Plusieurs lignes d'erreur dans les log : Undefined index
Depuis 2 jours j’ai plusieurs lignes d’erreur dans les logs " cron_execution "
Avez-vous la meme chose de votre coté ?
Lien avec la modif récente de l’API ?
0389|PHP Notice:  Undefined index: data in /var/www/html/plugins/viessmannIot/core/class/viessmannIot.class.php on line 1805
0390|PHP Notice:  Undefined index: data in /var/www/html/plugins/viessmannIot/core/class/viessmannIot.class.php on line 1805
0391|PHP Notice:  Undefined index: data in /var/www/html/plugins/viessmannIot/core/class/viessmannIot.class.php on line 1805
0392|PHP Warning:  array_key_exists() expects parameter 2 to be array, null given in /var/www/html/plugins/viessmannIot/core/php/viessmannApi.php on line 454
0393|PHP Notice:  Trying to access array offset on value of type null in /var/www/html/plugins/viessmannIot/core/class/viessmannIot.class.php on line 1805
0394|PHP Notice:  Undefined index: data in /var/www/html/plugins/viessmannIot/core/class/viessmannIot.class.php on line 1805
0395|PHP Notice:  Undefined index: data in /var/www/html/plugins/viessmannIot/core/class/viessmannIot.class.php on line 1805
0396|PHP Notice:  Undefined index: data in /var/www/html/plugins/viessmannIot/core/class/viessmannIot.class.php on line 1805
0397|PHP Notice:  Undefined index: data in /var/www/html/plugins/viessmannIot/core/class/viessmannIot.class.php on line 1805
0398|PHP Notice:  Undefined index: data in /var/www/html/plugins/viessmannIot/core/class/viessmannIot.class.php on line 1805
0399|PHP Notice:  Undefined index: data in /var/www/html/plugins/viessmannIot/core/class/viessmannIot.class.php on line 1805
0400|PHP Notice:  Undefined index: data in /var/www/html/plugins/viessmannIot/core/class/viessmannIot.class.php on line 1805
0401|PHP Notice:  Undefined index: data in /var/www/html/plugins/viessmannIot/core/class/viessmannIot.class.php on line 1805
0402|PHP Notice:  Undefined index: data in /var/www/html/plugins/viessmannIot/core/class/viessmannIot.class.php on line 182
0403|PHP Warning:  count(): Parameter must be an array or an object that implements Countable in /var/www/html/plugins/viessmannIot/core/class/viessmannIot.class.php on line 182
0404|PHP Notice:  Undefined index: data in /var/www/html/plugins/viessmannIot/core/class/viessmannIot.class.php on line 1805
0405|PHP Notice:  Undefined index: data in /var/www/html/plugins/viessmannIot/core/class/viessmannIot.class.php on line 1805
0406|PHP Notice:  Undefined index: data in /var/www/html/plugins/viessmannIot/core/class/viessmannIot.class.php on line 1805
Page santé jeedom qui contient des informations sur votre version php…
Informations Jeedom**
Core : 4.4.20 (master)
DNS Jeedom : oui
Plugin : ViessmannIot
Version : 2025-07-23 08:13:23 (stable)
Statut Démon : Démarré - (2025-09-08 16:49:06)
Chez moi ça fonctionne mais je modifie le code pour essayer d’éviter le problème
Philippe
