Mes dependances bloquent a l’installation
J’ai desinstallé/reinstallé, et essayé egalement avec la version beta, c’est le meme probleme…
Je suis sur une Jeedom Atlas 4.1.28
Voici le log de l’installation
Mille merci pour votre aide
Pierre
Launch install of googlecast dependancies
-- Current OS version :
Description: Debian GNU/Linux 10 (buster)
-- Updating repo...
Hit:1 http://security.debian.org buster/updates InRelease
Hit:2 http://deb.debian.org/debian buster InRelease
Hit:3 http://deb.debian.org/debian buster-updates InRelease
Hit:4 http://deb.debian.org/debian buster-backports InRelease
Hit:5 https://deb.nodesource.com/node_14.x buster InRelease
Hit:6 http://armbian.hosthatch.com/apt buster InRelease
Reading package lists...
-- Installation of python3 and dependancies
Building dependency tree...
Reading state information...
build-essential is already the newest version (12.6).
python-dev is already the newest version (2.7.16-1).
python3 is already the newest version (3.7.3-1).
0 upgraded, 0 newly installed, 0 to remove and 56 not upgraded.
-- Installed version of Python :
Python 3.7.3
Your version of python is compatible with this plugin.
-- Installation of pip for python3 and necessary libraries
python3-pip is already the newest version (18.1-5).
python3-dev is already the newest version (3.7.3-1).
python-requests is already the newest version (2.21.0-1).
-- Installation of audio sox library
sox is already the newest version (14.4.2+git20190427-1).
-- Installation of TTS libraries
libttspico-utils is already the newest version (1.0+git20130326-9).
-- Installation of libav/ffmpeg libraries
ffmpeg is already the newest version (7:4.1.8-0+deb10u1).
-- Upgrade setuptools with command pip3 if not up to date
Requirement already satisfied: setuptools>=42.0.0 in /usr/local/lib/python3.7/dist-packages (60.5.0)
-- Installed version of pip :
pip 18.1 from /usr/lib/python3/dist-packages/pip (python 3.7)
-- Installation of python library 'requests' with command pip3
Requirement already satisfied: requests>=2.21.0 in /usr/local/lib/python3.7/dist-packages (2.27.1)
Requirement already satisfied: certifi>=2017.4.17 in /usr/local/lib/python3.7/dist-packages (from requests>=2.21.0) (2021.10.8)
Requirement already satisfied: charset-normalizer~=2.0.0; python_version >= "3" in /usr/local/lib/python3.7/dist-packages (from requests>=2.21.0) (2.0.10)
Requirement already satisfied: idna<4,>=2.5; python_version >= "3" in /usr/local/lib/python3.7/dist-packages (from requests>=2.21.0) (3.3)
Requirement already satisfied: urllib3<1.27,>=1.21.1 in /usr/local/lib/python3.7/dist-packages (from requests>=2.21.0) (1.26.8)
-- Installation of python library 'protobuf' with command pip3
Requirement already satisfied: protobuf>=3.11.0 in /usr/local/lib/python3.7/dist-packages (3.19.3)
-- Installation of python library 'zeroconf' with command pip3
Requirement already satisfied: zeroconf==0.31.0 in /usr/local/lib/python3.7/dist-packages (0.31.0)
Requirement already satisfied: ifaddr>=0.1.7 in /usr/local/lib/python3.7/dist-packages (from zeroconf==0.31.0) (0.1.7)
-- Installation of python library 'click, bs4 and six' for TTS with command pip3
Failed building wheel for bs4
Requirement already satisfied: click in /usr/local/lib/python3.7/dist-packages (8.0.3)
Collecting bs4
Using cached https://files.pythonhosted.org/packages/10/ed/7e8b97591f6f456174139ec089c769f89a94a1a4025fe967691de971f314/bs4-0.0.1.tar.gz
Requirement already satisfied: six in /usr/local/lib/python3.7/dist-packages (1.16.0)
Requirement already satisfied: importlib-metadata; python_version < "3.8" in /usr/local/lib/python3.7/dist-packages (from click) (4.10.1)
Requirement already satisfied: beautifulsoup4 in /usr/local/lib/python3.7/dist-packages (from bs4) (4.10.0)
Requirement already satisfied: typing-extensions>=3.6.4; python_version < "3.8" in /usr/local/lib/python3.7/dist-packages (from importlib-metadata; python_version < "3.8"->click) (4.0.1)
Requirement already satisfied: zipp>=0.5 in /usr/local/lib/python3.7/dist-packages (from importlib-metadata; python_version < "3.8"->click) (3.7.0)
Requirement already satisfied: soupsieve>1.2 in /usr/local/lib/python3.7/dist-packages (from beautifulsoup4->bs4) (2.3.1)
Building wheels for collected packages: bs4
Running setup.py bdist_wheel for bs4: started
Running setup.py bdist_wheel for bs4: finished with status 'error'
Complete output from command /usr/bin/python3 -u -c "import setuptools, tokenize;__file__='/tmp/pip-install-hm7r37ep/bs4/setup.py';f=getattr(tokenize, 'open', open)(__file__);code=f.read().replace('
');f.close();exec(compile(code, __file__, 'exec'))" bdist_wheel -d /tmp/pip-wheel-t2gqz9d_ --python-tag cp37:
usage: -c [global_opts] cmd1 [cmd1_opts] [cmd2 [cmd2_opts] ...]
or: -c --help [cmd1 cmd2 ...]
or: -c --help-commands
or: -c cmd --help
error: invalid command 'bdist_wheel'
Running setup.py clean for bs4
Failed to build bs4
Installing collected packages: bs4
Running setup.py install for bs4: started
Running setup.py install for bs4: finished with status 'done'
Successfully installed bs4
-- Installation of python library 'tqdm, websocket-client, casttube' for plex/youtube with command pip3
Requirement already satisfied: tqdm in /usr/local/lib/python3.7/dist-packages (4.62.3)
Requirement already satisfied: websocket-client in /usr/local/lib/python3.7/dist-packages (1.2.3)
Requirement already satisfied: casttube in /usr/local/lib/python3.7/dist-packages (0.2.1)
Requirement already satisfied: requests in /usr/local/lib/python3.7/dist-packages (from casttube) (2.27.1)
Requirement already satisfied: certifi>=2017.4.17 in /usr/local/lib/python3.7/dist-packages (from requests->casttube) (2021.10.8)
Requirement already satisfied: urllib3<1.27,>=1.21.1 in /usr/local/lib/python3.7/dist-packages (from requests->casttube) (1.26.8)
Requirement already satisfied: idna<4,>=2.5; python_version >= "3" in /usr/local/lib/python3.7/dist-packages (from requests->casttube) (3.3)
Requirement already satisfied: charset-normalizer~=2.0.0; python_version >= "3" in /usr/local/lib/python3.7/dist-packages (from requests->casttube) (2.0.10)
-- Installation of dependencies is done !
