[2022-06-23 12:14:34]INFO : Start zigbeed
[2022-06-23 12:14:34]INFO : Log level : debug
[2022-06-23 12:14:34]INFO : PID file : /tmp/jeedom/zigbee/deamon_1.pid
[2022-06-23 12:14:34]INFO : Device : /dev/ttyUSB0
[2022-06-23 12:14:34]INFO : Apikey : T7uyv0kLwk9pEmJ6UVl8BmEmaPCPk5clPU7cXxsEgOru4klNSK7NN2BjqWAMrSg7
[2022-06-23 12:14:34]INFO : Callback : http://127.0.0.1:80/plugins/zigbee/core/php/jeeZigbee.php
[2022-06-23 12:14:34]INFO : Cycle : 0.3
[2022-06-23 12:14:34]INFO : Controller : ezsp
[2022-06-23 12:14:34]INFO : Channel : 15
[2022-06-23 12:14:34]INFO : Data folder : /var/www/html/plugins/zigbee/data/1
[2022-06-23 12:14:34]INFO : Device folder : /var/www/html/plugins/zigbee/data/device
[2022-06-23 12:14:34]INFO : Folder OTA : None
[2022-06-23 12:14:34]INFO : Zigpy advance configuration file : None
File "/var/www/html/plugins/zigbee/resources/zigbeed/zigbeed.py", line 235, in
from bellows.zigbee.application import ControllerApplication
File "/usr/local/lib/python3.7/dist-packages/bellows/zigbee/application.py", line 9, in
import zigpy.application
ModuleNotFoundError: No module named 'zigpy'
[2022-06-23 12:24:18]INFO : Start zigbeed
[2022-06-23 12:24:18]INFO : Log level : debug
[2022-06-23 12:24:18]INFO : PID file : /tmp/jeedom/zigbee/deamon_1.pid
[2022-06-23 12:24:18]INFO : Device : /dev/ttyUSB0
[2022-06-23 12:24:18]INFO : Apikey : T7uyv0kLwk9pEmJ6UVl8BmEmaPCPk5clPU7cXxsEgOru4klNSK7NN2BjqWAMrSg7
[2022-06-23 12:24:18]INFO : Callback : http://127.0.0.1:80/plugins/zigbee/core/php/jeeZigbee.php
[2022-06-23 12:24:18]INFO : Cycle : 0.3
[2022-06-23 12:24:18]INFO : Controller : ezsp
[2022-06-23 12:24:18]INFO : Channel : 15
[2022-06-23 12:24:18]INFO : Data folder : /var/www/html/plugins/zigbee/data/1
[2022-06-23 12:24:18]INFO : Device folder : /var/www/html/plugins/zigbee/data/device
[2022-06-23 12:24:18]INFO : Folder OTA : None
[2022-06-23 12:24:18]INFO : Zigpy advance configuration file : None
[2022-06-23 12:24:21]DEBUG : SQLite version for : 3.27.2
File "/usr/local/lib/python3.7/dist-packages/bellows/zigbee/application.py", line 25, in
import bellows.ezsp
File "/usr/local/lib/python3.7/dist-packages/bellows/ezsp/__init__.py", line 21, in
import bellows.types as t
File "/usr/local/lib/python3.7/dist-packages/bellows/types/__init__.py", line 3, in
from .struct import * # noqa: F401,F403
File "/usr/local/lib/python3.7/dist-packages/bellows/types/struct.py", line 258, in
class EmberNetworkParameters(EzspStruct):
File "/usr/local/lib/python3.7/dist-packages/bellows/types/struct.py", line 286, in EmberNetworkParameters
def zigpy_network_information(self) -> app_state.NetworkInformation:
AttributeError: module 'zigpy.state' has no attribute 'NetworkInformation'
Tu peux essayer de remettre a jour le plugin j’ai fait une correction pour ca ya quelques minutes, si ca plante toujours je t’invite a lire le sujet principal qui contiendra surement ton probleme.
ok je vais essayer
J’essai juste d’être utile
PS : Je passe sur le sujet principal
