Problème inclusion Aqara WS-EUK01
je viens de faire l’acquisition de 2 interrupteurs Aqara WS-EUK01.
J’essaie de les faire fonctionner sur mon Jeedom (Raspberry 4, en version 4.3.21 avec le plugin jeeZigbee et une clé Conbee II).
L’inclusion semble bien se passer puisque dans Jeedom et Zigbee2MQTT les interrupteurs apparaissent bien.
Zigbee2MQTT:info  2023-12-21 16:39:11: Device '0x54ef441000817967' joined
Zigbee2MQTT:info  2023-12-21 16:39:11: MQTT publish: topic 'zigbee2mqtt/bridge/event', payload '{"data":{"friendly_name":"0x54ef441000817967","ieee_address":"0x54ef441000817967"},"type":"device_joined"}'
Zigbee2MQTT:info  2023-12-21 16:39:11: MQTT publish: topic 'zigbee2mqtt/bridge/log', payload '{"message":{"friendly_name":"0x54ef441000817967"},"type":"device_connected"}'
Zigbee2MQTT:info  2023-12-21 16:39:11: MQTT publish: topic 'zigbee2mqtt/0x54ef441000817967', payload '{"device":{"applicationVersion":11,"dateCode":"01-12-2021","friendlyName":"0x54ef441000817967","hardwareVersion":1,"ieeeAddr":"0x54ef441000817967","manufacturerID":4447,"manufacturerName":"LUMI","model":"WS-EUK01","networkAddress":1017,"powerSource":"Mains (single phase)","stackVersion":2,"type":"EndDevice","zclVersion":3},"last_seen":"2023-12-21T15:39:11.148Z","linkquality":255}'
Zigbee2MQTT:info  2023-12-21 16:39:11: Starting interview of '0x54ef441000817967'
Zigbee2MQTT:info  2023-12-21 16:39:11: MQTT publish: topic 'zigbee2mqtt/bridge/event', payload '{"data":{"friendly_name":"0x54ef441000817967","ieee_address":"0x54ef441000817967","status":"started"},"type":"device_interview"}'
Zigbee2MQTT:info  2023-12-21 16:39:11: MQTT publish: topic 'zigbee2mqtt/bridge/log', payload '{"message":"interview_started","meta":{"friendly_name":"0x54ef441000817967"},"type":"pairing"}'
Zigbee2MQTT:info  2023-12-21 16:39:12: MQTT publish: topic 'zigbee2mqtt/0x54ef441000817967', payload '{"device":{"applicationVersion":11,"dateCode":"01-12-2021","friendlyName":"0x54ef441000817967","hardwareVersion":1,"ieeeAddr":"0x54ef441000817967","manufacturerID":4447,"manufacturerName":"LUMI","model":"WS-EUK01","networkAddress":1017,"powerSource":"Mains (single phase)","stackVersion":2,"type":"EndDevice","zclVersion":3},"last_seen":"2023-12-21T15:39:12.356Z","linkquality":255}'
Zigbee2MQTT:info  2023-12-21 16:39:12: Successfully interviewed '0x54ef441000817967', device has successfully been paired
Zigbee2MQTT:info  2023-12-21 16:39:12: Device '0x54ef441000817967' is supported, identified as: Xiaomi Aqara smart wall switch H1 EU (no neutral, single rocker) (WS-EUK01)
Zigbee2MQTT:info  2023-12-21 16:39:12: MQTT publish: topic 'zigbee2mqtt/bridge/event', payload '{"data":{"definition":{"description":"Aqara smart wall switch H1 EU (no neutral, single rocker)","exposes":[{"features":[{"access":7,"description":"On/off state of the switch","label":"State","name":"state","property":"state","type":"binary","value_off":"OFF","value_on":"ON","value_toggle":"TOGGLE"}],"type":"switch"},{"access":1,"description":"Triggered action (e.g. a button click)","label":"Action","name":"action","property":"action","type":"enum","values":["single","double"]},{"access":7,"description":"Enable/disable the power outage memory, this recovers the on/off mode after power failure","label":"Power outage memory","name":"power_outage_memory","property":"power_outage_memory","type":"binary","value_off":false,"value_on":true},{"access":7,"description":"After turn on, the indicator light turns on while switch is off, and vice versa","label":"Flip indicator light","name":"flip_indicator_light","property":"flip_indicator_light","type":"binary","value_off":"OFF","value_on":"ON"},{"access":7,"description":"Enable/disable the LED at night","label":"LED disabled night","name":"led_disabled_night","property":"led_disabled_night","type":"binary","value_off":false,"value_on":true},{"access":1,"description":"Number of power outages (since last pairing)","label":"Power outage count","name":"power_outage_count","property":"power_outage_count","type":"numeric"},{"access":1,"description":"Temperature of the device","label":"Device temperature","name":"device_temperature","property":"device_temperature","type":"numeric","unit":"°C"},{"access":7,"description":"Decoupled mode","label":"Operation mode","name":"operation_mode","property":"operation_mode","type":"enum","values":["control_relay","decoupled"]},{"access":7,"description":"Anti flicker mode can be used to solve blinking issues of some lights.Quick mode makes the device respond faster.","label":"Mode switch","name":"mode_switch","property":"mode_switch","type":"enum","values":["anti_flicker_mode","quick_mode"]},{"access":1,"description":"Link quality (signal strength)","label":"Linkquality","name":"linkquality","property":"linkquality","type":"numeric","unit":"lqi","value_max":255,"value_min":0}],"model":"WS-EUK01","options":[{"access":2,"description":"State actions will also be published as 'action' when true (default false).","label":"State action","name":"state_action","property":"state_action","type":"binary","value_off":false,"value_on":true},{"access":2,"description":"Calibrates the device_temperature value (absolute offset), takes into effect on next report of device.","label":"Device temperature calibration","name":"device_temperature_calibration","property":"device_temperature_calibration","type":"numeric"}],"supports_ota":false,"vendor":"Xiaomi"},"friendly_name":"0x54ef441000817967","ieee_address":"0x54ef441000817967","status":"successful","supported":true},"type":"device_interview"}'
Zigbee2MQTT:info  2023-12-21 16:39:12: Configuring '0x54ef441000817967'
Zigbee2MQTT:info  2023-12-21 16:39:12: MQTT publish: topic 'zigbee2mqtt/bridge/log', payload '{"message":"interview_successful","meta":{"description":"Aqara smart wall switch H1 EU (no neutral, single rocker)","friendly_name":"0x54ef441000817967","model":"WS-EUK01","supported":true,"vendor":"Xiaomi"},"type":"pairing"}'
Zigbee2MQTT:info  2023-12-21 16:39:12: Successfully configured '0x54ef441000817967'
Par contre, après, impossible de les utiliser depuis Jeedom. Lorsque j’essaie une action, j’obtiens systématiquement ce type de message d’erreur
Zigbee2MQTT:error 2023-12-21 16:47:42: Publish 'set' 'state' to '0x54ef441000817967' failed: 'Error: Command 0x54ef441000817967/1 genOnOff.off({}, {"sendWhen":"immediate","timeout":10000,"disableResponse":false,"disableRecovery":false,"disableDefaultResponse":false,"direction":0,"srcEndpoint":null,"reservedBits":0,"manufacturerCode":null,"transactionSequenceNumber":null,"writeUndiv":false}) failed (no response received (21))'
(Le numéro 21 en fin de ligne change, j’ai déjà eu pas mal de numéro différent, je ne sais pas à quoi il correspond).
J’ai essayé de changer de channel zigbee (passage de 11 à 25), mais sans résultats.
Le matériel semble pourtant supporté par MQTT : Xiaomi WS-EUK01 control via MQTT | Zigbee2MQTT
J’ai essayé plusieurs fois de le réinclure mais toujours sans résultats.
Je précise que j’ai d’autres modules zigbee qui sont pleinement opérationnel, y compris du matériel Aqara (des sondes WSDCGQ11LM)
Avez-vous une idée ?
Essaye de les réappairer (sans les supprimer de z2m) en passant z2m en mode appairage et en les reinitialisant. Peut-être que l’interview s’est mal passé !
