Problème ay démarrage
bonjour j’ai un souci au demmarage voici le long merci d’avance
[START CONSISTENCY]
PHP Fatal error: Uncaught Error: Undefined class constant ‹ MYSQL_ATTR_INIT_COMMAND › in /var/www/html/core/class/DB.class.php:41
Stack trace:
#0 /var/www/html/core/class/DB.class.php(54): DB->__construct()
#1 /var/www/html/core/class/DB.class.php(86): DB::getConnection()
#2 /var/www/html/core/class/DB.class.php(595): DB::Prepare('describe cmd', Array, 1)
#3 /var/www/html/core/class/DB.class.php(587): DB::compareTable(Array)
#4 /var/www/html/core/class/DB.class.php(512): DB::compareDatabase(Array)
#5 /var/www/html/install/database.php(31): DB::compareAndFix(Array, ‹ all ›, true)
#6 {main}
thrown in /var/www/html/core/class/DB.class.php on line 41
[START CHECK AND FIX DB]
Stack trace:
#2 /var/www/html/core/class/config.class.php(145): DB::Prepare(‹ SELECT value
… ›, Array, 0)
#3 /var/www/html/install/consistency.php(49): config::byKey(‹ object:summary ›)
#4 {main}
J’ai le même problème, avez-vous une solution ?
[START CONSISTENCY]
PHP Fatal error: Uncaught Error: Undefined class constant ‹ MYSQL_ATTR_INIT_COMMAND › in /var/www/html/core/class/DB.class.php:40
Stack trace:
#0 /var/www/html/core/class/DB.class.php(50): DB::initConnection()
#1 /var/www/html/core/class/DB.class.php(82): DB::getConnection()
#2 /var/www/html/core/class/DB.class.php(595): DB::Prepare(‹ describe cmd‹ , Array, 1)
#6 {main}
thrown in /var/www/html/core/class/DB.class.php on line 40
Stack trace:
#2 /var/www/html/core/class/config.class.php(173): DB::Prepare(‹ SELECT key,`v… ›, Array, 1)
#3 /var/www/html/core/class/translate.class.php(34): config::byKeys(Array)
#4 /var/www/html/core/class/translate.class.php(151): translate::getConfig(‹ language ›, ‹ fr_FR ›)
#5 /var/www/html/core/class/translate.class.php(75): translate::getLanguage()
#6 /var/www/html/core/class/translate.class.php(54): translate::exec( ›{{Chauffage}} ›, ‹ /var/www/html/c… ›, false)
#7 /var/www/html/core/class/translate.class.php(165): translate::sentence(‹ Chauffage ›, ‹ /var/www/html/c… ›, false)
#8 /var/www/html/core/config/jeedom.config.php(23): __(‹ Chauffage ›, ‹ /var/www/html/c… ›)
#9 /var/www/html/core/php/utils.inc.php(70): require_once(’/var/www/html/c…’)
#10 /var/www/html/core in /var/www/html/core/class/DB.class.php on line 40
