La prise a été acheté seule depuis un magasin de vente de produit électrique.
Box Atlas en Zigbee
Warning 2024-02-14 21:15:50Device '0x000474000023165c' left the network
Info 2024-02-14 21:15:51MQTT publish: topic 'zigbee2mqtt/bridge/event', payload '{"data":{"friendly_name":"0x000474000023165c","ieee_address":"0x000474000023165c"},"type":"device_leave"}'
Warning 2024-02-14 21:15:51Device '0x000474000023165c' left the network
Info 2024-02-14 21:15:53MQTT publish: topic 'zigbee2mqtt/0x000474000023165c', payload '{"device":{"applicationVersion":0,"dateCode":" \u000020221220\u0000\u0000\u0000\u0000\u0000","friendlyName":"0x000474000023165c","hardwareVersion":2,"ieeeAddr":"0x000474000023165c","manufacturerID":4129,"manufacturerName":" Legrand","model":"067775/741811","networkAddress":6747,"powerSource":"Mains (single phase)","softwareBuildID":"003e","stackVersion":66,"type":"Router","zclVersion":2},"last_seen":"2024-02-14T20:15:54.171Z","linkquality":192}'
Info 2024-02-14 21:15:53Device '0x000474000023165c' joined
Info 2024-02-14 21:15:53MQTT publish: topic 'zigbee2mqtt/bridge/event', payload '{"data":{"friendly_name":"0x000474000023165c","ieee_address":"0x000474000023165c"},"type":"device_joined"}'
Info 2024-02-14 21:15:53Starting interview of '0x000474000023165c'
Info 2024-02-14 21:15:53MQTT publish: topic 'zigbee2mqtt/bridge/event', payload '{"data":{"friendly_name":"0x000474000023165c","ieee_address":"0x000474000023165c","status":"started"},"type":"device_interview"}'
Info 2024-02-14 21:15:53MQTT publish: topic 'zigbee2mqtt/0x000474000023165c', payload '{"device":{"applicationVersion":0,"dateCode":" \u000020221220\u0000\u0000\u0000\u0000\u0000","friendlyName":"0x000474000023165c","hardwareVersion":2,"ieeeAddr":"0x000474000023165c","manufacturerID":4129,"manufacturerName":" Legrand","model":"067775/741811","networkAddress":6747,"powerSource":"Mains (single phase)","softwareBuildID":"003e","stackVersion":66,"type":"Router","zclVersion":2},"last_seen":"2024-02-14T20:15:54.448Z","linkquality":192}'
Info 2024-02-14 21:15:53MQTT publish: topic 'zigbee2mqtt/0x000474000023165c', payload '{"device":{"applicationVersion":0,"dateCode":" \u000020221220\u0000\u0000\u0000\u0000\u0000","friendlyName":"0x000474000023165c","hardwareVersion":2,"ieeeAddr":"0x000474000023165c","manufacturerID":4129,"manufacturerName":" Legrand","model":"067775/741811","networkAddress":6747,"powerSource":"Mains (single phase)","softwareBuildID":"003e","stackVersion":66,"type":"Router","zclVersion":2},"last_seen":"2024-02-14T20:15:54.451Z","linkquality":192}'
Debug 2024-02-14 21:15:53Received Zigbee message from '0x000474000023165c', type 'readResponse', cluster 'genBasic', data '{"appVersion":0}' from endpoint 1 with groupID 0
Debug 2024-02-14 21:15:53Skipping message, still interviewing
Info 2024-02-14 21:15:53MQTT publish: topic 'zigbee2mqtt/0x000474000023165c', payload '{"device":{"applicationVersion":0,"dateCode":" \u000020221220\u0000\u0000\u0000\u0000\u0000","friendlyName":"0x000474000023165c","hardwareVersion":2,"ieeeAddr":"0x000474000023165c","manufacturerID":4129,"manufacturerName":" Legrand","model":"067775/741811","networkAddress":6747,"powerSource":"Mains (single phase)","softwareBuildID":"003e","stackVersion":66,"type":"Router","zclVersion":2},"last_seen":"2024-02-14T20:15:54.670Z","linkquality":116}'
Info 2024-02-14 21:15:53Successfully interviewed '0x000474000023165c', device has successfully been paired
Info 2024-02-14 21:15:53Device '0x000474000023165c' is supported, identified as: Legrand Power socket with power consumption monitoring (067775/741811)
Info 2024-02-14 21:15:53MQTT publish: topic 'zigbee2mqtt/bridge/event', payload '{"data":{"definition":{"description":"Power socket with power consumption monitoring","exposes":[{"features":[{"access":7,"description":"On/off state of the switch","label":"State","name":"state","property":"state","type":"binary","value_off":"OFF","value_on":"ON","value_toggle":"TOGGLE"}],"type":"switch"},{"access":1,"description":"Triggered action (e.g. a button click)","label":"Action","name":"action","property":"action","type":"enum","values":["identify"]},{"access":1,"category":"diagnostic","description":"Instantaneous measured power","label":"Power","name":"power","property":"power","type":"numeric","unit":"W"},{"access":1,"description":"Instantaneous measured apparent power","label":"Power apparent","name":"power_apparent","property":"power_apparent","type":"numeric","unit":"VA"},{"access":7,"description":"Enables the LED when the power socket is turned off, allowing to see it in the dark","label":"Led in dark","name":"led_in_dark","property":"led_in_dark","type":"binary","value_off":"OFF","value_on":"ON"},{"access":7,"description":"Enables the LED when the device is turned on","label":"Led if on","name":"led_if_on","property":"led_if_on","type":"binary","value_off":"OFF","value_on":"ON"},{"access":7,"category":"config","description":"Controls the behavior when the device is powered on after power loss. If you get an `UNSUPPORTED_ATTRIBUTE` error, the device does not support it.","label":"Power-on behavior","name":"power_on_behavior","property":"power_on_behavior","type":"enum","values":["off","previous","on"]},{"access":1,"category":"diagnostic","description":"Link quality (signal strength)","label":"Linkquality","name":"linkquality","property":"linkquality","type":"numeric","unit":"lqi","value_max":255,"value_min":0}],"model":"067775/741811","options":[{"access":2,"description":"Calibrates the power value (percentual offset), takes into effect on next report of device.","label":"Power calibration","name":"power_calibration","property":"power_calibration","type":"numeric"},{"access":2,"description":"Number of digits after decimal point for power, takes into effect on next report of device. This option can only decrease the precision, not increase it.","label":"Power precision","name":"power_precision","property":"power_precision","type":"numeric","value_max":3,"value_min":0},{"access":2,"description":"State actions will also be published as 'action' when true (default false).","label":"State action","name":"state_action","property":"state_action","type":"binary","value_off":false,"value_on":true}],"supports_ota":true,"vendor":"Legrand"},"friendly_name":"0x000474000023165c","ieee_address":"0x000474000023165c","status":"successful","supported":true},"type":"device_interview"}'
Info 2024-02-14 21:15:53Configuring '0x000474000023165c'
Info 2024-02-14 21:15:53MQTT publish: topic 'zigbee2mqtt/0x000474000023165c', payload '{"device":{"applicationVersion":0,"dateCode":" \u000020221220\u0000\u0000\u0000\u0000\u0000","friendlyName":"0x000474000023165c","hardwareVersion":2,"ieeeAddr":"0x000474000023165c","manufacturerID":4129,"manufacturerName":" Legrand","model":"067775/741811","networkAddress":6747,"powerSource":"Mains (single phase)","softwareBuildID":"003e","stackVersion":66,"type":"Router","zclVersion":2},"last_seen":"2024-02-14T20:15:55.096Z","linkquality":116}'
Debug 2024-02-14 21:16:01Received Zigbee message from '0x000474000023165c', type 'read', cluster 'genBasic', data '[61440]' from endpoint 1 with groupID 0
Info 2024-02-14 21:16:01MQTT publish: topic 'zigbee2mqtt/0x000474000023165c', payload '{"device":{"applicationVersion":0,"dateCode":" \u000020221220\u0000\u0000\u0000\u0000\u0000","friendlyName":"0x000474000023165c","hardwareVersion":2,"ieeeAddr":"0x000474000023165c","manufacturerID":4129,"manufacturerName":" Legrand","model":"067775/741811","networkAddress":6747,"powerSource":"Mains (single phase)","softwareBuildID":"003e","stackVersion":66,"type":"Router","zclVersion":2},"last_seen":"2024-02-14T20:16:02.336Z","linkquality":120}'
Error 2024-02-14 21:16:04Failed to configure '0x000474000023165c', attempt 1 (Error: {"address":6747,"clusterId":32801,"sequence":62} after 10000ms at Object.start (/var/www/html/plugins/z2m/resources/zigbee2mqtt/node_modules/zigbee-herdsman/src/utils/waitress.ts:63:23) at Driver.zdoRequest (/var/www/html/plugins/z2m/resources/zigbee2mqtt/node_modules/zigbee-herdsman/src/adapter/ezsp/driver/driver.ts:667:43) at /var/www/html/plugins/z2m/resources/zigbee2mqtt/node_modules/zigbee-herdsman/src/adapter/ezsp/adapter/ezspAdapter.ts:566:13 at Queue.execute (/var/www/html/plugins/z2m/resources/zigbee2mqtt/node_modules/zigbee-herdsman/src/utils/queue.ts:35:20) at Endpoint.bind (/var/www/html/plugins/z2m/resources/zigbee2mqtt/node_modules/zigbee-herdsman/src/controller/model/endpoint.ts:551:13) at Object.bind (/var/www/html/plugins/z2m/resources/zigbee2mqtt/node_modules/zigbee-herdsman-converters/src/lib/reporting.ts:43:9) at Object.configure (/var/www/html/plugins/z2m/resources/zigbee2mqtt/node_modules/zigbee-herdsman-converters/src/devices/legrand.ts:366:13) at Configure.configure (/var/www/html/plugins/z2m/resources/zigbee2mqtt/lib/extension/configure.ts:120:13) at EventEmitter.wrappedCallback (/var/www/html/plugins/z2m/resources/zigbee2mqtt/lib/eventBus.ts:174:17))
Warning 2024-02-14 21:16:04Device '0x000474000023165c' left the network
Info 2024-02-14 21:16:04MQTT publish: topic 'zigbee2mqtt/bridge/event', payload '{"data":{"friendly_name":"0x000474000023165c","ieee_address":"0x000474000023165c"},"type":"device_leave"}'
Info 2024-02-14 21:16:06MQTT publish: topic 'zigbee2mqtt/0x000474000023165c', payload '{"device":{"applicationVersion":0,"dateCode":" \u000020221220\u0000\u0000\u0000\u0000\u0000","friendlyName":"0x000474000023165c","hardwareVersion":2,"ieeeAddr":"0x000474000023165c","manufacturerID":4129,"manufacturerName":" Legrand","model":"067775/741811","networkAddress":65116,"powerSource":"Mains (single phase)","softwareBuildID":"003e","stackVersion":66,"type":"Router","zclVersion":2},"last_seen":"2024-02-14T20:16:07.537Z","linkquality":120}'
Info 2024-02-14 21:16:06Device '0x000474000023165c' joined
Info 2024-02-14 21:16:06MQTT publish: topic 'zigbee2mqtt/bridge/event', payload '{"data":{"friendly_name":"0x000474000023165c","ieee_address":"0x000474000023165c"},"type":"device_joined"}'
Info 2024-02-14 21:16:06Starting interview of '0x000474000023165c'
Info 2024-02-14 21:16:06MQTT publish: topic 'zigbee2mqtt/bridge/event', payload '{"data":{"friendly_name":"0x000474000023165c","ieee_address":"0x000474000023165c","status":"started"},"type":"device_interview"}'
Info 2024-02-14 21:16:17MQTT publish: topic 'zigbee2mqtt/0x000474000023165c', payload '{"device":{"applicationVersion":0,"dateCode":" \u000020221220\u0000\u0000\u0000\u0000\u0000","friendlyName":"0x000474000023165c","hardwareVersion":2,"ieeeAddr":"0x000474000023165c","manufacturerID":4129,"manufacturerName":" Legrand","model":"067775/741811","networkAddress":1984,"powerSource":"Mains (single phase)","softwareBuildID":"003e","stackVersion":66,"type":"Router","zclVersion":2},"last_seen":"2024-02-14T20:16:18.302Z","linkquality":120}'
Info 2024-02-14 21:16:17MQTT publish: topic 'zigbee2mqtt/0x000474000023165c', payload '{"device":{"applicationVersion":0,"dateCode":" \u000020221220\u0000\u0000\u0000\u0000\u0000","friendlyName":"0x000474000023165c","hardwareVersion":2,"ieeeAddr":"0x000474000023165c","manufacturerID":4129,"manufacturerName":" Legrand","model":"067775/741811","networkAddress":1984,"powerSource":"Mains (single phase)","softwareBuildID":"003e","stackVersion":66,"type":"Router","zclVersion":2},"last_seen":"2024-02-14T20:16:18.412Z","linkquality":120}'
Debug 2024-02-14 21:16:24Received Zigbee message from '0x000474000023165c', type 'read', cluster 'genBasic', data '[61440]' from endpoint 1 with groupID 0
Debug 2024-02-14 21:16:24Skipping message, still interviewing
Info 2024-02-14 21:16:24MQTT publish: topic 'zigbee2mqtt/0x000474000023165c', payload '{"device":{"applicationVersion":0,"dateCode":" \u000020221220\u0000\u0000\u0000\u0000\u0000","friendlyName":"0x000474000023165c","hardwareVersion":2,"ieeeAddr":"0x000474000023165c","manufacturerID":4129,"manufacturerName":" Legrand","model":"067775/741811","networkAddress":1984,"powerSource":"Mains (single phase)","softwareBuildID":"003e","stackVersion":66,"type":"Router","zclVersion":2},"last_seen":"2024-02-14T20:16:25.778Z","linkquality":116}'
Warning 2024-02-14 21:16:24Device '0x000474000023165c' left the network
Info 2024-02-14 21:16:25MQTT publish: topic 'zigbee2mqtt/bridge/event', payload '{"data":{"friendly_name":"0x000474000023165c","ieee_address":"0x000474000023165c"},"type":"device_leave"}'
Warning 2024-02-14 21:16:25Device '0x000474000023165c' left the network
Voici le log Z2M en debug :
0433|[2024-02-14 21:33:43]DEBUG : {"zigbee2mqtt":{"bridge":{"logging":{"level":"error","message":"Entity '0x000474000023165c' is unknown"}}}}
0434|[2024-02-14 21:33:43]DEBUG : [execute] zigbee2mqtt/0x000474000023165c/set => {"state":"ON"}
0435|[2024-02-14 21:33:43]DEBUG : {"zigbee2mqtt":{"bridge":{"logging":{"level":"error","message":"Entity '0x000474000023165c' is unknown"}}}}
0436|[2024-02-14 21:33:43]DEBUG : [execute] zigbee2mqtt/0x000474000023165c/set => {"state":"ON"}
0437|[2024-02-14 21:33:44]DEBUG : {"zigbee2mqtt":{"bridge":{"logging":{"level":"error","message":"Entity '0x000474000023165c' is unknown"}}}}
0438|[2024-02-14 21:33:44]DEBUG : [execute] zigbee2mqtt/0x000474000023165c/set => {"state":"ON"}
0439|[2024-02-14 21:33:44]DEBUG : {"zigbee2mqtt":{"bridge":{"logging":{"level":"error","message":"Entity '0x000474000023165c' is unknown"}}}}
Tschaï
