Hello,I’m triying to connect the Zy-m100 from Aliexpress to my Jeedom,but i think it isn’t compatible or I can’t …do you know if have I to buy the tuya gateway or can I connect it directly?.
Thanks
Hello
You are wrting that you are trying to connect it to your Jeedom but with which plugin?
I’m connecting it with the Zigbee pluggin.it has been discovered,but I can’t see the model.I have tried to put some similar ,but it doesn’t work.
It doesn’t look to be supported yet.
Could you share the needed information based on the how-to implement new device in the documentation? If zigpy already implemented it, it should be quick for the Jeedom team to add it to the plugin.
THANKS…I have witten it here
https://community.jeedom.com/t/implement-zy-m100-tuya-human-presence-sensor/98557
