [bssid] => 78:11:dc:4a:29:8e [build_version] => 180336 [cast_build_revision] => 1.42.180336 [closed_caption] => Array ( ) [connected] => 1 [ethernet_connected] => [has_update] => [hotspot_bssid] => FA:8F:CA:3C:8E:80 [ip_address] => 192.168.2.45 [locale] => fr [location] => Array ( [country_code] => FR [latitude] => 255 [longitude] => 255 ) [mac_address] => 00:00:00:00:00:00 [name] => Smart Clock [opt_in] => Array ( [crash] => 1 [opencast] => [stats] => 1 ) [public_key] => MIIBCgKCAQEAo37bqyEWm1T5FLwIn+016rh7DaQGtHHGfnFHhhsc8Nw0rInNm91oiKjBcvTOwGJ7K8cz+s32pJ8mQDiJI/9NbqLCOHoqnaZpXvmJsAAkzEEmCKRoVo3ZFmWStTcM4iB6Szs7noHRDw90qWMt8F8imlp6nQiALCKMKda0wx0drkGAEjO6gvJw/lePTAKuC0RfD6B/BJQxGyq+a4Xfk+bh6JXE75pPiWDkIZIIX6+IB27hNogY2ECh3Pr+3ml5oIuMVGkXy1JcW3rekfE0sT2Jx8P4eDO4CTGltfM7g8zWNSx/lxnUjwQR+6tWysShaqBkbFxZnA6lDATvC5zi2lsPbwIDAQAB [release_track] => gb-stable-channel [setup_state] => 60 [setup_stats] => Array ( [historically_succeeded] => 1 [num_check_connectivity] => 0 [num_connect_wifi] => 0 [num_connected_wifi_not_saved] => 0 [num_initial_eureka_info] => 0 [num_obtain_ip] => 0 ) [ssdp_udn] => 85840f88-28c0-719e-3d86-e6efc4f8487f [ssid] => reyur-wifi-5g [time_format] => 2 [timezone] => Europe/Paris [tos_accepted] => 1 [uma_client_id] => f6cf1fd3-73b0-4efc-a9d0-30e16d712a1e [uptime] => 24617.426608 [version] => 10 [wpa_configured] => 1 [wpa_id] => 0 [wpa_state] => 10 )
[2020-07-04 21:30:16][DEBUG] : getInfoHttp : Result success : unknown => unknown
[2020-07-04 21:30:16][INFO] : Lancement démon googlecast : /usr/bin/python3 /var/www/html/plugins/googlecast/resources/googlecast.py --loglevel debug --socketport 55012 --sockethost 127.0.0.1 --callback http://127.0.0.1:80/plugins/googlecast/core/php/googlecast.api.php --apikey 69HOxpIEqvbLbAsrvYRrMhW1dRJl2Hkj --ttsweb http://192.168.2.30 --ttslang fr-FR --ttsengine jeedomtts --ttsspeed 0.8 --ttscache 1 --ttsgapikey none --gcttsvoice fr-FR-Standard-A --ttsdefaultrestoretime 1300 --ttsdefaultsilenceduration 300 --daemonname local --cyclefactor 1 --defaultstatus ' '
[2020-07-04 21:30:16][DEBUG] : Request response content : Array ( [bssid] => 78:11:dc:4a:29:8e [build_version] => 195690 [cast_build_revision] => 1.46.195690 [closed_caption] => Array ( ) [connected] => 1 [ethernet_connected] => [has_update] => [hotspot_bssid] => FA:8F:CA:6F:91:E0 [ip_address] => 192.168.2.39 [locale] => fr [location] => Array ( [country_code] => FR [latitude] => 255 [longitude] => 255 ) [mac_address] => 20:DF:B9:39:91:9A [name] => Google Home SDB [noise_level] => -89 [opt_in] => Array ( [crash] => [opencast] => [stats] => ) [public_key] => MIIBCgKCAQEAzYMDHN8AEkkizFEbSXjRvXskYxCSy/8bRNWNWCUQ5zJm1qVWzZTeloMbUH4a8MeABBOpACNX3C7iUwT9IUFTZpTxi3GO8lI5Fm8hLUlEXmw0ub/SQ4aS0WwI0ejgWPcwhKYsQoPBIvwCXQ/gSrw/7QIh6nCr79vpMjcwGDbZLVqSrwlklW1Q+Pvyrmef5f4pUJvdp9uEUuKq+3EfAEsXyyhNaNzfpSmPuKgRQsMfwoJfR8UFtdL8rsdigqcP+pigcfCsgx5iQkNtwrkGczl/uw0rDc1csqZb5g/LTG/MqZoPTOLan/4XvNe2xPoBV02bP82Q4GdJ1zsqdwSvRdyvCQIDAQAB [release_track] => stable-channel [setup_state] => 60 [setup_stats] => Array ( [historically_succeeded] => 1 [num_check_connectivity] => 0 [num_connect_wifi] => 0 [num_connected_wifi_not_saved] => 0 [num_initial_eureka_info] => 0 [num_obtain_ip] => 0 ) [signal_level] => -52 [ssdp_udn] => 5a558218-753c-7f5b-3089-e392600f1ad0 [ssid] => reyur-wifi-5g [time_format] => 2 [timezone] => Europe/Paris [tos_accepted] => 1 [uptime] => 67112.535338 [version] => 10 [wpa_configured] => 1 [wpa_id] => 0 [wpa_state] => 10 )
[2020-07-04 21:30:16][DEBUG] : getInfoHttp : Result success : 1.46.195690 => 1.46.195690
[2020-07-04 21:30:16][DEBUG] : getInfoHttp : cmd=getconfig|value=assistant/alarms|data=$.alarm.[0].fire_time|fnc=ts2long|reterror=Undefined
[2020-07-04 21:30:16][WARNING] : Le jeton Google Home n'est pas configuré!
[2020-07-04 21:30:16][DEBUG] : getInfoHttp : Result success : => Undefined
[2020-07-04 21:30:16][DEBUG] : getInfoHttp : cmd=getconfig|value=assistant/alarms|data=$.alarm.[0].status|reterror=0
[2020-07-04 21:30:16][DEBUG] : getInfoHttp : Result success : => 0
[2020-07-04 21:30:16][DEBUG] : Request response content : Array ( [bssid] => 78:11:dc:4a:29:8e [build_version] => 195690 [cast_build_revision] => 1.46.195690 [closed_caption] => Array ( ) [connected] => 1 [ethernet_connected] => [has_update] => [hotspot_bssid] => FA:8F:CA:6F:91:E0 [ip_address] => 192.168.2.39 [locale] => fr [location] => Array ( [country_code] => FR [latitude] => 255 [longitude] => 255 ) [mac_address] => 20:DF:B9:39:91:9A [name] => Google Home SDB [noise_level] => -89 [opt_in] => Array ( [crash] => [opencast] => [stats] => ) [public_key] => MIIBCgKCAQEAzYMDHN8AEkkizFEbSXjRvXskYxCSy/8bRNWNWCUQ5zJm1qVWzZTeloMbUH4a8MeABBOpACNX3C7iUwT9IUFTZpTxi3GO8lI5Fm8hLUlEXmw0ub/SQ4aS0WwI0ejgWPcwhKYsQoPBIvwCXQ/gSrw/7QIh6nCr79vpMjcwGDbZLVqSrwlklW1Q+Pvyrmef5f4pUJvdp9uEUuKq+3EfAEsXyyhNaNzfpSmPuKgRQsMfwoJfR8UFtdL8rsdigqcP+pigcfCsgx5iQkNtwrkGczl/uw0rDc1csqZb5g/LTG/MqZoPTOLan/4XvNe2xPoBV02bP82Q4GdJ1zsqdwSvRdyvCQIDAQAB [release_track] => stable-channel [setup_state] => 60 [setup_stats] => Array ( [historically_succeeded] => 1 [num_check_connectivity] => 0 [num_connect_wifi] => 0 [num_connected_wifi_not_saved] => 0 [num_initial_eureka_info] => 0 [num_obtain_ip] => 0 ) [signal_level] => -51 [ssdp_udn] => 5a558218-753c-7f5b-3089-e392600f1ad0 [ssid] => reyur-wifi-5g [time_format] => 2 [timezone] => Europe/Paris [tos_accepted] => 1 [uptime] => 67112.965683 [version] => 10 [wpa_configured] => 1 [wpa_id] => 0 [wpa_state] => 10 )
[2020-07-04 21:30:17][DEBUG] : getInfoHttp : Error while accessing device (offline ?)
[2020-07-04 21:30:17][DEBUG] : getInfoHttp : Result error (previous result) : 1.44.185164
[2020-07-04 21:30:17][DEBUG] : getInfoHttp : Result error (with default) : 1.44.185164 => 1.44.185164
[2020-07-04 21:30:17][DEBUG] : getInfoHttp : cmd=getconfig|data=opencast_pin_code
[2020-07-04 21:30:18][DEBUG] : getInfoHttp : Error while accessing device (offline ?)
[2020-07-04 21:30:18][DEBUG] : getInfoHttp : Result error (previous result) : unknown
[2020-07-04 21:30:18][DEBUG] : getInfoHttp : Result error (with default) : unknown => unknown
[2020-07-04 21:30:20][DEBUG] : This is a message from googlecast program local
[2020-07-04 21:30:20][INFO] : Process started. Sending known devices now...
et :
[2020-07-04 21:30:20][INFO] : ------------------------------------------------------
[2020-07-04 21:30:20][INFO] : GLOBAL------STARTING googlecast
[2020-07-04 21:30:20][INFO] : GLOBAL------Scan Timeout : 5
[2020-07-04 21:30:20][INFO] : GLOBAL------Scan Frequency : 60
[2020-07-04 21:30:20][INFO] : GLOBAL------Log level : debug
[2020-07-04 21:30:20][INFO] : GLOBAL------Socket port : 55012
[2020-07-04 21:30:20][INFO] : GLOBAL------Socket host : 127.0.0.1
[2020-07-04 21:30:20][INFO] : GLOBAL------PID file : /tmp/googlecast.pid
[2020-07-04 21:30:20][INFO] : GLOBAL------Apikey : *******************************
[2020-07-04 21:30:20][INFO] : GLOBAL------TTS Jeedom server : http://192.168.2.30
[2020-07-04 21:30:20][INFO] : GLOBAL------TTS default language : fr-FR
[2020-07-04 21:30:20][INFO] : GLOBAL------TTS default engine : jeedomtts
[2020-07-04 21:30:20][INFO] : GLOBAL------TTS default speech speed : 0.8
[2020-07-04 21:30:20][INFO] : GLOBAL------TTS Google API Key (optional) : NOK
[2020-07-04 21:30:20][INFO] : GLOBAL------TTS default delay before volume restore : 1300 ms
[2020-07-04 21:30:20][INFO] : GLOBAL------TTS default silence before tts : 300 ms
[2020-07-04 21:30:20][INFO] : GLOBAL------Cache status : True
[2020-07-04 21:30:20][INFO] : GLOBAL------Callback : http://127.0.0.1:80/plugins/googlecast/core/php/googlecast.api.php
[2020-07-04 21:30:20][INFO] : GLOBAL------Event cycle : 0.5
[2020-07-04 21:30:20][INFO] : GLOBAL------Main cycle : 2.0
[2020-07-04 21:30:20][INFO] : GLOBAL------Default status message :
[2020-07-04 21:30:20][DEBUG] : Writing PID 16278 to /tmp/googlecast.pid
[2020-07-04 21:30:20][DEBUG] : Init request module v2.21.0
[2020-07-04 21:30:20][INFO] : GLOBAL------Network communication to jeedom OK.
[2020-07-04 21:30:20][DEBUG] : SOCKETHANDLER------Socket interface started
[2020-07-04 21:30:20][DEBUG] : SOCKETHANDLER------LoopNetServer Thread started
[2020-07-04 21:30:20][INFO] : GLOBAL------Socket started and waiting for messages from Jeedom...
[2020-07-04 21:30:20][DEBUG] : SOCKETHANDLER------Listening on: [127.0.0.1:55012]
[2020-07-04 21:30:20][DEBUG] : WARMUPNOTIF------ Checking file generation...
[2020-07-04 21:30:20][DEBUG] : SENDER------Send to jeedom : {'started': 1, 'source': 'local'}
[2020-07-04 21:30:20][DEBUG] : SCANNER------ Start scanning... (schedule)
[2020-07-04 21:30:20][DEBUG] : ZEROCONF------ Stopping zeroconf monitoring thread...
[2020-07-04 21:30:20][DEBUG] : ZEROCONF------ Start zeroconf monitoring thread...
[2020-07-04 21:30:20][ERROR] : ZEROCONF START------Exception on zeroconf monitoring : module 'zeroconf' has no attribute 'BadTypeInNameException'
[2020-07-04 21:30:20][DEBUG] : Traceback (most recent call last):
File "/var/www/html/plugins/googlecast/resources/pychromecast/pychromecast/discovery.py", line 116, in start_discovery
service_browser = zeroconf.ServiceBrowser(
AttributeError: module 'zeroconf' has no attribute 'ServiceBrowser'
During handling of the above exception, another exception occurred:
File "/var/www/html/plugins/googlecast/resources/googlecast.py", line 2075, in zeroconfMonitoring_start
tries=1, retry_wait=2, timeout=globals.SCAN_TIMEOUT, blocking=False, callback=ccdiscovery_callback)
File "/var/www/html/plugins/googlecast/resources/pychromecast/pychromecast/__init__.py", line 210, in get_chromecasts
listener, browser = start_discovery(internal_callback)
File "/var/www/html/plugins/googlecast/resources/pychromecast/pychromecast/discovery.py", line 122, in start_discovery
zeroconf.BadTypeInNameException,
AttributeError: module 'zeroconf' has no attribute 'BadTypeInNameException'
[2020-07-04 21:30:20][DEBUG] : SOCKETHANDLER------Client connected to [127.0.0.1:33628]
[2020-07-04 21:30:20][DEBUG] : SOCKETHANDLER------Message read from socket: {"apikey": "XXXXXXXXXXXXX", "cmd": "add", "device": {"uuid": "c1b3ca06-07e8-4b39-0164-6bdfc7adcf8b", "options": {"ignore_CEC": "0"}}}
[2020-07-04 21:30:20][DEBUG] : SOCKETHANDLER------Client disconnected from [127.0.0.1:33628]
[2020-07-04 21:30:20][DEBUG] : SOCKETHANDLER------Client connected to [127.0.0.1:33630]
[2020-07-04 21:30:20][DEBUG] : SOCKETHANDLER------Message read from socket: {"apikey": "XXXXXXXXXXXXX", "cmd": "add", "device": {"uuid": "85840f88-28c0-719e-3d86-e6efc4f8487f", "options": {"ignore_CEC": "0"}}}
[2020-07-04 21:30:20][DEBUG] : SOCKETHANDLER------Client disconnected from [127.0.0.1:33630]
[2020-07-04 21:30:20][DEBUG] : SOCKETHANDLER------Client connected to [127.0.0.1:33632]
[2020-07-04 21:30:20][DEBUG] : SOCKETHANDLER------Message read from socket: {"apikey": "XXXXXXXXXXXXX", "cmd": "add", "device": {"uuid": "5a558218-753c-7f5b-3089-e392600f1ad0", "options": {"ignore_CEC": "0"}}}
[2020-07-04 21:30:20][DEBUG] : SOCKETHANDLER------Client disconnected from [127.0.0.1:33632]
[2020-07-04 21:30:20][DEBUG] : SOCKETHANDLER------Client connected to [127.0.0.1:33634]
[2020-07-04 21:30:20][DEBUG] : SOCKETHANDLER------Message read from socket: {"apikey": "XXXXXXXXXXXXX", "cmd": "add", "device": {"uuid": "47b4d393-5398-5a62-e0d7-8b59dddf139d", "options": {"ignore_CEC": "0"}}}
[2020-07-04 21:30:20][DEBUG] : SOCKETHANDLER------Client disconnected from [127.0.0.1:33634]
[2020-07-04 21:30:21][DEBUG] : SOCKET-READ------Message received in socket JEEDOM_SOCKET_MESSAGE
[2020-07-04 21:30:21][DEBUG] : SOCKET-READ------Received command from jeedom : add
[2020-07-04 21:30:21][DEBUG] : SOCKET-READ------Add device : {'uuid': 'c1b3ca06-07e8-4b39-0164-6bdfc7adcf8b', 'options': {'ignore_CEC': '0'}}
[2020-07-04 21:30:21][DEBUG] : SOCKET-READ------Add device : {'uuid': '85840f88-28c0-719e-3d86-e6efc4f8487f', 'options': {'ignore_CEC': '0'}}
[2020-07-04 21:30:21][DEBUG] : SCANNER------No connection to device c1b3ca06-07e8-4b39-0164-6bdfc7adcf8b
[2020-07-04 21:30:21][DEBUG] : SCANNER------No connection to device 85840f88-28c0-719e-3d86-e6efc4f8487f
[2020-07-04 21:30:21][DEBUG] : SENDER------Send to jeedom : {'devices': {'c1b3ca06-07e8-4b39-0164-6bdfc7adcf8b': {'uuid': 'c1b3ca06-07e8-4b39-0164-6bdfc7adcf8b', 'status': {'uuid': 'c1b3ca06-07e8-4b39-0164-6bdfc7adcf8b', 'is_stand_by': False, 'is_active_input': False, 'display_name': '', 'status_text': ' ', 'app_id': '', 'icon_url': '', 'is_busy': False, 'title': '', 'artist': '', 'series_title': '', 'stream_type': '', 'player_state': ''}, 'typemsg': 'info', 'lastOnline': 0, 'online': False, 'lastSent': 1593891021, 'lastOfflineSent': 1593891021, 'options': {'ignore_CEC': '0'}, 'lastScan': 1593891021}}}
[2020-07-04 21:30:21][DEBUG] : SENDER------Send to jeedom : {'devices': {'85840f88-28c0-719e-3d86-e6efc4f8487f': {'uuid': '85840f88-28c0-719e-3d86-e6efc4f8487f', 'status': {'uuid': '85840f88-28c0-719e-3d86-e6efc4f8487f', 'is_stand_by': False, 'is_active_input': False, 'display_name': '', 'status_text': ' ', 'app_id': '', 'icon_url': '', 'is_busy': False, 'title': '', 'artist': '', 'series_title': '', 'stream_type': '', 'player_state': ''}, 'typemsg': 'info', 'lastOnline': 0, 'online': False, 'lastSent': 1593891021, 'lastOfflineSent': 1593891021, 'options': {'ignore_CEC': '0'}, 'lastScan': 1593891021}}}
[2020-07-04 21:30:22][DEBUG] : SOCKET-READ------Message received in socket JEEDOM_SOCKET_MESSAGE
[2020-07-04 21:30:22][DEBUG] : SOCKET-READ------Received command from jeedom : add
[2020-07-04 21:30:22][DEBUG] : SOCKET-READ------Add device : {'uuid': '5a558218-753c-7f5b-3089-e392600f1ad0', 'options': {'ignore_CEC': '0'}}
[2020-07-04 21:30:22][DEBUG] : SCANNER------ Start scanning... (schedule)
[2020-07-04 21:30:22][DEBUG] : MEMORY---- Total CPU time used : 3.814s (190.68%) | Last 2 sec : 3.814s (190.68%) | Memory : 34 Mo
[2020-07-04 21:30:22][DEBUG] : ZEROCONF------ Stopping zeroconf monitoring thread...
[2020-07-04 21:30:22][DEBUG] : ZEROCONF------ Start zeroconf monitoring thread...
[2020-07-04 21:30:22][DEBUG] : SOCKET-READ------Add device : {'uuid': '47b4d393-5398-5a62-e0d7-8b59dddf139d', 'options': {'ignore_CEC': '0'}}
[2020-07-04 21:30:22][ERROR] : ZEROCONF START------Exception on zeroconf monitoring : module 'zeroconf' has no attribute 'BadTypeInNameException'
[2020-07-04 21:30:22][DEBUG] : Traceback (most recent call last):
[2020-07-04 21:30:23][DEBUG] : SCANNER------No connection to device c1b3ca06-07e8-4b39-0164-6bdfc7adcf8b
[2020-07-04 21:30:23][DEBUG] : SCANNER------No connection to device 85840f88-28c0-719e-3d86-e6efc4f8487f
[2020-07-04 21:30:23][DEBUG] : SCANNER------No connection to device 5a558218-753c-7f5b-3089-e392600f1ad0
[2020-07-04 21:30:23][DEBUG] : SCANNER------No connection to device 47b4d393-5398-5a62-e0d7-8b59dddf139d
[2020-07-04 21:30:23][DEBUG] : SENDER------Send to jeedom : {'devices': {'5a558218-753c-7f5b-3089-e392600f1ad0': {'uuid': '5a558218-753c-7f5b-3089-e392600f1ad0', 'status': {'uuid': '5a558218-753c-7f5b-3089-e392600f1ad0', 'is_stand_by': False, 'is_active_input': False, 'display_name': '', 'status_text': ' ', 'app_id': '', 'icon_url': '', 'is_busy': False, 'title': '', 'artist': '', 'series_title': '', 'stream_type': '', 'player_state': ''}, 'typemsg': 'info', 'lastOnline': 0, 'online': False, 'lastSent': 1593891023, 'lastOfflineSent': 1593891023, 'options': {'ignore_CEC': '0'}, 'lastScan': 1593891023}}}
[2020-07-04 21:30:23][DEBUG] : SENDER------Send to jeedom : {'devices': {'47b4d393-5398-5a62-e0d7-8b59dddf139d': {'uuid': '47b4d393-5398-5a62-e0d7-8b59dddf139d', 'status': {'uuid': '47b4d393-5398-5a62-e0d7-8b59dddf139d', 'is_stand_by': False, 'is_active_input': False, 'display_name': '', 'status_text': ' ', 'app_id': '', 'icon_url': '', 'is_busy': False, 'title': '', 'artist': '', 'series_title': '', 'stream_type': '', 'player_state': ''}, 'typemsg': 'info', 'lastOnline': 0, 'online': False, 'lastSent': 1593891023, 'lastOfflineSent': 1593891023, 'options': {'ignore_CEC': '0'}, 'lastScan': 1593891023}}}
