commande « sudo dmesg » avec la clé :
freebox@Jeedom-free:~$ sudo dmesg
[ 0.000000] Booting Linux on physical CPU 0x0000000000 [0x410fd081]
[ 0.000000] Linux version 4.19.0-16-arm64 (debian-kernel@lists.debian.org) (gcc version 8.3.0 (Debian 8.3.0-6)) #1 SMP Debian 4.19.181-1 (2021-03-19)
[ 0.000000] efi: Getting EFI parameters from FDT:
[ 0.000000] efi: EFI v2.70 by EDK II
[ 0.000000] efi: SMBIOS 3.0=0x7b5c0000 MEMATTR=0x78fc2018 ACPI 2.0=0x77f00000 RNG=0x7b67d298
[ 0.000000] efi: seeding entropy pool
[ 0.000000] secureboot: Secure boot disabled
[ 0.000000] cma: Reserved 64 MiB at 0x0000000073c00000
[ 0.000000] ACPI: Early table checksum verification disabled
[ 0.000000] ACPI: RSDP 0x0000000077F00000 000024 (v02 BOCHS )
[ 0.000000] ACPI: XSDT 0x0000000077EF0000 000054 (v01 BOCHS BXPCFACP 00000001 01000013)
[ 0.000000] ACPI: FACP 0x0000000077EB0000 00010C (v05 BOCHS BXPCFACP 00000001 BXPC 00000001)
[ 0.000000] ACPI: DSDT 0x0000000077EC0000 004848 (v02 BOCHS BXPCDSDT 00000001 BXPC 00000001)
[ 0.000000] ACPI: APIC 0x0000000077EA0000 0000F4 (v03 BOCHS BXPCAPIC 00000001 BXPC 00000001)
[ 0.000000] ACPI: GTDT 0x0000000077E90000 000060 (v02 BOCHS BXPCGTDT 00000001 BXPC 00000001)
[ 0.000000] ACPI: MCFG 0x0000000077E80000 00003C (v01 BOCHS BXPCMCFG 00000001 BXPC 00000001)
[ 0.000000] ACPI: SPCR 0x0000000077E70000 000050 (v02 BOCHS BXPCSPCR 00000001 BXPC 00000001)
[ 0.000000] ACPI: IORT 0x0000000077E60000 00007C (v00 BOCHS BXPCIORT 00000001 BXPC 00000001)
[ 0.000000] ACPI: SPCR: console: pl011,mmio,0x9000000,9600
[ 0.000000] ACPI: NUMA: Failed to initialise from firmware
[ 0.000000] NUMA: Faking a node at [mem 0x0000000040000000-0x000000007bcfffff]
[ 0.000000] NUMA: NODE_DATA [mem 0x7bced3c0-0x7bceefff]
[ 0.000000] Zone ranges:
[ 0.000000] DMA32 [mem 0x0000000040000000-0x000000007bcfffff]
[ 0.000000] Normal empty
[ 0.000000] Movable zone start for each node
[ 0.000000] Early memory node ranges
[ 0.000000] node 0: [mem 0x0000000040000000-0x0000000077f0ffff]
[ 0.000000] node 0: [mem 0x0000000077f10000-0x00000000781dffff]
[ 0.000000] node 0: [mem 0x00000000781e0000-0x000000007b4bffff]
[ 0.000000] node 0: [mem 0x000000007b4c0000-0x000000007b54ffff]
[ 0.000000] node 0: [mem 0x000000007b550000-0x000000007b55ffff]
[ 0.000000] node 0: [mem 0x000000007b560000-0x000000007b67ffff]
[ 0.000000] node 0: [mem 0x000000007b680000-0x000000007bcfffff]
[ 0.000000] Zeroed struct page in unavailable ranges: 800 pages
[ 0.000000] Initmem setup node 0 [mem 0x0000000040000000-0x000000007bcfffff]
[ 0.000000] On node 0 totalpages: 244992
[ 0.000000] DMA32 zone: 3828 pages used for memmap
[ 0.000000] DMA32 zone: 0 pages reserved
[ 0.000000] DMA32 zone: 244992 pages, LIFO batch:63
[ 0.000000] psci: probing for conduit method from ACPI.
[ 0.000000] psci: PSCIv1.0 detected in firmware.
[ 0.000000] psci: Using standard PSCI v0.2 function IDs
[ 0.000000] psci: Trusted OS migration not required
[ 0.000000] psci: SMC Calling Convention v1.1
[ 0.000000] ACPI: SRAT not present
[ 0.000000] random: get_random_bytes called from start_kernel+0x9c/0x4bc with crng_init=0
[ 0.000000] percpu: Embedded 25 pages/cpu s62104 r8192 d32104 u102400
[ 0.000000] pcpu-alloc: s62104 r8192 d32104 u102400 alloc=25*4096
[ 0.000000] pcpu-alloc: [0] 0 [0] 1
[ 0.000000] Detected PIPT I-cache on CPU0
[ 0.000000] ARM_SMCCC_ARCH_WORKAROUND_1 missing from firmware
[ 0.000000] CPU features: enabling workaround for EL2 vector hardening
[ 0.000000] CPU features: kernel page table isolation forced ON by KASLR
[ 0.000000] CPU features: detected: Kernel page table isolation (KPTI)
[ 0.000000] Built 1 zonelists, mobility grouping on. Total pages: 241164
[ 0.000000] Policy zone: DMA32
[ 0.000000] Kernel command line: BOOT_IMAGE=/boot/vmlinuz-4.19.0-16-arm64 root=UUID=5bca12bc-64aa-494d-b443-f4d493b395cd ro biosdevname=0 net.ifnames=0 console=tty0 console=ttyAMA0,115200 earlyprintk=ttyAMA0,115200 consoleblank=0 systemd.show_status=true
[ 0.000000] Memory: 847936K/979968K available (9020K kernel code, 1616K rwdata, 2816K rodata, 4800K init, 538K bss, 66496K reserved, 65536K cma-reserved)
[ 0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=2, Nodes=1
[ 0.000000] ftrace: allocating 33302 entries in 131 pages
[ 0.000000] rcu: Hierarchical RCU implementation.
[ 0.000000] rcu: RCU restricting CPUs from NR_CPUS=256 to nr_cpu_ids=2.
[ 0.000000] rcu: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=2
[ 0.000000] NR_IRQS: 64, nr_irqs: 64, preallocated irqs: 0
[ 0.000000] GICv2m: ACPI overriding V2M MSI_TYPER (base:80, num:64)
[ 0.000000] GICv2m: range[mem 0x08020000-0x08020fff], SPI[80:143]
[ 0.000000] arch_timer: cp15 timer(s) running at 25.00MHz (virt).
[ 0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x5c40939b5, max_idle_ns: 440795202646 ns
[ 0.000001] sched_clock: 56 bits at 25MHz, resolution 40ns, wraps every 4398046511100ns
[ 0.000044] Console: colour dummy device 80x25
[ 0.000218] console [tty0] enabled
[ 0.000252] ACPI: Core revision 20180810
[ 0.000346] Calibrating delay loop (skipped), value calculated using timer frequency.. 50.00 BogoMIPS (lpj=100000)
[ 0.000354] pid_max: default: 32768 minimum: 301
[ 0.000396] Security Framework initialized
[ 0.000402] Yama: disabled by default; enable with sysctl kernel.yama.*
[ 0.000432] AppArmor: AppArmor initialized
[ 0.000653] Dentry cache hash table entries: 131072 (order: 8, 1048576 bytes)
[ 0.000761] Inode-cache hash table entries: 65536 (order: 7, 524288 bytes)
[ 0.000783] Mount-cache hash table entries: 2048 (order: 2, 16384 bytes)
[ 0.000791] Mountpoint-cache hash table entries: 2048 (order: 2, 16384 bytes)
[ 0.001172] ACPI PPTT: No PPTT table found, cpu topology may be inaccurate
[ 0.001340] ASID allocator initialised with 32768 entries
[ 0.001384] rcu: Hierarchical SRCU implementation.
[ 0.001916] Remapping and enabling EFI services.
[ 0.002277] smp: Bringing up secondary CPUs ...
[ 0.026434] Detected PIPT I-cache on CPU1
[ 0.026502] CPU1: Booted secondary processor 0x0000000001 [0x410fd081]
[ 0.026612] smp: Brought up 1 node, 2 CPUs
[ 0.026627] SMP: Total of 2 processors activated.
[ 0.026633] CPU features: detected: 32-bit EL0 Support
[ 0.029942] CPU: All CPU(s) started at EL1
[ 0.029963] alternatives: patching kernel code
[ 0.030511] devtmpfs: initialized
[ 0.030824] Registered cp15_barrier emulation handler
[ 0.030843] Registered setend emulation handler
[ 0.030917] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
[ 0.030933] futex hash table entries: 512 (order: 3, 32768 bytes)
[ 0.031475] pinctrl core: initialized pinctrl subsystem
[ 0.031713] SMBIOS 3.0.0 present.
[ 0.031722] DMI: QEMU KVM Virtual Machine, BIOS 0.0.0 02/06/2015
[ 0.031849] NET: Registered protocol family 16
[ 0.032002] audit: initializing netlink subsys (disabled)
[ 0.032107] audit: type=2000 audit(0.028:1): state=initialized audit_enabled=0 res=1
[ 0.032408] cpuidle: using governor ladder
[ 0.032434] cpuidle: using governor menu
[ 0.032518] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
[ 0.033286] DMA: preallocated 256 KiB pool for atomic allocations
[ 0.033350] ACPI: bus type PCI registered
[ 0.033355] acpiphp: ACPI Hot Plug PCI Controller Driver version: 0.5
[ 0.033399] Serial: AMBA PL011 UART driver
[ 0.035047] HugeTLB registered 2.00 MiB page size, pre-allocated 0 pages
[ 0.035511] ACPI: Added _OSI(Module Device)
[ 0.035519] ACPI: Added _OSI(Processor Device)
[ 0.035523] ACPI: Added _OSI(3.0 _SCP Extensions)
[ 0.035527] ACPI: Added _OSI(Processor Aggregator Device)
[ 0.035532] ACPI: Added _OSI(Linux-Dell-Video)
[ 0.035536] ACPI: Added _OSI(Linux-Lenovo-NV-HDMI-Audio)
[ 0.046816] ACPI: 1 ACPI AML tables successfully acquired and loaded
[ 0.047863] ACPI: Interpreter enabled
[ 0.047869] ACPI: Using GIC for interrupt routing
[ 0.047894] ACPI: MCFG table detected, 1 entries
[ 0.051432] ARMH0011:00: ttyAMA0 at MMIO 0x9000000 (irq = 4, base_baud = 0) is a SBSA
[ 0.129038] console [ttyAMA0] enabled
[ 0.131418] ACPI: PCI Root Bridge [PCI0] (domain 0000 [bus 00-ff])
[ 0.132113] acpi PNP0A08:00: _OSC: OS supports [ExtendedConfig ASPM ClockPM Segments MSI]
[ 0.133154] acpi PNP0A08:00: _OSC: platform does not support [SHPCHotplug LTR]
[ 0.134054] acpi PNP0A08:00: _OSC: OS now controls [PCIeHotplug PME AER PCIeCapability]
[ 0.135268] acpi PNP0A08:00: ECAM area [mem 0x4010000000-0x401fffffff] reserved by PNP0C02:00
[ 0.136202] acpi PNP0A08:00: ECAM at [mem 0x4010000000-0x401fffffff] for [bus 00-ff]
[ 0.137055] Remapped I/O 0x000000003eff0000 to [io 0x0000-0xffff window]
[ 0.137899] PCI host bridge to bus 0000:00
[ 0.138343] pci_bus 0000:00: root bus resource [mem 0x10000000-0x3efeffff window]
[ 0.139137] pci_bus 0000:00: root bus resource [io 0x0000-0xffff window]
[ 0.140035] pci_bus 0000:00: root bus resource [mem 0x8000000000-0xffffffffff window]
[ 0.140867] pci_bus 0000:00: root bus resource [bus 00-ff]
[ 0.141508] pci 0000:00:00.0: [1b36:0008] type 00 class 0x060000
[ 0.141861] pci 0000:00:01.0: [1af4:1001] type 00 class 0x010000
[ 0.142429] pci 0000:00:01.0: reg 0x10: [io 0x0000-0x007f]
[ 0.142859] pci 0000:00:01.0: reg 0x14: [mem 0x10002000-0x10002fff]
[ 0.144363] pci 0000:00:01.0: reg 0x20: [mem 0x8000000000-0x8000003fff 64bit pref]
[ 0.145314] pci 0000:00:02.0: [1af4:1004] type 00 class 0x010000
[ 0.145910] pci 0000:00:02.0: reg 0x10: [io 0x0080-0x00bf]
[ 0.146418] pci 0000:00:02.0: reg 0x14: [mem 0x10001000-0x10001fff]
[ 0.147930] pci 0000:00:02.0: reg 0x20: [mem 0x8000004000-0x8000007fff 64bit pref]
[ 0.148912] pci 0000:00:03.0: [1af4:1000] type 00 class 0x020000
[ 0.149528] pci 0000:00:03.0: reg 0x10: [io 0x0100-0x011f]
[ 0.150027] pci 0000:00:03.0: reg 0x14: [mem 0x10000000-0x10000fff]
[ 0.151513] pci 0000:00:03.0: reg 0x20: [mem 0x8000008000-0x800000bfff 64bit pref]
[ 0.152475] pci 0000:00:04.0: [1af4:1005] type 00 class 0x00ff00
[ 0.153097] pci 0000:00:04.0: reg 0x10: [io 0x00e0-0x00ff]
[ 0.155074] pci 0000:00:04.0: reg 0x20: [mem 0x800000c000-0x800000ffff 64bit pref]
[ 0.155961] pci 0000:00:05.0: [1af4:1002] type 00 class 0x00ff00
[ 0.156588] pci 0000:00:05.0: reg 0x10: [io 0x00c0-0x00df]
[ 0.158445] pci 0000:00:05.0: reg 0x20: [mem 0x8000010000-0x8000013fff 64bit pref]
[ 0.159460] pci 0000:00:01.0: BAR 4: assigned [mem 0x8000000000-0x8000003fff 64bit pref]
[ 0.160394] pci 0000:00:02.0: BAR 4: assigned [mem 0x8000004000-0x8000007fff 64bit pref]
[ 0.161290] pci 0000:00:03.0: BAR 4: assigned [mem 0x8000008000-0x800000bfff 64bit pref]
[ 0.162183] pci 0000:00:04.0: BAR 4: assigned [mem 0x800000c000-0x800000ffff 64bit pref]
[ 0.163093] pci 0000:00:05.0: BAR 4: assigned [mem 0x8000010000-0x8000013fff 64bit pref]
[ 0.163982] pci 0000:00:01.0: BAR 1: assigned [mem 0x10000000-0x10000fff]
[ 0.164837] pci 0000:00:02.0: BAR 1: assigned [mem 0x10001000-0x10001fff]
[ 0.165569] pci 0000:00:03.0: BAR 1: assigned [mem 0x10002000-0x10002fff]
[ 0.166299] pci 0000:00:01.0: BAR 0: assigned [io 0x1000-0x107f]
[ 0.167449] pci 0000:00:02.0: BAR 0: assigned [io 0x1080-0x10bf]
[ 0.168567] pci 0000:00:03.0: BAR 0: assigned [io 0x10c0-0x10df]
[ 0.169825] pci 0000:00:04.0: BAR 0: assigned [io 0x10e0-0x10ff]
[ 0.170951] pci 0000:00:05.0: BAR 0: assigned [io 0x1100-0x111f]
[ 0.172037] pci_bus 0000:00: resource 4 [mem 0x10000000-0x3efeffff window]
[ 0.172040] pci_bus 0000:00: resource 5 [io 0x0000-0xffff window]
[ 0.172042] pci_bus 0000:00: resource 6 [mem 0x8000000000-0xffffffffff window]
[ 0.172095] ACPI: PCI Interrupt Link [GSI0] (IRQs *35)
[ 0.172665] ACPI: PCI Interrupt Link [GSI1] (IRQs *36)
[ 0.173248] ACPI: PCI Interrupt Link [GSI2] (IRQs *37)
[ 0.173955] ACPI: PCI Interrupt Link [GSI3] (IRQs *38)
[ 0.174988] vgaarb: loaded
[ 0.175376] pps_core: LinuxPPS API ver. 1 registered
[ 0.175993] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[ 0.176969] PTP clock support registered
[ 0.177396] EDAC MC: Ver: 3.0.0
[ 0.178020] Registered efivars operations
[ 0.178998] clocksource: Switched to clocksource arch_sys_counter
[ 0.197426] VFS: Disk quotas dquot_6.6.0
[ 0.197913] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
[ 0.198863] AppArmor: AppArmor Filesystem Enabled
[ 0.199570] pnp: PnP ACPI init
[ 0.200119] system 00:00: [mem 0x4010000000-0x401fffffff window] could not be reserved
[ 0.200971] system 00:00: Plug and Play ACPI device, IDs PNP0c02 (active)
[ 0.200981] pnp: PnP ACPI: found 1 devices
[ 0.204794] NET: Registered protocol family 2
[ 0.205489] tcp_listen_portaddr_hash hash table entries: 512 (order: 1, 8192 bytes)
[ 0.206328] TCP established hash table entries: 8192 (order: 4, 65536 bytes)
[ 0.207157] TCP bind hash table entries: 8192 (order: 5, 131072 bytes)
[ 0.207905] TCP: Hash tables configured (established 8192 bind 8192)
[ 0.208772] UDP hash table entries: 512 (order: 2, 16384 bytes)
[ 0.209415] UDP-Lite hash table entries: 512 (order: 2, 16384 bytes)
[ 0.210155] NET: Registered protocol family 1
[ 0.210633] NET: Registered protocol family 44
[ 0.211213] PCI: CLS 0 bytes, default 64
[ 0.211273] Unpacking initramfs...
[ 0.760532] Freeing initrd memory: 24444K
[ 0.792981] hw perfevents: enabled with armv8_pmuv3_0 PMU driver, 7 counters available
[ 0.793852] kvm [1]: HYP mode not available
[ 0.795468] Initialise system trusted keyrings
[ 0.795983] Key type blacklist registered
[ 0.796503] workingset: timestamp_bits=42 max_order=18 bucket_order=0
[ 0.799178] zbud: loaded
[ 0.999316] Key type asymmetric registered
[ 0.999796] Asymmetric key parser 'x509' registered
[ 1.000341] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 246)
[ 1.001209] io scheduler noop registered
[ 1.001630] io scheduler deadline registered
[ 1.002148] io scheduler cfq registered (default)
[ 1.002654] io scheduler mq-deadline registered
[ 1.004125] pl061_gpio ARMH0061:00: PL061 GPIO chip @0x0000000009030000 registered
[ 1.005078] shpchp: Standard Hot Plug PCI Controller Driver version: 0.4
[ 1.006073] input: Power Button as /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0C:00/input/input0
[ 1.006980] ACPI: Power Button [PWRB]
[ 1.008399] Serial: 8250/16550 driver, 4 ports, IRQ sharing enabled
[ 1.009562] Serial: AMBA driver
[ 1.009966] msm_serial: driver initialized
[ 1.010527] ACPI PPTT: No PPTT table found, cache topology may be inaccurate
[ 1.011393] ACPI PPTT: No PPTT table found, cache topology may be inaccurate
[ 1.012148] cacheinfo: Unable to detect cache hierarchy for CPU 0
[ 1.013050] mousedev: PS/2 mouse device common for all mice
[ 1.014062] rtc-efi rtc-efi: rtc core: registered rtc-efi as rtc0
[ 1.015111] ledtrig-cpu: registered to indicate activity on CPUs
[ 1.016397] NET: Registered protocol family 10
[ 1.032279] Segment Routing with IPv6
[ 1.032756] mip6: Mobile IPv6
[ 1.033084] NET: Registered protocol family 17
[ 1.033659] mpls_gso: MPLS GSO support
[ 1.034422] registered taskstats version 1
[ 1.034871] Loading compiled-in X.509 certificates
[ 1.081411] Loaded X.509 cert 'Debian Secure Boot CA: 6ccece7e4c6c0d1f6149f3dd27dfcc5cbb419ea1'
[ 1.082386] Loaded X.509 cert 'Debian Secure Boot Signer 2021 - linux: 4b6ef5abca669825178e052c84667ccbc0531f8c'
[ 1.083821] zswap: loaded using pool lzo/zbud
[ 1.084359] AppArmor: AppArmor sha1 policy hashing enabled
[ 1.085154] rtc-efi rtc-efi: setting system clock to 2021-05-03 20:56:46 UTC (1620075406)
[ 1.089031] Freeing unused kernel memory: 4800K
[ 1.099153] Run /init as init process
[ 1.233104] PCI Interrupt Link [GSI1] enabled at IRQ 36
[ 1.234185] virtio-pci 0000:00:01.0: enabling device (0005 -> 0007)
[ 1.239108] PCI Interrupt Link [GSI2] enabled at IRQ 37
[ 1.239741] virtio-pci 0000:00:02.0: enabling device (0005 -> 0007)
[ 1.244804] PCI Interrupt Link [GSI3] enabled at IRQ 38
[ 1.245430] virtio-pci 0000:00:03.0: enabling device (0005 -> 0007)
[ 1.254650] PCI Interrupt Link [GSI0] enabled at IRQ 35
[ 1.256526] virtio-pci 0000:00:04.0: enabling device (0005 -> 0007)
[ 1.266467] virtio-pci 0000:00:05.0: enabling device (0005 -> 0007)
[ 1.274944] virtio_blk virtio0: [vda] 88080392 512-byte logical blocks (45.1 GB/42.0 GiB)
[ 1.285954] vda: vda1 vda2
[ 1.290979] SCSI subsystem initialized
[ 1.295637] scsi host0: Virtio SCSI HBA
[ 1.298209] scsi 0:0:0:0: CD-ROM QEMU QEMU CD-ROM 2.5+ PQ: 0 ANSI: 5
[ 1.376820] random: fast init done
[ 1.428241] sr 0:0:0:0: Power-on or device reset occurred
[ 1.429224] sr 0:0:0:0: [sr0] scsi3-mmc drive: 16x/50x cd/rw xa/form2 cdda tray
[ 1.430037] cdrom: Uniform CD-ROM driver Revision: 3.20
[ 1.431309] sr 0:0:0:0: Attached scsi CD-ROM sr0
[ 2.519346] EXT4-fs (vda2): mounted filesystem with ordered data mode. Opts: (null)
[ 2.774957] systemd[1]: Inserted module 'autofs4'
[ 2.788812] random: crng init done
[ 2.802041] systemd[1]: systemd 241 running in system mode. (+PAM +AUDIT +SELINUX +IMA +APPARMOR +SMACK +SYSVINIT +UTMP +LIBCRYPTSETUP +GCRYPT +GNUTLS +ACL +XZ +LZ4 +SECCOMP +BLKID +ELFUTILS +KMOD -IDN2 +IDN -PCRE2 default-hierarchy=hybrid)
[ 2.804948] systemd[1]: Detected virtualization kvm.
[ 2.805534] systemd[1]: Detected architecture arm64.
[ 2.808446] systemd[1]: Set hostname to <Jeedom-free>.
[ 3.069953] systemd[1]: /lib/systemd/system/fail2ban.service:12: PIDFile= references path below legacy directory /var/run/, updating /var/run/fail2ban/fail2ban.pid → /run/fail2ban/fail2ban.pid; please update the unit file accordingly.
[ 3.093194] systemd[1]: Created slice system-getty.slice.
[ 3.094029] systemd[1]: Reached target System Time Synchronized.
[ 3.094797] systemd[1]: Reached target Swap.
[ 3.095555] systemd[1]: Listening on initctl Compatibility Named Pipe.
[ 3.096441] systemd[1]: Started Forward Password Requests to Wall Directory Watch.
[ 3.244492] EXT4-fs (vda2): re-mounted. Opts: errors=remount-ro
[ 3.290369] systemd-journald[179]: Received request to flush runtime journal from PID 1
[ 3.623587] EFI Variables Facility v0.08 2004-May-17
[ 3.628828] pstore: Using compression: deflate
[ 3.629370] pstore: Registered efi as persistent store backend
[ 3.630913] sr 0:0:0:0: Attached scsi generic sg0 type 5
[ 3.753077] cryptd: max_cpu_qlen set to 1000
[ 3.889910] FAT-fs (vda1): Volume was not properly unmounted. Some data may be corrupt. Please run fsck.
[ 4.004899] audit: type=1400 audit(1620075409.416:2): apparmor="STATUS" operation="profile_load" profile="unconfined" name="/usr/bin/man" pid=274 comm="apparmor_parser"
[ 4.007404] audit: type=1400 audit(1620075409.416:3): apparmor="STATUS" operation="profile_load" profile="unconfined" name="man_filter" pid=274 comm="apparmor_parser"
[ 4.009988] audit: type=1400 audit(1620075409.416:4): apparmor="STATUS" operation="profile_load" profile="unconfined" name="man_groff" pid=274 comm="apparmor_parser"
[ 4.017451] audit: type=1400 audit(1620075409.428:5): apparmor="STATUS" operation="profile_load" profile="unconfined" name="/usr/sbin/ntpd" pid=275 comm="apparmor_parser"
[ 4.020702] audit: type=1400 audit(1620075409.432:6): apparmor="STATUS" operation="profile_load" profile="unconfined" name="nvidia_modprobe" pid=276 comm="apparmor_parser"
[ 4.022370] audit: type=1400 audit(1620075409.432:7): apparmor="STATUS" operation="profile_load" profile="unconfined" name="nvidia_modprobe//kmod" pid=276 comm="apparmor_parser"
[ 4.794554] ISO 9660 Extensions: Microsoft Joliet Level 3
[ 4.799728] ISO 9660 Extensions: RRIP_1991A
[ 7.601133] FS-Cache: Loaded
[ 7.607989] Key type dns_resolver registered
[ 7.707848] FS-Cache: Netfs 'cifs' registered for caching
[ 7.712927] Key type cifs.spnego registered
[ 7.713734] Key type cifs.idmap registered
[ 7.715940] No dialect specified on mount. Default has changed to a more secure dialect, SMB2.1 or later (e.g. SMB3), from CIFS (SMB1). To use the less secure SMB1 dialect to access old servers which do not support SMB3 (or SMB2.1) specify vers=1.0 on mount.
[ 7.826025] Adding 1048572k swap on /var/swap. Priority:-2 extents:5 across:1212412k FS
