Prise Tuya 16A non reconnue automatiquement
J’ouvre un nouveau sujet a propos d’une prise Tuya Zigbee, qui s’appaire correctement dans le plugin mais qui n’est pas reconnu automatiquement,
Je l’ai positionné comme étant un module : [BW-SHP13] BLITZWOLF - Prise intelligente EU 16A et il fonctionne.
Les données brutes sont :
    "ieee": "84:fd:27:ff:fe:92:d7:ee",
    "nwk": 2126,
    "status": 2,
    "lqi": "224",
    "rssi": "-44",
    "last_seen": "1620868105.0579898",
    "node_descriptor": "01:40:8e:02:10:52:52:00:00:2c:52:00:00",
    "endpoints": [
            "id": 1,
            "status": 1,
            "device_type": 266,
            "profile_id": 260,
            "manufacturer": "_TZ3000_cphmq0q7",
            "model": "TS011F",
            "output_clusters": [
                    "id": 25,
                    "name": "Ota",
                    "attributes": []
                    "id": 10,
                    "name": "Time",
                    "attributes": []
            "input_clusters": [
                    "id": 0,
                    "name": "Basic",
                    "attributes": [
                            "id": 0,
                            "name": "zcl_version",
                            "value": 3
                            "id": 1,
                            "name": "app_version",
                            "value": 67
                            "id": 2,
                            "name": "stack_version",
                            "value": 0
                            "id": 3,
                            "name": "hw_version",
                            "value": 1
                            "id": 4,
                            "name": "manufacturer",
                            "value": "_TZ3000_cphmq0q7"
                            "id": 5,
                            "name": "model",
                            "value": "TS011F"
                            "id": 6,
                            "name": "date_code",
                            "value": ""
                            "id": 7,
                            "name": "power_source",
                            "value": 1
                    "id": 3,
                    "name": "Identify",
                    "attributes": []
                    "id": 4,
                    "name": "Groups",
                    "attributes": []
                    "id": 5,
                    "name": "Scenes",
                    "attributes": []
                    "id": 6,
                    "name": "On\/Off",
                    "attributes": [
                            "id": 0,
                            "name": "on_off",
                            "value": 1
                    "id": 1794,
                    "name": "Metering",
                    "attributes": [
                            "id": 0,
                            "name": "current_summ_delivered",
                            "value": 0
                    "id": 2820,
                    "name": "Electrical Measurement",
                    "attributes": [
                            "id": 1291,
                            "name": "active_power",
                            "value": 20
                    "id": 57344,
                    "name": "Cluster",
                    "attributes": []
                    "id": 57345,
                    "name": "Cluster",
                    "attributes": []
            "id": 242,
            "status": 1,
            "device_type": 97,
            "profile_id": 41440,
            "manufacturer": null,
            "model": null,
                    "id": 33,
                    "name": "GreenPowerProxy",
                    "attributes": []
            "input_clusters": []
    "signature": {
        "model": "TS011F",
        "node_desc": {
            "byte1": 1,
            "byte2": 64,
            "mac_capability_flags": 142,
            "manufacturer_code": 4098,
            "maximum_buffer_size": 82,
            "maximum_incoming_transfer_size": 82,
            "server_mask": 11264,
            "maximum_outgoing_transfer_size": 82,
        "endpoints": {
            "1": {
                "profile_id": 260,
                "device_type": 266,
                "input_clusters": [
                    0,
                    3,
                    4,
                    5,
                    6,
                    1794,
                    2820,
                    57344,
                    57345
                    25,
                    10
            "242": {
                "device_type": 97,
                "input_clusters": [],
                    33
    "class": "zigpy.device"
Les logs Zigbee spécifiques au module sont :
[2021-05-13 03:21:21][DEBUG] : {"devices":{"84:fd:27:ff:fe:92:d7:ee":{"1":{"6":[{"value":"Bool.false","cluster_name":"On\/Off"}]}}}}
[2021-05-13 03:21:21][DEBUG] : Search attribut for 84:fd:27:ff:fe:92:d7:ee logicalId : 1::6::0 => Bool.false
[2021-05-13 03:21:23][DEBUG] : {"devices":{"84:fd:27:ff:fe:92:d7:ee":{"1":{"2820":{"1291":{"value":"0","cluster_name":"Electrical Measurement"}}}}}}
[2021-05-13 03:21:23][DEBUG] : Search attribut for 84:fd:27:ff:fe:92:d7:ee logicalId : 1::2820::1291 => 0
[2021-05-13 03:21:29][DEBUG] : {"devices":{"84:fd:27:ff:fe:92:d7:ee":{"1":{"6":[{"value":"Bool.true","cluster_name":"On\/Off"}]}}}}
[2021-05-13 03:21:29][DEBUG] : Search attribut for 84:fd:27:ff:fe:92:d7:ee logicalId : 1::6::0 => Bool.true
[2021-05-13 03:21:39][DEBUG] : {"devices":{"84:fd:27:ff:fe:92:d7:ee":{"1":[{"1":{"value":"67","cluster_name":"Basic"}}]}}}
[2021-05-13 03:21:39][DEBUG] : Search attribut for 84:fd:27:ff:fe:92:d7:ee logicalId : 1::0::1 => 67
[2021-05-13 03:21:53][DEBUG] : {"devices":{"84:fd:27:ff:fe:92:d7:ee":{"1":{"2820":{"1291":{"value":"0","cluster_name":"Electrical Measurement"}}}}}}
[2021-05-13 03:21:53][DEBUG] : Search attribut for 84:fd:27:ff:fe:92:d7:ee logicalId : 1::2820::1291 => 0
[2021-05-13 03:21:54][DEBUG] : {"devices":{"84:fd:27:ff:fe:92:d7:ee":{"1":{"6":[{"value":"Bool.false","cluster_name":"On\/Off"}]}}}}
[2021-05-13 03:21:54][DEBUG] : Search attribut for 84:fd:27:ff:fe:92:d7:ee logicalId : 1::6::0 => Bool.false
Le lien vers les site de vente de la prise :
https://fr.aliexpress.com/item/1005002261340242.html
Voici une image représentative de la prise :
Une image détourée arrivera très prochainement.
:innocent:
Ca sera dans la beta de demain (quand il y aura l’image je mettrais a jour aussi)
Je suis pas certain que ce soit une 16 Ampères …
pour 2300 Watts …
Charge 600 Watts …
En plus ils parlent de WiFi …
tout a revoir au niveau de la fiche produit !
  • as-tu la remontée de la puissance W correcte et rafraichissement rapide ? Certaines prises sont toutes les 15min seulement
  • as-tu la consommation en kwh bien remontée (souvent reste à 0)
  • après coupure de courant, la prise retrouve son état ou d’office éteinte ?
