Je viens de faire `la maj à l’instant. Même souci.
Un bout de log en mode debug pour aider.
Jeedom version 4.1.28
Plugin Zigbee du 08-01-2022 en Stable (dernière Maj)
Le démon est ok.
2022-01-09 16:19:03][DEBUG] : http://127.0.0.1:8089/device/all?with_attributes=2 type : GET
[2022-01-09 16:19:03][DEBUG] : {"with_attributes":2}
[2022-01-09 16:19:03][DEBUG] : http://127.0.0.1:8089/group/all type : GET
[2022-01-09 16:19:03][DEBUG] : null
[2022-01-09 16:19:04][DEBUG] : http://127.0.0.1:8089/device/all?with_attributes=2 type : GET
[2022-01-09 16:19:04][DEBUG] : {"with_attributes":2}
[2022-01-09 16:19:04][DEBUG] : http://127.0.0.1:8089/group/all type : GET
[2022-01-09 16:19:04][DEBUG] : null
[2022-01-09 16:19:05][DEBUG] : http://127.0.0.1:8089/device/all?with_attributes=2 type : GET
[2022-01-09 16:19:05][DEBUG] : {"with_attributes":2}
[2022-01-09 16:19:05][DEBUG] : http://127.0.0.1:8089/group/all type : GET
[2022-01-09 16:19:05][DEBUG] : null
[2022-01-09 16:19:06][DEBUG] : http://127.0.0.1:8089/application/info type : GET
[2022-01-09 16:19:06][DEBUG] : http://127.0.0.1:8089/device/all type : GET
[2022-01-09 16:19:06][DEBUG] : null
[2022-01-09 16:19:06][DEBUG] : {"with_attributes":0}
[2022-01-09 16:19:06][DEBUG] : http://127.0.0.1:8089/network/map type : GET
[2022-01-09 16:19:06][DEBUG] : [{"ieee":"84:fd:27:ff:fe:0e:46:eb","nwk":"0x0000","lqi":null,"rssi":null,"device_type":"Coordinator","manufacturer":"Silicon Labs","model":"EZSP","offline":false,"neighbours":[{"ieee":"00:17:88:01:02:d8:97:94","nwk":"0xcbcf","lqi":88,"rssi":null,"pan_id":"0e:74:2c:79:46:13:44:60","device_type":"Router","rx_on_when_idle":"On","relation":"Sibling","new_joins_accepted":"Unknown","depth":15,"model":"LCT010","manufacturer":"Signify Netherlands B.V.","offline":false,"supported":true}]},{"ieee":"84:fd:27:ff:fe:92:82:31","nwk":"0x563b","lqi":88,"rssi":-78,"device_type":"Router","manufacturer":"SONOFF","model":"01MINIZB","offline":false,"neighbours":[{"ieee":"00:17:88:01:02:d8:97:94","nwk":"0xcbcf","lqi":56,"rssi":null,"pan_id":"0e:74:2c:79:46:13:44:60","device_type":"Router","rx_on_when_idle":"On","relation":"Sibling","new_joins_accepted":"Unknown","depth":15,"model":"LCT010","manufacturer":"Signify Netherlands B.V.","offline":false,"supported":true},{"ieee":"84:fd:27:ff:fe:0e:46:eb","nwk":"0x0000","lqi":42,"rssi":null,"pan_id":"0e:74:2c:79:46:13:44:60","device_type":"Coordinator","rx_on_when_idle":"On","relation":"Parent","new_joins_accepted":"Unknown","depth":0,"model":"EZSP","manufacturer":"Silicon Labs","offline":false,"supported":true}]},{"ieee":"00:17:88:01:02:d8:97:94","nwk":"0xcbcf","lqi":null,"rssi":null,"device_type":"Router","manufacturer":"Signify Netherlands B.V.","model":"LCT010","offline":false,"neighbours":[{"ieee":"84:fd:27:ff:fe:92:82:31","nwk":"0x563b","lqi":0,"rssi":-78,"pan_id":"0e:74:2c:79:46:13:44:60","device_type":"Router","rx_on_when_idle":"On","relation":"None_of_the_above","new_joins_accepted":"Accepting","depth":1,"model":"01MINIZB","manufacturer":"SONOFF","offline":false,"supported":true},{"ieee":"84:fd:27:ff:fe:0e:46:eb","nwk":"0x0000","lqi":75,"rssi":null,"pan_id":"0e:74:2c:79:46:13:44:60","device_type":"Coordinator","rx_on_when_idle":"On","relation":"Parent","new_joins_accepted":"Accepting","depth":0,"model":"EZSP","manufacturer":"Silicon Labs","offline":false,"supported":true}]}]
[2022-01-09 16:19:06][DEBUG] : [{"ieee":"84:fd:27:ff:fe:0e:46:eb","nwk":0,"status":2,"lqi":"None","rssi":"None","last_seen":"None","node_descriptor":"00:40:8f:cd:ab:52:80:00:41:2c:80:00:00","endpoints":[{"id":1,"status":1,"device_type":48879,"profile_id":260,"manufacturer":null,"model":null,"output_clusters":[],"input_clusters":[]}],"signature":{"manufacturer":"Silicon Labs","model":"EZSP","node_desc":{"logical_type":0,"complex_descriptor_available":0,"user_descriptor_available":0,"reserved":0,"aps_flags":0,"frequency_band":8,"mac_capability_flags":143,"manufacturer_code":43981,"maximum_buffer_size":82,"maximum_incoming_transfer_size":128,"server_mask":11329,"maximum_outgoing_transfer_size":128,"descriptor_capability_field":0},"endpoints":{"1":{"profile_id":260,"device_type":48879,"input_clusters":[],"output_clusters":[]}}},"class":"bellows.zigbee.application"},{"ieee":"84:fd:27:ff:fe:92:82:31","nwk":22075,"status":2,"lqi":"88","rssi":"-78","last_seen":"1641741506.1277688","node_descriptor":"01:40:8e:02:10:52:52:00:00:2c:52:00:00","endpoints":[{"id":1,"status":1,"device_type":256,"profile_id":260,"manufacturer":"SONOFF","model":"01MINIZB","output_clusters":[{"id":4096,"name":"LightLink","attributes":[]}],"input_clusters":[{"id":0,"name":"Basic","attributes":[{"id":0,"name":"zcl_version","value":3},{"id":4,"name":"manufacturer","value":"SONOFF"},{"id":5,"name":"model","value":"01MINIZB"},{"id":6,"name":"date_code","value":"20200927"},{"id":7,"name":"power_source","value":0}]},{"id":3,"name":"Identify","attributes":[]},{"id":4,"name":"Groups","attributes":[]},{"id":5,"name":"Scenes","attributes":[]},{"id":6,"name":"On\/Off","attributes":[{"id":0,"name":"on_off","value":0}]},{"id":4096,"name":"LightLink","attributes":[]}]},{"id":242,"status":1,"device_type":97,"profile_id":41440,"manufacturer":null,"model":null,"output_clusters":[{"id":33,"name":"GreenPowerProxy","attributes":[]}],"input_clusters":[]}],"signature":{"manufacturer":"SONOFF","model":"01MINIZB","node_desc":{"logical_type":1,"complex_descriptor_available":0,"user_descriptor_available":0,"reserved":0,"aps_flags":0,"frequency_band":8,"mac_capability_flags":142,"manufacturer_code":4098,"maximum_buffer_size":82,"maximum_incoming_transfer_size":82,"server_mask":11264,"maximum_outgoing_transfer_size":82,"descriptor_capability_field":0},"endpoints":{"1":{"profile_id":260,"device_type":256,"input_clusters":[0,3,4,5,6,4096],"output_clusters":[4096]},"242":{"profile_id":41440,"device_type":97,"input_clusters":[],"output_clusters":[33]}}},"class":"zigpy.device"},{"ieee":"00:17:88:01:02:d8:97:94","nwk":52175,"status":2,"lqi":"None","rssi":"None","last_seen":"None","node_descriptor":"01:40:8e:0b:10:47:2d:00:00:00:2d:00:00","endpoints":[{"id":11,"status":1,"device_type":528,"profile_id":49246,"manufacturer":"Signify Netherlands B.V.","model":"LCT010","output_clusters":[{"id":25,"name":"Ota","attributes":[]}],"input_clusters":[{"id":0,"name":"Basic","attributes":[{"id":0,"name":"zcl_version","value":1},{"id":1,"name":"app_version","value":2},{"id":2,"name":"stack_version","value":1},{"id":3,"name":"hw_version","value":1},{"id":4,"name":"manufacturer","value":"Signify Netherlands B.V."},{"id":5,"name":"model","value":"LCT010"},{"id":6,"name":"date_code","value":"20210331"},{"id":7,"name":"power_source","value":1},{"id":16384,"name":"sw_build_id","value":"1.88.1"}]},{"id":3,"name":"Identify","attributes":[]},{"id":4,"name":"Groups","attributes":[]},{"id":5,"name":"Scenes","attributes":[]},{"id":6,"name":"On\/Off","attributes":[{"id":0,"name":"on_off","value":1},{"id":16387,"name":"start_up_on_off","value":1}]},{"id":8,"name":"Level control","attributes":[{"id":0,"name":"current_level","value":254},{"id":16384,"name":"start_up_current_level","value":254}]},{"id":4096,"name":"LightLink","attributes":[]},{"id":64515,"name":"Manufacturer Specific","attributes":[]},{"id":768,"name":"Color Control","attributes":[{"id":3,"name":"current_x","value":14577},{"id":4,"name":"current_y","value":8990},{"id":7,"name":"color_temperature","value":500},{"id":16400,"name":"start_up_color_temperature","value":366}]},{"id":64513,"name":"Manufacturer Specific","attributes":[]}]},{"id":242,"status":1,"device_type":97,"profile_id":41440,"manufacturer":null,"model":null,"output_clusters":[{"id":33,"name":"GreenPowerProxy","attributes":[]}],"input_clusters":[{"id":33,"name":"GreenPowerProxy","attributes":[]}]}],"signature":{"manufacturer":"Signify Netherlands B.V.","model":"LCT010","node_desc":{"logical_type":1,"complex_descriptor_available":0,"user_descriptor_available":0,"reserved":0,"aps_flags":0,"frequency_band":8,"mac_capability_flags":142,"manufacturer_code":4107,"maximum_buffer_size":71,"maximum_incoming_transfer_size":45,"server_mask":0,"maximum_outgoing_transfer_size":45,"descriptor_capability_field":0},"endpoints":{"11":{"profile_id":49246,"device_type":528,"input_clusters":[0,3,4,5,6,8,4096,64515,768,64513],"output_clusters":[25]},"242":{"profile_id":41440,"device_type":97,"input_clusters":[33],"output_clusters":[33]}}},"class":"zigpy.device"}]
[2022-01-09 16:19:19][DEBUG] : http://127.0.0.1:8089/device/get_basic_info type : PUT
[2022-01-09 16:19:19][DEBUG] : {"ieee":"00:17:88:01:02:d8:97:94"}
[2022-01-09 16:19:22][DEBUG] : ""
[2022-01-09 16:19:25][DEBUG] : http://127.0.0.1:8089/device/get_basic_info type : PUT
[2022-01-09 16:19:25][DEBUG] : {"ieee":"84:fd:27:ff:fe:0e:46:eb"}
[2022-01-09 16:19:25][DEBUG] : ""
[2022-01-09 16:19:26][DEBUG] : http://127.0.0.1:8089/device/get_basic_info type : PUT
[2022-01-09 16:19:26][DEBUG] : {"ieee":"84:fd:27:ff:fe:0e:46:eb"}
[2022-01-09 16:19:26][DEBUG] : ""
[2022-01-09 16:19:27][DEBUG] : http://127.0.0.1:8089/device/get_basic_info type : PUT
[2022-01-09 16:19:27][DEBUG] : {"ieee":"84:fd:27:ff:fe:0e:46:eb"}
[2022-01-09 16:19:27][DEBUG] : ""
[2022-01-09 16:19:28][DEBUG] : http://127.0.0.1:8089/device/get_basic_info type : PUT
[2022-01-09 16:19:28][DEBUG] : {"ieee":"84:fd:27:ff:fe:0e:46:eb"}
[2022-01-09 16:19:28][DEBUG] : ""
[2022-01-09 16:19:29][DEBUG] : http://127.0.0.1:8089/device/get_basic_info type : PUT
[2022-01-09 16:19:29][DEBUG] : {"ieee":"84:fd:27:ff:fe:0e:46:eb"}
[2022-01-09 16:19:29][DEBUG] : ""
[2022-01-09 16:19:30][DEBUG] : http://127.0.0.1:8089/device/get_basic_info type : PUT
[2022-01-09 16:19:30][DEBUG] : {"ieee":"84:fd:27:ff:fe:0e:46:eb"}
[2022-01-09 16:19:30][DEBUG] : ""
[2022-01-09 16:19:34][DEBUG] : http://127.0.0.1:8089/device/all?with_attributes=2 type : GET
[2022-01-09 16:19:34][DEBUG] : {"with_attributes":2}
[2022-01-09 16:19:34][DEBUG] : http://127.0.0.1:8089/group/all type : GET
[2022-01-09 16:19:34][DEBUG] : null
[2022-01-09 16:19:35][DEBUG] : http://127.0.0.1:8089/device/all?with_attributes=2 type : GET
[2022-01-09 16:19:35][DEBUG] : {"with_attributes":2}
[2022-01-09 16:19:35][DEBUG] : http://127.0.0.1:8089/group/all type : GET
[2022-01-09 16:19:35][DEBUG] : null
[2022-01-09 16:19:36][DEBUG] : http://127.0.0.1:8089/device/all?with_attributes=2 type : GET
[2022-01-09 16:19:36][DEBUG] : {"with_attributes":2}
[2022-01-09 16:19:36][DEBUG] : http://127.0.0.1:8089/group/all type : GET
[2022-01-09 16:19:36][DEBUG] : null
[2022-01-09 16:19:41][DEBUG] : http://127.0.0.1:8089/device/all type : GET
[2022-01-09 16:19:41][DEBUG] : http://127.0.0.1:8089/application/info type : GET
[2022-01-09 16:19:41][DEBUG] : {"with_attributes":0}
[2022-01-09 16:19:41][DEBUG] : null
[2022-01-09 16:19:41][DEBUG] : http://127.0.0.1:8089/network/map type : GET
[2022-01-09 16:19:41][DEBUG] : [{"ieee":"84:fd:27:ff:fe:0e:46:eb","nwk":"0x0000","lqi":null,"rssi":null,"device_type":"Coordinator","manufacturer":"Silicon Labs","model":"EZSP","offline":false,"neighbours":[{"ieee":"00:17:88:01:02:d8:97:94","nwk":"0xcbcf","lqi":88,"rssi":null,"pan_id":"0e:74:2c:79:46:13:44:60","device_type":"Router","rx_on_when_idle":"On","relation":"Sibling","new_joins_accepted":"Unknown","depth":15,"model":"LCT010","manufacturer":"Signify Netherlands B.V.","offline":false,"supported":true}]},{"ieee":"84:fd:27:ff:fe:92:82:31","nwk":"0x563b","lqi":88,"rssi":-78,"device_type":"Router","manufacturer":"SONOFF","model":"01MINIZB","offline":false,"neighbours":[{"ieee":"00:17:88:01:02:d8:97:94","nwk":"0xcbcf","lqi":56,"rssi":null,"pan_id":"0e:74:2c:79:46:13:44:60","device_type":"Router","rx_on_when_idle":"On","relation":"Sibling","new_joins_accepted":"Unknown","depth":15,"model":"LCT010","manufacturer":"Signify Netherlands B.V.","offline":false,"supported":true},{"ieee":"84:fd:27:ff:fe:0e:46:eb","nwk":"0x0000","lqi":42,"rssi":null,"pan_id":"0e:74:2c:79:46:13:44:60","device_type":"Coordinator","rx_on_when_idle":"On","relation":"Parent","new_joins_accepted":"Unknown","depth":0,"model":"EZSP","manufacturer":"Silicon Labs","offline":false,"supported":true}]},{"ieee":"00:17:88:01:02:d8:97:94","nwk":"0xcbcf","lqi":null,"rssi":null,"device_type":"Router","manufacturer":"Signify Netherlands B.V.","model":"LCT010","offline":false,"neighbours":[{"ieee":"84:fd:27:ff:fe:92:82:31","nwk":"0x563b","lqi":0,"rssi":-78,"pan_id":"0e:74:2c:79:46:13:44:60","device_type":"Router","rx_on_when_idle":"On","relation":"None_of_the_above","new_joins_accepted":"Accepting","depth":1,"model":"01MINIZB","manufacturer":"SONOFF","offline":false,"supported":true},{"ieee":"84:fd:27:ff:fe:0e:46:eb","nwk":"0x0000","lqi":75,"rssi":null,"pan_id":"0e:74:2c:79:46:13:44:60","device_type":"Coordinator","rx_on_when_idle":"On","relation":"Parent","new_joins_accepted":"Accepting","depth":0,"model":"EZSP","manufacturer":"Silicon Labs","offline":false,"supported":true}]}]
[2022-01-09 16:19:41][DEBUG] : [{"ieee":"84:fd:27:ff:fe:0e:46:eb","nwk":0,"status":2,"lqi":"None","rssi":"None","last_seen":"None","node_descriptor":"00:40:8f:cd:ab:52:80:00:41:2c:80:00:00","endpoints":[{"id":1,"status":1,"device_type":48879,"profile_id":260,"manufacturer":null,"model":null,"output_clusters":[],"input_clusters":[]}],"signature":{"manufacturer":"Silicon Labs","model":"EZSP","node_desc":{"logical_type":0,"complex_descriptor_available":0,"user_descriptor_available":0,"reserved":0,"aps_flags":0,"frequency_band":8,"mac_capability_flags":143,"manufacturer_code":43981,"maximum_buffer_size":82,"maximum_incoming_transfer_size":128,"server_mask":11329,"maximum_outgoing_transfer_size":128,"descriptor_capability_field":0},"endpoints":{"1":{"profile_id":260,"device_type":48879,"input_clusters":[],"output_clusters":[]}}},"class":"bellows.zigbee.application"},{"ieee":"84:fd:27:ff:fe:92:82:31","nwk":22075,"status":2,"lqi":"88","rssi":"-78","last_seen":"1641741506.1277688","node_descriptor":"01:40:8e:02:10:52:52:00:00:2c:52:00:00","endpoints":[{"id":1,"status":1,"device_type":256,"profile_id":260,"manufacturer":"SONOFF","model":"01MINIZB","output_clusters":[{"id":4096,"name":"LightLink","attributes":[]}],"input_clusters":[{"id":0,"name":"Basic","attributes":[{"id":0,"name":"zcl_version","value":3},{"id":4,"name":"manufacturer","value":"SONOFF"},{"id":5,"name":"model","value":"01MINIZB"},{"id":6,"name":"date_code","value":"20200927"},{"id":7,"name":"power_source","value":0}]},{"id":3,"name":"Identify","attributes":[]},{"id":4,"name":"Groups","attributes":[]},{"id":5,"name":"Scenes","attributes":[]},{"id":6,"name":"On\/Off","attributes":[{"id":0,"name":"on_off","value":0}]},{"id":4096,"name":"LightLink","attributes":[]}]},{"id":242,"status":1,"device_type":97,"profile_id":41440,"manufacturer":null,"model":null,"output_clusters":[{"id":33,"name":"GreenPowerProxy","attributes":[]}],"input_clusters":[]}],"signature":{"manufacturer":"SONOFF","model":"01MINIZB","node_desc":{"logical_type":1,"complex_descriptor_available":0,"user_descriptor_available":0,"reserved":0,"aps_flags":0,"frequency_band":8,"mac_capability_flags":142,"manufacturer_code":4098,"maximum_buffer_size":82,"maximum_incoming_transfer_size":82,"server_mask":11264,"maximum_outgoing_transfer_size":82,"descriptor_capability_field":0},"endpoints":{"1":{"profile_id":260,"device_type":256,"input_clusters":[0,3,4,5,6,4096],"output_clusters":[4096]},"242":{"profile_id":41440,"device_type":97,"input_clusters":[],"output_clusters":[33]}}},"class":"zigpy.device"},{"ieee":"00:17:88:01:02:d8:97:94","nwk":52175,"status":2,"lqi":"None","rssi":"None","last_seen":"None","node_descriptor":"01:40:8e:0b:10:47:2d:00:00:00:2d:00:00","endpoints":[{"id":11,"status":1,"device_type":528,"profile_id":49246,"manufacturer":"Signify Netherlands B.V.","model":"LCT010","output_clusters":[{"id":25,"name":"Ota","attributes":[]}],"input_clusters":[{"id":0,"name":"Basic","attributes":[{"id":0,"name":"zcl_version","value":1},{"id":1,"name":"app_version","value":2},{"id":2,"name":"stack_version","value":1},{"id":3,"name":"hw_version","value":1},{"id":4,"name":"manufacturer","value":"Signify Netherlands B.V."},{"id":5,"name":"model","value":"LCT010"},{"id":6,"name":"date_code","value":"20210331"},{"id":7,"name":"power_source","value":1},{"id":16384,"name":"sw_build_id","value":"1.88.1"}]},{"id":3,"name":"Identify","attributes":[]},{"id":4,"name":"Groups","attributes":[]},{"id":5,"name":"Scenes","attributes":[]},{"id":6,"name":"On\/Off","attributes":[{"id":0,"name":"on_off","value":1},{"id":16387,"name":"start_up_on_off","value":1}]},{"id":8,"name":"Level control","attributes":[{"id":0,"name":"current_level","value":254},{"id":16384,"name":"start_up_current_level","value":254}]},{"id":4096,"name":"LightLink","attributes":[]},{"id":64515,"name":"Manufacturer Specific","attributes":[]},{"id":768,"name":"Color Control","attributes":[{"id":3,"name":"current_x","value":14577},{"id":4,"name":"current_y","value":8990},{"id":7,"name":"color_temperature","value":500},{"id":16400,"name":"start_up_color_temperature","value":366}]},{"id":64513,"name":"Manufacturer Specific","attributes":[]}]},{"id":242,"status":1,"device_type":97,"profile_id":41440,"manufacturer":null,"model":null,"output_clusters":[{"id":33,"name":"GreenPowerProxy","attributes":[]}],"input_clusters":[{"id":33,"name":"GreenPowerProxy","attributes":[]}]}],"signature":{"manufacturer":"Signify Netherlands B.V.","model":"LCT010","node_desc":{"logical_type":1,"complex_descriptor_available":0,"user_descriptor_available":0,"reserved":0,"aps_flags":0,"frequency_band":8,"mac_capability_flags":142,"manufacturer_code":4107,"maximum_buffer_size":71,"maximum_incoming_transfer_size":45,"server_mask":0,"maximum_outgoing_transfer_size":45,"descriptor_capability_field":0},"endpoints":{"11":{"profile_id":49246,"device_type":528,"input_clusters":[0,3,4,5,6,8,4096,64515,768,64513],"output_clusters":[25]},"242":{"profile_id":41440,"device_type":97,"input_clusters":[33],"output_clusters":[33]}}},"class":"zigpy.device"}]
[2022-01-09 16:19:41][DEBUG] : {"ieee":"84:fd:27:ff:fe:0e:46:eb","version":"0.42.0","nwk":0,"config":{"database_path":"\/var\/www\/html\/plugins\/zigbee\/data\/1\/network_ezsp.db","device":{"path":"\/dev\/ttyUSB0","baudrate":115200,"flow_control":"software"},"network":{"channel":15,"key":null,"channels":34635776,"update_id":0,"pan_id":null,"tc_address":null,"tc_link_key":"5a:69:67:42:65:65:41:6c:6c:69:61:6e:63:65:30:39","extended_pan_id":null,"key_sequence_number":0},"ota":{"otau_directory":"\/var\/www\/html\/plugins\/zigbee\/data\/ota","ikea_provider":true,"ikea_update_url":"http:\/\/fw.ota.homesmart.ikea.net\/feed\/version_info.json","ledvance_provider":true},"ezsp":{"CONFIG_APS_UNICAST_MESSAGE_COUNT":12,"CONFIG_SOURCE_ROUTE_TABLE_SIZE":16,"CONFIG_ADDRESS_TABLE_SIZE":8},"topology_scan_enabled":true,"source_routing":false,"handle_unknown_devices":false,"topology_scan_skip_coordinator":false,"topology_scan_period":240,"ezsp_policies":[],"ezsp_config":[]},"ezsp":{"extendedPanId":"60:44:13:46:79:2c:74:0e","panId":"0xbe09","radioTxPower":8,"radioChannel":15,"nwkManagerId":"0x0","nwkUpdateId":"0x0","version":"6.9.1.0 build 214"}}
[2022-01-09 16:19:44][DEBUG] : http://127.0.0.1:8089/network/map type : GET
[2022-01-09 16:19:44][DEBUG] : null
[2022-01-09 16:19:44][DEBUG] : [{"ieee":"84:fd:27:ff:fe:0e:46:eb","nwk":"0x0000","lqi":null,"rssi":null,"device_type":"Coordinator","manufacturer":"Silicon Labs","model":"EZSP","offline":false,"neighbours":[{"ieee":"00:17:88:01:02:d8:97:94","nwk":"0xcbcf","lqi":88,"rssi":null,"pan_id":"0e:74:2c:79:46:13:44:60","device_type":"Router","rx_on_when_idle":"On","relation":"Sibling","new_joins_accepted":"Unknown","depth":15,"model":"LCT010","manufacturer":"Signify Netherlands B.V.","offline":false,"supported":true}]},{"ieee":"84:fd:27:ff:fe:92:82:31","nwk":"0x563b","lqi":88,"rssi":-78,"device_type":"Router","manufacturer":"SONOFF","model":"01MINIZB","offline":false,"neighbours":[{"ieee":"00:17:88:01:02:d8:97:94","nwk":"0xcbcf","lqi":56,"rssi":null,"pan_id":"0e:74:2c:79:46:13:44:60","device_type":"Router","rx_on_when_idle":"On","relation":"Sibling","new_joins_accepted":"Unknown","depth":15,"model":"LCT010","manufacturer":"Signify Netherlands B.V.","offline":false,"supported":true},{"ieee":"84:fd:27:ff:fe:0e:46:eb","nwk":"0x0000","lqi":42,"rssi":null,"pan_id":"0e:74:2c:79:46:13:44:60","device_type":"Coordinator","rx_on_when_idle":"On","relation":"Parent","new_joins_accepted":"Unknown","depth":0,"model":"EZSP","manufacturer":"Silicon Labs","offline":false,"supported":true}]},{"ieee":"00:17:88:01:02:d8:97:94","nwk":"0xcbcf","lqi":null,"rssi":null,"device_type":"Router","manufacturer":"Signify Netherlands B.V.","model":"LCT010","offline":false,"neighbours":[{"ieee":"84:fd:27:ff:fe:92:82:31","nwk":"0x563b","lqi":0,"rssi":-78,"pan_id":"0e:74:2c:79:46:13:44:60","device_type":"Router","rx_on_when_idle":"On","relation":"None_of_the_above","new_joins_accepted":"Accepting","depth":1,"model":"01MINIZB","manufacturer":"SONOFF","offline":false,"supported":true},{"ieee":"84:fd:27:ff:fe:0e:46:eb","nwk":"0x0000","lqi":75,"rssi":null,"pan_id":"0e:74:2c:79:46:13:44:60","device_type":"Coordinator","rx_on_when_idle":"On","relation":"Parent","new_joins_accepted":"Accepting","depth":0,"model":"EZSP","manufacturer":"Silicon Labs","offline":false,"supported":true}]}]
[2022-01-09 16:19:50][DEBUG] : http://127.0.0.1:8089/device/get_basic_info type : PUT
[2022-01-09 16:19:50][DEBUG] : {"ieee":"84:fd:27:ff:fe:0e:46:eb"}
[2022-01-09 16:19:50][DEBUG] : ""
[2022-01-09 16:20:05][DEBUG] : http://127.0.0.1:8089/device/get_basic_info type : PUT
[2022-01-09 16:20:05][DEBUG] : {"ieee":"00:17:88:01:02:d8:97:94"}
[2022-01-09 16:20:08][DEBUG] : ""
[2022-01-09 16:20:18][DEBUG] : http://127.0.0.1:8089/device/command type : PUT
[2022-01-09 16:20:18][DEBUG] : {"ieee":"84:fd:27:ff:fe:92:82:31","cmd":[{"endpoint":1,"cluster":"on_off","command":"on","await":1}],"allowQueue":false}
[2022-01-09 16:20:26][DEBUG] : http://127.0.0.1:8089/device/command type : PUT
[2022-01-09 16:20:26][DEBUG] : {"ieee":"84:fd:27:ff:fe:92:82:31","cmd":[{"endpoint":1,"cluster":"on_off","command":"on","await":1}],"allowQueue":false}
[2022-01-09 16:20:28][ERROR] : Erreur exécution de la commande [Monitoring][Alimentation Tablette][On] : Erreur lors de la requete : http://127.0.0.1:8089/device/command(PUT), data : {"ieee":"84:fd:27:ff:fe:92:82:31","cmd":[{"endpoint":1,"cluster":"on_off","command":"on","await":1}],"allowQueue":false} erreur : {"state":"error","result":"[0x563b:1:0x0006]: Message send failure","code":0}
[2022-01-09 16:20:37][ERROR] : Erreur exécution de la commande [Monitoring][Alimentation Tablette][On] : Erreur lors de la requete : http://127.0.0.1:8089/device/command(PUT), data : {"ieee":"84:fd:27:ff:fe:92:82:31","cmd":[{"endpoint":1,"cluster":"on_off","command":"on","await":1}],"allowQueue":false} erreur : {"state":"error","result":"[0x563b:1:0x0006]: Message send failure","code":0}
[2022-01-09 16:22:19][DEBUG] : http://127.0.0.1:8089/device/all?with_attributes=2 type : GET
[2022-01-09 16:22:19][DEBUG] : {"with_attributes":2}
[2022-01-09 16:22:19][DEBUG] : http://127.0.0.1:8089/group/all type : GET
[2022-01-09 16:22:19][DEBUG] : null
[2022-01-09 16:22:22][DEBUG] : {"devices":{"84:fd:27:ff:fe:92:82:31":{"1":{"6":[{"value":"Bool.false","cluster_name":"On\/Off"}]}}}}
[2022-01-09 16:22:22][DEBUG] : Search attribut for 84:fd:27:ff:fe:92:82:31 logicalId : 1::6::0 => Bool.false convert to 0
