Plus de teleinfo apres mis a jour
Suite a la mise a jour le plugin ne démarre plus
[2022-04-08 11:41:52]INFO : GLOBAL------Start teleinfod
[2022-04-08 11:41:52]INFO : GLOBAL------Cycle Sommeil : 0.5
[2022-04-08 11:41:52]INFO : GLOBAL------Socket port : 55062
[2022-04-08 11:41:52]INFO : GLOBAL------Socket host : 127.0.0.1
[2022-04-08 11:41:52]INFO : GLOBAL------Log level : debug
[2022-04-08 11:41:52]INFO : GLOBAL------Callback : http://127.0.0.1:80/plugins/teleinfo/core/php/jeeTeleinfo.php
[2022-04-08 11:41:52]INFO : GLOBAL------Vitesse : 1200
[2022-04-08 11:41:52]INFO : GLOBAL------Apikey :
[2022-04-08 11:41:52]INFO : GLOBAL------Cycle : 1.0
[2022-04-08 11:41:52]INFO : GLOBAL------Port : /dev/ttyUSB0
[2022-04-08 11:41:52]INFO : GLOBAL------Type : conso
[2022-04-08 11:41:52]INFO : GLOBAL------Mode : historique
[2022-04-08 11:41:52]DEBUG : Writing PID 11966 to /tmp/jeedom/teleinfo/teleinfo_conso.pid
[2022-04-08 11:41:52]DEBUG : Init request module v2.27.1
[2022-04-08 11:41:52]DEBUG : Starting new HTTP connection (1): 127.0.0.1:80
[2022-04-08 11:41:52]DEBUG : http://127.0.0.1:80 "GET /plugins/teleinfo/core/php/jeeTeleinfo.php?apikey= HTTP/1.1" 200 0
[2022-04-08 11:41:52]DEBUG : Socket interface started
[2022-04-08 11:41:52]DEBUG : LoopNetServer Thread started
[2022-04-08 11:41:52]DEBUG : Listening on: [127.0.0.1:55062]
[2022-04-08 11:41:52]INFO : GLOBAL------Start listening...
[2022-04-08 11:41:52]DEBUG : TELEINFO------INIT CONNECTION
[2022-04-08 11:41:52]INFO : GLOBAL------Preparing Teleinfo...
[2022-04-08 11:41:52]DEBUG : GLOBAL------Read Socket Thread Launched
[2022-04-08 11:41:52]INFO : TELEINFO------RUN
[2022-04-08 11:41:52]INFO : TELEINFO------OPEN CONNECTION
[2022-04-08 11:41:52]INFO : GLOBAL------Shutdown
[2022-04-08 11:41:52]INFO : Removing PID file /tmp/jeedom/teleinfo/teleinfo_conso.pid
[2022-04-08 11:41:52]DEBUG : LoopNetServer Thread stopped
[2022-04-08 11:41:52]DEBUG : Exit 0
Error:
name 'error' is not defined
Bonjour mika-nt28,
je rencontre exactement le meme probleme, j’ai posté un message à ce sujet.
ça me rassure, je me sent moins seul :slight_smile:
J’ai regarder rapidement dans le code
Je n’est pas de connexion serial.
Je n’est pas poussé plus loin car le lib est bien installé et les paramètres sont correctement initialisé.
Peut-être un soucis avec mon compteur ou mon modem
La solution la plus rapide est que vous reveniez sur la version du plugin de votre backup.
L’un d’entre vous avait il déjà testé la version bêta avant de passer en stable ?
Pouvez vous décrire quel modèle vous avez ? Version debian, jeedom…
Bonjour GiDom,
j’ai restauré mon jeedom (4.2.14) de ce matin, et tout est revenu en ordre.
je tourne sur RPI 4.
apres quelques tentatives infructueuses ( update php, tests divers et variés, désactivations de plugins, changement de socket ) j’ai opté pour un retour en arrière ne trouvant pas où se situe le probleme.
Idem pour moi, restauration obligatoire (merci les backups)
Le but n’est pas de restaurer Jeedom mais que le plugin soit fonctionnel, le pire est que dans les changelog il n’y a aucune information sur cette MAJ
De mon côté mise à jour réussi j’ai juste du relancer le Démon qui n’est pas reparti automatiquement. C’est vrais que l’on ne sais pas ce que cette MAJ apporte ! rien dans Changelog.
Encore une fois désolé pour ceux qui ont eu des soucis. Pour rappel, je ne suis pas le dev du plugin, je ne suis pas dev non plus, j’essaie de rendre service.
La maj en stable est bloqué pour l’instant, dans les prochains jour, rollback sur la version stable qui ne posait pas de problème, les dernières mise à jour se feront uniquement en BETA, les gens qui ont eu des problèmes avec la mise à jour seront invité à tester la BETA pour être sûr que la nouvelle version du plugin fonctionne chez tous le monde.
Cordialement
Bonjour à tous, désolé c’est sans doute de ma faute mais je ne vois vraiment pas ce qui a pu se passer, la seule modification que j’ai apportée concerne le fichier pour utiliser le modem 2 compteurs de chez cartelectronic.
Je viens de mettre à jour chez moi et ça marche bien. Est qu’un d’entre vous a toujours son plugin planté?
bonjour
je suis revenu à la version core 4.6.5 ( celle de mon backup ) et tout est ok .
est ce que tu avais relancé les dépendances après la mise à jour?
