Probléme retour d'info TS0011
Bonjour a tous , j’ai 1 modules qui existe dans la liste tuya mais il fonctionne a en partie
Module connecté ON/OFF sans neutre TS0011
Le on/off fonctionne mais je n’ai pas le retour d’état, il est toujours a 1, l’image du module dans le plugin zigbee est différente par contre
    "ieee": "a4:c1:38:73:a0:f8:29:d0",
    "nwk": 39482,
    "status": 2,
    "lqi": "140",
    "rssi": "-65",
    "last_seen": "1639501520.4341936",
    "node_descriptor": "02:40:80:41:11:42:42:00:00:2a:42:00:00",
    "endpoints": [
            "id": 1,
            "status": 1,
            "device_type": 256,
            "profile_id": 260,
            "manufacturer": "_TZ3000_ji4araar",
            "model": "TS0011",
            "output_clusters": [
                    "id": 25,
                    "name": "Ota",
                    "attributes": []
                    "id": 10,
                    "name": "Time",
                    "attributes": []
            "input_clusters": [
                    "id": 3,
                    "name": "Identify",
                    "attributes": []
                    "id": 4,
                    "name": "Groups",
                    "attributes": []
                    "id": 5,
                    "name": "Scenes",
                    "attributes": []
                    "id": 6,
                    "name": "On\/Off",
                    "attributes": [
                            "id": 0,
                            "name": "on_off",
                            "value": 1
                    "id": 57344,
                    "name": "Cluster",
                    "attributes": []
                    "id": 57345,
                    "name": "Cluster",
                    "attributes": []
                    "id": 0,
                    "name": "Basic",
                    "attributes": [
                            "id": 0,
                            "name": "zcl_version",
                            "value": 3
                            "id": 1,
                            "name": "app_version",
                            "value": 67
                            "id": 2,
                            "name": "stack_version",
                            "value": 0
                            "id": 3,
                            "name": "hw_version",
                            "value": 1
                            "id": 4,
                            "name": "manufacturer",
                            "value": "_TZ3000_ji4araar"
                            "id": 5,
                            "name": "model",
                            "value": "TS0011"
                            "id": 6,
                            "name": "date_code",
                            "value": ""
                            "id": 7,
                            "name": "power_source",
                            "value": 3
    "signature": {
        "model": "TS0011",
        "node_desc": {
            "logical_type": 2,
            "reserved": 0,
            "aps_flags": 0,
            "frequency_band": 8,
            "mac_capability_flags": 128,
            "manufacturer_code": 4417,
            "maximum_buffer_size": 66,
            "maximum_incoming_transfer_size": 66,
            "server_mask": 10752,
            "maximum_outgoing_transfer_size": 66,
        "endpoints": {
            "1": {
                "profile_id": 260,
                "device_type": 256,
                "input_clusters": [
                    3,
                    4,
                    5,
                    6,
                    57344,
                    57345,
                    0
                    25,
                    10
    "class": "zigpy.device"
Bonjour @Francky62 ,
je viens de regarder les configurations TS0011 actuellement dans le plugin et je ne constate pas d’erreur.
Pour ma part ce module fonctionne correctement chez moi.
Essaie de recréer les commandes, sinon supprimer le module et refait une inclusion.
C’est bizarre car ton tree info est correct
Bluette du soir : le jour où les Tuyas (ou Girier) seront Intelligents les poules seront dignes d’Einstein
:rofl:
Déja fait mais cela ne change rien , c’est dommage, le on/off fonctionne bien
la commande etat est 1::6::0
:joy: Comme on dit, on en a pour son argent … mais pour des bricoles, tu n’a pas envie de mettre beaucoup plus desfois. Cependant, le zigbee n’etant pas trop cher, cela pourait s’appliquer a plein de module et pourtant beaucoup fonctionne trés bien .
C’est juste le titre que le constructeur donne à ses bidules qui contiennent tout au plus un relai quelques capas et un microcontrôleur à 15 centimes qui m’exaspère car il les traite d’intelligents. Je me demande entre le module et le chef marketing de la société qui est le plus intelligent in fine.
:upside_down_face:
Il ne s’inclu pas bien , il a peut etre une variante
@Yves19
Le probléme est le nom aussi, il ont tous les memes référence alors qu’il sont totalement différent … TS0011, TZ3000 …
Bonsoir dans les données brutes tu a le nom de guerre
il faut allez voir si il y a bien un json correspondant dans les sous dossier du plugin :wink:
html/plugins/zigbee/core/config/devices/tuya
EDIT à 1er vue je le vois pas en Bêta
Il te faut donc passer par une demande d’intégration
Merci j’ai fait la demande et je passe le sujet en résolu
Je vais regarder aussi pour l’autre module, je ne savais pas que tous les Json son dans le plugin
Et oui c’est aussi cela les chinoiseries. Rebranding , pas de gestion de configuration , aussi vite apparu aussi vite parti, …et je ne parle même pas de la (absence de) sécurité des bidules.
