Problème inclusion capteurs Tuya
Jeedom V 4.3.20
Debian 10.13
Plugin JeeZigbee
Je viens de recevoir des capteurs de température TUYA ZTH05 compatible
https://www.zigbee2mqtt.io/devices/ZTH05.html
Je ne parviens pas pas a inclure ces nouveaux périphérique.
Log Z2m (debug)
[2023-12-07 18:11:37][DEBUG] : {"zigbee2mqtt":{"bridge":{"logging":{"level":"info","message":"Zigbee: allowing new devices to join."}}}}
[2023-12-07 18:12:42][DEBUG] : {"zigbee2mqtt":{"bridge":{"logging":{"level":"info","message":"MQTT publish: topic 'zigbee2mqtt\/bridge\/response\/permit_join', payload '{\"data\":{},\"error\":\"APS TIMEOUT\",\"status\":\"error\"}'"},"response":{"permit_join":{"data":[],"error":"APS TIMEOUT","status":"error"}}}}}
[2023-12-07 18:15:38][DEBUG] : {"zigbee2mqtt":{"bridge":{"logging":{"level":"debug","message":"Saving state to file \/var\/www\/html\/plugins\/z2m\/data\/state.json"}}}}
[2023-12-07 18:20:38][DEBUG] : {"zigbee2mqtt":{"bridge":{"logging":{"level":"debug","message":"Saving state to file \/var\/www\/html\/plugins\/z2m\/data\/state.json"}}}}
[2023-12-07 18:25:38][DEBUG] : {"zigbee2mqtt":{"bridge":{"logging":{"level":"debug","message":"Saving state to file \/var\/www\/html\/plugins\/z2m\/data\/state.json"}}}}
[2023-12-07 18:30:38][DEBUG] : {"zigbee2mqtt":{"bridge":{"logging":{"level":"debug","message":"Saving state to file \/var\/www\/html\/plugins\/z2m\/data\/state.json"}}}}
[2023-12-07 18:35:38][DEBUG] : {"zigbee2mqtt":{"bridge":{"logging":{"level":"debug","message":"Saving state to file \/var\/www\/html\/plugins\/z2m\/data\/state.json"}}}}
Logs Z2md
Zigbee2MQTT:debug 2023-12-07 18:11:37: Received MQTT message on 'zigbee2mqtt/bridge/request/permit_join' with data '{"value": true, "time": 180}'
Zigbee2MQTT:info  2023-12-07 18:11:37: Zigbee: allowing new devices to join.
Zigbee2MQTT:error 2023-12-07 18:12:42: Request 'zigbee2mqtt/bridge/request/permit_join' failed with error: 'APS TIMEOUT'
Zigbee2MQTT:debug 2023-12-07 18:12:42: Error: APS TIMEOUT
    at Driver.processApsBusyQueue (/var/www/html/plugins/z2m/resources/zigbee2mqtt/node_modules/zigbee-herdsman/src/adapter/deconz/driver/driver.ts:723:28)
    at Timeout._onTimeout (/var/www/html/plugins/z2m/resources/zigbee2mqtt/node_modules/zigbee-herdsman/src/adapter/deconz/driver/driver.ts:162:56)
    at listOnTimeout (node:internal/timers:559:17)
    at processTimers (node:internal/timers:502:7)
Zigbee2MQTT:info  2023-12-07 18:12:42: MQTT publish: topic 'zigbee2mqtt/bridge/response/permit_join', payload '{"data":{},"error":"APS TIMEOUT","status":"error"}'
Zigbee2MQTT:debug 2023-12-07 18:15:38: Saving state to file /var/www/html/plugins/z2m/data/state.json
Zigbee2MQTT:debug 2023-12-07 18:20:38: Saving state to file /var/www/html/plugins/z2m/data/state.json
Zigbee2MQTT:debug 2023-12-07 18:25:38: Saving state to file /var/www/html/plugins/z2m/data/state.json
Zigbee2MQTT:debug 2023-12-07 18:30:38: Saving state to file /var/www/html/plugins/z2m/data/state.json
Zigbee2MQTT:debug 2023-12-07 18:35:38: Saving state to file /var/www/html/plugins/z2m/data/state.json
Quelle est votre version de zigbee2mqtt 1.??.??
Il s’agit de la version 1.34.0.
Après de nombreuses tentative, j’ai enfin réussi à inclure mes capteurs.
Merci pour votre contribution
Y a-t-il une astuce, j’ai le même problème avec des SMART PLUG LEXMAN 10A
Comme ce sont mes premiers objets Zigbee, je ne sais pas si c’est un problème de ma config ou lié à ces composants. Et j’ai fait de nombreuses tentatives.
Debug 2023-12-07 07:52:08Received MQTT message on 'zigbee2mqtt/bridge/request/permit_join' with data '{"value": true, "time": 180}'
Info 2023-12-07 07:52:08Zigbee: allowing new devices to join.
Error 2023-12-07 07:53:13Request 'zigbee2mqtt/bridge/request/permit_join' failed with error: 'APS TIMEOUT'
Debug 2023-12-07 07:53:14Error: APS TIMEOUT at Driver.processApsBusyQueue (/var/www/html/plugins/z2m/resources/zigbee2mqtt/node_modules/zigbee-herdsman/src/adapter/deconz/driver/driver.ts:723:28) at Timeout._onTimeout (/var/www/html/plugins/z2m/resources/zigbee2mqtt/node_modules/zigbee-herdsman/src/adapter/deconz/driver/driver.ts:162:56) at listOnTimeout (node:internal/timers:559:17) at processTimers (node:internal/timers:502:7)
Info 2023-12-07 07:53:14MQTT publish: topic 'zigbee2mqtt/bridge/response/permit_join', payload '{"data":{},"error":"APS TIMEOUT","status":"error"}'
Ma version de Jeedom est 4.3.20 et zigbee2mqtt 1.34
Merci à tous ceux qui pourront me filer un coup de main avec ce problème
La page santé jeedom, la page de configuration de jeezigbee, de mqtt2, et le nombre de devices dans zigbee2mqtt.
Votre conbee, quel type? Comment est-elle reliée à la box? Etc
Merci de vous pencher sur mon problème.
Après un reboot complet de la smart, cela a fonctionné. Aucune idée pourquoi, mais ça marche :slight_smile:
