Problème Plugin/serveur NUT
J’ai installé le plugin Nut pour la supervision de mon UPS MGE Ellipse Max 600.
J’ai créer le serveur Nut, sauf que lorsqu’il est connecté, l’onduleur fini par s’éteindre dans les 12h.
Mon fichier /etc/nut/upsmon.conf est comme suit:
MONITOR myups@localhost 1 ******** ******** "master"
MINSUPPLIES 1
FINALDELAY 5
SHUTDOWNCMD "/sbin/shutdown -h +0"
POLLFREQ 5
POLLFREQALERT 5
HOSTSYNC 15
DEADTIME 15
POWERDOWNFLAG /etc/killpower
NOTIFYMSG ONLINE        "UPS %s on line power"
NOTIFYMSG ONBATT        "UPS %s on battery"
NOTIFYMSG LOWBATT       "UPS %s battery is low"
NOTIFYMSG FSD           "UPS %s: forced shutdown in progress"
NOTIFYMSG COMMOK        "Communications with UPS %s established"
NOTIFYMSG COMMBAD       "Communications with UPS %s lost"
NOTIFYMSG SHUTDOWN      "Auto logout and shutdown proceeding"
NOTIFYMSG REPLBATT      "UPS %s battery needs to be replaced"
NOTIFYMSG NOCOMM        "UPS %s is unavailable"
NOTIFYMSG NOPARENT      "upsmon parent process died - shutdown impossible"
NOTIFYFLAG ONLINE       SYSLOG+WALL
NOTIFYFLAG ONBATT       SYSLOG+WALL
NOTIFYFLAG LOWBATT      SYSLOG+WALL
NOTIFYFLAG FSD          SYSLOG+WALL
NOTIFYFLAG COMMOK       SYSLOG+WALL
NOTIFYFLAG COMMBAD      SYSLOG+WALL
NOTIFYFLAG SHUTDOWN     SYSLOG+WALL
RBWARNTIME 43200
NOCOMMWARNTIME 300
FINALDELAY 5
Je ne sais pas ce qui provoque cette coupure de l’ondulé.
Si je déconnecte le port com, il ne se coupe pas.
Une idée?
Voici ce qu’il apparait dans le fichier syslog
Oct 10 10:38:51 jeedom-pc kernel: [103514.607878] usb 1-3: new low-speed USB device number 11 using xhci_hcd
Oct 10 10:38:53 jeedom-pc kernel: [103515.918119] usb 1-3: New USB device found, idVendor=0463, idProduct=ffff, bcdDevice=42.41
Oct 10 10:38:53 jeedom-pc kernel: [103515.918128] usb 1-3: New USB device strings: Mfr=1, Product=2, SerialNumber=4
Oct 10 10:38:53 jeedom-pc kernel: [103515.918133] usb 1-3: Product: Ellipse MAX
Oct 10 10:38:53 jeedom-pc kernel: [103515.918137] usb 1-3: Manufacturer: MGE UPS SYSTEMS
Oct 10 10:38:53 jeedom-pc kernel: [103515.918141] usb 1-3: SerialNumber: PbAc
Oct 10 10:38:53 jeedom-pc mtp-probe: checking bus 1, device 11: "/sys/devices/pci0000:00/0000:00:15.0/usb1/1-3"
Oct 10 10:38:53 jeedom-pc mtp-probe: bus: 1, device: 11 was not an MTP device
Oct 10 10:38:53 jeedom-pc kernel: [103515.951350] hidraw: raw HID events driver (C) Jiri Kosina
Oct 10 10:38:53 jeedom-pc kernel: [103516.152062] usbcore: registered new interface driver usbhid
Oct 10 10:38:53 jeedom-pc kernel: [103516.152066] usbhid: USB HID core driver
Oct 10 10:38:53 jeedom-pc kernel: [103516.169842] hid-generic 0003:0463:FFFF.0001: hiddev0,hidraw0: USB HID v1.10 Device [MGE UPS SYSTEMS Ellipse MA$
Oct 10 10:38:56 jeedom-pc upsmon[608]: Poll UPS [myups@localhost] failed - Driver not connected
Oct 10 10:39:01 jeedom-pc CRON[28485]: (root) CMD (  [ -x /usr/lib/php/sessionclean ] && if [ ! -d /run/systemd/system ]; then /usr/lib/php/sessionc$
Oct 10 10:39:01 jeedom-pc CRON[28486]: (www-data) CMD (/usr/bin/php /var/www/html/core/php/jeeCron.php >> /dev/null)
Oct 10 10:39:01 jeedom-pc systemd[1]: Starting Clean php session files...
Oct 10 10:39:01 jeedom-pc upsmon[608]: Poll UPS [myups@localhost] failed - Driver not connected
Oct 10 10:39:01 jeedom-pc systemd[1]: phpsessionclean.service: Succeeded.
J’ai repris de 0 et suivi un autre tuto pour le serveur, toujours une commande de shutdown de l’onduleur.
résolu, erreur nom de fichier upssched.conf
