Bonjour je tente d’integré ma gateway moes zigbee " model ethernet " j’ai bien l’ip et le jeton la dessu pas de souci , mais quand je l’integre j’ai un retour d’etat sur la commande connecté de -1
du coup je ne vois vraiment pas ou sa coince
voici le log debug
[2021-03-28 15:53:00][DEBUG] : Receive from:192.168.1.79
[2021-03-28 15:53:00][DEBUG] : gateway @192.168.1.79
[2021-03-28 15:53:00][DEBUG] : Update devices @192.168.1.79 canal:1
[2021-03-28 15:53:00][DEBUG] : Update devices @192.168.1.79 canal:2
[2021-03-28 15:53:13][DEBUG] : << Update state of: gateway @192.168.1.79
[2021-03-28 15:53:13][DEBUG] : << Update state of: pir 1 @192.168.1.79
[2021-03-28 15:53:13][DEBUG] : Cmd to 192.168.1.79: {"gwId":"bf75cd62892f269f39zfja","cid":"bf75cd62892f269f39zfja"} - Try:192.168.1.79 6668 - Connect OK!
[2021-03-28 15:53:13][DEBUG] : Receive from:192.168.1.79
[2021-03-28 15:53:27][DEBUG] : ** gateway - TuyaCustom2_Hub_V2 @192.168.1.79 - c:1 **
[2021-03-28 15:53:27][DEBUG] : key:0 @192.168.1.79 c:1 d:14
[2021-03-28 15:53:28][DEBUG] : ** pir 1 - TuyaCustom2_V2 @192.168.1.79 - c:2 **
[2021-03-28 15:53:28][DEBUG] : key:0 @192.168.1.79 c:2 d:15
[2021-03-28 15:53:34][DEBUG] : << Update state of: gateway @192.168.1.79
[2021-03-28 15:53:34][DEBUG] : << Update state of: pir 1 @192.168.1.79
[2021-03-28 15:53:34][DEBUG] : Cmd to 192.168.1.79: {"gwId":"bf75cd62892f269f39zfja","cid":"bf75cd62892f269f39zfja"} - Try:192.168.1.79 6668 - Connect OK!
[2021-03-28 15:53:34][DEBUG] : Receive from:192.168.1.79
[2021-03-28 15:53:40][DEBUG] : Receive from:192.168.1.79
[2021-03-28 15:53:40][DEBUG] : gateway @192.168.1.79
[2021-03-28 15:53:40][DEBUG] : Update devices @192.168.1.79 canal:1
[2021-03-28 15:53:40][DEBUG] : Update devices @192.168.1.79 canal:2
[2021-03-28 15:53:55][DEBUG] : << Update state of: gateway @192.168.1.79
[2021-03-28 15:53:55][DEBUG] : << Update state of: pir 1 @192.168.1.79
[2021-03-28 15:53:55][DEBUG] : Cmd to 192.168.1.79: {"gwId":"bf75cd62892f269f39zfja","cid":"bf75cd62892f269f39zfja"} - Try:192.168.1.79 6668 - Connect OK!
[2021-03-28 15:53:55][DEBUG] : Receive from:192.168.1.79
