Bonjour, je n’arrive toujours pas a installer les dépendances du plugin EIB/KNX. Mais J’ai réussi à récupérer des logs… Arrivé à ce stade la jeedom est plantée et plus rien n’est aceesible (ni en http, ni en ssh…)
pourriez vous m’aider à me dire ce qui bloque s’il vous plait…?
-- Performing Test FMT_CPP11_SNPRINTF
-- Performing Test FMT_CPP11_SNPRINTF - Success
-- Performing Test SUPPORTS_VARIADIC_TEMPLATES
-- Performing Test SUPPORTS_VARIADIC_TEMPLATES - Success
-- Performing Test SUPPORTS_INITIALIZER_LIST
-- Performing Test SUPPORTS_INITIALIZER_LIST - Success
-- Performing Test SUPPORTS_ENUM_BASE
-- Performing Test SUPPORTS_ENUM_BASE - Success
-- Performing Test SUPPORTS_TYPE_TRAITS
-- Performing Test SUPPORTS_TYPE_TRAITS - Success
-- Performing Test SUPPORTS_USER_DEFINED_LITERALS
-- Performing Test SUPPORTS_USER_DEFINED_LITERALS - Success
-- Looking for open
-- Looking for open - found
-- Target 'doc' disabled (requires doxygen)
-- Looking for pthread.h
-- Looking for pthread.h - found
-- Looking for pthread_create
-- Looking for pthread_create - not found
-- Looking for pthread_create in pthreads
-- Looking for pthread_create in pthreads - not found
-- Looking for pthread_create in pthread - found
-- Found Threads: TRUE
-- Performing Test HAVE_FNO_DELETE_NULL_POINTER_CHECKS
-- Performing Test HAVE_FNO_DELETE_NULL_POINTER_CHECKS - Success
-- Performing Test HAVE_FNO_EXCEPTIONS_FLAG
-- Performing Test HAVE_FNO_EXCEPTIONS_FLAG - Success
-- Configuring done
-- Generating done
-- Build files have been written to: /usr/local/src/knxd/knxd/libfmt
+ make fmt
make[2]: Entering directory '/usr/local/src/knxd/knxd/libfmt'
make[3]: Entering directory '/usr/local/src/knxd/knxd/libfmt'
make[4]: Entering directory '/usr/local/src/knxd/knxd/libfmt'
make[5]: Entering directory '/usr/local/src/knxd/knxd/libfmt'
Scanning dependencies of target fmt
make[5]: Leaving directory '/usr/local/src/knxd/knxd/libfmt'
[ 20%] Building CXX object fmt/CMakeFiles/fmt.dir/posix.cc.o
[ 40%] Building CXX object fmt/CMakeFiles/fmt.dir/format.cc.o
[ 60%] Building CXX object fmt/CMakeFiles/fmt.dir/ostream.cc.o
[ 80%] Building CXX object fmt/CMakeFiles/fmt.dir/printf.cc.o
[100%] Linking CXX static library libfmt.a
[100%] Built target fmt
make[4]: Leaving directory '/usr/local/src/knxd/knxd/libfmt'
make[3]: Leaving directory '/usr/local/src/knxd/knxd/libfmt'
make[2]: Leaving directory '/usr/local/src/knxd/knxd/libfmt'
checking fmt/printf.h usability...
yes
checking fmt/printf.h presence... yes
checking for fmt/printf.h... yes
checking for ev_run in -lev...
yes
checking for indent... no
checking for fastjar... no
checking for jar... no
checking for gcj... no
checking for javac... no
checking for struct sockaddr_in.sin_len... no
checking that generated files are newer than configure... done
configure: creating ./config.status
config.status: creating Makefile
config.status: creating src/common/Makefile
config.status: creating src/Makefile
config.status: creating src/include/Makefile
config.status: creating src/client/Makefile
config.status: creating src/examples/Makefile
config.status: creating src/libserver/Makefile
config.status: creating src/server/Makefile
config.status: creating src/backend/Makefile
config.status: creating src/client/def/Makefile
config.status: creating src/client/c/Makefile
config.status: creating src/client/java/Makefile
config.status: creating src/client/php/Makefile
config.status: creating src/client/cs/Makefile
config.status: creating src/client/perl/Makefile
config.status: creating src/client/python/Makefile
config.status: creating src/client/pascal/Makefile
config.status: creating src/client/ruby/Makefile
config.status: creating src/client/lua/Makefile
config.status: creating src/client/go/Makefile
config.status: creating src/usb/Makefile
config.status: creating src/tools/Makefile
config.status: creating systemd/Makefile
config.status: creating systemd/knxd.service
config.status: creating systemd/knxd.socket
config.status: creating config.h
config.status: executing depfiles commands
config.status: executing libtool commands
configure: WARNING: unrecognized options: --disable-maintainer-mode
make[1]: Leaving directory '/usr/local/src/knxd/knxd'
dh_auto_build
make -j4
make[1]: Entering directory '/usr/local/src/knxd/knxd'
echo "#define PKGDATADIR \"/usr/share/knxd\"" >path.h
echo "#define PKGLIBDIR \"/usr/lib/aarch64-linux-gnu/knxd\"" >>path.h
echo "#define REAL_VERSION \"0.14.51\"" >>version.h.new
cmp -s version.h.new version.h && rm version.h.new || mv version.h.new version.h
make all-recursive
make[2]: Entering directory '/usr/local/src/knxd/knxd'
Making all in .
make[3]: Entering directory '/usr/local/src/knxd/knxd'
make[3]: Nothing to be done for 'all-am'.
make[3]: Leaving directory '/usr/local/src/knxd/knxd'
Making all in src
make[3]: Entering directory '/usr/local/src/knxd/knxd/src'
Making all in common
make[4]: Entering directory '/usr/local/src/knxd/knxd/src/common'
CXX image.o
CXX loadimage.o
CXX iobuf.o
CC inih.o
CXX inifile.o
AR libcommon.a
ar: `u' modifier ignored since `D' is the default (see `U')
make[4]: Leaving directory '/usr/local/src/knxd/knxd/src/common'
Making all in include
make[4]: Entering directory '/usr/local/src/knxd/knxd/src/include'
make[4]: Nothing to be done for 'all'.
make[4]: Leaving directory '/usr/local/src/knxd/knxd/src/include'
Making all in client
make[4]: Entering directory '/usr/local/src/knxd/knxd/src/client'
Making all in def
make[5]: Entering directory '/usr/local/src/knxd/knxd/src/client/def'
make[5]: Nothing to be done for 'all'.
make[5]: Leaving directory '/usr/local/src/knxd/knxd/src/client/def'
Making all in c
make[5]: Entering directory '/usr/local/src/knxd/knxd/src/client/c'
mkdir -p gen
mkdir -p gen
mkdir -p gen
mkdir -p gen
echo '#include "eibclient-int.h"' > gen/loadimage.c
echo '#include "eibclient-int.h"' > gen/getapdu.c
echo '#include "eibclient-int.h"' > gen/mcpropertyread.c
echo '#include "def/'`basename gen/loadimage.c|sed -e "s/\.c/.inc/g"`'"' >> gen/loadimage.c
echo '#include "eibclient-int.h"' > gen/mprogmodeoff.c
echo '#include "def/'`basename gen/getapdu.c|sed -e "s/\.c/.inc/g"`'"' >> gen/getapdu.c
echo '#include "def/'`basename gen/mcpropertyread.c|sed -e "s/\.c/.inc/g"`'"' >> gen/mcpropertyread.c
echo '#include "def/'`basename gen/mprogmodeoff.c|sed -e "s/\.c/.inc/g"`'"' >> gen/mprogmodeoff.c
mkdir -p gen
mkdir -p gen
mkdir -p gen
echo '#include "eibclient-int.h"' > gen/opentconnection.c
echo '#include "eibclient-int.h"' > gen/getapdusrc.c
echo '#include "def/'`basename gen/opentconnection.c|sed -e "s/\.c/.inc/g"`'"' >> gen/opentconnection.c
mkdir -p gen
echo '#include "eibclient-int.h"' > gen/mcauthorize.c
echo '#include "def/'`basename gen/getapdusrc.c|sed -e "s/\.c/.inc/g"`'"' >> gen/getapdusrc.c
echo '#include "def/'`basename gen/mcauthorize.c|sed -e "s/\.c/.inc/g"`'"' >> gen/mcauthorize.c
echo '#include "eibclient-int.h"' > gen/mcpropertyscan.c
mkdir -p gen
echo '#include "def/'`basename gen/mcpropertyscan.c|sed -e "s/\.c/.inc/g"`'"' >> gen/mcpropertyscan.c
mkdir -p gen
echo '#include "eibclient-int.h"' > gen/mprogmodeon.c
echo '#include "def/'`basename gen/mprogmodeon.c|sed -e "s/\.c/.inc/g"`'"' >> gen/mprogmodeon.c
mkdir -p gen
echo '#include "eibclient-int.h"' > gen/opentgroup.c
mkdir -p gen
echo '#include "def/'`basename gen/opentgroup.c|sed -e "s/\.c/.inc/g"`'"' >> gen/opentgroup.c
echo '#include "eibclient-int.h"' > gen/mcconnect.c
echo '#include "eibclient-int.h"' > gen/getbusmonitorpacket.c
mkdir -p gen
echo '#include "def/'`basename gen/getbusmonitorpacket.c|sed -e "s/\.c/.inc/g"`'"' >> gen/getbusmonitorpacket.c
echo '#include "eibclient-int.h"' > gen/mcpropertywrite.c
echo '#include "def/'`basename gen/mcconnect.c|sed -e "s/\.c/.inc/g"`'"' >> gen/mcconnect.c
mkdir -p gen
echo '#include "def/'`basename gen/mcpropertywrite.c|sed -e "s/\.c/.inc/g"`'"' >> gen/mcpropertywrite.c
mkdir -p gen
echo '#include "eibclient-int.h"' > gen/mprogmodestatus.c
mkdir -p gen
echo '#include "def/'`basename gen/mprogmodestatus.c|sed -e "s/\.c/.inc/g"`'"' >> gen/mprogmodestatus.c
echo '#include "eibclient-int.h"' > gen/opentindividual.c
echo '#include "def/'`basename gen/opentindividual.c|sed -e "s/\.c/.inc/g"`'"' >> gen/opentindividual.c
echo '#include "eibclient-int.h"' > gen/getgroupsrc.c
mkdir -p gen
echo '#include "def/'`basename gen/getgroupsrc.c|sed -e "s/\.c/.inc/g"`'"' >> gen/getgroupsrc.c
mkdir -p gen
echo '#include "eibclient-int.h"' > gen/mcgetmaskversion.c
echo '#include "def/'`basename gen/mcgetmaskversion.c|sed -e "s/\.c/.inc/g"`'"' >> gen/mcgetmaskversion.c
mkdir -p gen
echo '#include "eibclient-int.h"' > gen/mcreadadc.c
mkdir -p gen
echo '#include "eibclient-int.h"' > gen/mprogmodetoggle.c
mkdir -p gen
echo '#include "def/'`basename gen/mcreadadc.c|sed -e "s/\.c/.inc/g"`'"' >> gen/mcreadadc.c
echo '#include "def/'`basename gen/mprogmodetoggle.c|sed -e "s/\.c/.inc/g"`'"' >> gen/mprogmodetoggle.c
echo '#include "eibclient-int.h"' > gen/openttpdu.c
echo '#include "eibclient-int.h"' > gen/groupcacheclear.c
echo '#include "def/'`basename gen/openttpdu.c|sed -e "s/\.c/.inc/g"`'"' >> gen/openttpdu.c
echo '#include "def/'`basename gen/groupcacheclear.c|sed -e "s/\.c/.inc/g"`'"' >> gen/groupcacheclear.c
mkdir -p gen
mkdir -p gen
mkdir -p gen
echo '#include "eibclient-int.h"' > gen/mcgetpeitype.c
mkdir -p gen
echo '#include "eibclient-int.h"' > gen/mcread.c
echo '#include "eibclient-int.h"' > gen/mreadindividualaddresses.c
echo '#include "def/'`basename gen/mcgetpeitype.c|sed -e "s/\.c/.inc/g"`'"' >> gen/mcgetpeitype.c
echo '#include "def/'`basename gen/mcread.c|sed -e "s/\.c/.inc/g"`'"' >> gen/mcread.c
echo '#include "eibclient-int.h"' > gen/openvbusmonitor.c
echo '#include "def/'`basename gen/mreadindividualaddresses.c|sed -e "s/\.c/.inc/g"`'"' >> gen/mreadindividualaddresses.c
echo '#include "def/'`basename gen/openvbusmonitor.c|sed -e "s/\.c/.inc/g"`'"' >> gen/openvbusmonitor.c
mkdir -p gen
mkdir -p gen
mkdir -p gen
echo '#include "eibclient-int.h"' > gen/groupcachedisable.c
mkdir -p gen
echo '#include "def/'`basename gen/groupcachedisable.c|sed -e "s/\.c/.inc/g"`'"' >> gen/groupcachedisable.c
echo '#include "eibclient-int.h"' > gen/mcprogmodeoff.c
echo '#include "eibclient-int.h"' > gen/mcrestart.c
echo '#include "eibclient-int.h"' > gen/mwriteindividualaddress.c
echo '#include "def/'`basename gen/mcprogmodeoff.c|sed -e "s/\.c/.inc/g"`'"' >> gen/mcprogmodeoff.c
echo '#include "def/'`basename gen/mcrestart.c|sed -e "s/\.c/.inc/g"`'"' >> gen/mcrestart.c
echo '#include "def/'`basename gen/mwriteindividualaddress.c|sed -e "s/\.c/.inc/g"`'"' >> gen/mwriteindividualaddress.c
mkdir -p gen
mkdir -p gen
echo '#include "eibclient-int.h"' > gen/openvbusmonitortext.c
mkdir -p gen
mkdir -p gen
echo '#include "eibclient-int.h"' > gen/groupcacheenable.c
echo '#include "def/'`basename gen/openvbusmonitortext.c|sed -e "s/\.c/.inc/g"`'"' >> gen/openvbusmonitortext.c
echo '#include "def/'`basename gen/groupcacheenable.c|sed -e "s/\.c/.inc/g"`'"' >> gen/groupcacheenable.c
echo '#include "eibclient-int.h"' > gen/mcprogmodeon.c
echo '#include "eibclient-int.h"' > gen/mcsetkey.c
mkdir -p gen
echo '#include "def/'`basename gen/mcprogmodeon.c|sed -e "s/\.c/.inc/g"`'"' >> gen/mcprogmodeon.c
echo '#include "def/'`basename gen/mcsetkey.c|sed -e "s/\.c/.inc/g"`'"' >> gen/mcsetkey.c
mkdir -p gen
echo '#include "eibclient-int.h"' > gen/openbusmonitor.c
echo '#include "eibclient-int.h"' > gen/reset.c
echo '#include "def/'`basename gen/openbusmonitor.c|sed -e "s/\.c/.inc/g"`'"' >> gen/openbusmonitor.c
echo '#include "def/'`basename gen/reset.c|sed -e "s/\.c/.inc/g"`'"' >> gen/reset.c
mkdir -p gen
mkdir -p gen
echo '#include "eibclient-int.h"' > gen/groupcacheread.c
echo '#include "def/'`basename gen/groupcacheread.c|sed -e "s/\.c/.inc/g"`'"' >> gen/groupcacheread.c
echo '#include "eibclient-int.h"' > gen/mcprogmodestatus.c
mkdir -p gen
echo '#include "def/'`basename gen/mcprogmodestatus.c|sed -e "s/\.c/.inc/g"`'"' >> gen/mcprogmodestatus.c
mkdir -p gen
echo '#include "eibclient-int.h"' > gen/mcwrite.c
mkdir -p gen
echo '#include "def/'`basename gen/mcwrite.c|sed -e "s/\.c/.inc/g"`'"' >> gen/mcwrite.c
mkdir -p gen
echo '#include "eibclient-int.h"' > gen/openbusmonitortext.c
echo '#include "eibclient-int.h"' > gen/sendapdu.c
echo '#include "def/'`basename gen/openbusmonitortext.c|sed -e "s/\.c/.inc/g"`'"' >> gen/openbusmonitortext.c
echo '#include "def/'`basename gen/sendapdu.c|sed -e "s/\.c/.inc/g"`'"' >> gen/sendapdu.c
echo '#include "eibclient-int.h"' > gen/groupcachereadsync.c
mkdir -p gen
echo '#include "def/'`basename gen/groupcachereadsync.c|sed -e "s/\.c/.inc/g"`'"' >> gen/groupcachereadsync.c
mkdir -p gen
echo '#include "eibclient-int.h"' > gen/mcprogmodetoggle.c
mkdir -p gen
echo '#include "def/'`basename gen/mcprogmodetoggle.c|sed -e "s/\.c/.inc/g"`'"' >> gen/mcprogmodetoggle.c
echo '#include "eibclient-int.h"' > gen/mcwriteplain.c
echo '#include "def/'`basename gen/mcwriteplain.c|sed -e "s/\.c/.inc/g"`'"' >> gen/mcwriteplain.c
echo '#include "eibclient-int.h"' > gen/opengroupsocket.c
mkdir -p gen
mkdir -p gen
echo '#include "def/'`basename gen/opengroupsocket.c|sed -e "s/\.c/.inc/g"`'"' >> gen/opengroupsocket.c
echo '#include "eibclient-int.h"' > gen/sendgroup.c
echo '#include "eibclient-int.h"' > gen/groupcacheremove.c
mkdir -p gen
echo '#include "def/'`basename gen/sendgroup.c|sed -e "s/\.c/.inc/g"`'"' >> gen/sendgroup.c
echo '#include "def/'`basename gen/groupcacheremove.c|sed -e "s/\.c/.inc/g"`'"' >> gen/groupcacheremove.c
mkdir -p gen
echo '#include "eibclient-int.h"' > gen/mcpropertydesc.c
echo '#include "eibclient-int.h"' > gen/mgetmaskversion.c
mkdir -p gen
echo '#include "def/'`basename gen/mcpropertydesc.c|sed -e "s/\.c/.inc/g"`'"' >> gen/mcpropertydesc.c
echo '#include "def/'`basename gen/mgetmaskversion.c|sed -e "s/\.c/.inc/g"`'"' >> gen/mgetmaskversion.c
mkdir -p gen
echo '#include "eibclient-int.h"' > gen/sendtpdu.c
echo '#include "eibclient-int.h"' > gen/opentbroadcast.c
echo '#include "def/'`basename gen/sendtpdu.c|sed -e "s/\.c/.inc/g"`'"' >> gen/sendtpdu.c
echo '#include "def/'`basename gen/opentbroadcast.c|sed -e "s/\.c/.inc/g"`'"' >> gen/opentbroadcast.c
mkdir -p gen
mkdir -p gen
echo '#include "eibclient-int.h"' > gen/gettpdu.c
mkdir -p gen
echo '#include "eibclient-int.h"' > gen/mcindividual.c
echo '#include "def/'`basename gen/gettpdu.c|sed -e "s/\.c/.inc/g"`'"' >> gen/gettpdu.c
mkdir -p gen
echo '#include "def/'`basename gen/mcindividual.c|sed -e "s/\.c/.inc/g"`'"' >> gen/mcindividual.c
echo '#include "eibclient-int.h"' > gen/openbusmonitorts.c
echo '#include "eibclient-int.h"' > gen/groupcachelastupdates.c
mkdir -p gen
echo '#include "def/'`basename gen/openbusmonitorts.c|sed -e "s/\.c/.inc/g"`'"' >> gen/openbusmonitorts.c
echo '#include "def/'`basename gen/groupcachelastupdates.c|sed -e "s/\.c/.inc/g"`'"' >> gen/groupcachelastupdates.c
mkdir -p gen
echo '#include "eibclient-int.h"' > gen/openvbusmonitorts.c
echo '#include "eibclient-int.h"' > gen/getbusmonitorpacketts.c
echo '#include "def/'`basename gen/openvbusmonitorts.c|sed -e "s/\.c/.inc/g"`'"' >> gen/openvbusmonitorts.c
echo '#include "def/'`basename gen/getbusmonitorpacketts.c|sed -e "s/\.c/.inc/g"`'"' >> gen/getbusmonitorpacketts.c
make all-am
make[6]: Entering directory '/usr/local/src/knxd/knxd/src/client/c'
CC close.lo
CC closesync.lo
CC complete.lo
CC io.lo
CC openlocal.lo
CC openremote.lo
CC openurl.lo
CC pollcomplete.lo
CC pollfd.lo
CC gen/getapdu.lo
CC gen/loadimage.lo
CC gen/mcpropertyread.lo
CC gen/mprogmodeoff.lo
CC gen/opentconnection.lo
CC gen/getapdusrc.lo
CC gen/mcauthorize.lo
CC gen/mcpropertyscan.lo
CC gen/mprogmodeon.lo
CC gen/opentgroup.lo
CC gen/getbusmonitorpacket.lo
CC gen/mcconnect.lo
CC gen/mcpropertywrite.lo
CC gen/mprogmodestatus.lo
CC gen/opentindividual.lo
CC gen/getgroupsrc.lo
CC gen/mcgetmaskversion.lo
CC gen/mcreadadc.lo
CC gen/mprogmodetoggle.lo
CC gen/openttpdu.lo
CC gen/groupcacheclear.lo
CC gen/mcgetpeitype.lo
CC gen/mcread.lo
CC gen/mreadindividualaddresses.lo
CC gen/openvbusmonitor.lo
CC gen/groupcachedisable.lo
CC gen/mcprogmodeoff.lo
CC gen/mcrestart.lo
CC gen/mwriteindividualaddress.lo
CC gen/openvbusmonitortext.lo
CC gen/groupcacheenable.lo
CC gen/mcprogmodeon.lo
CC gen/mcsetkey.lo
CC gen/openbusmonitor.lo
CC gen/reset.lo
CC gen/groupcacheread.lo
CC gen/mcprogmodestatus.lo
CC gen/mcwrite.lo
CC gen/openbusmonitortext.lo
CC gen/sendapdu.lo
CC gen/groupcachereadsync.lo
CC gen/mcprogmodetoggle.lo
CC gen/mcwriteplain.lo
CC gen/opengroupsocket.lo
CC gen/sendgroup.lo
CC gen/groupcacheremove.lo
CC gen/mcpropertydesc.lo
CC gen/mgetmaskversion.lo
CC gen/opentbroadcast.lo
CC gen/sendtpdu.lo
CC gen/gettpdu.lo
CC gen/mcindividual.lo
CC gen/groupcachelastupdates.lo
CC gen/openbusmonitorts.lo
CC gen/openvbusmonitorts.lo
CC gen/getbusmonitorpacketts.lo
CCLD libeibclient.la
make[6]: Leaving directory '/usr/local/src/knxd/knxd/src/client/c'
make[5]: Leaving directory '/usr/local/src/knxd/knxd/src/client/c'
Making all in php
make[5]: Entering directory '/usr/local/src/knxd/knxd/src/client/php'
sed -ne 's/#define \(IMG_[A-Z_0-9]\+\) \+\([0-9]\+\)/ const = ;/p' ../../../src/common/eibloadresult.h > result.inc
CXX dummy.o
if gcc -E -I../../../src/include -I../../../src/client -I../../../src/client -D__cplusplus -MT EIBConnection.post -MD -MP -MF ".deps/EIBConnection.Tpo" -P -x c -O0 -o EIBConnection.post EIBConnection.pre; \
then mv -f ".deps/EIBConnection.Tpo" ".deps/EIBConnection.Po"; else rm -f ".deps/EIBConnection.Tpo"; exit 1; fi
cat EIBConnection.post > EIBConnection.php
no EIBConnection.php || /bin/true
/bin/bash: no: command not found
sed -i -e 's/== =/===/g' EIBConnection.php
sed -i -e 's/= &/=\& /g' EIBConnection.php
cat lic.inc EIBConnection.php end.inc > eibclient.php
AR libdummy.a
make[5]: Leaving directory '/usr/local/src/knxd/knxd/src/client/php'
Making all in perl
make[5]: Entering directory '/usr/local/src/knxd/knxd/src/client/perl'
sed -ne 's/#define \(IMG_[A-Z_0-9]\+\) \+\([0-9]\+\)/ use constant => ;/p' ../../../src/common/eibloadresult.h > result.inc
CXX dummy.o
if gcc -E -I../../../src/include -I../../../src/client -I../../../src/client -I. -D__cplusplus -MT EIBConnection.post -MD -MP -MF ".deps/EIBConnection.Tpo" -P -x c -O0 -o EIBConnection.post EIBConnection.pre; \
sed -e 's/ARRAY \?(\([A-Za-z][A-Za-z0-9_]*\))/@/g' EIBConnection.post > EIBConnection.p1
perl -MO=Deparse EIBConnection.p1 > EIBConnection.p
AR libdummy.a
EIBConnection.p1 syntax OK
cat lic.inc EIBConnection.p > EIBConnection.pm
make[5]: Leaving directory '/usr/local/src/knxd/knxd/src/client/perl'
Making all in cs
make[5]: Entering directory '/usr/local/src/knxd/knxd/src/client/cs'
sed -ne 's/#define \(IMG_[A-Z_0-9]\+\) \+\([0-9]\+\)/public const int = ;/p' ../../../src/common/eibloadresult.h > result.inc
cat lic.inc EIBConnection.post > EIBConnection.cs
no EIBConnection.cs || /bin/true
make all-am
make[6]: Entering directory '/usr/local/src/knxd/knxd/src/client/cs'
CXX dummy.o
AR libdummy.a
make[6]: Leaving directory '/usr/local/src/knxd/knxd/src/client/cs'
make[5]: Leaving directory '/usr/local/src/knxd/knxd/src/client/cs'
Making all in python
make[5]: Entering directory '/usr/local/src/knxd/knxd/src/client/python'
sed -ne 's/#define \(IMG_[A-Z_0-9]\+\) \+\([0-9]\+\)/ = /p' ../../../src/common/eibloadresult.h > result.inc
CC gen.o
CCLD gen
./gen > gen.inc
cat io.inc gen.inc result.inc > EIBConnection.py
make[5]: Leaving directory '/usr/local/src/knxd/knxd/src/client/python'
Making all in pascal
make[5]: Entering directory '/usr/local/src/knxd/knxd/src/client/pascal'
sed -ne 's/#define \(IMG_[A-Z_0-9]\+\) \+\([0-9]\+\)/Const = ;
CC genh.o
CC gen.o
CCLD genh
./genh > genh.inc
CCLD gen
./gen > gen.inc
cat header1.inc result.inc header2.inc genh.inc body1.inc gen.inc body2.inc > EIBD.pas
make[5]: Leaving directory '/usr/local/src/knxd/knxd/src/client/pascal'
Making all in ruby
make[5]: Entering directory '/usr/local/src/knxd/knxd/src/client/ruby'
CC gen.o
CCLD gen
./gen > gen.inc
cat io.inc gen.inc result.inc footer.inc > EIBConnection.rb
make[5]: Leaving directory '/usr/local/src/knxd/knxd/src/client/ruby'
Making all in lua
make[5]: Entering directory '/usr/local/src/knxd/knxd/src/client/lua'
CC gen.o
CCLD gen
./gen > gen.inc
cat io.inc gen.inc result.inc > EIBConnection.lua
make[5]: Leaving directory '/usr/local/src/knxd/knxd/src/client/lua'
Making all in go
make[5]: Entering directory '/usr/local/src/knxd/knxd/src/client/go'
sed -ne 's/#define \(IMG_[A-Z_0-9]\+\) \+\([0-9]\+\)/const = /p' ../../../src/common/eibloadresult.h > result.inc
CC gen.o
CCLD gen
./gen > gen.inc
cat io.inc gen.inc result.inc > EIBConnection.go
make[5]: Leaving directory '/usr/local/src/knxd/knxd/src/client/go'
Making all in .
make[5]: Entering directory '/usr/local/src/knxd/knxd/src/client'
make[5]: Nothing to be done for 'all-am'.
make[5]: Leaving directory '/usr/local/src/knxd/knxd/src/client'
make[4]: Leaving directory '/usr/local/src/knxd/knxd/src/client'
Making all in usb
make[4]: Entering directory '/usr/local/src/knxd/knxd/src/usb'
CXX findknxusb.o
CXX usb.o
CXX dummy.o
findknxusb.cpp: In function 'int main()':
findknxusb.cpp:126:31: warning: 'void libusb_set_debug(libusb_context*, int)' is deprecated: Use libusb_set_option instead [-Wdeprecated-declarations]
libusb_set_debug (context, 0);
In file included from findknxusb.cpp:24:
/usr/include/libusb-1.0/libusb.h:1300:18: note: declared here
void LIBUSB_CALL libusb_set_debug(libusb_context *ctx, int level);
CXXLD findknxusb
AR libusb.a
make[4]: Leaving directory '/usr/local/src/knxd/knxd/src/usb'
Making all in libserver
make[4]: Entering directory '/usr/local/src/knxd/knxd/src/libserver'
CXX common.o
CXX trace.o
CXX emi.o
CXX lowlevel.o
CXX cm_tp1.o
CXX cm_ip.o
CXX lpdu.o
CXX link.o
CXX npdu.o
CXX layer3.o
CXX router.o
CXX groupcache.o
CXX groupcacheclient.o
