Pour mon plan je l’ai fait en SVG en utilisant le plugin HTML Display
<style>
.parpaing {
stroke-width: 10;
fill: none;
.placo {
stroke-width: 5;
fill: none;
.porte {
stroke-width: 2;
fill: none;
stroke: #249DFF;
stroke-opacity: 0.6;
.ouvrant {
stroke-width: 1;
stroke: #249DFF;
stroke-opacity: 0.4;
fill: none;
.mobilier {
stroke-width: 5;
stroke: #249DFF;
stroke-opacity: 0.2;
fill: none;
</style>
<svg height="900" width="1400">
<!--canape-->
<rect class="mobilier" x="850" y="160" width="60" height="150" />
<polyline points="870,160 870,310" class="mobilier" />
<polyline points="870,235 910,235" class="mobilier" />
<!--tb-->
<rect class="mobilier" x="940" y="210" width="40" height="90" />
<!--tele-->
<rect class="mobilier" x="1020" y="250" width="30" height="90" />
<!--ficus-->
<circle cx="670" cy="130" r="20" class="mobilier" />
<!--poele-->
<circle cx="850" cy="430" r="20" class="mobilier" />
<!--vaiseller-->
<rect class="mobilier" x="835" y="480" width="35" height="60" />
<!--buffet-->
<rect class="mobilier" x="645" y="280" width="35" height="140" />
<!--table-->
<rect class="mobilier" x="730" y="220" width="50" height="150" />
<!--cuisine-->
<rect class="mobilier" x="705" y="597" width="40" height="160" />
<rect class="mobilier" x="750" y="718" width="120" height="40" />
<rect class="mobilier" x="705" y="550" width="40" height="40" />
<rect class="mobilier" x="835" y="640" width="35" height="35" />
<!--entree-->
<use xlink:href="#porte" x="644" y="717" />
<!--couloir-->
<use xlink:href="#porte" x="538" y="606" transform="rotate(270 538 606)" />
<!--cuisine-->
<use xlink:href="#porte" x="927" y="574" transform="rotate(90 927 574)" />
<!--cellier-->
<use xlink:href="#porte" x="882" y="390" />
<!--jardin-->
<use xlink:href="#porte" x="1110" y="497" transform="rotate(180 1110 497)" />
<!--bureau-->
<use xlink:href="#porte" x="499" y="500" />
<!--wc-->
<use xlink:href="#porte" x="640" y="548" transform="rotate(90 640 548)" />
<!--robin-->
<use xlink:href="#porte" x="402" y="553" transform="rotate(270 402 553)" />
<!--sdb-->
<use xlink:href="#porte" x="348" y="606" transform="rotate(270 348 606)" />
<!--chambre-->
<use xlink:href="#porte" x="528" y="607" transform="rotate(90 528 607)" />
<!--ami-->
<use xlink:href="#porte" x="457" y="662" transform="rotate(180 457 662)" />
<use xlink:href="#maison" x="0" y="0" stroke="#249DFF" />
<use xlink:href="#maison" x="0" y="0" stroke="url(#pattern)" />
</svg>
<svg version="1.1" xmlns="http://www.w3.org/2000/svg">
<defs>
<!-- Pattern courtesy of https://iros.github.io/patternfills/ -->
<pattern id="pattern" patternUnits="userSpaceOnUse" width='6' height='6'>
<path d="M5 0h1L0 6V5zM6 5v1H5z" fill="#111" fill-opacity="0.5" />
</pattern>
<symbol id="porte">
<polyline points="2,2 2,52 52,52 " class="porte" />
<path d="M 2,2 C 26,2 52,26 52,52" class="ouvrant" />
</symbol>
<symbol id="maison">
<!--robin-->
<polyline points="495,300 495,445 460,445 460,550 " class="placo" />
<polyline points="265,480 400,480 400,555" class="placo" />
<polyline points="400,550 405,550 " class="placo" />
<!--sdb-->
<polyline points="265,610 405,610 " class="placo" />
<polyline points="400,610 400,605 " class="placo" />
<!--ami-->
<polyline points="455,610 475,610 " class="placo" />
<polyline points="470,610 470,725 435,725 435,820" class="placo" />
<!--chambre-->
<polyline points="525,610 633,610 633,765 " class="placo" />
<polyline points="590,610 590,605" class="placo" />
<!--bureau-->
<polyline points="455,550 500,550 " class="placo" />
<polyline points="550,550 595,550 " class="placo" />
<polyline points="590,555 590,460 637,460" class="placo" />
<!--wc-->
<polyline points="637,550 637,305" class="placo" />
<!--cuisine-->
<polyline points="700,765 700,545 780,545" class="placo" />
<polyline points="830,545 877,545" class="placo" />
<polyline points="877,625 877,765 " class="placo" />
<polyline points="877,575 877,395 920,360 1100,360" class="placo" />
<!--cellier-->
<polyline points="1100,440 935,440" class="placo" />
<polyline points="885,440 877,440" class="placo" />
<polyline points="1105,445 1105,355 1060,355 1060,245 1035,215" class="parpaing" />
<polyline points="1060,820 1105,820 1105,490" class="parpaing" />
<polyline points="820,765 875,765 875,820 930,820" class="parpaing" />
<polyline points="695,765 765,765" class="parpaing" />
<polyline points="575,820 635,820 635,765 645,765" class="parpaing" />
<polyline points="520,820 385,820" class="parpaing" />
<polyline points="330,820 260,820 260,300 355,300" class="parpaing" />
<polyline points="410,300 535,300" class="parpaing" />
<polyline points="590,300 635,300 635,235" class="parpaing" />
<polyline points="635,180 635,90 720,90" class="parpaing" />
<polyline points="850,90 930,90 960,125" class="parpaing" />
</symbol>
</defs>
</svg>
ça me permet de pouvoir modifier très facilement les épaisseurs, couleurs, etc
