j’ai une A4 Avant de 2024. L’appli MyAudi fonctionne normalement avec toutes les infos mais le plugin indique une erreur de connexion au serveur.
J’ai lu un peu les différentes discussions et je me dis que c’est côté Audi qu’il y a un soucis mais pas sûr.
Possible un petit coup de pouce? ![]()
Informations Jeedom
Core : 4.4.12 (master)
DNS Jeedom : non
Plugin : My Audi
Version : 2024-08-19 01:07:54 (stable)
Statut Démon : Démarré - (2024-08-19 23:51:10)
Informations complémentaires
Log des dépendances:
+ touch /tmp/jeedom_install_in_progress_myaudi
+ echo 1
+ echo 2
apt: no process found
apt-get: no process found
+ sudo apt update
Hit:1 http://ftp.fr.debian.org/debian buster InRelease
Hit:2 http://ftp.fr.debian.org/debian buster-updates InRelease
Hit:3 http://security.debian.org/debian-security buster/updates InRelease
Hit:4 https://deb.nodesource.com/node_18.x nodistro InRelease
Reading package lists...
Building dependency tree...
Reading state information...
All packages are up to date.
+ echo 3
+ sudo apt install -o Dpkg::Options::=--force-confdef -y python3-requests
python3-requests is already the newest version (2.21.0-1+deb10u1).
0 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
+ echo 4
+ sudo apt install -o Dpkg::Options::=--force-confdef -y python3-bs4
python3-bs4 is already the newest version (4.7.1-1).
+ echo 5
++ awk '$1 <= 4'
++ find /usr/local/lib/python2.7/dist-packages/ /usr/local/lib/python3.7/dist-packages/ -mindepth 1 -maxdepth 1 -type d -exec du -ks '{}' +
++ cut -f 2-
+ RESULTTODELETE=
++ echo ''
++ sed 's, ,\ ,g'
+ RESULTTODELETE2=
+ xargs rm -rf
+ echo ''
+ echo 6
+ sudo pip3 cache purge
Files removed: 104
+ echo 7
+ sudo pip3 install --upgrade pip
Requirement already satisfied: pip in /usr/local/lib/python3.7/dist-packages (24.0)
WARNING: Running pip as the 'root' user can result in broken permissions and conflicting behaviour with the system package manager. It is recommended to use a virtual environment instead: https://pip.pypa.io/warnings/venv
+ echo 8
+ sudo python3 -m pip install --force-reinstall --upgrade requests
Collecting requests
Downloading requests-2.31.0-py3-none-any.whl.metadata (4.6 kB)
Collecting charset-normalizer<4,>=2 (from requests)
Downloading charset_normalizer-3.3.2-cp37-cp37m-manylinux_2_17_x86_64.manylinux2014_x86_64.whl.metadata (33 kB)
Collecting idna<4,>=2.5 (from requests)
Downloading idna-3.7-py3-none-any.whl.metadata (9.9 kB)
Collecting urllib3<3,>=1.21.1 (from requests)
Downloading urllib3-2.0.7-py3-none-any.whl.metadata (6.6 kB)
Collecting certifi>=2017.4.17 (from requests)
Downloading certifi-2024.7.4-py3-none-any.whl.metadata (2.2 kB)
Downloading requests-2.31.0-py3-none-any.whl (62 kB)
━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━ 62.6/62.6 kB 2.1 MB/s eta 0:00:00
Downloading certifi-2024.7.4-py3-none-any.whl (162 kB)
━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━ 163.0/163.0 kB 5.6 MB/s eta 0:00:00
Downloading charset_normalizer-3.3.2-cp37-cp37m-manylinux_2_17_x86_64.manylinux2014_x86_64.whl (136 kB)
━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━ 136.8/136.8 kB 10.1 MB/s eta 0:00:00
Downloading idna-3.7-py3-none-any.whl (66 kB)
━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━ 66.8/66.8 kB 7.2 MB/s eta 0:00:00
Downloading urllib3-2.0.7-py3-none-any.whl (124 kB)
━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━ 124.2/124.2 kB 11.5 MB/s eta 0:00:00
Installing collected packages: urllib3, idna, charset-normalizer, certifi, requests
Attempting uninstall: urllib3
Found existing installation: urllib3 2.0.7
Uninstalling urllib3-2.0.7:
Successfully uninstalled urllib3-2.0.7
Attempting uninstall: idna
Found existing installation: idna 3.7
Uninstalling idna-3.7:
Successfully uninstalled idna-3.7
Attempting uninstall: charset-normalizer
Found existing installation: charset-normalizer 3.3.2
Uninstalling charset-normalizer-3.3.2:
Successfully uninstalled charset-normalizer-3.3.2
Attempting uninstall: certifi
Found existing installation: certifi 2024.7.4
Uninstalling certifi-2024.7.4:
Successfully uninstalled certifi-2024.7.4
Attempting uninstall: requests
Found existing installation: requests 2.31.0
Uninstalling requests-2.31.0:
Successfully uninstalled requests-2.31.0
ERROR: pip's dependency resolver does not currently take into account all the packages that are installed. This behaviour is the source of the following dependency conflicts.
python-miio 0.5.12 requires importlib_metadata<2,>=1; python_version <= "3.7", but you have importlib-metadata 6.7.0 which is incompatible.
zigpy-zigate 0.11.0 requires pyserial>=3.5, but you have pyserial 3.4 which is incompatible.
Successfully installed certifi-2024.7.4 charset-normalizer-3.3.2 idna-3.7 requests-2.31.0 urllib3-2.0.7
+ echo 9
+ sudo python3 -m pip install --force-reinstall --upgrade voluptuous
Collecting voluptuous
Downloading voluptuous-0.14.1-py3-none-any.whl.metadata (20 kB)
Downloading voluptuous-0.14.1-py3-none-any.whl (30 kB)
Installing collected packages: voluptuous
Attempting uninstall: voluptuous
Found existing installation: voluptuous 0.14.1
Uninstalling voluptuous-0.14.1:
Successfully uninstalled voluptuous-0.14.1
Successfully installed voluptuous-0.14.1
+ echo 10
+ sudo python3 -m pip install --force-reinstall --upgrade aiohttp
Collecting aiohttp
Downloading aiohttp-3.8.6-cp37-cp37m-manylinux_2_17_x86_64.manylinux2014_x86_64.whl.metadata (7.7 kB)
Collecting attrs>=17.3.0 (from aiohttp)
Downloading attrs-24.2.0-py3-none-any.whl.metadata (11 kB)
Collecting charset-normalizer<4.0,>=2.0 (from aiohttp)
Using cached charset_normalizer-3.3.2-cp37-cp37m-manylinux_2_17_x86_64.manylinux2014_x86_64.whl.metadata (33 kB)
Collecting multidict<7.0,>=4.5 (from aiohttp)
Downloading multidict-6.0.5-cp37-cp37m-manylinux_2_17_x86_64.manylinux2014_x86_64.whl.metadata (4.2 kB)
Collecting async-timeout<5.0,>=4.0.0a3 (from aiohttp)
Downloading async_timeout-4.0.3-py3-none-any.whl.metadata (4.2 kB)
Collecting yarl<2.0,>=1.0 (from aiohttp)
Downloading yarl-1.9.4-cp37-cp37m-manylinux_2_17_x86_64.manylinux2014_x86_64.whl.metadata (31 kB)
Collecting frozenlist>=1.1.1 (from aiohttp)
Downloading frozenlist-1.3.3-cp37-cp37m-manylinux_2_5_x86_64.manylinux1_x86_64.manylinux_2_17_x86_64.manylinux2014_x86_64.whl.metadata (4.7 kB)
Collecting aiosignal>=1.1.2 (from aiohttp)
Downloading aiosignal-1.3.1-py3-none-any.whl.metadata (4.0 kB)
Collecting asynctest==0.13.0 (from aiohttp)
Downloading asynctest-0.13.0-py3-none-any.whl.metadata (5.4 kB)
Collecting typing-extensions>=3.7.4 (from aiohttp)
Downloading typing_extensions-4.7.1-py3-none-any.whl.metadata (3.1 kB)
Collecting importlib-metadata (from attrs>=17.3.0->aiohttp)
Downloading importlib_metadata-6.7.0-py3-none-any.whl.metadata (4.9 kB)
Collecting idna>=2.0 (from yarl<2.0,>=1.0->aiohttp)
Using cached idna-3.7-py3-none-any.whl.metadata (9.9 kB)
Collecting zipp>=0.5 (from importlib-metadata->attrs>=17.3.0->aiohttp)
Downloading zipp-3.15.0-py3-none-any.whl.metadata (3.7 kB)
Downloading aiohttp-3.8.6-cp37-cp37m-manylinux_2_17_x86_64.manylinux2014_x86_64.whl (987 kB)
━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━ 988.0/988.0 kB 11.0 MB/s eta 0:00:00
Downloading asynctest-0.13.0-py3-none-any.whl (26 kB)
Downloading aiosignal-1.3.1-py3-none-any.whl (7.6 kB)
Downloading async_timeout-4.0.3-py3-none-any.whl (5.7 kB)
Downloading attrs-24.2.0-py3-none-any.whl (63 kB)
━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━ 63.0/63.0 kB 5.8 MB/s eta 0:00:00
Using cached charset_normalizer-3.3.2-cp37-cp37m-manylinux_2_17_x86_64.manylinux2014_x86_64.whl (136 kB)
Downloading frozenlist-1.3.3-cp37-cp37m-manylinux_2_5_x86_64.manylinux1_x86_64.manylinux_2_17_x86_64.manylinux2014_x86_64.whl (148 kB)
━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━ 148.0/148.0 kB 15.8 MB/s eta 0:00:00
Downloading multidict-6.0.5-cp37-cp37m-manylinux_2_17_x86_64.manylinux2014_x86_64.whl (99 kB)
━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━ 99.8/99.8 kB 11.0 MB/s eta 0:00:00
Downloading typing_extensions-4.7.1-py3-none-any.whl (33 kB)
Downloading yarl-1.9.4-cp37-cp37m-manylinux_2_17_x86_64.manylinux2014_x86_64.whl (289 kB)
━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━ 289.8/289.8 kB 24.7 MB/s eta 0:00:00
Using cached idna-3.7-py3-none-any.whl (66 kB)
Downloading importlib_metadata-6.7.0-py3-none-any.whl (22 kB)
Downloading zipp-3.15.0-py3-none-any.whl (6.8 kB)
Installing collected packages: zipp, typing-extensions, multidict, idna, frozenlist, charset-normalizer, asynctest, yarl, importlib-metadata, async-timeout, aiosignal, attrs, aiohttp
Attempting uninstall: zipp
Found existing installation: zipp 3.15.0
Uninstalling zipp-3.15.0:
Successfully uninstalled zipp-3.15.0
Attempting uninstall: typing-extensions
Found existing installation: typing_extensions 4.7.1
Uninstalling typing_extensions-4.7.1:
Successfully uninstalled typing_extensions-4.7.1
Attempting uninstall: multidict
Found existing installation: multidict 6.0.5
Uninstalling multidict-6.0.5:
Successfully uninstalled multidict-6.0.5
Attempting uninstall: frozenlist
Found existing installation: frozenlist 1.3.3
Uninstalling frozenlist-1.3.3:
Successfully uninstalled frozenlist-1.3.3
Attempting uninstall: asynctest
Found existing installation: asynctest 0.13.0
Uninstalling asynctest-0.13.0:
Successfully uninstalled asynctest-0.13.0
Attempting uninstall: yarl
Found existing installation: yarl 1.9.4
Uninstalling yarl-1.9.4:
Successfully uninstalled yarl-1.9.4
Attempting uninstall: importlib-metadata
Found existing installation: importlib-metadata 6.7.0
Uninstalling importlib-metadata-6.7.0:
Successfully uninstalled importlib-metadata-6.7.0
Attempting uninstall: async-timeout
Found existing installation: async-timeout 4.0.3
Uninstalling async-timeout-4.0.3:
Successfully uninstalled async-timeout-4.0.3
Attempting uninstall: aiosignal
Found existing installation: aiosignal 1.3.1
Uninstalling aiosignal-1.3.1:
Successfully uninstalled aiosignal-1.3.1
Attempting uninstall: attrs
Found existing installation: attrs 24.2.0
Uninstalling attrs-24.2.0:
Successfully uninstalled attrs-24.2.0
Attempting uninstall: aiohttp
Found existing installation: aiohttp 3.8.6
Uninstalling aiohttp-3.8.6:
Successfully uninstalled aiohttp-3.8.6
Successfully installed aiohttp-3.8.6 aiosignal-1.3.1 async-timeout-4.0.3 asynctest-0.13.0 attrs-24.2.0 charset-normalizer-3.3.2 frozenlist-1.3.3 idna-3.7 importlib-metadata-6.7.0 multidict-6.0.5 typing-extensions-4.7.1 yarl-1.9.4 zipp-3.15.0
+ echo 11
+ php /var/www/html/core/class/../php/jeecli.php plugin dependancy_end myaudi
+ echo 12
+ rm /tmp/jeedom_install_in_progress_myaudi
Log du démon:
[2024-08-19 23:51:11.610][INFO] : Start daemon
[2024-08-19 23:51:11.610][INFO] : Log level : debug
[2024-08-19 23:51:11.610][DEBUG] : Socket port : 55066
[2024-08-19 23:51:11.610][DEBUG] : PID file : /tmp/jeedom/myaudi/deamon.pid
[2024-08-19 23:51:11.610][DEBUG] : country : FR
[2024-08-19 23:51:11.610][DEBUG] : Writing PID 20520 to /tmp/jeedom/myaudi/deamon.pid
[2024-08-19 23:51:11.610][DEBUG] : Init request module v2.31.0
[2024-08-19 23:51:11.610][DEBUG] : Using selector: EpollSelector
[2024-08-19 23:51:12.371][DEBUG] : Encoding detection on empty bytes, assuming utf_8 intention.
[2024-08-19 23:51:12.437][DEBUG] : Encoding detection on empty bytes, assuming utf_8 intention.
[2024-08-19 23:51:12.531][DEBUG] : Encoding detection on empty bytes, assuming utf_8 intention.
[2024-08-19 23:51:12.637][DEBUG] : Encoding detection on empty bytes, assuming utf_8 intention.
[2024-08-19 23:51:13.170][ERROR] : Login to Audi service failed, trying again in 10 seconds
[2024-08-19 23:51:23.822][DEBUG] : Encoding detection on empty bytes, assuming utf_8 intention.
[2024-08-19 23:51:23.879][DEBUG] : Encoding detection on empty bytes, assuming utf_8 intention.
[2024-08-19 23:51:23.958][DEBUG] : Encoding detection on empty bytes, assuming utf_8 intention.
[2024-08-19 23:51:24.080][DEBUG] : Encoding detection on empty bytes, assuming utf_8 intention.
[2024-08-19 23:51:24.420][ERROR] : Login to Audi service failed, trying again in 10 seconds
[2024-08-19 23:51:35.015][DEBUG] : Encoding detection on empty bytes, assuming utf_8 intention.
[2024-08-19 23:51:35.078][DEBUG] : Encoding detection on empty bytes, assuming utf_8 intention.
[2024-08-19 23:51:35.166][DEBUG] : Encoding detection on empty bytes, assuming utf_8 intention.
[2024-08-19 23:51:35.299][DEBUG] : Encoding detection on empty bytes, assuming utf_8 intention.
[2024-08-19 23:51:35.645][ERROR] : Login to Audi service failed: 'client_id'
[2024-08-19 23:51:35.645][DEBUG] : End of Update
[2024-08-19 23:51:35.645][DEBUG] : Start listening
[2024-08-19 23:51:35.645][DEBUG] : Socket interface started
[2024-08-19 23:51:35.645][DEBUG] : LoopNetServer Thread started
[2024-08-19 23:51:35.645][DEBUG] : Listening on: [localhost:55066]
[2024-08-20 00:00:22.455][DEBUG] : Client connected to [127.0.0.1:56984]
[2024-08-20 00:00:22.455][DEBUG] : Message read from socket: b'{"method":"getVehicleData","vin":"wauzzzf42ra131222","apikey":"SdzbWNWjJ8Wp1Lb4Xwp4NWzno2xkTvAgtmPjHrrH88MtRhSaSilbjvYUDENjGgIW"}'
[2024-08-20 00:00:22.455][DEBUG] : Client disconnected from [127.0.0.1:56984]
[2024-08-20 00:00:22.465][DEBUG] : Message received in socket JEEDOM_SOCKET_MESSAGE
[2024-08-20 00:00:22.466][ERROR] : Unclosed client session
client_session: <aiohttp.client.ClientSession object at 0x7ffacf96e3c8>
[2024-08-20 00:00:22.466][ERROR] : Unclosed connector
connections: ['[(<aiohttp.client_proto.ResponseHandler object at 0x7ffacf9ca660>, 3846921.076820625)]', '[(<aiohttp.client_proto.ResponseHandler object at 0x7ffacef0ea08>, 3846921.938256116)]', '[(<aiohttp.client_proto.ResponseHandler object at 0x7ffacef0e5f8>, 3846922.255606208)]', '[(<aiohttp.client_proto.ResponseHandler object at 0x7ffacdee14c0>, 3846922.283898197)]']
connector: <aiohttp.connector.TCPConnector object at 0x7ffacf96e400>
[2024-08-20 00:00:23.369][DEBUG] : Encoding detection on empty bytes, assuming utf_8 intention.
[2024-08-20 00:00:23.425][DEBUG] : Encoding detection on empty bytes, assuming utf_8 intention.
[2024-08-20 00:00:23.506][DEBUG] : Encoding detection on empty bytes, assuming utf_8 intention.
[2024-08-20 00:00:23.641][DEBUG] : Encoding detection on empty bytes, assuming utf_8 intention.
[2024-08-20 00:00:25.690][ERROR] : Login to Audi service failed, trying again in 10 seconds
[2024-08-20 00:00:36.347][DEBUG] : Encoding detection on empty bytes, assuming utf_8 intention.
[2024-08-20 00:00:36.414][DEBUG] : Encoding detection on empty bytes, assuming utf_8 intention.
[2024-08-20 00:00:36.501][DEBUG] : Encoding detection on empty bytes, assuming utf_8 intention.
[2024-08-20 00:00:36.601][DEBUG] : Encoding detection on empty bytes, assuming utf_8 intention.
[2024-08-20 00:00:37.009][ERROR] : Login to Audi service failed, trying again in 10 seconds
[2024-08-20 00:00:47.650][DEBUG] : Encoding detection on empty bytes, assuming utf_8 intention.
[2024-08-20 00:00:47.706][DEBUG] : Encoding detection on empty bytes, assuming utf_8 intention.
[2024-08-20 00:00:47.785][DEBUG] : Encoding detection on empty bytes, assuming utf_8 intention.
[2024-08-20 00:00:47.888][DEBUG] : Encoding detection on empty bytes, assuming utf_8 intention.
[2024-08-20 00:00:48.210][ERROR] : Login to Audi service failed: 'client_id'
[2024-08-20 00:00:48.210][DEBUG] : End of Update
[2024-08-20 00:00:48.848][DEBUG] : Encoding detection on empty bytes, assuming utf_8 intention.
[2024-08-20 00:00:48.906][DEBUG] : Encoding detection on empty bytes, assuming utf_8 intention.
[2024-08-20 00:00:48.974][DEBUG] : Encoding detection on empty bytes, assuming utf_8 intention.
[2024-08-20 00:00:49.088][DEBUG] : Encoding detection on empty bytes, assuming utf_8 intention.
[2024-08-20 00:00:49.408][ERROR] : Login to Audi service failed, trying again in 10 seconds
[2024-08-20 00:01:00.200][DEBUG] : Encoding detection on empty bytes, assuming utf_8 intention.
[2024-08-20 00:01:00.259][DEBUG] : Encoding detection on empty bytes, assuming utf_8 intention.
[2024-08-20 00:01:00.334][DEBUG] : Encoding detection on empty bytes, assuming utf_8 intention.
[2024-08-20 00:01:00.476][DEBUG] : Encoding detection on empty bytes, assuming utf_8 intention.
[2024-08-20 00:01:03.120][ERROR] : Login to Audi service failed, trying again in 10 seconds
[2024-08-20 00:01:13.756][DEBUG] : Encoding detection on empty bytes, assuming utf_8 intention.
[2024-08-20 00:01:13.815][DEBUG] : Encoding detection on empty bytes, assuming utf_8 intention.
[2024-08-20 00:01:13.898][DEBUG] : Encoding detection on empty bytes, assuming utf_8 intention.
[2024-08-20 00:01:14.020][DEBUG] : Encoding detection on empty bytes, assuming utf_8 intention.
[2024-08-20 00:01:14.534][ERROR] : Login to Audi service failed: 'client_id'
[2024-08-20 00:01:45.318][DEBUG] : Encoding detection on empty bytes, assuming utf_8 intention.
[2024-08-20 00:01:45.378][DEBUG] : Encoding detection on empty bytes, assuming utf_8 intention.
[2024-08-20 00:01:45.458][DEBUG] : Encoding detection on empty bytes, assuming utf_8 intention.
[2024-08-20 00:01:45.579][DEBUG] : Encoding detection on empty bytes, assuming utf_8 intention.
[2024-08-20 00:01:46.002][ERROR] : Login to Audi service failed, trying again in 10 seconds
[2024-08-20 00:01:56.599][DEBUG] : Encoding detection on empty bytes, assuming utf_8 intention.
[2024-08-20 00:01:56.659][DEBUG] : Encoding detection on empty bytes, assuming utf_8 intention.
[2024-08-20 00:01:56.744][DEBUG] : Encoding detection on empty bytes, assuming utf_8 intention.
[2024-08-20 00:01:56.864][DEBUG] : Encoding detection on empty bytes, assuming utf_8 intention.
[2024-08-20 00:01:59.439][ERROR] : Login to Audi service failed, trying again in 10 seconds
[2024-08-20 00:02:10.112][DEBUG] : Encoding detection on empty bytes, assuming utf_8 intention.
[2024-08-20 00:02:10.185][DEBUG] : Encoding detection on empty bytes, assuming utf_8 intention.
[2024-08-20 00:02:10.262][DEBUG] : Encoding detection on empty bytes, assuming utf_8 intention.
[2024-08-20 00:02:10.373][DEBUG] : Encoding detection on empty bytes, assuming utf_8 intention.
[2024-08-20 00:02:10.722][ERROR] : Login to Audi service failed: 'client_id'
[2024-08-20 00:15:21.361][DEBUG] : Client connected to [127.0.0.1:40516]
[2024-08-20 00:15:21.361][DEBUG] : Message read from socket: b'{"method":"getVehicleData","vin":"wauzzzf42ra131222","apikey":"SdzbWNWjJ8Wp1Lb4Xwp4NWzno2xkTvAgtmPjHrrH88MtRhSaSilbjvYUDENjGgIW"}'
[2024-08-20 00:15:21.361][DEBUG] : Client disconnected from [127.0.0.1:40516]
[2024-08-20 00:15:21.366][DEBUG] : Message received in socket JEEDOM_SOCKET_MESSAGE
[2024-08-20 00:15:21.366][ERROR] : Unclosed client session
client_session: <aiohttp.client.ClientSession object at 0x7ffacdeda710>
[2024-08-20 00:15:21.367][ERROR] : Unclosed connector
connections: ['[(<aiohttp.client_proto.ResponseHandler object at 0x7ffacef0e048>, 3847556.099545963)]', '[(<aiohttp.client_proto.ResponseHandler object at 0x7ffacdee14c0>, 3847557.012015541)]', '[(<aiohttp.client_proto.ResponseHandler object at 0x7ffacf9cac10>, 3847557.330955984)]', '[(<aiohttp.client_proto.ResponseHandler object at 0x7ffacdee1d48>, 3847557.361345948)]']
connector: <aiohttp.connector.TCPConnector object at 0x7ffacdeda0f0>
[2024-08-20 00:15:22.231][DEBUG] : Encoding detection on empty bytes, assuming utf_8 intention.
[2024-08-20 00:15:22.282][DEBUG] : Encoding detection on empty bytes, assuming utf_8 intention.
[2024-08-20 00:15:22.373][DEBUG] : Encoding detection on empty bytes, assuming utf_8 intention.
[2024-08-20 00:15:22.483][DEBUG] : Encoding detection on empty bytes, assuming utf_8 intention.
[2024-08-20 00:15:22.968][ERROR] : Login to Audi service failed, trying again in 10 seconds
[2024-08-20 00:15:33.630][DEBUG] : Encoding detection on empty bytes, assuming utf_8 intention.
[2024-08-20 00:15:33.712][DEBUG] : Encoding detection on empty bytes, assuming utf_8 intention.
[2024-08-20 00:15:33.786][DEBUG] : Encoding detection on empty bytes, assuming utf_8 intention.
[2024-08-20 00:15:33.922][DEBUG] : Encoding detection on empty bytes, assuming utf_8 intention.
[2024-08-20 00:15:34.276][ERROR] : Login to Audi service failed, trying again in 10 seconds
[2024-08-20 00:15:44.931][DEBUG] : Encoding detection on empty bytes, assuming utf_8 intention.
[2024-08-20 00:15:44.994][DEBUG] : Encoding detection on empty bytes, assuming utf_8 intention.
[2024-08-20 00:15:45.071][DEBUG] : Encoding detection on empty bytes, assuming utf_8 intention.
[2024-08-20 00:15:45.182][DEBUG] : Encoding detection on empty bytes, assuming utf_8 intention.
[2024-08-20 00:15:45.483][ERROR] : Login to Audi service failed: 'client_id'
[2024-08-20 00:15:45.484][DEBUG] : End of Update
[2024-08-20 00:15:46.123][DEBUG] : Encoding detection on empty bytes, assuming utf_8 intention.
[2024-08-20 00:15:46.190][DEBUG] : Encoding detection on empty bytes, assuming utf_8 intention.
[2024-08-20 00:15:46.280][DEBUG] : Encoding detection on empty bytes, assuming utf_8 intention.
[2024-08-20 00:15:46.408][DEBUG] : Encoding detection on empty bytes, assuming utf_8 intention.
[2024-08-20 00:15:46.714][ERROR] : Login to Audi service failed, trying again in 10 seconds
[2024-08-20 00:15:57.305][DEBUG] : Encoding detection on empty bytes, assuming utf_8 intention.
[2024-08-20 00:15:57.370][DEBUG] : Encoding detection on empty bytes, assuming utf_8 intention.
[2024-08-20 00:15:57.455][DEBUG] : Encoding detection on empty bytes, assuming utf_8 intention.
[2024-08-20 00:15:57.580][DEBUG] : Encoding detection on empty bytes, assuming utf_8 intention.
[2024-08-20 00:15:57.914][ERROR] : Login to Audi service failed, trying again in 10 seconds
[2024-08-20 00:16:08.492][DEBUG] : Encoding detection on empty bytes, assuming utf_8 intention.
[2024-08-20 00:16:08.559][DEBUG] : Encoding detection on empty bytes, assuming utf_8 intention.
[2024-08-20 00:16:08.634][DEBUG] : Encoding detection on empty bytes, assuming utf_8 intention.
[2024-08-20 00:16:08.741][DEBUG] : Encoding detection on empty bytes, assuming utf_8 intention.
[2024-08-20 00:16:09.064][ERROR] : Login to Audi service failed: 'client_id'
[2024-08-20 00:16:39.881][DEBUG] : Encoding detection on empty bytes, assuming utf_8 intention.
[2024-08-20 00:16:39.938][DEBUG] : Encoding detection on empty bytes, assuming utf_8 intention.
[2024-08-20 00:16:40.010][DEBUG] : Encoding detection on empty bytes, assuming utf_8 intention.
[2024-08-20 00:16:40.150][DEBUG] : Encoding detection on empty bytes, assuming utf_8 intention.
[2024-08-20 00:16:40.639][ERROR] : Login to Audi service failed, trying again in 10 seconds
[2024-08-20 00:16:51.262][DEBUG] : Encoding detection on empty bytes, assuming utf_8 intention.
[2024-08-20 00:16:51.327][DEBUG] : Encoding detection on empty bytes, assuming utf_8 intention.
[2024-08-20 00:16:51.409][DEBUG] : Encoding detection on empty bytes, assuming utf_8 intention.
[2024-08-20 00:16:51.532][DEBUG] : Encoding detection on empty bytes, assuming utf_8 intention.
[2024-08-20 00:16:51.872][ERROR] : Login to Audi service failed, trying again in 10 seconds
[2024-08-20 00:17:02.572][DEBUG] : Encoding detection on empty bytes, assuming utf_8 intention.
[2024-08-20 00:17:02.637][DEBUG] : Encoding detection on empty bytes, assuming utf_8 intention.
[2024-08-20 00:17:02.729][DEBUG] : Encoding detection on empty bytes, assuming utf_8 intention.
[2024-08-20 00:17:02.848][DEBUG] : Encoding detection on empty bytes, assuming utf_8 intention.
[2024-08-20 00:17:03.259][ERROR] : Login to Audi service failed: 'client_id'
Log du plugin:
[2024-08-19 19:30:24][DEBUG] : params to send to daemon:{"method":"getVehicleData","vin":"wauzzzf42ra131222"}
[2024-08-19 19:45:24][DEBUG] : params to send to daemon:{"method":"getVehicleData","vin":"wauzzzf42ra131222"}
[2024-08-19 20:00:21][DEBUG] : params to send to daemon:{"method":"getVehicleData","vin":"wauzzzf42ra131222"}
[2024-08-19 20:15:22][DEBUG] : params to send to daemon:{"method":"getVehicleData","vin":"wauzzzf42ra131222"}
[2024-08-19 20:30:21][DEBUG] : params to send to daemon:{"method":"getVehicleData","vin":"wauzzzf42ra131222"}
[2024-08-19 20:45:21][DEBUG] : params to send to daemon:{"method":"getVehicleData","vin":"wauzzzf42ra131222"}
[2024-08-19 21:00:22][DEBUG] : params to send to daemon:{"method":"getVehicleData","vin":"wauzzzf42ra131222"}
[2024-08-19 21:15:21][DEBUG] : params to send to daemon:{"method":"getVehicleData","vin":"wauzzzf42ra131222"}
[2024-08-19 21:30:21][DEBUG] : params to send to daemon:{"method":"getVehicleData","vin":"wauzzzf42ra131222"}
[2024-08-19 21:45:21][DEBUG] : params to send to daemon:{"method":"getVehicleData","vin":"wauzzzf42ra131222"}
[2024-08-19 22:00:21][DEBUG] : params to send to daemon:{"method":"getVehicleData","vin":"wauzzzf42ra131222"}
[2024-08-19 22:15:21][DEBUG] : params to send to daemon:{"method":"getVehicleData","vin":"wauzzzf42ra131222"}
[2024-08-19 22:30:21][DEBUG] : params to send to daemon:{"method":"getVehicleData","vin":"wauzzzf42ra131222"}
[2024-08-19 22:45:30][DEBUG] : Lancement de : /var/www/html/core/class/../../core/php/jeePlugin.php plugin_id=myaudi function=pre_update callInstallFunction=1
[2024-08-19 22:45:30][INFO] : Début d'activation du plugin
[2024-08-19 22:45:32][INFO] : Info sur le démon : {"log":"myaudi","state":"nok","launchable":"nok","launchable_message":"Les crons et d\u00e9mons sont d\u00e9sactiv\u00e9s","auto":"0","last_launch":"2024-08-10 01:14:01"}
[2024-08-19 22:45:32][DEBUG] : Lancement de : /var/www/html/core/class/../../core/php/jeePlugin.php plugin_id=myaudi function=update callInstallFunction=1
[2024-08-19 22:46:24][INFO] : Lancement démon MyAudi
[2024-08-19 22:46:27][INFO] : Lancement démon MyAudi
[2024-08-19 22:46:38][DEBUG] : params to send to daemon:{"method":"getVehicles"}
[2024-08-19 22:48:56][INFO] : Lancement démon MyAudi
[2024-08-19 22:57:19][INFO] : Lancement démon MyAudi
[2024-08-19 22:57:34][DEBUG] : LOCK_STATE_VEHICLE: 1
[2024-08-19 22:57:34][DEBUG] : OPEN_STATE_VEHICLE: 1
[2024-08-19 22:57:52][INFO] : Lancement démon MyAudi
[2024-08-19 22:59:17][INFO] : Lancement démon MyAudi
[2024-08-19 23:00:13][INFO] : Lancement démon MyAudi
[2024-08-19 23:00:21][DEBUG] : params to send to daemon:{"method":"getVehicleData","vin":"wauzzzf42ra131222"}
[2024-08-19 23:00:40][DEBUG] : params to send to daemon:{"method":"getVehicles"}
[2024-08-19 23:03:51][INFO] : Lancement démon MyAudi
[2024-08-19 23:08:34][INFO] : Lancement démon MyAudi
[2024-08-19 23:11:00][INFO] : Lancement démon MyAudi
[2024-08-19 23:15:21][DEBUG] : params to send to daemon:{"method":"getVehicleData","vin":"wauzzzf42ra131222"}
[2024-08-19 23:18:16][INFO] : Lancement démon MyAudi
[2024-08-19 23:20:33][DEBUG] : params to send to daemon:{"method":"getVehicles"}
[2024-08-19 23:21:38][INFO] : Lancement démon MyAudi
[2024-08-19 23:28:43][INFO] : Lancement démon MyAudi
[2024-08-19 23:29:13][INFO] : Lancement démon MyAudi
[2024-08-19 23:30:21][DEBUG] : params to send to daemon:{"method":"getVehicleData","vin":"wauzzzf42ra131222"}
[2024-08-19 23:45:21][DEBUG] : params to send to daemon:{"method":"getVehicleData","vin":"wauzzzf42ra131222"}
[2024-08-19 23:48:02][INFO] : Lancement démon MyAudi
[2024-08-19 23:49:16][DEBUG] : Lancement de : /var/www/html/core/class/../../core/php/jeePlugin.php plugin_id=myaudi function=pre_update callInstallFunction=1
[2024-08-19 23:49:16][INFO] : Début d'activation du plugin
[2024-08-19 23:49:18][INFO] : Info sur le démon : {"log":"myaudi","state":"nok","launchable":"ok","launchable_message":"Gestion automatique d\u00e9sactiv\u00e9e","auto":"0","last_launch":"2024-08-19 23:48:01"}
[2024-08-19 23:49:18][DEBUG] : Lancement de : /var/www/html/core/class/../../core/php/jeePlugin.php plugin_id=myaudi function=update callInstallFunction=1
[2024-08-19 23:50:25][INFO] : Lancement démon MyAudi
[2024-08-19 23:50:53][DEBUG] : Lancement de : /var/www/html/core/class/../../core/php/jeePlugin.php plugin_id=myaudi function=pre_update callInstallFunction=1
[2024-08-19 23:50:53][INFO] : Début d'activation du plugin
[2024-08-19 23:50:55][INFO] : Info sur le démon : {"log":"myaudi","state":"nok","launchable":"ok","launchable_message":"Gestion automatique d\u00e9sactiv\u00e9e","auto":"0","last_launch":"2024-08-19 23:50:24"}
[2024-08-19 23:50:55][DEBUG] : Lancement de : /var/www/html/core/class/../../core/php/jeePlugin.php plugin_id=myaudi function=update callInstallFunction=1
[2024-08-19 23:51:11][INFO] : Lancement démon MyAudi
[2024-08-20 00:00:22][DEBUG] : params to send to daemon:{"method":"getVehicleData","vin":"wauzzzf42ra131222"}
[2024-08-20 00:15:21][DEBUG] : params to send to daemon:{"method":"getVehicleData","vin":"wauzzzf42ra131222"}
