@MIps tu veux lesquels ?
Log BLEA :
[2021-01-27 15:00:43][ERROR] : Erreur sur la fonction deamon_start du plugin : Vous devez attendre au moins 45 secondes entre deux lancements du démon. Dernier lancement : 2021-01-27 15:00:07
Log BLEA_LOCAL (très long)
[2021-01-27 14:36:31.748][DEBUG] : SOCKET-READ------Received command from jeedom : add
[2021-01-27 14:36:31.749][DEBUG] : SOCKET-READ------Add device : {'id': '80:EA:CA:89:50:AC', 'delay': 900, 'needsrefresh': 0, 'name': 'miflora', 'refreshlist': [], 'islocked': 0, 'emitterallowed': 'all', 'refresherallowed': 'all', 'specificconfiguration': [], 'absent': '', 'type': '', 'model': 'miflora/miflora'}
[2021-01-27 14:36:32.049][DEBUG] : SOCKET-READ------Message received in socket JEEDOM_SOCKET_MESSAGE
[2021-01-27 14:36:32.050][DEBUG] : SOCKET-READ------Received command from jeedom : add
[2021-01-27 14:36:32.050][DEBUG] : SOCKET-READ------Add device : {'id': 'C4:7C:8D:6B:0E:F3', 'delay': 900, 'needsrefresh': 0, 'name': 'miflora', 'refreshlist': [], 'islocked': 0, 'emitterallowed': 'all', 'refresherallowed': 'all', 'specificconfiguration': [], 'absent': '', 'type': '', 'model': 'miflora/miflora'}
[2021-01-27 14:36:32.350][DEBUG] : SOCKET-READ------Message received in socket JEEDOM_SOCKET_MESSAGE
[2021-01-27 14:36:32.351][DEBUG] : SOCKET-READ------Received command from jeedom : add
[2021-01-27 14:36:32.351][DEBUG] : SOCKET-READ------Add device : {'id': 'C7:5C:7F:20:47:13', 'delay': 0, 'needsrefresh': 0, 'name': 'myfox', 'refreshlist': [], 'islocked': 0, 'emitterallowed': 'all', 'refresherallowed': 'all', 'specificconfiguration': [], 'absent': '', 'type': '', 'model': 'myfox/myfox'}
[2021-01-27 14:36:32.652][DEBUG] : SOCKET-READ------Message received in socket JEEDOM_SOCKET_MESSAGE
[2021-01-27 14:36:32.652][DEBUG] : SOCKET-READ------Received command from jeedom : add
[2021-01-27 14:36:32.652][DEBUG] : SOCKET-READ------Add device : {'id': 'F6:1C:A4:95:1F:AA', 'delay': 0, 'needsrefresh': 0, 'name': 'myfox', 'refreshlist': [], 'islocked': 0, 'emitterallowed': 'all', 'refresherallowed': 'all', 'specificconfiguration': [], 'absent': '', 'type': '', 'model': 'myfox/myfox'}
[2021-01-27 14:36:32.953][DEBUG] : SOCKET-READ------Message received in socket JEEDOM_SOCKET_MESSAGE
[2021-01-27 14:36:32.954][DEBUG] : SOCKET-READ------Received command from jeedom : add
[2021-01-27 14:36:32.954][DEBUG] : SOCKET-READ------Add device : {'id': 'DA:AF:01:BE:4E:2A', 'delay': 0, 'needsrefresh': 0, 'name': 'myfox', 'refreshlist': [], 'islocked': 0, 'emitterallowed': 'local', 'refresherallowed': 'local', 'specificconfiguration': [], 'absent': '', 'type': '', 'model': 'myfox/myfox'}
[2021-01-27 14:36:33.255][DEBUG] : SOCKET-READ------Message received in socket JEEDOM_SOCKET_MESSAGE
[2021-01-27 14:36:33.255][DEBUG] : SOCKET-READ------Received command from jeedom : add
[2021-01-27 14:36:33.255][DEBUG] : SOCKET-READ------Add device : {'id': 'C6:E7:A3:2C:7E:71', 'delay': 0, 'needsrefresh': 0, 'name': 'myfox', 'refreshlist': [], 'islocked': 0, 'emitterallowed': 'all', 'refresherallowed': 'all', 'specificconfiguration': [], 'absent': '', 'type': '', 'model': 'myfox/myfox'}
[2021-01-27 14:36:33.556][DEBUG] : SOCKET-READ------Message received in socket JEEDOM_SOCKET_MESSAGE
[2021-01-27 14:36:33.556][DEBUG] : SOCKET-READ------Received command from jeedom : add
[2021-01-27 14:36:33.557][DEBUG] : SOCKET-READ------Add device : {'id': 'DF:4B:B8:25:62:2E', 'delay': 0, 'needsrefresh': 0, 'name': 'myfox', 'refreshlist': [], 'islocked': 0, 'emitterallowed': 'all', 'refresherallowed': 'all', 'specificconfiguration': [], 'absent': '', 'type': '', 'model': 'myfox/myfox'}
[2021-01-27 14:36:33.857][DEBUG] : SOCKET-READ------Message received in socket JEEDOM_SOCKET_MESSAGE
[2021-01-27 14:36:33.858][DEBUG] : SOCKET-READ------Received command from jeedom : add
[2021-01-27 14:36:33.858][DEBUG] : SOCKET-READ------Add device : {'id': 'D7:82:09:B7:F9:E0', 'delay': 0, 'needsrefresh': 0, 'name': 'nut', 'refreshlist': [], 'islocked': 0, 'emitterallowed': 'all', 'refresherallowed': 'all', 'specificconfiguration': [], 'absent': '', 'type': '', 'model': 'nut/nut_mini_bleu'}
[2021-01-27 14:36:34.158][DEBUG] : SOCKET-READ------Message received in socket JEEDOM_SOCKET_MESSAGE
[2021-01-27 14:36:34.159][DEBUG] : SOCKET-READ------Received command from jeedom : add
[2021-01-27 14:36:34.159][DEBUG] : SOCKET-READ------Add device : {'id': 'F9:92:4F:7A:9E:B9', 'delay': 0, 'needsrefresh': 0, 'name': 'nut', 'refreshlist': [], 'islocked': 0, 'emitterallowed': 'all', 'refresherallowed': 'all', 'specificconfiguration': {'batteryhandle': '0x17'}, 'absent': '', 'type': '', 'model': 'nut/nut_mini_bleu'}
[2021-01-27 14:36:34.460][DEBUG] : SOCKET-READ------Message received in socket JEEDOM_SOCKET_MESSAGE
[2021-01-27 14:36:34.460][DEBUG] : SOCKET-READ------Received command from jeedom : add
[2021-01-27 14:36:34.460][DEBUG] : SOCKET-READ------Add device : {'id': 'CD:16:83:11:EF:38', 'delay': 0, 'needsrefresh': 0, 'name': 'nut', 'refreshlist': [], 'islocked': 0, 'emitterallowed': 'all', 'refresherallowed': 'all', 'specificconfiguration': {'batteryhandle': '0x17'}, 'absent': '', 'type': '', 'model': 'nut/nut_mini_bleu'}
[2021-01-27 14:36:34.761][DEBUG] : SOCKET-READ------Message received in socket JEEDOM_SOCKET_MESSAGE
[2021-01-27 14:36:34.761][DEBUG] : SOCKET-READ------Received command from jeedom : add
[2021-01-27 14:36:34.762][DEBUG] : SOCKET-READ------Add device : {'id': 'F3:25:C6:D2:AA:0F', 'delay': 0, 'needsrefresh': 0, 'name': 'nut', 'refreshlist': [], 'islocked': 0, 'emitterallowed': 'all', 'refresherallowed': 'all', 'specificconfiguration': [], 'absent': '', 'type': '', 'model': 'nut/nut_mini_bleu'}
[2021-01-27 14:36:35.062][DEBUG] : SOCKET-READ------Message received in socket JEEDOM_SOCKET_MESSAGE
[2021-01-27 14:36:35.063][DEBUG] : SOCKET-READ------Received command from jeedom : add
[2021-01-27 14:36:35.063][DEBUG] : SOCKET-READ------Add device : {'id': 'D2:1C:3B:44:54:D9', 'delay': 0, 'needsrefresh': 0, 'name': 'nut', 'refreshlist': [], 'islocked': 0, 'emitterallowed': 'all', 'refresherallowed': 'all', 'specificconfiguration': {'batteryhandle': '0x17'}, 'absent': '', 'type': '', 'model': 'nut/nut_mini_bleu'}
[2021-01-27 14:36:35.364][DEBUG] : SOCKET-READ------Message received in socket JEEDOM_SOCKET_MESSAGE
[2021-01-27 14:36:35.364][DEBUG] : SOCKET-READ------Received command from jeedom : add
[2021-01-27 14:36:35.364][DEBUG] : SOCKET-READ------Add device : {'id': '5C:CA:D3:41:5A:F3', 'delay': 0, 'needsrefresh': 0, 'name': 'miscale2', 'refreshlist': [], 'islocked': 0, 'emitterallowed': 'all', 'refresherallowed': 'all', 'specificconfiguration': {'Jérôme': {'name': 'Jérôme', 'height': '184', 'weight': 81.35, 'sex': 'male', 'age': '10-12-1974'}, 'Auria': {'name': 'Auria', 'height': '168', 'weight': '45', 'sex': 'female', 'age': '11-07-2003'}, 'Camille': {'name': 'Camille', 'height': '171', 'weight': 64.95, 'sex': 'female', 'age': '16-02-1974'}, 'Justine': {'name': 'Justine', 'height': '176', 'weight': 51.9, 'sex': 'female', 'age': '01-01-2002'}, 'Lubin': {'name': 'Lubin', 'height': '153', 'weight': 1.8, 'sex': 'male', 'age': '16-02-2009'}}, 'absent': '', 'type': '', 'model': 'miscale2/miscale2'}
[2021-01-27 14:36:35.665][DEBUG] : SOCKET-READ------Message received in socket JEEDOM_SOCKET_MESSAGE
[2021-01-27 14:36:35.666][DEBUG] : SOCKET-READ------Received command from jeedom : ready
[2021-01-27 14:36:35.666][DEBUG] : Daemon is ready
[2021-01-27 14:36:46.516][DEBUG] : SCANNER------Clearing seen
[2021-01-27 14:36:54.706][DEBUG] : Send to jeedom : {'heartbeat': 1, 'source': 'local', 'version': '2.9'}
[2021-01-27 14:36:54.711][DEBUG] : Starting new HTTP connection (1): 127.0.0.1:80
[2021-01-27 14:36:54.736][DEBUG] : http://127.0.0.1:80 "POST /plugins/blea/core/php/jeeBlea.php?apikey=htPCVB8cJ103mp3ayWm75AMvEAUG169t HTTP/1.1" 200 0
Can't get device info: No such device
[2021-01-27 14:59:26.961][ERROR] : GLOBAL------Exception on scanner (didn't resolve there is an issue with bluetooth) : Failed to execute management command 'le on' (code: 17, error: Invalid Index)
log Antenne_Atelier (les autres sont identiques en message)
[2021-01-27 13:28:13.211][ERROR] : GLOBAL------Fatal error : [Errno 98] Address already in use
