Problème avec zigbee-herdsman
J ai voulu installer zigbeelinker mais j’ai un message qui revient en permanence :
zigbee2mqtt_demon ##### Le service zigbee2mqtt s’est arrêté #####
Le demon de zigbeelinker semble fonctionner car il est OK.
Voici le log ou je vois l’erreur:
Zigbee2MQTT:debug 2022-12-25 18:04:23: Loaded state from file /var/www/html/plugins/zigbee2mqtt/data/zigbee2mqtt/state.json
Zigbee2MQTT:info  2022-12-25 18:04:23: Logging to console and directory: '/var/www/html/plugins/zigbee2mqtt/data/zigbee2mqtt/log/2022-12-25.18-04-23' filename: log.txt
Zigbee2MQTT:debug 2022-12-25 18:04:23: Removing old log directory '/var/www/html/plugins/zigbee2mqtt/data/zigbee2mqtt/log/2022-12-25.17-41-06'
Zigbee2MQTT:info  2022-12-25 18:04:23: Starting Zigbee2MQTT version 1.28.4 (commit #52e545f9)
Zigbee2MQTT:info  2022-12-25 18:04:23: Starting zigbee-herdsman (0.14.76)
Zigbee2MQTT:debug 2022-12-25 18:04:23: Using zigbee-herdsman with settings: '{"adapter":{"concurrent":null,"delay":null,"disableLED":false},"backupPath":"/var/www/html/plugins/zigbee2mqtt/data/zigbee2mqtt/coordinator_backup.json","databaseBackupPath":"/var/www/html/plugins/zigbee2mqtt/data/zigbee2mqtt/database.db.backup","databasePath":"/var/www/html/plugins/zigbee2mqtt/data/zigbee2mqtt/database.db","network":{"channelList":[20],"extendedPanID":[221,221,221,221,221,221,221,221],"networkKey":"HIDDEN","panID":10390},"serialPort":{"adapter":"deconz"}}'
2022-12-25T17:04:23.476Z zigbee-herdsman:adapter No path provided, auto detecting path
2022-12-25T17:04:23.695Z zigbee-herdsman:adapter Auto detected path '/dev/ttyACM0' from adapter 'DeconzAdapter'
2022-12-25T17:04:23.697Z zigbee-herdsman:deconz:driver Set delay to 0
2022-12-25T17:04:23.699Z zigbee-herdsman:controller:log Starting with options '{"network":{"networkKeyDistribute":false,"networkKey":[119,35,45,2,183,101,175,220,93,125,224,73,96,45,88,4],"panID":10390,"extendedPanID":[221,221,221,221,221,221,221,221],"channelList":[20]},"serialPort":{"path":"/dev/ttyACM0","adapter":"deconz"},"databasePath":"/var/www/html/plugins/zigbee2mqtt/data/zigbee2mqtt/database.db","databaseBackupPath":"/var/www/html/plugins/zigbee2mqtt/data/zigbee2mqtt/database.db.backup","backupPath":"/var/www/html/plugins/zigbee2mqtt/data/zigbee2mqtt/coordinator_backup.json","adapter":{"disableLED":false,"concurrent":null,"delay":null}}'
2022-12-25T17:04:23.699Z zigbee-herdsman:deconz:driver Opening with /dev/ttyACM0
2022-12-25T17:04:23.705Z zigbee-herdsman:deconz:driver Serialport opened
2022-12-25T17:04:23.707Z zigbee-herdsman:controller:log Started with result 'resumed'
2022-12-25T17:04:23.707Z zigbee-herdsman:controller:log Injected database: true, adapter: true
2022-12-25T17:04:23.730Z zigbee-herdsman:deconz:driver send read parameter request from queue. seqNr: 1 paramId: 1
2022-12-25T17:04:26.700Z zigbee-herdsman:deconz:adapter checking coordinator simple descriptor
2022-12-25T17:04:26.707Z zigbee-herdsman:deconz:driver DATA_REQUEST - destAddr: 0x0 EP:0 SeqNr. 2 request id: 1
2022-12-25T17:04:33.730Z zigbee-herdsman:deconz:driver Timeout for request - CMD: 0xa seqNr: 1
Zigbee2MQTT:error 2022-12-25 18:04:33: Error while starting zigbee-herdsman
Zigbee2MQTT:error 2022-12-25 18:04:33: Failed to start zigbee
Zigbee2MQTT:error 2022-12-25 18:04:33: Check https://www.zigbee2mqtt.io/guide/installation/20_zigbee2mqtt-fails-to-start.html for possible solutions
Zigbee2MQTT:error 2022-12-25 18:04:33: Exiting...
Zigbee2MQTT:error 2022-12-25 18:04:33: undefined
Voici ma config :
Boitier Jeedom Atlas sous zigbee
et une clef combe 2
Je souhaite savoir si ma clef est bien configurer.
La clef Combee 2 a été mis sur un port USB Bleu (En haut à gauche des 4 ports usb), est ce le bon endroit ?
Ca me permettrait d’avancer à résoudre mon problème et si vous avez une piste pour m’aider je suis preneur.
Tu parles de ZigbeeLinker (basé sur Z2M) et tu mets des copie d’écran du plugin Zigbee Jeedom …
SI tu utilises ZigbeeLinker, tu ne dois pas configurer la clé sous le plugin Zigbee
Merci MaGoo pour cette precision
Je pensais qu’il fallait mettre la clef sur Zigbee Atlas.
Je l’ai enlevé puis redémarrer le boitier Atlas.
Puis relancer les dépendances ZigbeeLinker et cela fonctionne
J’ai pu ajouter un module sans souci.
Donc impec, je vais pouvoir tester
Merci pour ton aide
