Hello la team,
J’ai un petit problème sur des prises DIO first (pack de 3 prises).
Voici la trame ON que j’intercepte pour une prise :
[2019-12-04 23:45:00][DEBUG] : Message: 0B 11 00 D1 00 83 44 66 01 01 0F 50
[2019-12-04 23:45:00][DEBUG] : Decode : 0B 11 00 D1 00 83 44 66 01 01 0F 50
[2019-12-04 23:45:00][DEBUG] : Test message: 0B 11 00 D1 00 83 44 66 01 01 0F 50
[2019-12-04 23:45:00][DEBUG] : PacketType: 11
[2019-12-04 23:45:00][DEBUG] : SubType: 00
[2019-12-04 23:45:00][DEBUG] : SeqNbr: D1
[2019-12-04 23:45:00][DEBUG] : Id1: 00
[2019-12-04 23:45:00][DEBUG] : Id2: 83
[2019-12-04 23:45:00][DEBUG] : Decode data : {‹ raw ›: ‹ 0B1100D10083446601010F50 ›, ‹ signal ›: ‹ 5 ›, ‹ subtype ›: ‹ 00 ›, ‹ command ›: ‹ On ›, ‹ dimlevel ›: ‹ 100 ›, ‹ unitcode ›: ‹ 1 ›, ‹ packettype ›: ‹ 11 ›, ‹ id ›: ‹ 00834466 ›}
[2019-12-04 23:45:00][DEBUG] : Send to jeedom : {‹ devices ›: {‹ 00834466111 ›: {‹ raw ›: ‹ 0B1100D10083446601010F50 ›, ‹ signal ›: ‹ 5 ›, ‹ subtype ›: ‹ 00 ›, ‹ command ›: ‹ On ›, ‹ dimlevel ›: ‹ 100 ›, ‹ unitcode ›: ‹ 1 ›, ‹ packettype ›: ‹ 11 ›, ‹ id ›: ‹ 00834466 ›}}}
[2019-12-04 23:45:00][DEBUG] : Starting new HTTPS connection (1): 127.0.0.1
Et voici une trame OFF :
[2019-12-04 23:45:08][DEBUG] : Message: 0B 11 00 D2 00 83 44 66 01 00 00 50
[2019-12-04 23:45:08][DEBUG] : Decode : 0B 11 00 D2 00 83 44 66 01 00 00 50
[2019-12-04 23:45:08][DEBUG] : Test message: 0B 11 00 D2 00 83 44 66 01 00 00 50
[2019-12-04 23:45:08][DEBUG] : PacketType: 11
[2019-12-04 23:45:08][DEBUG] : SubType: 00
[2019-12-04 23:45:08][DEBUG] : SeqNbr: D2
[2019-12-04 23:45:08][DEBUG] : Id1: 00
[2019-12-04 23:45:08][DEBUG] : Id2: 83
[2019-12-04 23:45:08][DEBUG] : Decode data : {‹ raw ›: ‹ 0B1100D20083446601000050 ›, ‹ signal ›: ‹ 5 ›, ‹ subtype ›: ‹ 00 ›, ‹ command ›: ‹ Off ›, ‹ dimlevel ›: ‹ 0 ›, ‹ unitcode ›: ‹ 1 ›, ‹ packettype ›: ‹ 11 ›, ‹ id ›: ‹ 00834466 ›}
[2019-12-04 23:45:08][DEBUG] : Send to jeedom : {‹ devices ›: {‹ 00834466111 ›: {‹ raw ›: ‹ 0B1100D20083446601000050 ›, ‹ signal ›: ‹ 5 ›, ‹ subtype ›: ‹ 00 ›, ‹ command ›: ‹ Off ›, ‹ dimlevel ›: ‹ 0 ›, ‹ unitcode ›: ‹ 1 ›, ‹ packettype ›: ‹ 11 ›, ‹ id ›: ‹ 00834466 ›}}}
[2019-12-04 23:45:08][DEBUG] : Starting new HTTPS connection (1): 127.0.0.1
[2019-12-04 23:45:08][DEBUG] : https://127.0.0.1:443 « POST /plugins/rfxcom/core/php/jeeRfxcom.php?apikey=J839QCw5vOGwI8v9Gqcy4gl5IFu1Vk74 HTTP/1.1 » 200 0
Ma question est comment intégrer cela dans Jeedom, en sachant que sur ces trames, la séquence change tout le temps …
J’avais créé une action avec le logical id suivant : 0B1100D1#ID#01010F50
Mais à chaque impulsion sur la telecommande la séquence s’incrémente, et mon logical id n’est plus bon …
