Probleme installation clé combee
Hello
Je tente d’installer ma clé Combee sur ma mini + (V4.0.40 Strech) et lors de l’installation de Deconz (en local) j’ai des erreurs dans la log, et ma clé n’est pas vu. Elle est bien détectée si je la met sur un poste en Windows.
La log :
*             Installation deconz                      *
Hit:1 http://security.debian.org stretch/updates InRelease
Ign:2 http://httpredir.debian.org/debian stretch InRelease
Get:3 http://httpredir.debian.org/debian stretch-updates InRelease [91.0 kB]
Hit:4 http://httpredir.debian.org/debian stretch Release
Ign:5 https://repo.solid-build.xyz/debian/stretch/bsp-imx6 ./ InRelease
Get:7 https://repo.solid-build.xyz/debian/stretch/bsp-imx6 ./ Release.gpg [481 B]
Err:7 https://repo.solid-build.xyz/debian/stretch/bsp-imx6 ./ Release.gpg
  The following signatures were invalid: EXPKEYSIG A86C36D7E45C02CD BSP:IMX6 OBS Project <BSP:IMX6@mxobs>
Fetched 91.5 kB in 3s (23.8 kB/s)
Reading package lists...
W: An error occurred during the signature verification. The repository is not updated and the previous index files will be used. GPG error: https://repo.solid-build.xyz/debian/stretch/bsp-imx6 ./ Release: The following signatures were invalid: EXPKEYSIG A86C36D7E45C02CD BSP:IMX6 OBS Project <BSP:IMX6@mxobs>
W: Failed to fetch https://repo.solid-build.xyz/debian/stretch/bsp-imx6/./Release.gpg  The following signatures were invalid: EXPKEYSIG A86C36D7E45C02CD BSP:IMX6 OBS Project <BSP:IMX6@mxobs>
W: Some index files failed to download. They have been ignored, or old ones used instead.
Building dependency tree...
Reading state information...
libqt5serialport5 is already the newest version (5.7.1~20161021-2).
libqt5websockets5 is already the newest version (5.7.1~20161021-4).
0 upgraded, 0 newly installed, 0 to remove and 138 not upgraded.
It's armv7l, RPI
--2020-02-17 09:21:34--  https://images.jeedom.com/resources/deconz/rpi/deconz.deb
Resolving images.jeedom.com (images.jeedom.com)... 213.32.73.75
Connecting to images.jeedom.com (images.jeedom.com)|213.32.73.75|:443... connected.
HTTP request sent, awaiting response... 200 OK
Length: 5115196 (4.9M) [application/x-debian-package]
Saving to: '/tmp/deconz.deb'
     0K .......... .......... .......... .......... ..........  1%  937K 5s
    50K .......... .......... .......... .......... ..........  2% 2.00M 4s
   100K .......... .......... .......... .......... ..........  3% 1.99M 3s
   150K .......... .......... .......... .......... ..........  4% 2.05M 3s
   200K .......... .......... .......... .......... ..........  5% 1.97M 3s
   250K .......... .......... .......... .......... ..........  6% 2.01M 3s
   300K .......... .......... .......... .......... ..........  7% 1.89M 3s
   350K .......... .......... .......... .......... ..........  8% 1.98M 3s
   400K .......... .......... .......... .......... ..........  9% 1.56M 3s
   450K .......... .......... .......... .......... .......... 10% 2.00M 3s
   500K .......... .......... .......... .......... .......... 11% 2.01M 2s
   550K .......... .......... .......... .......... .......... 12% 1.98M 2s
   600K .......... .......... .......... .......... .......... 13% 1.96M 2s
   650K .......... .......... .......... .......... .......... 14% 1.99M 2s
   700K .......... .......... .......... .......... .......... 15% 1.98M 2s
   750K .......... .......... .......... .......... .......... 16% 1.98M 2s
   800K .......... .......... .......... .......... .......... 17% 1.50M 2s
   850K .......... .......... .......... .......... .......... 18% 1.99M 2s
   900K .......... .......... .......... .......... .......... 19% 2.06M 2s
   950K .......... .......... .......... .......... .......... 20% 1.98M 2s
  1000K .......... .......... .......... .......... .......... 21% 1.97M 2s
  1050K .......... .......... .......... .......... .......... 22% 1.98M 2s
  1100K .......... .......... .......... .......... .......... 23% 2.00M 2s
  1150K .......... .......... .......... .......... .......... 24%  391K 2s
  1200K .......... .......... .......... .......... .......... 25% 1.99M 2s
  1250K .......... .......... .......... .......... .......... 26% 1.89M 2s
  1300K .......... .......... .......... .......... .......... 27% 1.77M 2s
  1350K .......... .......... .......... .......... .......... 28% 2.16M 2s
  1400K .......... .......... .......... .......... .......... 29% 1.74M 2s
  1450K .......... .......... .......... .......... .......... 30% 1.53M 2s
  1500K ....
 .......... .......... .......... 31% 2.19M 2s
  1550K .......... .......... .......... .......... .......... 32% 2.27M 2s
  1600K .......... .......... .......... .......... .......... 33% 2.04M 2s
  1650K .......... .......... .......... .......... .......... 34% 1.74M 2s
  1700K .......... .......... .......... .......... .......... 35% 2.02M 2s
  1750K .......... .......... .......... .......... .......... 36% 2.01M 2s
  1800K .......... .......... .......... .......... .......... 37% 1.77M 2s
  1850K .......... .......... .......... .......... .......... 38% 2.01M 2s
  1900K .......... .......... .......... .......... .......... 39% 1.77M 2s
  1950K .......... .......... .......... .......... .......... 40% 2.00M 2s
  2000K .......... .......... .......... .......... .......... 41% 2.03M 2s
  2050K .......... .......... .......... .......... .......... 42% 1.73M 2s
  2100K .......... .......... .......... .......... .......... 43% 2.04M 2s
  2150K .......... .......... .......... .......... .......... 44% 1.74M 2s
  2200K .......... .......... .......... .......... .......... 45% 2.08M 2s
  2250K .......... .......... .......... .......... .......... 46% 2.06M 2s
  2300K .......... .......... .......... .......... .......... 47% 1.73M 1s
  2350K .......... .......... .......... .......... .......... 48%  631K 2s
  2400K .......... .......... .......... .......... .......... 49% 2.02M 1s
  2450K .......... .......... .......... .......... .......... 50% 1.97M 1s
  2500K .......... .......... .......... .......... .......... 51% 1.73M 1s
  2550K .......... .......... .......... .......... .......... 52% 2.02M 1s
  2600K .......... .......... .......... .......... .......... 53% 1.73M 1s
  2650K .......... .......... .......... .......... .......... 54% 2.02M 1s
  2700K .......... .......... .......... .......... .......... 55% 2.02M 1s
  2750K .......... .......... .......... .......... .......... 56% 1.75M 1s
  2800K .......... .......... .......... .......... .......... 57% 2.08M 1s
  2850K .......... .......... .......... .......... .......... 58% 1.76M 1s
  2900K .......... .......... .......... .......... .......... 59% 2.03M 1s
  2950K .......... .......... .......... .......... .......... 60% 2.02M 1s
  3000K .......... .......... .......... .......... .......... 61% 1.74M 1s
  3050K .......... .......... .......... .......... .......... 62% 2.00M 1s
  3100K .......... .......... .......... .......... .......... 63% 1.78M 1s
  3150K .......... .......... .......... .......... .......... 64% 2.05M 1s
  3200K .......... .......... .......... .......... .......... 65% 1.99M 1s
  3250K .......... .......... .......... .......... .......... 66% 1.77M 1s
  3300K .......... .......... .......... .......... .......... 67% 2.00M 1s
  3350K .......... .......... .......... .......... .......... 68% 1.78M 1s
  3400K .......... .......... .......... .......... .......... 69% 1.99M 1s
  3450K .......... .......... .......... .......... .......... 70% 2.05M 1s
  3500K .......... .......... .......... .......... .......... 71% 1.72M 1s
  3550K .......... .......... .......... .......... .......... 72% 1.91M 1s
  3600K .......... .......... .......... .......... .......... 73% 2.02M 1s
  3650K .......... .......... .......... .......... .......... 74% 2.03M 1s
  3700K .......... .......... .......... .......... .......... 75% 1.39M 1s
  3750K .......... .......... .......... .......
... .......... 76% 2.80M 1s
  3800K .......... .......... .......... .......... .......... 77% 1.74M 1s
  3850K .......... .......... .......... .......... .......... 78% 2.02M 1s
  3900K .......... .......... .......... .......... .......... 79% 2.09M 1s
  3950K .......... .......... .......... .......... .......... 80% 1.72M 1s
  4000K .......... .......... .......... .......... .......... 81% 2.04M 1s
  4050K .......... .......... .......... .......... .......... 82% 1.74M 0s
  4100K .......... .......... .......... .......... .......... 83% 2.02M 0s
  4150K .......... .......... .......... .......... .......... 84% 2.01M 0s
  4200K .......... .......... .......... .......... .......... 85% 1.77M 0s
  4250K .......... .......... .......... .......... .......... 86% 1.99M 0s
  4300K .......... .......... .......... .......... .......... 87% 1.79M 0s
  4350K .......... .......... .......... .......... .......... 88% 1.99M 0s
  4400K .......... .......... .......... .......... .......... 89% 2.07M 0s
  4450K .......... .......... .......... .......... .......... 90% 1.73M 0s
  4500K .......... .......... .......... .......... .......... 91% 2.05M 0s
  4550K .......... .......... .......... .......... .......... 92% 1.72M 0s
  4600K .......... .......... .......... .......... .......... 93% 2.08M 0s
  4650K .......... .......... .......... .......... .......... 94% 2.01M 0s
  4700K .......... .......... .......... .......... .......... 95% 1.75M 0s
  4750K .......... .......... .......... .......... .......... 96% 1.89M 0s
  4800K .......... .......... .......... .......... .......... 97% 1.98M 0s
  4850K .......... .......... .......... .......... .......... 98% 2.03M 0s
  4900K .......... .......... .......... .......... .......... 99% 1.76M 0s
  4950K .......... .......... .......... .......... .....     100% 2.13M=2.7s
2020-02-17 09:21:37 (1.79 MB/s) - '/tmp/deconz.deb' saved [5115196/5115196]
Selecting previously unselected package deconz.
(Reading database ... 59849 files and directories currently installed.)
Preparing to unpack /tmp/deconz.deb ...
tput: unknown terminal "unknown"
Unpacking deconz (2.05.71-raspbian-stretch-beta) ...
dpkg: dependency problems prevent configuration of deconz:
 deconz depends on wiringpi; however:
  Package wiringpi is not installed.
dpkg: error processing package deconz (--install):
 dependency problems - leaving unconfigured
Processing triggers for mime-support (3.60) ...
Errors were encountered while processing:
 deconz
Hit:3 http://httpredir.debian.org/debian stretch-updates InRelease
Get:6 https://repo.solid-build.xyz/debian/stretch/bsp-imx6 ./ Release [985 B]
Fetched 1466 B in 3s (393 B/s)
Correcting dependencies...
The following packages will be REMOVED:
  deconz
0 upgraded, 0 newly installed, 1 to remove and 138 not upgraded.
1 not fully installed or removed.
After this operation, 21.3 MB disk space will be freed.
(Reading database ... 5%
(Reading database ... 10%
(Reading database ... 15%
(Reading database ... 20%
(Reading database ... 25%
(Reading database ... 30%
(Reading database ... 35%
(Reading database ... 40%
(Reading database ... 45%
(Reading database ... 50%
(Reading database ... 55%
(Reading database ... 60%
(Reading database ... 65%
(Reading database ... 70%
(Reading database ... 75%
(Reading database ... 80%
(Reading database ... 85%
(Reading database ... 90%
(Reading database ... 95%
(Reading database ... 100%
(Reading database ... 60498 files and directories currently installed.)
Removing deconz (2.05.71-raspbian-stretch-beta) ...
Failed to disable unit: No such file or directory
Failed to stop deconz-gui.service: Unit deconz-gui.service not loaded.
Failed to stop deconz.service: Unit deconz.service not loaded.
*             Installation terminée                    *
Salut Claude,
Très naivement, tu as lancé l’installation des dépendance avant celle de déconz?
Hello @Bben
Déjà, je te remercie de t’intéresser à mon cas. <Et oui, les dépendances en premier (lors de l’install du plugin) et ensuite Deconz (lorsque j’ai mis la clé)
Avec l’erreur mentionnée au début de ton log (sur ce qui doit être l’update) j’ai trouvé sur cette page :
EXPKEYSIG on repo.solid-build.xyz
Up to April 2018 we did not have a facility in place to update our repository signing key. While the key has been renewed on our build server, it did expire on any images from before October 22th 2017.
You know that you are affected when apt-get update shows an error message such as:
debian@clearfog:~$ sudo apt update
Err:6 https://repo.solid-build.xyz/debian/stretch/bsp-imx6 ./ Release.gpg
It is suggested that you install our solidrun-keyring package from our repos by hand. In the future this package will be used to roll out key extensions in the future. Navigate to stretch or jessie; Find the deb by name of solidrun-keyring_*_all.deb and install. Now apt should once again be happy about our key.
Je ne comprends pas tout.
Dans ton lien, on parle de err:6 alors que j’ai err:7
Err:**7** https://repo.solid-build.xyz/debian/stretch/bsp-imx6 ./ Release.gpg
J’ai trouvé ceci également qui en parle. (on retrouve le « 7 », mais pas sur que ce soit un id d’erreur ceci dit.) Sur stretch il fait une autorisation d’update non authentifié(?)
Je ne pourrais t’aider plus, ma méconnaissance de la mini+ et de tt l’environnement debian atteint ses limites.
J’aurais cru à un pb documenté, mais on ne trouve pas grd chose, et l’ancien forum rame à mort pour moi
Si @Loic passe par là peut être
En tout cas je te remercie.
Je viens de voir que le plugin n’est pas compatible 32 bits. La mini + est 32 bits.
Je cherche une autre solution.
