pour les logs, j’ai ça :
[2021-04-04 10:11:15][DEBUG] : >───────── Type de box compatible Tiles ? : OK
[2021-04-04 10:11:15][DEBUG] : ┌───────── LOG DEBUG : TILES / NODES
[2021-04-04 10:11:15][DEBUG] : >> ================ >> LOG POUR DEBUG : NODES
[2021-04-04 10:11:15][DEBUG] : ┌───────── Début de Mise à jour
[2021-04-04 10:11:15][DEBUG] : │ [Freebox Request Connexion] : GET sur la l'adresse mafreebox.freebox.fr/api/v8/home/nodes(null)
[2021-04-04 10:11:15][DEBUG] : │ [Freebox Request Result] : { "result" : [ { "adapter" : 6, "category" : "light", "group" : { "label" : "" }, "id" : 7, "label" : "Hue white lamp 2", "name" : "node_7", "props" : { "Hue id" : 2 }, "show_endpoints" : [ { "category" : "", "ep_type" : "slot", "id" : 1, "label" : "Enclenché", "name" : "switch", "ui" : { "access" : "rw", "display" : "toggle", "icon_url" : "/resources/images/home/pictos/light.png", "value_type" : "bool" }, "value" : false, "value_type" : "bool", "visibility" : "normal" }, { "category" : "", "ep_type" : "slot", "id" : 2, "label" : "Luminosité", "name" : "luminosity", "ui" : { "access" : "rw", "display" : "slider", "icon_url" : "/resources/images/home/pictos/lumiere_luminosity.png" }, "value" : 0, "value_type" : "int", "visibility" : "normal" } ], "signal_links" : [ ], "slot_links" : [ ], "status" : "unreachable", "type" : { "abstract" : false, "endpoints" : [ { "ep_type" : "slot", "id" : 0, "label" : "Enclenché", "name" : "switch_state", "value_type" : "bool", "visiblity" : "normal" }, { "ep_type" : "slot", "id" : 1, "label" : "Enclenché", "name" : "switch", "value_type" : "bool", "visiblity" : "normal" }, { "ep_type" : "slot", "id" : 2, "label" : "Luminosité", "name" : "luminosity", "value_type" : "int", "visiblity" : "normal" }, { "ep_type" : "signal", "id" : 3, "label" : "Enclenché", "name" : "switch_state", "param_type" : "void", "value_type" : "bool", "visiblity" : "internal" }, { "ep_type" : "signal", "id" : 4, "label" : "Enclenché", "name" : "switch", "param_type" : "void", "value_type" : "bool", "visiblity" : "internal" }, { "ep_type" : "signal", "id" : 5, "label" : "Luminosité", "name" : "luminosity", "param_type" : "void", "value_type" : "int", "visiblity" : "internal" } ], "generic" : false, "icon" : "/resources/images/home/pictos/objets-connectes.png", "inherit" : "node::hue", "label" : "Dimmable Light", "name" : "node::hue::Dimmable light", "params" : { }, "physical" : true } }, { "adapter" : 6, "category" : "light", "group" : { "label" : "" }, "id" : 8, "label" : "Hue salon", "name" : "node_8", "props" : { "Hue id" : 3 }, "show_endpoints" : [ { "category" : "", "ep_type" : "slot", "id" : 1, "label" : "Enclenché", "name" : "switch", "ui" : { "access" : "rw", "display" : "toggle", "icon_url" : "/resources/images/home/pictos/light.png", "value_type" : "bool" }, "value" : false, "value_type" : "bool", "visibility" : "normal" }, { "category" : "", "ep_type" : "slot", "id" : 2, "label" : "Couleur", "name" : "hs", "ui" : { "access" : "rw", "display" : "color", "icon_url" : "/resources/images/home/pictos/lumiere_color.png" }, "value" : 0, "value_type" : "int", "visibility" : "normal" }, { "category" : "", "ep_type" : "slot", "id" : 3, "label" : "Luminosité", "name" : "v", "ui" : { "access" : "rw", "display" : "slider", "icon_url" : "/resources/images/home/pictos/lumiere_luminosity.png" }, "value" : 0, "value_type" : "int", "visibility" : "normal" } ], "signal_links" : [ ], "slot_links" : [ ], "status" : "unreachable", "type" : { "abstract" : false, "endpoints" : [ { "ep_type" : "slot", "id" : 0, "label" : "Enclenché", "name" : "switch_state", "value_type" : "bool", "visiblity" : "normal" }, { "ep_type" : "slot", "id" : 1, "label" : "Enclenché", "name" : "switch", "value_type" : "bool", "visiblity" : "normal" }, { "ep_type" : "slot", "id" : 2, "label" : "Couleur", "name" : "hs", "value_type" : "int", "visiblity" : "normal" }, { "ep_type" : "slot", "id" : 3, "label" : "Luminosité", "name" : "v", "value_type" : "int", "visiblity" : "normal" }, { "ep_type" : "signal", "id" : 4, "label" : "Enclenché", "name" : "switch_state", "param_type" : "void", "value_type" : "bool", "visiblity" : "internal" }, { "ep_type" : "signal", "id" : 5, "label" : "Enclenché", "name" : "switch", "param_type" : "void", "value_type" : "bool", "visiblity" : "internal" }, { "ep_type" : "signal", "id" : 6, "label" : "Couleur", "name" : "hs", "param_type" : "void", "value_type" : "int", "visiblity" : "internal" }, { "ep_type" : "signal", "id" : 7, "label" : "Luminosité", "name" : "v", "param_type" : "void", "value_type" : "int", "visiblity" : "internal" } ], "generic" : false, "icon" : "/resources/images/home/pictos/objets-connectes.png", "inherit" : "node::hue", "label" : "Extended Color Light", "name" : "node::hue::Extended color light", "params" : { }, "physical" : true } }, { "adapter" : 6, "category" : "light", "group" : { "label" : "" }, "id" : 9, "label" : "Hue cuisine", "name" : "node_9", "props" : { "Hue id" : 4 }, "show_endpoints" : [ { "category" : "", "ep_type" : "slot", "id" : 1, "label" : "Enclenché", "name" : "switch", "ui" : { "access" : "rw", "display" : "toggle", "icon_url" : "/resources/images/home/pictos/light.png", "value_type" : "bool" }, "value" : false, "value_type" : "bool", "visibility" : "normal" }, { "category" : "", "ep_type" : "slot", "id" : 2, "label" : "Luminosité", "name" : "luminosity", "ui" : { "access" : "rw", "display" : "slider", "icon_url" : "/resources/images/home/pictos/lumiere_luminosity.png" }, "value" : 0, "value_type" : "int", "visibility" : "normal" } ], "signal_links" : [ ], "slot_links" : [ ], "status" : "unreachable", "type" : { "abstract" : false, "endpoints" : [ { "ep_type" : "slot", "id" : 0, "label" : "Enclenché", "name" : "switch_state", "value_type" : "bool", "visiblity" : "normal" }, { "ep_type" : "slot", "id" : 1, "label" : "Enclenché", "name" : "switch", "value_type" : "bool", "visiblity" : "normal" }, { "ep_type" : "slot", "id" : 2, "label" : "Luminosité", "name" : "luminosity", "value_type" : "int", "visiblity" : "normal" }, { "ep_type" : "signal", "id" : 3, "label" : "Enclenché", "name" : "switch_state", "param_type" : "void", "value_type" : "bool", "visiblity" : "internal" }, { "ep_type" : "signal", "id" : 4, "label" : "Enclenché", "name" : "switch", "param_type" : "void", "value_type" : "bool", "visiblity" : "internal" }, { "ep_type" : "signal", "id" : 5, "label" : "Luminosité", "name" : "luminosity", "param_type" : "void", "value_type" : "int", "visiblity" : "internal" } ], "generic" : false, "icon" : "/resources/images/home/pictos/objets-connectes.png", "inherit" : "node::hue", "label" : "Dimmable Light", "name" : "node::hue::Dimmable light", "params" : { }, "physical" : true } } ], "success" : true }
[2021-04-04 10:11:15][DEBUG] : └─────────
[2021-04-04 10:11:15][DEBUG] : >> ================ >> LOG POUR DEBUG : TILES
[2021-04-04 10:11:15][DEBUG] : │ [Freebox Request Connexion] : GET sur la l'adresse mafreebox.freebox.fr/api/v8/home/tileset/all(null)
[2021-04-04 10:11:15][DEBUG] : │ [Freebox Request Result] : { "result" : [ { "action" : "intensity_picker", "data" : [ { "ep_id" : 0, "label" : "Enclenché", "name" : "switch_state", "refresh" : 2000, "signal_id" : 4, "slot_id" : 0, "ui" : { "access" : "rw", "display" : "icon", "icon_url" : "/resources/images/home/pictos/lumiere_%.png", "value_type" : "bool" }, "value" : false, "value_type" : "bool" }, { "ep_id" : 2, "label" : "Luminosité", "name" : "luminosity", "refresh" : 2000, "signal_id" : 5, "slot_id" : 2, "ui" : { "access" : "rw", "display" : "slider", "icon_url" : "/resources/images/home/pictos/lumiere_luminosity.png" }, "value" : 127, "value_type" : "int" } ], "ep_type" : "slot", "group" : { "label" : "" }, "label" : "Hue white lamp 2", "node_id" : 7, "type" : "light" }, { "action" : "color_picker", "data" : [ { "ep_id" : 0, "label" : "Enclenché", "name" : "switch_state", "refresh" : 2000, "signal_id" : 4, "slot_id" : 0, "ui" : { "access" : "rw", "display" : "icon", "icon_url" : "/resources/images/home/pictos/lumiere_%.png", "value_type" : "bool" }, "value" : false, "value_type" : "bool" }, { "ep_id" : 2, "label" : "Couleur", "name" : "hs", "refresh" : 2000, "signal_id" : 6, "slot_id" : 2, "ui" : { "access" : "rw", "display" : "color", "icon_url" : "/resources/images/home/pictos/lumiere_color.png" }, "value" : 2049201, "value_type" : "int" }, { "ep_id" : 3, "label" : "Luminosité", "name" : "v", "refresh" : 2000, "signal_id" : 7, "slot_id" : 3, "ui" : { "access" : "rw", "display" : "slider", "icon_url" : "/resources/images/home/pictos/lumiere_luminosity.png" }, "value" : 137, "value_type" : "int" } ], "ep_type" : "slot", "group" : { "label" : "" }, "label" : "Hue salon", "node_id" : 8, "type" : "light" }, { "action" : "intensity_picker", "data" : [ { "ep_id" : 0, "label" : "Enclenché", "name" : "switch_state", "refresh" : 2000, "signal_id" : 4, "slot_id" : 0, "ui" : { "access" : "rw", "display" : "icon", "icon_url" : "/resources/images/home/pictos/lumiere_%.png", "value_type" : "bool" }, "value" : false, "value_type" : "bool" }, { "ep_id" : 2, "label" : "Luminosité", "name" : "luminosity", "refresh" : 2000, "signal_id" : 5, "slot_id" : 2, "ui" : { "access" : "rw", "display" : "slider", "icon_url" : "/resources/images/home/pictos/lumiere_luminosity.png" }, "value" : 254, "value_type" : "int" } ], "ep_type" : "slot", "group" : { "label" : "" }, "label" : "Hue cuisine", "node_id" : 9, "type" : "light" } ], "success" : true }
[2021-04-04 10:11:15][DEBUG] : └───────── FIN LOG DEBUG : TILES / NODES
[2021-04-04 10:12:02][DEBUG] : ================= CRON pour l'actualisation de : Air Média ==================
[2021-04-04 10:12:02][DEBUG] : ================= CRON pour l'actualisation de : Wifi ==================
[2021-04-04 10:12:02][DEBUG] : ┌───────── Début de Mise à jour
[2021-04-04 10:12:02][DEBUG] : │ [Freebox Request Connexion] : GET sur la l'adresse mafreebox.freebox.fr/api/v8/wifi/mac_filter/([])
[2021-04-04 10:12:02][DEBUG] : │ [Freebox Request Result] : {"success":true}
[2021-04-04 10:12:02][DEBUG] : └─────────
[2021-04-04 10:12:02][DEBUG] : >───────── Liste Noire :
[2021-04-04 10:12:02][DEBUG] : >───────── Liste Blanche :
[2021-04-04 10:12:02][DEBUG] : │ [Freebox Request Connexion] : GET sur la l'adresse mafreebox.freebox.fr/api/v8/wifi/config(null)
[2021-04-04 10:12:02][DEBUG] : │ [Freebox Request Result] : {"success":true,"result":{"enabled":true,"mac_filter_state":"disabled"}}
[2021-04-04 10:12:02][DEBUG] : │ [Freebox Request Connexion] : GET sur la l'adresse mafreebox.freebox.fr/api/v8/wifi/planning(null)
[2021-04-04 10:12:02][DEBUG] : │ [Freebox Request Result] : {"success":true,"result":{"use_planning":false,"resolution":48,"mapping":["on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on"]}}
[2021-04-04 10:12:02][DEBUG] : │ [Freebox Request Connexion] : GET sur la l'adresse mafreebox.freebox.fr/api/v8/wifi/wps/config(null)
[2021-04-04 10:12:02][DEBUG] : │ [Freebox Request Result] : {"success":true,"result":{"enabled":true}}
[2021-04-04 10:13:02][DEBUG] : ================= CRON pour l'actualisation de : Air Média ==================
[2021-04-04 10:13:02][DEBUG] : ================= CRON pour l'actualisation de : Wifi ==================
[2021-04-04 10:13:02][DEBUG] : ┌───────── Début de Mise à jour
[2021-04-04 10:13:02][DEBUG] : │ [Freebox Request Connexion] : GET sur la l'adresse mafreebox.freebox.fr/api/v8/wifi/mac_filter/([])
[2021-04-04 10:13:02][DEBUG] : │ [Freebox Request Result] : {"success":true}
[2021-04-04 10:13:02][DEBUG] : └─────────
[2021-04-04 10:13:02][DEBUG] : >───────── Liste Noire :
[2021-04-04 10:13:02][DEBUG] : >───────── Liste Blanche :
[2021-04-04 10:13:02][DEBUG] : │ [Freebox Request Connexion] : GET sur la l'adresse mafreebox.freebox.fr/api/v8/wifi/config(null)
[2021-04-04 10:13:02][DEBUG] : │ [Freebox Request Result] : {"success":true,"result":{"enabled":true,"mac_filter_state":"disabled"}}
[2021-04-04 10:13:02][DEBUG] : │ [Freebox Request Connexion] : GET sur la l'adresse mafreebox.freebox.fr/api/v8/wifi/planning(null)
[2021-04-04 10:13:02][DEBUG] : │ [Freebox Request Result] : {"success":true,"result":{"use_planning":false,"resolution":48,"mapping":["on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on"]}}
[2021-04-04 10:13:02][DEBUG] : │ [Freebox Request Connexion] : GET sur la l'adresse mafreebox.freebox.fr/api/v8/wifi/wps/config(null)
[2021-04-04 10:13:02][DEBUG] : │ [Freebox Request Result] : {"success":true,"result":{"enabled":true}}
[2021-04-04 10:14:02][DEBUG] : ================= CRON pour l'actualisation de : Air Média ==================
[2021-04-04 10:14:02][DEBUG] : ================= CRON pour l'actualisation de : Wifi ==================
[2021-04-04 10:14:02][DEBUG] : ┌───────── Début de Mise à jour
[2021-04-04 10:14:02][DEBUG] : │ [Freebox Request Connexion] : GET sur la l'adresse mafreebox.freebox.fr/api/v8/wifi/mac_filter/([])
[2021-04-04 10:14:02][DEBUG] : │ [Freebox Request Result] : {"success":true}
[2021-04-04 10:14:02][DEBUG] : └─────────
[2021-04-04 10:14:02][DEBUG] : >───────── Liste Noire :
[2021-04-04 10:14:02][DEBUG] : >───────── Liste Blanche :
[2021-04-04 10:14:02][DEBUG] : │ [Freebox Request Connexion] : GET sur la l'adresse mafreebox.freebox.fr/api/v8/wifi/config(null)
[2021-04-04 10:14:02][DEBUG] : │ [Freebox Request Result] : {"success":true,"result":{"enabled":true,"mac_filter_state":"disabled"}}
[2021-04-04 10:14:02][DEBUG] : │ [Freebox Request Connexion] : GET sur la l'adresse mafreebox.freebox.fr/api/v8/wifi/planning(null)
[2021-04-04 10:14:02][DEBUG] : │ [Freebox Request Result] : {"success":true,"result":{"use_planning":false,"resolution":48,"mapping":["on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on"]}}
[2021-04-04 10:14:02][DEBUG] : │ [Freebox Request Connexion] : GET sur la l'adresse mafreebox.freebox.fr/api/v8/wifi/wps/config(null)
[2021-04-04 10:14:02][DEBUG] : │ [Freebox Request Result] : {"success":true,"result":{"enabled":true}}
[2021-04-04 10:15:03][DEBUG] : ================= CRON pour l'actualisation de : Air Média ==================
[2021-04-04 10:15:03][DEBUG] : ================= CRON pour l'actualisation de : Téléchargements ==================
[2021-04-04 10:15:03][DEBUG] : ┌───────── Début de Mise à jour
[2021-04-04 10:15:03][DEBUG] : │ [Freebox Request Connexion] : GET sur la l'adresse mafreebox.freebox.fr/api/v8/downloads/stats/(null)
[2021-04-04 10:15:03][DEBUG] : │ [Freebox Request Result] : {"success":true,"result":{"throttling_rate":{"rx_rate":0,"tx_rate":0},"nb_tasks_stopped":0,"dht_stats":{"enabled":false,"node_count_ipv6":0,"enabled_ipv6":false,"node_count":0},"nb_tasks_checking":0,"nb_tasks_queued":0,"blocklist_hits":0,"blocklist_entries":0,"nb_tasks_extracting":0,"nb_tasks_done":0,"nb_tasks_stopping":0,"nzb_config_status":{"status":"error","error":"connection_refused"},"conn_ready":true,"nb_peer":0,"throttling_mode":"normal","nb_tasks_active":0,"nb_tasks_seeding":0,"nb_tasks_error":1,"tx_rate":0,"nb_tasks_repairing":0,"nb_tasks":1,"nb_rss":0,"nb_tasks_downloading":0,"nb_rss_items_unread":0,"rx_rate":0,"throttling_is_scheduled":false}}
