J’ai fais CTRL + O, puis entrée mais ça sauvegarde pas !
Il me propose d’autre commandes (voir la fin du log).
login as: pi
pi@192.168.0.17's password:
Access denied
Linux jeedom 5.4.72-v7+ #1356 SMP Thu Oct 22 13:56:54 BST 2020 armv7l
The programs included with the Debian GNU/Linux system are free software;
the exact distribution terms for each program are described in the
individual files in /usr/share/doc/*/copyright.
Debian GNU/Linux comes with ABSOLUTELY NO WARRANTY, to the extent
permitted by applicable law.
Last login: Tue Nov 24 09:40:26 2020 from 192.168.0.29
pi@jeedom:~ $ sudo nano /etc/sysctl.conf
GNU nano 3.2 /etc/sysctl.conf
# /etc/sysctl.conf - Configuration file for setting system variables
# See /etc/sysctl.d/ for additional system variables.
# See sysctl.conf (5) for information.
#kernel.domainname = example.com
# Uncomment the following to stop low-level messages on console
#kernel.printk = 3 4 1 3
##############################################################3
# Functions previously found in netbase
# Uncomment the next two lines to enable Spoof protection (reverse-path filter)
# Turn on Source Address Verification in all interfaces to
# prevent some spoofing attacks
#net.ipv4.conf.default.rp_filter=1
#net.ipv4.conf.all.rp_filter=1
# Uncomment the next line to enable TCP/IP SYN cookies
# See http://lwn.net/Articles/277146/
# Note: This may impact IPv6 TCP sessions too
#net.ipv4.tcp_syncookies=1
# Uncomment the next line to enable packet forwarding for IPv4
#net.ipv4.ip_forward=1
# Uncomment the next line to enable packet forwarding for IPv6
# Enabling this option disables Stateless Address Autoconfiguration
# based on Router Advertisements for this host
#net.ipv6.conf.all.forwarding=1
File Name to Write: /etc/sysctl.conf
^G Get Help M-D DOS Format M-A Append M-B Backup File
^C Cancel M-M Mac Format M-P Prepend ^T To Files
Tu as bien lancé la commande avec sudo au début, dans tous les cas ?? sudo nano xxxxx
et pas nano xxxxx
Tu es pas connecté plusieurs fois ?
De toute façon, pas de sauvegarde => pas de risque de tout casser puiqu’on modifie rien
Bon j’ai redémarré le RPI et le PC
Je me suis connecté au RPI
la commande cat /proc/sys/vm/swappiness fonctionne et me répond 60 OK.
Donc je tape sudo nano /etc/sysctl.conf pour définir la valeur à 10 en ajoutant le bloc vm swappiness = 10 et la je ne peu pas ajouter le bloc, j’ai directement ce message :
login as: pi
Last login: Tue Nov 24 16:19:21 2020 from 192.168.0.29
pi@jeedom:~ $ cat /proc/sys/vm/swappiness
60
# Additional settings - these settings can improve the network
# security of the host and prevent against some network attacks
# including spoofing attacks and man in the middle attacks through
# redirection. Some network environments, however, require that these
# settings are disabled so review and enable them as needed.
# Do not accept ICMP redirects (prevent MITM attacks)
#net.ipv4.conf.all.accept_redirects = 0
#net.ipv6.conf.all.accept_redirects = 0
# _or_
^G Get Help ^O Write Out ^W Where Is ^K Cut Text ^J Justify ^C Cur Pos
^X Exit ^R Read File ^\ Replace ^U Uncut Text^T To Spell ^_ Go To Line
