Probleme de démarrage RFXCOM
J’ai un soucis avec le plugin RFXcom depuis un certain temps… Mais j’avoue que je ne sais pas depuis quand…
Bref voici ce que j’ai dans les logs RFXCOM:
"Traceback (most recent call last):
File "/var/www/html/plugins/rfxcom/resources/rfxcomd/rfxcomd.py", line 23, in <module>
from jeedomdaemon.base_config import BaseConfig
File "/usr/local/lib/python3.9/dist-packages/jeedomdaemon/__init__.py", line 1, in <module>
from .base_daemon import BaseDaemon
File "/usr/local/lib/python3.9/dist-packages/jeedomdaemon/base_daemon.py", line 15, in <module>
from .aio_connector import Publisher, Listener
File "/usr/local/lib/python3.9/dist-packages/jeedomdaemon/aio_connector.py", line 9, in <module>
import aiohttp
File "/usr/local/lib/python3.9/dist-packages/aiohttp/__init__.py", line 6, in <module>
from .client import (
File "/usr/local/lib/python3.9/dist-packages/aiohttp/client.py", line 87, in <module>
from .connector import (
File "/usr/local/lib/python3.9/dist-packages/aiohttp/connector.py", line 64, in <module>
from .resolver import DefaultResolver
File "/usr/local/lib/python3.9/dist-packages/aiohttp/resolver.py", line 12, in <module>
import aiodns
File "/usr/local/lib/python3.9/dist-packages/aiodns/__init__.py", line 60, in <module>
class DNSResolver:
File "/usr/local/lib/python3.9/dist-packages/aiodns/__init__.py", line 162, in DNSResolver
) -> asyncio.Future[list[pycares.ares_query_a_result]]: ...
AttributeError: module 'pycares' has no attribute 'ares_query_a_result'"
J’ai testé la réinstallation des dépendances et la seule erreur que j’ai c’est:
« gpiozero 2.0.1 requires importlib-metadata~=4.6; python_version < « 3.10 », but you have importlib-metadata 8.7.1 which is incompatible.
gpiozero 2.0.1 requires importlib-resources~=5.0; python_version < « 3.10 », but you have importlib-resources 6.5.2 which is incompatible. »
Je rajoute:
et :
Supprime le dossier python_venv qui se trouve dans html/plugins/rfxcom/resources/ et relance les dépendances pour voir…
Il est sur Debian 11 donc pas de python_venv; avec les plugins installés via le script du core, le venv n’est là qu’à partir de Debian 12.
Il faudrait tous les logs au complet, y compris l’installation des dépendances.
log collé dans un bloc Texte préformaté
je voudrais voir la liste des plugins également
Oui je suis encore en Debian 11…
Voici les logs de l’installaiton des dépendances:
+ touch /tmp/jeedom_install_in_progress_rfxcom
+ echo 1
+ echo 2
+ sudo chmod +x /var/www/html/core/class/../../plugins/rfxcom/resources/pre-install.sh
+ sudo /var/www/html/core/class/../../plugins/rfxcom/resources/pre-install.sh
Launch pre-install of rfxcom dependancy
WARNING: Skipping serial as it is not installed.
WARNING: Running pip as the 'root' user can result in broken permissions and conflicting behaviour with the system package manager, possibly rendering your system unusable. It is recommended to use a virtual environment instead: https://pip.pypa.io/warnings/venv. Use the --root-user-action option if you know what you are doing and want to suppress this warning.
Reading package lists...
Building dependency tree...
Reading state information...
Package 'python3-serial' is not installed, so not removed
0 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
+ echo 3
apt: no process found
apt-get: no process found
+ sudo apt update
Hit:1 http://deb.debian.org/debian bullseye InRelease
Hit:2 http://deb.debian.org/debian bullseye-updates InRelease
Hit:3 http://security.debian.org/debian-security bullseye-security InRelease
Get:4 http://archive.raspberrypi.org/debian bullseye InRelease [39.0 kB]
Hit:5 https://deb.nodesource.com/node_22.x nodistro InRelease
Get:7 http://archive.raspberrypi.org/debian bullseye/main armhf Packages [330 kB]
Get:8 http://archive.raspberrypi.org/debian bullseye/main arm64 Packages [323 kB]
Hit:6 https://packagecloud.io/ookla/speedtest-cli/debian bullseye InRelease
Fetched 692 kB in 12s (56.2 kB/s)
All packages are up to date.
+ echo 4
+ sudo apt install -o Dpkg::Options::=--force-confdef -y python3
python3 is already the newest version (3.9.2-3).
+ echo 5
+ sudo apt install -o Dpkg::Options::=--force-confdef -y python3-pip
python3-pip is already the newest version (20.3.4-4+rpt1+deb11u1).
+ echo 6
+ sudo apt install -o Dpkg::Options::=--force-confdef -y build-essential
+ echo 7
+ sudo apt install -o Dpkg::Options::=--force-confdef -y python3-pyudev
python3-pyudev is already the newest version (0.22.0-2).
+ echo 8
+ sudo apt install -o Dpkg::Options::=--force-confdef -y python3-dev
python3-dev is already the newest version (3.9.2-3).
+ echo 9
+ sudo apt install -o Dpkg::Options::=--force-confdef -y python3-requests
python3-requests is already the newest version (2.25.1+dfsg-2).
+ echo 10
+ sudo apt install -o Dpkg::Options::=--force-confdef -y python3-setuptools
python3-setuptools is already the newest version (52.0.0-4+deb11u2).
+ echo 11
++ awk '$1 <= 4'
++ find /usr/local/lib/python3.9/dist-packages/ -mindepth 1 -maxdepth 1 -type d -exec du -ks '{}' +
++ cut -f 2-
+ RESULTTODELETE=
++ echo ''
++ sed 's, ,\ ,g'
+ RESULTTODELETE2=
+ echo ''
+ xargs rm -rf
+ echo 12
+ sudo pip3 cache purge
Files removed: 136 (7.9 MB)
Directories removed: 0
+ echo 13
+ sudo pip3 install --upgrade pip
Looking in indexes: https://pypi.org/simple, https://www.piwheels.org/simple
Requirement already satisfied: pip in /usr/local/lib/python3.9/dist-packages (26.0.1)
WARNING: Error parsing dependencies of gpg: Invalid version: '1.14.0-unknown'
+ echo 14
+ sudo python3 -m pip install --force-reinstall --upgrade six
Collecting six
Downloading https://www.piwheels.org/simple/six/six-1.17.0-py2.py3-none-any.whl (11 kB)
Installing collected packages: six
Attempting uninstall: six
Found existing installation: six 1.17.0
Uninstalling six-1.17.0:
Successfully uninstalled six-1.17.0
Successfully installed six-1.17.0
+ echo 15
+ sudo python3 -m pip install --force-reinstall --upgrade requests
Collecting requests
Downloading https://www.piwheels.org/simple/requests/requests-2.32.5-py3-none-any.whl (64 kB)
Collecting charset_normalizer<4,>=2 (from requests)
Downloading charset_normalizer-3.4.5-cp39-cp39-manylinux2014_aarch64.manylinux_2_17_aarch64.manylinux_2_28_aarch64.whl.metadata (39 kB)
Collecting idna<4,>=2.5 (from requests)
Downloading https://www.piwheels.org/simple/idna/idna-3.11-py3-none-any.whl (71 kB)
Collecting urllib3<3,>=1.21.1 (from requests)
Downloading https://www.piwheels.org/simple/urllib3/urllib3-2.6.3-py3-none-any.whl (131 kB)
Collecting certifi>=2017.4.17 (from requests)
Downloading https://www.piwheels.org/simple/certifi/certifi-2026.2.25-py3-none-any.whl (153 kB)
Downloading charset_normalizer-3.4.5-cp39-cp39-manylinux2014_aarch64.manylinux_2_17_aarch64.manylinux_2_28_aarch64.whl (189 kB)
Installing collected packages: urllib3, idna, charset_normalizer, certifi, requests
Attempting uninstall: urllib3
Found existing installation: urllib3 2.6.3
Uninstalling urllib3-2.6.3:
Successfully uninstalled urllib3-2.6.3
Attempting uninstall: idna
Found existing installation: idna 3.11
Uninstalling idna-3.11:
Successfully uninstalled idna-3.11
Attempting uninstall: charset_normalizer
Found existing installation: charset-normalizer 3.4.5
Uninstalling charset-normalizer-3.4.5:
Successfully uninstalled charset-normalizer-3.4.5
Attempting uninstall: certifi
Found existing installation: certifi 2026.2.25
Uninstalling certifi-2026.2.25:
Successfully uninstalled certifi-2026.2.25
Attempting uninstall: requests
Found existing installation: requests 2.32.5
Uninstalling requests-2.32.5:
Successfully uninstalled requests-2.32.5
Successfully installed certifi-2026.2.25 charset_normalizer-3.4.5 idna-3.11 requests-2.32.5 urllib3-2.6.3
+ echo 16
+ sudo python3 -m pip install --force-reinstall --upgrade setuptools
Collecting setuptools
Downloading https://www.piwheels.org/simple/setuptools/setuptools-82.0.0-py3-none-any.whl (1.0 MB)
━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━ 1.0/1.0 MB 843.1 kB/s  0:00:00
Installing collected packages: setuptools
Attempting uninstall: setuptools
Found existing installation: setuptools 82.0.0
Uninstalling setuptools-82.0.0:
Successfully uninstalled setuptools-82.0.0
ERROR: pip's dependency resolver does not currently take into account all the packages that are installed. This behaviour is the source of the following dependency conflicts.
gpiozero 2.0.1 requires importlib-metadata~=4.6; python_version < "3.10", but you have importlib-metadata 8.7.1 which is incompatible.
gpiozero 2.0.1 requires importlib-resources~=5.0; python_version < "3.10", but you have importlib-resources 6.5.2 which is incompatible.
Successfully installed setuptools-82.0.0
+ echo 17
+ sudo python3 -m pip install --force-reinstall --upgrade pyudev
Collecting pyudev
Downloading https://www.piwheels.org/simple/pyudev/pyudev-0.24.4-py3-none-any.whl (62 kB)
Installing collected packages: pyudev
Attempting uninstall: pyudev
Found existing installation: pyudev 0.24.4
Uninstalling pyudev-0.24.4:
Successfully uninstalled pyudev-0.24.4
Successfully installed pyudev-0.24.4
+ echo 18
+ sudo python3 -m pip install --force-reinstall --upgrade pyserial
Collecting pyserial
Downloading https://www.piwheels.org/simple/pyserial/pyserial-3.5-py2.py3-none-any.whl (90 kB)
Installing collected packages: pyserial
Attempting uninstall: pyserial
Found existing installation: pyserial 3.5
Uninstalling pyserial-3.5:
Successfully uninstalled pyserial-3.5
Successfully installed pyserial-3.5
+ echo 19
+ sudo python3 -m pip install --force-reinstall --upgrade jeedomdaemon
Collecting jeedomdaemon
Downloading https://www.piwheels.org/simple/jeedomdaemon/jeedomdaemon-1.2.9-py3-none-any.whl (10 kB)
Collecting aiohttp (from jeedomdaemon)
Downloading aiohttp-3.13.3-cp39-cp39-manylinux2014_aarch64.manylinux_2_17_aarch64.manylinux_2_28_aarch64.whl.metadata (8.1 kB)
Collecting aiohappyeyeballs>=2.5.0 (from aiohttp->jeedomdaemon)
Downloading https://www.piwheels.org/simple/aiohappyeyeballs/aiohappyeyeballs-2.6.1-py3-none-any.whl (15 kB)
Collecting aiosignal>=1.4.0 (from aiohttp->jeedomdaemon)
Downloading https://www.piwheels.org/simple/aiosignal/aiosignal-1.4.0-py3-none-any.whl (7.5 kB)
Collecting async-timeout<6.0,>=4.0 (from aiohttp->jeedomdaemon)
Downloading https://www.piwheels.org/simple/async-timeout/async_timeout-5.0.1-py3-none-any.whl (6.2 kB)
Collecting attrs>=17.3.0 (from aiohttp->jeedomdaemon)
Downloading https://www.piwheels.org/simple/attrs/attrs-25.4.0-py3-none-any.whl (67 kB)
Collecting frozenlist>=1.1.1 (from aiohttp->jeedomdaemon)
Downloading frozenlist-1.8.0-cp39-cp39-manylinux2014_aarch64.manylinux_2_17_aarch64.manylinux_2_28_aarch64.whl.metadata (20 kB)
Collecting multidict<7.0,>=4.5 (from aiohttp->jeedomdaemon)
Downloading multidict-6.7.1-cp39-cp39-manylinux2014_aarch64.manylinux_2_17_aarch64.manylinux_2_28_aarch64.whl.metadata (5.3 kB)
Collecting propcache>=0.2.0 (from aiohttp->jeedomdaemon)
Downloading propcache-0.4.1-cp39-cp39-manylinux2014_aarch64.manylinux_2_17_aarch64.manylinux_2_28_aarch64.whl.metadata (13 kB)
Collecting yarl<2.0,>=1.17.0 (from aiohttp->jeedomdaemon)
Downloading yarl-1.22.0-cp39-cp39-manylinux2014_aarch64.manylinux_2_17_aarch64.manylinux_2_28_aarch64.whl.metadata (75 kB)
Collecting typing-extensions>=4.1.0 (from multidict<7.0,>=4.5->aiohttp->jeedomdaemon)
Downloading https://www.piwheels.org/simple/typing-extensions/typing_extensions-4.15.0-py3-none-any.whl (44 kB)
Collecting idna>=2.0 (from yarl<2.0,>=1.17.0->aiohttp->jeedomdaemon)
Using cached https://www.piwheels.org/simple/idna/idna-3.11-py3-none-any.whl (71 kB)
Downloading aiohttp-3.13.3-cp39-cp39-manylinux2014_aarch64.manylinux_2_17_aarch64.manylinux_2_28_aarch64.whl (1.7 MB)
━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━ 1.7/1.7 MB 3.0 MB/s  0:00:00
Downloading multidict-6.7.1-cp39-cp39-manylinux2014_aarch64.manylinux_2_17_aarch64.manylinux_2_28_aarch64.whl (240 kB)
Downloading yarl-1.22.0-cp39-cp39-manylinux2014_aarch64.manylinux_2_17_aarch64.manylinux_2_28_aarch64.whl (347 kB)
Downloading frozenlist-1.8.0-cp39-cp39-manylinux2014_aarch64.manylinux_2_17_aarch64.manylinux_2_28_aarch64.whl (221 kB)
Downloading propcache-0.4.1-cp39-cp39-manylinux2014_aarch64.manylinux_2_17_aarch64.manylinux_2_28_aarch64.whl (201 kB)
Installing collected packages: typing-extensions, propcache, idna, frozenlist, attrs, async-timeout, aiohappyeyeballs, multidict, aiosignal, yarl, aiohttp, jeedomdaemon
Attempting uninstall: typing-extensions
Found existing installation: typing_extensions 4.15.0
Uninstalling typing_extensions-4.15.0:
Successfully uninstalled typing_extensions-4.15.0
Attempting uninstall: propcache
Found existing installation: propcache 0.4.1
Uninstalling propcache-0.4.1:
Successfully uninstalled propcache-0.4.1
Attempting uninstall: frozenlist
Found existing installation: frozenlist 1.8.0
Uninstalling frozenlist-1.8.0:
Successfully uninstalled frozenlist-1.8.0
Attempting uninstall: attrs
Found existing installation: attrs 25.4.0
Uninstalling attrs-25.4.0:
Successfully uninstalled attrs-25.4.0
Attempting uninstall: async-timeout
Found existing installation: async-timeout 5.0.1
Uninstalling async-timeout-5.0.1:
Successfully uninstalled async-timeout-5.0.1
Attempting uninstall: aiohappyeyeballs
Found existing installation: aiohappyeyeballs 2.6.1
Uninstalling aiohappyeyeballs-2.6.1:
Successfully uninstalled aiohappyeyeballs-2.6.1
Attempting uninstall: multidict
Found existing installation: multidict 6.7.1
Uninstalling multidict-6.7.1:
Successfully uninstalled multidict-6.7.1
Attempting uninstall: aiosignal
Found existing installation: aiosignal 1.4.0
Uninstalling aiosignal-1.4.0:
Successfully uninstalled aiosignal-1.4.0
Attempting uninstall: yarl
Found existing installation: yarl 1.22.0
Uninstalling yarl-1.22.0:
Successfully uninstalled yarl-1.22.0
Attempting uninstall: aiohttp
Found existing installation: aiohttp 3.13.3
Uninstalling aiohttp-3.13.3:
Successfully uninstalled aiohttp-3.13.3
Attempting uninstall: jeedomdaemon
Found existing installation: jeedomdaemon 1.2.9
Uninstalling jeedomdaemon-1.2.9:
Successfully uninstalled jeedomdaemon-1.2.9
Successfully installed aiohappyeyeballs-2.6.1 aiohttp-3.13.3 aiosignal-1.4.0 async-timeout-5.0.1 attrs-25.4.0 frozenlist-1.8.0 idna-3.11 jeedomdaemon-1.2.9 multidict-6.7.1 propcache-0.4.1 typing-extensions-4.15.0 yarl-1.22.0
+ echo 20
+ php /var/www/html/core/class/../php/jeecli.php plugin dependancy_end rfxcom
+ echo 21
+ rm /tmp/jeedom_install_in_progress_rfxcom
Et les plugins installés:
c’est le même problème qu’ici: Sonos3 Impossible de lancer le démon - #8 par Mips mais je n’ai plus eu de réponse
je peux aussi avoir le retour de
python3 -m pip list
voici le retour de la commande:
pi@JEEDOM:~ $ python3 -m pip list
Package             Version
aiodns              3.6.1
aioharmony          0.5.3
aiohttp             3.13.3
aiosignal           1.4.0
asn1crypto          1.5.1
async-timeout       5.0.1
attrs               25.4.0
certifi             2026.2.25
cffi                2.0.0
chardet             5.2.0
colorzero           2.0
cryptography        46.0.5
cupshelpers         1.0
dbus-python         1.2.16
distro              1.9.0
distro-info         1.0+deb11u1
frozenlist          1.8.0
gpg                 1.14.0-unknown
gpiozero            2.0.1
idna                3.11
importlib_metadata  8.7.1
importlib_resources 6.5.2
iotop               0.6
jeedomdaemon        1.2.9
multidict           6.7.1
numpy               2.0.2
packaging           26.0
picamera2           0.3.12
pidng               4.0.9
piexif              1.1.3
pillow              11.3.0
pip                 26.0.1
propcache           0.4.1
pyasn1              0.6.2
pyasn1_modules      0.4.2
pycairo             1.16.2
pycares             5.0.1
pycparser           2.23
pycrypto            2.6.1
pycups              2.0.1
pycurl              7.43.0.6
PyGObject           3.38.0
pyserial            3.5
pysmbc              1.0.23
python-apt          2.2.1.1
python-prctl        1.7
pyudev              0.24.4
requests            2.32.5
RPi.GPIO            0.7.0
setuptools          82.0.0
simplejpeg          1.9.0
six                 1.17.0
slixmpp             1.12.0
spidev              3.8
ssh-import-id       5.13
toml                0.10.2
unattended-upgrades 0.1
urllib3             2.6.3
v4l2-python3        0.3.5
wheel               0.46.3
yarl                1.22.0
zipp                3.23.0
c’est fait désolé.
ok donc c’est bien le même problème mais je n’ai aucune idée de quel plugin installe ces dépendances; ca créé une incompatibilité entre les 2;
du coup votre problème avec rfxcom est probablement apparu suite à l’installation ou la mise à jour d’un plugin qui a des dépendances python et à priori ca ne serait pas un plugin officiel.
Avec ces infos vous savez peut-être déduire le plugin en question.
vous pouvez essayer de forcer une version plus ancienne:
sudo python3 -m pip install --upgrade "pycares==4.5.0"
voici le retour:
pi@JEEDOM:~ $ sudo python3 -m pip install --upgrade "pycares==4.5.0"
Collecting pycares==4.5.0
  Downloading pycares-4.5.0-cp39-cp39-manylinux_2_17_aarch64.manylinux2014_aarch64.whl.metadata (4.1 kB)
Requirement already satisfied: cffi>=1.5.0 in /usr/local/lib/python3.9/dist-packages (from pycares==4.5.0) (2.0.0)
Requirement already satisfied: pycparser in /usr/local/lib/python3.9/dist-packages (from cffi>=1.5.0->pycares==4.5.0) (2.23)
Downloading pycares-4.5.0-cp39-cp39-manylinux_2_17_aarch64.manylinux2014_aarch64.whl (289 kB)
Installing collected packages: pycares
  Attempting uninstall: pycares
    Found existing installation: pycares 5.0.1
    Uninstalling pycares-5.0.1:
      Successfully uninstalled pycares-5.0.1
aiodns 3.6.1 requires pycares<5,>=4.9.0, but you have pycares 4.5.0 which is incompatible.
Successfully installed pycares-4.5.0
Et du coup le démon rfxcom démarre?
si pas, faites un downgrade de aiodns aussi:
sudo python3 -m pip install --upgrade "aiodns==3.2.0"
Le plugin est reparti. Merci à vous les gars !!
avec le changement sur aiodns ou juste pycares?
et bon… peut-être qu’un autre plugin sera down à présent puisqu’on a changé les dépendances…
le problème n’arriverait pas sous Debian 12
Hello, je réponds car je viens d’avoir le problème sur le daemon MyTado, c’est la version aiodns qui pose problème
Pour ce qui est de qui a mis à jour les versions, dans mon cas en tout cas, c’est moi qui ai fait un upgrade des paquets pip3 installés sur mon jeedom
Perso je mets à jour debian les yeux fermés. Python, je touche pas, trop de chance que cela cause un souci.
En général, je note les versions avant de faire la mise à jour et c’est la première fois que je rencontre un souci. Mais oui, si on ne sait pas ce qu’on fait, mieux vaut ne pas y toucher, par contre pour un utilisateur lamba ce n’est pas facile de comprendre que je ne faut pas le faire alors que l’option est dispo dans Jeedom
Il y a bcp de chose possible dans le core et c’est sur qu’en cliquant partout, ca casse :wink:
Le bouton est orange => c’est donc une opération qui n’est pas sans risque, il faut faire attention;
c’est le même principe partout.
Je ne vois pas ce qui peut être fait de plus (sans ajouter 4 popups de confirmations), ou alors on supprime toutes les fonctions avancées.
Mais à nouveau, sous Debian 12 (ou avec les plugins qui gère déjà un environnement virtuel) ca n’est plus un problème car les dépendances sont installées dans un environnement dédié au plugin donc on peut plus facilement mettre à jour le système (ou un plugin particulier) sans risque de casser les (autres) plugins.
La fonctionnalité dans le core ne met et continuera de ne mettre à jour que les packages systèmes.
Ah oui je n’avais pas percupé que la couleur orange c’était un avertissement (my bad)
