Problème intégration clé 3G 51078203 Huawei
Bonjour. Débutant sur jeedom Smart, je tourne en rond sur la mise en service du pluging SMS. J’ai lancé 2 interrogations sudo pour tenter de repérer le port d’installation de ma clé 3G Huawei (ci-joint les résultats). Il me semblait l’avoir lu comme clé compatible, mais pour l’instant le Demon reste sur statut NOK d’ou le doute qui s’installe.
Si vous avez un peu de temps pour me communiquer votre retour d’expérience… Merci
sudo lsusb
Bus 001 Device 007: ID 0658:0200 Sigma Designs, Inc.
Bus 001 Device 013: ID 12d1:1442 Huawei Technologies Co., Ltd.
Bus 001 Device 002: ID 05e3:0610 Genesys Logic, Inc. 4-port hub
Bus 001 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
Bus 002 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
sudo dmesg | grep USB
[ 0.570216] ehci_hcd: USB 2.0 ‹ Enhanced › Host Controller (EHCI) Driver
[ 0.570307] ohci_hcd: USB 1.1 ‹ Open › Host Controller (OHCI) Driver
[ 0.570379] cdc_acm: USB Abstract Control Model driver for USB modems and ISDN adapters
[ 0.570572] usbserial: USB Serial support registered for generic
[ 0.571776] usbhid: USB HID core driver
[ 2.415902] dwc_otg dwc2_b: new USB bus registered, assigned bus number 1
[ 2.441157] hub 1-0:1.0: USB hub found
[ 2.499800] dwc_otg dwc2_a: new USB bus registered, assigned bus number 2
[ 2.511861] hub 2-0:1.0: USB hub found
[ 2.842822] usb 1-1: new high-speed USB device number 2 using dwc_otg
[ 3.084556] hub 1-1:1.0: USB hub found
[ 3.363068] usb 1-1.4: new full-speed USB device number 3 using dwc_otg
[ 3.823055] usb 1-1.4: new full-speed USB device number 4 using dwc_otg
[ 4.283228] usb 1-1.4: new full-speed USB device number 5 using dwc_otg
[ 4.963112] usb 1-1.4: new full-speed USB device number 7 using dwc_otg
[ 5.072230] cdc_acm 1-1.4:1.0: ttyACM0: USB ACM device
[ 7.613073] usb 1-1.2: new high-speed USB device number 8 using dwc_otg
[ 7.771918] usb-storage 1-1.2:1.0: USB Mass Storage device detected
[ 19.672461] usb 1-1.2: USB disconnect, device number 8
[ 20.933123] usb 1-1.2: new high-speed USB device number 9 using dwc_otg
[ 4239.933692] usb 1-1.2: USB disconnect, device number 9
[ 4247.336122] usb 1-1.3: new high-speed USB device number 10 using dwc_otg
[ 4247.490445] usb-storage 1-1.3:1.0: USB Mass Storage device detected
[ 4247.871680] usb 1-1.3: USB disconnect, device number 10
[ 4248.876023] usb 1-1.3: new high-speed USB device number 11 using dwc_otg
[16342.744112] usb 1-1.3: USB disconnect, device number 11
[52941.028016] usb 1-1.3: new high-speed USB device number 12 using dwc_otg
[52941.176499] usb-storage 1-1.3:1.0: USB Mass Storage device detected
[52941.557197] usb 1-1.3: USB disconnect, device number 12
[52942.558048] usb 1-1.3: new high-speed USB device number 13 using dwc_otg
J’ai avancé là aussi. Utilisé DC Unlocker pour trouver le port COM mais avec le firmware Hilink 22.318 27 00 801 pas de port COM, le dongle est détecté pour une partie en carte réseau NDIS et d’autre un stochage usb, il me faut apparemment modifier le firmware vers une version Stick 21…
