Salut a tous,
Je n arrive pas a réaliser la restauration de ma sauvegarde aussi bien en SSH que via le mode rescue !
Je suspecte peut être le plugin ubiquiti qui pourrait déconner !
Serait il possible de désactiver des plugins via le modes rescue ?
En vous remerciant par avance
les logs dans l onglet HTTP.ERROR
0000|[Fri Sep 04 12:41:56.949048 2026] [mpm_prefork:notice] [pid 396:tid 396] AH00163: Apache/2.4.66 (Debian) configured -- resuming normal operations
0001|[Fri Sep 04 12:41:56.949312 2026] [core:notice] [pid 396:tid 396] AH00094: Command line: '/usr/sbin/apache2'
0002|[Fri Sep 04 12:42:06.838431 2026] [mpm_prefork:notice] [pid 396:tid 396] AH00170: caught SIGWINCH, shutting down gracefully
0003|[Fri Sep 04 14:42:51.386950 2026] [mpm_prefork:notice] [pid 396:tid 396] AH00163: Apache/2.4.66 (Debian) configured -- resuming normal operations
0004|[Fri Sep 04 14:42:51.387736 2026] [core:notice] [pid 396:tid 396] AH00094: Command line: '/usr/sbin/apache2'
0005|[Fri Sep 04 15:00:02.531891 2026] [php7:warn] [pid 1097:tid 1097] [client 192.168.1.80:55298] PHP Warning: require(/var/www/html/vendor/sabre/uri/lib/functions.php): failed to open stream: No such file or directory in /var/www/html/vendor/composer/autoload_real.php on line 71
0006|[Fri Sep 04 15:00:02.532152 2026] [php7:error] [pid 1097:tid 1097] [client 192.168.1.80:55298] PHP Fatal error: require(): Failed opening required '/var/www/html/vendor/composer/../sabre/uri/lib/functions.php' (include_path='.:/usr/share/php') in /var/www/html/vendor/composer/autoload_real.php on line 71
0007|[Fri Sep 04 15:00:02.939723 2026] [php7:warn] [pid 468:tid 468] [client 192.168.1.80:55307] PHP Warning: require(/var/www/html/vendor/composer/../sabre/uri/lib/functions.php): failed to open stream: No such file or directory in /var/www/html/vendor/composer/autoload_real.php on line 71
0008|[Fri Sep 04 15:00:02.939981 2026] [php7:error] [pid 468:tid 468] [client 192.168.1.80:55307] PHP Fatal error: require(): Failed opening required '/var/www/html/vendor/composer/../sabre/uri/lib/functions.php' (include_path='.:/usr/share/php') in /var/www/html/vendor/composer/autoload_real.php on line 71
0009|[Fri Sep 04 15:00:03.053466 2026] [php7:warn] [pid 1089:tid 1089] [client 192.168.1.80:55308] PHP Warning: require(/var/www/html/vendor/composer/../sabre/uri/lib/functions.php): failed to open stream: No such file or directory in /var/www/html/vendor/composer/autoload_real.php on line 71
0010|[Fri Sep 04 15:00:03.053548 2026] [php7:error] [pid 1089:tid 1089] [client 192.168.1.80:55308] PHP Fatal error: require(): Failed opening required '/var/www/html/vendor/composer/../sabre/uri/lib/functions.php' (include_path='.:/usr/share/php') in /var/www/html/vendor/composer/autoload_real.php on line 71
0011|[Fri Sep 04 15:00:03.171273 2026] [php7:warn] [pid 1099:tid 1099] [client 192.168.1.80:55309] PHP Warning: require(/var/www/html/vendor/composer/../sabre/uri/lib/functions.php): failed to open stream: No such file or directory in /var/www/html/vendor/composer/autoload_real.php on line 71
0012|[Fri Sep 04 15:00:03.171538 2026] [php7:error] [pid 1099:tid 1099] [client 192.168.1.80:55309] PHP Fatal error: require(): Failed opening required '/var/www/html/vendor/composer/../sabre/uri/lib/functions.php' (include_path='.:/usr/share/php') in /var/www/html/vendor/composer/autoload_real.php on line 71
0013|[Fri Sep 04 15:00:05.155240 2026] [php7:error] [pid 1096:tid 1096] [client 192.168.1.80:55286] PHP Fatal error: Uncaught Exception: [MySQL] Error code : 42S02 (1146). Table 'jeedom.config' doesn't exist : SELECT `value`,`key`\n\t\tFROM config\n\t\tWHERE `key` LIKE 'log::level::%' in /var/www/html/core/class/DB.class.php:120\nStack trace:\n#0 /var/www/html/core/class/config.class.php(285): DB::Prepare()\n#1 /var/www/html/core/class/log.class.php(62): config::getLogLevelPlugin()\n#2 /var/www/html/core/class/log.class.php(512): log::getConfig()\n#3 /var/www/html/core/php/utils.inc.php(253): log::exception()\n#4 /var/www/html/core/ajax/event.ajax.php(36): displayException()\n#5 {main}\n thrown in /var/www/html/core/class/DB.class.php on line 120
0014|[Fri Sep 04 15:00:05.344234 2026] [php7:error] [pid 2300:tid 2300] [client 192.168.1.80:55311] PHP Fatal error: Uncaught Error: Class 'ajax' not found in /var/www/html/core/ajax/event.ajax.php:36\nStack trace:\n#0 {main}\n thrown in /var/www/html/core/ajax/event.ajax.php on line 36
0015|[Fri Sep 04 15:00:05.468023 2026] [php7:error] [pid 465:tid 465] [client 192.168.1.80:55312] PHP Fatal error: Uncaught Error: Class 'ajax' not found in /var/www/html/core/ajax/event.ajax.php:36\nStack trace:\n#0 {main}\n thrown in /var/www/html/core/ajax/event.ajax.php on line 36
0016|[Fri Sep 04 15:00:05.470219 2026] [php7:error] [pid 1098:tid 1098] [client 192.168.1.141:53138] PHP Fatal error: Uncaught Exception: [MySQL] Error code : 42S02 (1146). Table 'jeedom.config' doesn't exist : SELECT `value`,`key`\n\t\tFROM config\n\t\tWHERE `key` LIKE 'log::level::%' in /var/www/html/core/class/DB.class.php:120\nStack trace:\n#0 /var/www/html/core/class/config.class.php(285): DB::Prepare()\n#1 /var/www/html/core/class/log.class.php(62): config::getLogLevelPlugin()\n#2 /var/www/html/core/class/log.class.php(512): log::getConfig()\n#3 /var/www/html/core/php/utils.inc.php(253): log::exception()\n#4 /var/www/html/core/ajax/event.ajax.php(36): displayException()\n#5 {main}\n thrown in /var/www/html/core/class/DB.class.php on line 120
0017|[Fri Sep 04 15:00:05.591036 2026] [php7:error] [pid 464:tid 464] [client 192.168.1.80:55313] PHP Fatal error: Uncaught Error: Class 'ajax' not found in /var/www/html/core/ajax/event.ajax.php:36\nStack trace:\n#0 {main}\n thrown in /var/www/html/core/ajax/event.ajax.php on line 36
0018|[Fri Sep 04 15:00:05.633461 2026] [php7:error] [pid 1300:tid 1300] [client 192.168.1.141:53241] PHP Fatal error: Uncaught Error: Class 'ajax' not found in /var/www/html/core/ajax/event.ajax.php:36\nStack trace:\n#0 {main}\n thrown in /var/www/html/core/ajax/event.ajax.php on line 36
0019|[Fri Sep 04 15:00:05.760373 2026] [php7:error] [pid 469:tid 469] [client 192.168.1.141:53242] PHP Fatal error: Uncaught Error: Class 'ajax' not found in /var/www/html/core/ajax/event.ajax.php:36\nStack trace:\n#0 {main}\n thrown in /var/www/html/core/ajax/event.ajax.php on line 36
0020|[Fri Sep 04 15:00:05.910180 2026] [php7:error] [pid 468:tid 468] [client 192.168.1.141:53243] PHP Fatal error: Uncaught Error: Class 'ajax' not found in /var/www/html/core/ajax/event.ajax.php:36\nStack trace:\n#0 {main}\n thrown in /var/www/html/core/ajax/event.ajax.php on line 36
0021|[Fri Sep 04 16:06:06.920197 2026] [php7:error] [pid 2300:tid 2300] [client 192.168.1.141:53779] PHP Fatal error: Uncaught Exception: [MySQL] Error code : 42S02 (1146). Table 'jeedom.config' doesn't exist : SELECT `value`,`key`\n\t\tFROM config\n\t\tWHERE `key` LIKE 'log::level::%' in /var/www/html/core/class/DB.class.php:120\nStack trace:\n#0 /var/www/html/core/class/config.class.php(285): DB::Prepare()\n#1 /var/www/html/core/class/log.class.php(62): config::getLogLevelPlugin()\n#2 /var/www/html/core/class/log.class.php(512): log::getConfig()\n#3 /var/www/html/core/php/utils.inc.php(253): log::exception()\n#4 /var/www/html/core/ajax/event.ajax.php(36): displayException()\n#5 {main}\n thrown in /var/www/html/core/class/DB.class.php on line 120
0022|[Fri Sep 04 16:06:08.429861 2026] [php7:error] [pid 1096:tid 1096] [client 192.168.1.141:53790] PHP Fatal error: Uncaught Error: Class 'ajax' not found in /var/www/html/core/ajax/event.ajax.php:36\nStack trace:\n#0 {main}\n thrown in /var/www/html/core/ajax/event.ajax.php on line 36
0023|[Fri Sep 04 16:06:08.558527 2026] [php7:error] [pid 12458:tid 12458] [client 192.168.1.141:53791] PHP Fatal error: Uncaught Error: Class 'ajax' not found in /var/www/html/core/ajax/event.ajax.php:36\nStack trace:\n#0 {main}\n thrown in /var/www/html/core/ajax/event.ajax.php on line 36
0024|[Fri Sep 04 16:06:08.685894 2026] [php7:error] [pid 465:tid 465] [client 192.168.1.141:53792] PHP Fatal error: Uncaught Error: Class 'ajax' not found in /var/www/html/core/ajax/event.ajax.php:36\nStack trace:\n#0 {main}\n thrown in /var/www/html/core/ajax/event.ajax.php on line 36
