Étant tout novice en domotique, je vous sollicite afin de m’aider à résoudre mon problème.
Je souhaite utiliser le plugin Enocean. Cependant, je n’arrive pas à le faire fonctionner car les dépendances sont NOK et les démons NOK.
Voici le journal des log :
Hit:1 http://security.debian.org buster/updates InRelease
Hit:2 http://httpredir.debian.org/debian buster InRelease
Hit:4 http://httpredir.debian.org/debian buster-updates InRelease
Hit:5 http://httpredir.debian.org/debian buster-backports InRelease
Hit:3 https://apt.armbian.com buster InRelease
Reading package lists...
Building dependency tree...
Reading state information...
Package 'python-enum' is not installed, so not removed
The following packages were automatically installed and are no longer required:
python-fasteners python-lockfile python-monotonic
Use 'sudo apt autoremove' to remove them.
python-serial is already the newest version (3.4-4).
python-pyudev is already the newest version (0.21.0-1).
python-requests is already the newest version (2.21.0-1).
Collecting enum-compat
Using cached https://files.pythonhosted.org/packages/41/46/8ed2368976d934652d8f33f1fdd86f5580fab45e890c90a848e83097a093/enum-compat-0.0.3.tar.gz
Complete output from command python setup.py egg_info:
File "<string>", line 1, in <module>
ImportError: No module named setuptools
Command "python setup.py egg_info" failed with error code 1 in /tmp/pip-install-_XmcCU/enum-compat/
Requirement already satisfied: beautifulsoup4 in /usr/local/lib/python2.7/dist-packages (4.9.0)
Requirement already satisfied: soupsieve<2.0 in /usr/local/lib/python2.7/dist-packages (from beautifulsoup4) (1.9.5)
Requirement already satisfied: backports.functools-lru-cache; python_version < "3" in /usr/local/lib/python2.7/dist-packages (from soupsieve<2.0->beautifulsoup4) (1.6.1)
* Installation terminée *
Lors de l’installation des étapes 11 (obtention de jeedom), une phrase en rouge disait :
« Command « python setup.py egg_info » failed with error code 1… »
J’ai utilisé Armbian_20.02.1_Orangepipcplus_buster_current_5.4.20
Je pense que cela est la base de mon problème !
Cela fait plusieurs jours que j’installe/désinstalle en vain
Je suis donc preneur de votre aide
