je suis sous VM Freebox Delta et clé Conbee II
J’essaie d’installer ZigbeeLinker pour essayer de faire fonctionner des émetteurs Trio2sys mais l’installation des dépendances s’arrête à 50% sans que mes compétences me permettent de comprendre pourquoi.
Quelqu’un aurait-il une idée ?
voici le log :
checking if zts is enabled... no
checking for re2c... no
configure: WARNING: You will need re2c 0.13.4 or later if you want to regenerate PHP parsers.
checking for gawk... gawk
checking for mosquitto support... yes, shared
checking for mosquitto files in default path... not found
configure: error: Please reinstall the mosquitto distribution
ERROR: `/tmp/pear/temp/Mosquitto/configure --with-php-config=/usr/bin/php-config --with-mosquitto' failed
##### Try installing client : Second method (complile)
Reading package lists...
Building dependency tree...
Reading state information...
build-essential is already the newest version (12.6).
0 upgraded, 0 newly installed, 0 to remove and 15 not upgraded.
1 not fully installed or removed.
Need to get 0 B/2194 kB of archives.
After this operation, 0 B of additional disk space will be used.
dpkg: error processing package dpkg (--configure):
package dpkg is not ready for configuration
cannot configure (current status 'half-installed')
Errors were encountered while processing:
dpkg
E: Sub-process /usr/bin/dpkg returned an error code (1)
Cloning into 'Mosquitto-PHP'...
Configuring for:
PHP Api Version: 20180731
Zend Module Api No: 20180731
Zend Extension Api No: 320180731
checking for grep that handles long lines and -e... /usr/bin/grep
checking for egrep... /usr/bin/grep -E
checking for a sed that does not truncate output... /usr/bin/sed
checking for cc... cc
checking whether the C compiler works... yes
checking for C compiler default output file name... a.out
checking for suffix of executables...
checking whether we are cross compiling... no
checking for suffix of object files... o
checking whether we are using the GNU C compiler... yes
checking whether cc accepts -g... yes
checking for cc option to accept ISO C89... none needed
checking how to run the C preprocessor... cc -E
checking for icc... no
checking for suncc... no
checking whether cc understands -c and -o together... yes
checking for system library directory... lib
checking if compiler supports -R... no
checking if compiler supports -Wl,-rpath,... yes
checking build system type... aarch64-unknown-linux-gnu
checking host system type... aarch64-unknown-linux-gnu
checking target system type... aarch64-unknown-linux-gnu
checking for PHP prefix... /usr
checking for PHP includes... -I/usr/include/php/20180731 -I/usr/include/php/20180731/main -I/usr/include/php/20180731/TSRM -I/usr/include/php/20180731/Zend -I/usr/include/php/20180731/ext -I/usr/include/php/20180731/ext/date/lib
checking for PHP extension directory... /usr/lib/php/20180731
checking for PHP installed headers prefix... /usr/include/php/20180731
checking if debug is enabled... no
make: *** No targets specified and no makefile found. Stop.
make: *** No rule to make target 'install'. Stop.
ERROR mosquitto.so file missing !
