Bonjour a tous,
une nouvelle fois j’ai besoin de vos lumières.
J’ai acheté un odroid c2 avec un DD eMMC. J’essai d’installer jeedom avec le très bon tutto de @akenad mais l’installation bloque lorsque j’installe jeedom a l’étape 3 :
étape 2 paquet principal réussie
Commence l'étape 3 base de données
Reading package lists... Done
Building dependency tree
Reading state information... Done
The following additional packages will be installed:
galera-3 gawk libaio1 libconfig-inifiles-perl libdbi-perl libreadline5
libsnappy1v5 mariadb-client-10.3 mariadb-client-core-10.3
mariadb-server-10.3 mariadb-server-core-10.3 mysql-common socat
Suggested packages:
gawk-doc libclone-perl libmldbm-perl libnet-daemon-perl
libsql-statement-perl mailx mariadb-test tinyca
Recommended packages:
libdbd-mysql-perl libterm-readkey-perl libhtml-template-perl
libsnappy1v5 mariadb-client mariadb-client-10.3 mariadb-client-core-10.3
mariadb-common mariadb-server mariadb-server-10.3 mariadb-server-core-10.3
mysql-common socat
0 upgraded, 16 newly installed, 0 to remove and 27 not upgraded.
Need to get 16.8 MB/18.7 MB of archives.
After this operation, 163 MB of additional disk space will be used.
Ign:1 http://httpredir.debian.org/debian buster/main arm64 mariadb-common all 1: 10.3.18-0+deb10u1
Err:2 http://httpredir.debian.org/debian buster/main arm64 libdbi-perl arm64 1.6 42-1+b1
404 Not Found [IP: 2a04:4e4*****4 80]
Err:3 http://httpredir.debian.org/debian buster/main arm64 mariadb-client-core-1 0.3 arm64 1:10.3.18-0+deb10u1
404 Not Found [IP: 2a04:4e*****44 80]
Err:4 http://httpredir.debian.org/debian buster/main arm64 mariadb-client-10.3 a rm64 1:10.3.18-0+deb10u1
404 Not Found [IP: 2a04:4*****644 80]
Err:5 http://httpredir.debian.org/debian buster/main arm64 mariadb-server-core-1 0.3 arm64 1:10.3.18-0+deb10u1
Err:6 http://httpredir.debian.org/debian buster/main arm64 mariadb-server-10.3 a rm64 1:10.3.18-0+deb10u1
404 Not Found [IP: 2a04:4e******44 80]
Ign:7 http://httpredir.debian.org/debian buster/main arm64 mariadb-client all 1: 10.3.18-0+deb10u1
Ign:8 http://httpredir.debian.org/debian buster/main arm64 mariadb-server all 1: 10.3.18-0+deb10u1
Err:1 http://httpredir.debian.org/debian buster/main arm64 mariadb-common all 1: 10.3.18-0+deb10u1
404 Not Found [IP: 2a04:4e******644 80]
Err:7 http://httpredir.debian.org/debian buster/main arm64 mariadb-client all 1: 10.3.18-0+deb10u1
J’espère qu’l n’y a pas d info sur ma vie dans ce log
