Problème d'installation des dépendances pour le plugin Enocean
Étant tout novice en domotique, je vous sollicite afin de m’aider à résoudre mon problème.
Je souhaite utiliser le plugin Enocean. Cependant, je n’arrive pas à le faire fonctionner car les dépendances sont NOK et les démons NOK.
Voici le journal des log :
Hit:1 http://security.debian.org buster/updates InRelease
Hit:2 http://httpredir.debian.org/debian buster InRelease
Hit:4 http://httpredir.debian.org/debian buster-updates InRelease
Hit:5 http://httpredir.debian.org/debian buster-backports InRelease
Hit:3 https://apt.armbian.com buster InRelease
Reading package lists...
Building dependency tree...
Reading state information...
Package 'python-enum' is not installed, so not removed
The following packages were automatically installed and are no longer required:
python-fasteners python-lockfile python-monotonic
Use 'sudo apt autoremove' to remove them.
python-serial is already the newest version (3.4-4).
python-pyudev is already the newest version (0.21.0-1).
python-requests is already the newest version (2.21.0-1).
Collecting enum-compat
Using cached https://files.pythonhosted.org/packages/41/46/8ed2368976d934652d8f33f1fdd86f5580fab45e890c90a848e83097a093/enum-compat-0.0.3.tar.gz
Complete output from command python setup.py egg_info:
File "<string>", line 1, in <module>
ImportError: No module named setuptools
Command "python setup.py egg_info" failed with error code 1 in /tmp/pip-install-_XmcCU/enum-compat/
Requirement already satisfied: beautifulsoup4 in /usr/local/lib/python2.7/dist-packages (4.9.0)
Requirement already satisfied: soupsieve<2.0 in /usr/local/lib/python2.7/dist-packages (from beautifulsoup4) (1.9.5)
Requirement already satisfied: backports.functools-lru-cache; python_version < "3" in /usr/local/lib/python2.7/dist-packages (from soupsieve<2.0->beautifulsoup4) (1.6.1)
Lors de l’installation des étapes 11 (obtention de jeedom), une phrase en rouge disait :
« Command « python setup.py egg_info » failed with error code 1… »
J’ai utilisé Armbian_20.02.1_Orangepipcplus_buster_current_5.4.20
Je pense que cela est la base de mon problème !
Cela fait plusieurs jours que j’installe/désinstalle en vain
Je suis donc preneur de votre aide :slight_smile:
Je sais pas si ça va beaucoup t’aider, j’avais aussi beaucoup galéré sur le sujet ! Au final j’avais fini par devoir faire une nouvelle installation complète (raspberry pi 3b, Raspbian Strech et passer en Jeedom v4). Et là miracle ça avait fini par tomber en marche…
Il y a un certain nombre de sujets sur le forum à propos de ces dépendances et démons. Un problème récurrent est la version de python.
Pour t’aider, les « experts » auront besoin de connaître le type de ton installation (VM, rpi, freebox,…), le système d’exploitation et sa version et ta version de jeedom.
Bonne chance ! :wink:
J’ai trouvé ça dans les autres sujets du forum. Peut-être que cela peut résoudre ton problème ?
Super Christophe,
Ça fonctionne parfaitement :slight_smile:
Un grand merci
