J’ai récemment fais l’acquisition de deux SONOFF DUALR3 que j’ai connecté via Ewelink.
J’ai ensuite synchroniser mon compte avec le plugin Ewejee. Mes deux objets ont correctement été synchronisés. L’un d’entre eux n’affiche aucune commande et l’autre affiche les commandes Allumer, Éteindre et Statut. La commande Statut renvoi 1 mais les des autres n’ont aucun effet.
Pourriez-vous m’aider à faire fonctionner le SONOFF DUALR3 sur le plugin Ewejee svp?
Voici les logs du plugin avec l’api masqué :
http://192.168.1.13:80 SSL ? non
Serveur correctement lancé sur http://localhost:6005 Le Mon Mar 01 2021 14:58:12 GMT+0100 (Central European Standard Time)
events.js:291
throw er; // Unhandled 'error' event
Error: listen EADDRINUSE: address already in use 127.0.0.1:6005
at Server.setupListenHandle [as _listen2] (net.js:1316:16)
at listenInCluster (net.js:1364:12)
at GetAddrInfoReqWrap.doListen [as callback] (net.js:1501:7)
at GetAddrInfoReqWrap.onlookup [as oncomplete] (dns.js:68:8)
Emitted 'error' event on Server instance at:
at emitErrorNT (net.js:1343:8)
at processTicksAndRejections (internal/process/task_queues.js:84:21) {
code: 'EADDRINUSE',
errno: 'EADDRINUSE',
syscall: 'listen',
address: '127.0.0.1',
port: 6005
{"error":0,"apikey":"24150226-2e4c-4f88-9aec-3fb3ca4a1798","config":{"hb":1,"hbInterval":145},"sequence":"1614607092000"}
*************************** Début de la synchronisation ***************************
[{"settings":{"opsNotify":0,"opsHistory":1,"alarmNotify":1,"wxAlarmNotify":0,"wxOpsNotify":0,"wxDoorbellNotify":0,"appDoorbellNotify":1},"family":{"id":"6038ada687c7160007f03b8a","index":0},"group":"","online":true,"shareUsersInfo":[{"family":{"id":"603ced38afab3600076f1cf3","index":-1},"apikey":"24150226-2e4c-4f88-9aec-3fb3ca4a1798","permit":15,"shareDate":"2021-03-01T13:36:38.966Z","comment":""}],"groups":[],"devGroups":[],"_id":"6038ae6d15290700072156af","relational":[],"deviceid":"1001220352","name":"Volet2","type":"10","apikey":*****,"extra":{"extra":{"uiid":126,"description":"20201224004","brandId":"5c4c1aee3a7d24c7100be054","apmac":"d0:27:02:44:03:f5","mac":"d0:27:02:44:03:f4","ui":"多功能双通道电量检测开关","modelInfo":"5f1e478208bb4f51db013bc5","model":"E32-2SW-P0","manufacturer":"深圳松诺技术有限公司","staMac":"94B97E69A0DC"},"_id":"5fe471699d1fdb25a428d058"},"createdAt":"2021-02-26T08:16:45.443Z","__v":0,"onlineTime":"2021-02-26T09:20:31.357Z","params":{"version":7,"workMode":2,"motorSwMode":3,"motorSwReverse":0,"outputReverse":1,"motorTurn":0,"calibState":1,"currLocation":100,"location":100,"sledBright":100,"staMac":"94B97E69A0DC","rssi":-39,"overload_00":{"minActPow":{"enabled":0,"value":10},"maxVoltage":{"enabled":0,"value":24000},"minVoltage":{"enabled":0,"value":10},"maxCurrent":{"enabled":0,"value":1500},"maxActPow":{"enabled":0,"value":360000}},"overload_01":{"minActPow":{"enabled":0,"value":10},"maxVoltage":{"enabled":0,"value":24000},"minVoltage":{"enabled":0,"value":10},"maxCurrent":{"enabled":0,"value":1500},"maxActPow":{"enabled":0,"value":360000}},"oneKwhState_00":0,"startTime_00":"","endTime_00":"","oneKwhState_01":0,"startTime_01":"","endTime_01":"","oneKwhData_00":0,"oneKwhData_01":0,"current_00":0,"voltage_00":24312,"actPow_00":0,"reactPow_00":0,"apparentPow_00":0,"current_01":0,"voltage_01":24312,"actPow_01":0,"reactPow_01":0,"apparentPow_01":0,"fwVersion":"1.2.0","timeZone":1,"calibration":1,"getKwh_00":1,"getKwh_01":1,"zyx_clear_timers":true,"bindInfos":{"gaction":["*****_ewelinkGoogleHome"]},"switch":"on"},"ip":"82.65.147.166","location":"","tags":{"m_1fbc_nico":"on","m_1798_nasd":"on"},"offlineTime":"2021-02-26T09:14:08.159Z","sharedBy":{"email":"nicolas.nowinski@gmail.com","apikey":*****,"permit":15,"shareTime":1614605798949},"devicekey":"21217ce2-1e67-4f9b-927e-38c5e6a747af","deviceUrl":"","brandName":"SONOFF","showBrand":true,"brandLogoUrl":"https://eu-ota.coolkit.cc/logo/q62PevoglDNmwUJ9oPE7kRrpt1nL1CoA.png","productModel":"DUALR3","devConfig":{},"uiid":126},{"settings":{"opsNotify":0,"opsHistory":1,"alarmNotify":1,"wxAlarmNotify":0,"wxOpsNotify":0,"wxDoorbellNotify":0,"appDoorbellNotify":1},"family":{"id":"6038ada687c7160007f03b8a","index":-1},"group":"","online":true,"shareUsersInfo":[{"family":{"id":"603ced38afab3600076f1cf3","index":0},"apikey":"24150226-2e4c-4f88-9aec-3fb3ca4a1798","permit":15,"shareDate":"2021-03-01T13:36:38.807Z","comment":""}],"groups":[],"devGroups":[],"_id":"6038b5672998cb000756aea3","relational":[],"deviceid":"1001220504","name":"Volet1","type":"10","apikey":*****,"extra":{"extra":{"uiid":126,"description":"20201224004","brandId":"5c4c1aee3a7d24c7100be054","apmac":"d0:27:02:44:07:59","mac":"d0:27:02:44:07:58","ui":"多功能双通道电量检测开关","modelInfo":"5f1e478208bb4f51db013bc5","model":"E32-2SW-P0","manufacturer":"深圳松诺技术有限公司","staMac":"94B97E68B2C0"},"_id":"5fe471699d1fdb25a428d20a"},"createdAt":"2021-02-26T08:46:31.799Z","__v":0,"tags":{"m_1fbc_nico":"on","m_1798_nasd":"on"},"onlineTime":"2021-02-26T09:23:34.797Z","params":{"version":7,"workMode":2,"motorSwMode":3,"motorSwReverse":0,"outputReverse":1,"motorTurn":0,"calibState":1,"currLocation":100,"location":100,"sledBright":100,"staMac":"94B97E68B2C0","rssi":-48,"overload_00":{"minActPow":{"enabled":0,"value":10},"maxVoltage":{"enabled":0,"value":24000},"minVoltage":{"enabled":0,"value":10},"maxCurrent":{"enabled":0,"value":1500},"maxActPow":{"enabled":0,"value":360000}},"overload_01":{"minActPow":{"enabled":0,"value":10},"maxVoltage":{"enabled":0,"value":24000},"minVoltage":{"enabled":0,"value":10},"maxCurrent":{"enabled":0,"value":1500},"maxActPow":{"enabled":0,"value":360000}},"oneKwhState_00":0,"startTime_00":"","endTime_00":"","oneKwhState_01":0,"startTime_01":"","endTime_01":"","oneKwhData_00":0,"oneKwhData_01":0,"current_00":0,"voltage_00":24313,"actPow_00":0,"reactPow_00":0,"apparentPow_00":0,"current_01":0,"voltage_01":24313,"actPow_01":0,"reactPow_01":0,"apparentPow_01":0,"fwVersion":"1.2.0","timeZone":1,"calibration":1,"zyx_clear_timers":true,"bindInfos":{"gaction":["*****_ewelinkGoogleHome"]},"getKwh_00":2,"getKwh_01":2},"ip":"82.65.147.166","location":"","offlineTime":"2021-02-26T09:23:24.458Z","sharedBy":{"email":"nicolas.nowinski@gmail.com","apikey":*****,"permit":15,"shareTime":1614605798767},"devicekey":"7c3479ab-3973-4ef8-acc5-a7665e282c9d","deviceUrl":"","brandName":"SONOFF","showBrand":true,"brandLogoUrl":"https://eu-ota.coolkit.cc/logo/q62PevoglDNmwUJ9oPE7kRrpt1nL1CoA.png","productModel":"DUALR3","devConfig":{},"uiid":126}]
*************************** Fin de la synchronisation ***************************
{"action":"update","userAgent":"app","apikey":*****,"deviceid":"1001220352","sequence":"1614607116042","params":{"switch":"off"}}
{"action":"update","userAgent":"app","apikey":*****,"deviceid":"1001220352","sequence":"1614607117901","params":{"switch":"on"}}
Cordialement.
